The Vette Corral on Saturday had in excess of 150 cars and probably many more on Sunday, great turnout.
Here's waving at Ya!
Thanks for the reference; I should have done a search before I asked.
Now I have to decide if I keep my '01 or grab a deal on an '04 (and in the process take a bath with 3,500 miles on it). I have an automatic and really want 6spd and HUD, bad! Do you think the "pre-driven" vets will regain fair value after the 2004 firesale is done?
With only 3500 miles hard to get value out of the car. How to decide what 6sp and HUD is worth, only you can judge. But, I think in the future there will be more 6sp cars on the market since it won't be an extra cost option on the C6, it will be interesting to see how that works out.
This article is not on the Vette but makes nice mention of it, so FWIW:
http://www.detnews.com/2004/autosconsumer/0407/28/g03-224855.htm
Enjoying driving the C5 for daily driver the C4 should go away this weekend
Good luck in your search for info and let us know if you find any more data.
I am also pushing 66,000 miles and the only unscheduled maintenance item, as been (fairly common to the breed) leaking differential seals, covered under warranty. I also do 15,000 mile oil and filter intervals since a 1600 mile new car engine break in. The car has literally been flawless, sans the earlier item. (in this paragraph)
MPG? If that's at the top of your list of "desires", you're probably looking at the wrong breed of car. I'm not expecting Prius MPG numbers, nor will I be disappointed if any sports car doesn't meet EPA specs.
-Do I like the way the "performance car", performs?
-Do I like the way it feels?
-Do I like the way it looks?
Those are my main priorities.
I am perfectly aware that the Corvettes are fully capable of 17 mpg and below.:) However it is neat to go 530 miles to Las Vegas 104 degrees from the San Jose area in less than 6 hrs (fuel and nature breaks) 5.3-5.5 hrs actual drive time with two folks, AC roaring and luggage for two weeks, and still get 26.5 mpg!
1. the best is a 4 point lift with correct rubber adapters or round type puck inserts (you should be carrying at least 1 to 2 of these in case you have a flat on the road.) If the guy really knows what he is doing (which you indicate he does not), dunnage is commonly used. The lift points are very small and hard to get to, so if it were mine I'd buy the puck adapters, but if not the idea is not to put stress on the underbody STP pieces.
2. next is the front and rear cross member jack points and jack stands under the small triangular parts. I personally use a special cut plywood to circumvent the posibility of metal deformation that spans the cross member pieces
3. using the puck like lift adapter, you can also just jack the front, one side at a time and since you indicate he will go under the vehicle, put jackstands under either the crossmember pieces and or the triangular shaped area.
4. there are actually more ways but this should work?
As for mileage vs. look and feel, YMMV most Vette drivers I know couldn't guess what mileage the car gets. OTOH as ruking1 notes, getting great mileage and having the performance is a nice benefit that I for one, appreciate. Now, knowing that my last tour of 125 miles at the track used about 14 gallons is just an indicator that I'm working down the lap times.
Personally, while the subject is unpleasant, I'd prefer to take a big hit in a BMW if I had a choice. But this would not deter me from a C5 if that's what I wanted.
As for fuel mileage, why on earth reject a car to save 100 gallons of gas a year, or conversely, select a car one is lukewarm about to save $250?
You gotta go with your passion, not the spec sheets. That has, in my experience, often led people to the wrong decision (for them I mean).
Hey, I'm back in the V-8 club after all these years! Just bought a Porsche 928. Can't beat a C5 but watch out if I get that stroker kit!
Off topic but I am more than glad I got the Z06 vs the M3!
All I did was agree with Mr. Shiftright and what the Corvette offers.
The areas that it may or may not be weak are of little importance to me.
2. next is the front and rear cross member jack points and jack stands under the small triangular parts. I personally use a special cut plywood to circumvent the posibility of metal deformation that spans the cross member pieces. You can put the jackstands under each of the 4 lift points or under the crossmember pieces front and/or rear or the triangular lift or support points
3. using the puck like lift adapter, you can also just jack the front, one side at a time and since you indicate he will go under the vehicle, put jackstands under either the crossmember pieces and or the triangular shaped area. If you have a hard time accessing the front from the front (to to no extended jack length) you can access the front crossmember from behind each front wheel. The only concern is jack placement can be a tad tricky due to different lift jack footprints.
Besides I already paid for the 928. I think I could do a LOT of mods for the $50K I'd need for a C5--hahaha.
What's a C5 weigh now? Somebody told me that a fiberglass body saves about 300 lbs.
RE: C5 safety record. What safety record? I thought that's what we were all googling but couldn't find. What do the insurance companies know that they don't get from crash tests I wonder?
Yeah, I wouldn't buy an M3 either. Too much money for what you get I think.
A further reason to go with the C5 over the 928 is Active Handling on the later versions of the C5. The 928 never had anything like Active Handling.
"Besides I already paid for the 928. I think I could do a LOT of mods for the $50K I'd need for a C5--hahaha."
You hit upon a pretty valid point! In fact you could mod say a Dodge Neon to blow the doors off any production exotic !
One of my DC plant friends up in Canada sent me a video off a news program of the 8 Corvettes that got stopped in unison, I think in MN, on their way to a meet somewhere. Nice quality video of all the cars and drivers [bad 15 minutes of fame] and the cops citing them for going 95 mph. Should be defensible though as I am sure the court would understand and appreciate: a. "Its hard to near impossible to keep this car below that speed, your Honor, it needs to breath."; or b. "We just came thru Canada and thought we were still running metric numbers." lol
It really has to do with my attitude that "if you are driving, DRIVE", don't be driven by a computer. I really WANT to be totally responsible for the consequences of what I do with a car. Gee, GM finally makes a Corvette that is totally fun to drive and then they want to give the computer all the control?
Modern cars are getting numb-er and numb-er relative to a "direct" relationship between man and machine. I feel like I'm 50 miles away from the road. I know, I know, many people don't want the noise, smell or various unpleasant sensations, but I do, so that's just me.
Maybe my issues stem from my appraisal work, where I see so many beautiful modern sports cars smashed up by people who really don't have a clue. The active handling didn't really help them, they just went beyond it. In a way, the active handling made it worse, because when they DID lose it, they were WAY WAY beyond their ability to bring it back home.
But I'll compromise! Active handling for all Lincoln Town Cars!!!
How about "Retro-Active" handling? If you do something really stupid, your C5 or Porsche goes into "Time Out Default" and you only get 100 HP for a week!
In practicality, I have to agree somewhat with your assessment. It stands to reason that to fully understand and effectively utilize this function, one must pratice making it come on; i.e., "advertently" triggering it. It is sort of like how do you expect folks to do 180's, 360's and 540's unless you practice it. Of course, unless you are on a track or other facility, local law enforcement and or the civilians might not take too kindly to your active handling training session.
I faced this (minor) dilemma with my teenage driver and promptly after one year under her belt driving sent her to drivers school.
IMO, common misconception is that any thing is less costly or risky to mod. I've now seen several C5's modded until they don't run and from my daughter who dated a Mustang guy, it was even more common there. Then there are those who do part of the job and get to the track with 500+hp and then break the rear end or similar, I know one guy who's on his third Super Charger and now has complete new drive train but is still on stock size tires! Why? Engineers get paid lots to make it all work together and after market may be fun but in most cases will ignore something important, be it C5 or 928, nice looking ride BTW.
Well, from another perspective, taking a $40k to $50k car out to Sears Point with walls at every turn when you've not done much beyond driving at the speed limit makes it look like a pretty nice crutch. Then again I have a vested interest in more than just the hardware. Seeing how many, in the past year and just less than a half, have put very nice wheels into walls or ditches and I'm glad it's there. At the SCCA tracks, Buttonwillow and Thunderhill, where there is much more run off, I will begin testing with it off since I've now taken the slip angle around a few turns in open wheel cars and have a very minimal comfort level.
Not having it on the public highways when you just might need it in an emergency and are most likely never going to turn it on if you stay even close to posted limits makes disliking it seem just a little too quick to judge, IMO. I've had it on hundreds of times on the track and only once off the track, in a hydroplane situation. Studies now show that 30 to 35% of rollover fatalities would survive with the option. Not something to ignore, even if you think you will know what to do and have any time to do it, when the unexpected happens.
Classic, watch out what you wish for! The C5 now has a recorder that can be replayed after an accident giving data leading up to the crash that has been used in court. All kinds of issues but makes me pause before doing something that just might not pass the WSJ test, how would this look on the front page in the morning? It's a road we are firmly going down as more electronics are added so wishing it wern't so will probably cause many to opt for things like; a "928". Enjoy!
I now turn it off during driving schools. It made me feel almost invincible....get stupid and the AH will set you straight, and it really did its job. What fun is that? Someone else driving your car.
Also, it eats brake pads in a hurry. I went thru a pair of REAR pads in one day...like 4 1/2 hour sessions. These were track pads....suspect I should not mention the name.
When you eat rear pads long before fronts, someone else is driving. Not good!
I had owned a used '68 427 Corvette when I was in college and wished I never sold it. The timing was right to finally buy a "new" Corvette and I weighed the pros and cons of the C5 vs. the new C6. In the end analysis and with the help of this thread, it only made since to buy a solid and fresh C5. For the value of the C5 and the headache of trying to buy an above MSRP first year C6 with who knows what first year problems, it became an easy choice. Especially after I drove one, it was a done deal.
I have to say that I will never buy a car by visiting the lot and getting into the box with the salesman. I used GM Buypower and did all my shopping on the internet. I found the 3 cars that were exactly what I wanted (color and options) at 3 different dealerships and let the bidding begin. I settled on a good deal, the car listed at $47,540 and with the rebate I got the car at $38,921. It is an incredible value when you compare it to other cars and it is truly the best bang for the buck. The other good thing is it is a fresh car, built on 6-29-04. It still had the plastic on the seats when I arrived at the dealer. The deal was already done and I just had to check the car out and sign off.
I am really impressed with this car and loving it. I have found nothing wrong with the car and I am in the process of doing a polish and wax job, which is really nice as I am tired of laying under them and fixing something.
So I just wanted to let all of you know that I appreciate all the good information and look forward to more great experiences with the new Corvette.
I know an EVEN BETTER device for preventing accidents. It is called the human brain. It comes in various sizes and yes, you can switch it off when you need to--LOL!
I had an experience driving on U.S. 101 just north of San Francisco International where I hit a patch of water at night in a rain storm. The car immediately hydroplaned and I was doing 360 degree turns until the car came to a stop after punching headfirst into a re-inforced concrete divider between the north and south lanes. Needless to say, the car was totaled. Just before the spin started, I was doing maybe 40 - 45 mph in deference to the rain, so, it was not as if I was pushing the envelope.
Five years later, DSTC became available and I wanted to see how it worked and I tested a Volvo that had DSTC (Volvo's version of Active Handling) in a large empty parking lot by driving into standing water during a rainstorm and the instant the car started to loose control, the engine management system cut the power and the brakes started selective application to stop the spin within less than a car length of when the spin started.
That made a believer out of me. I will take every bit of help and not argue about whether it was me or the computer that did the driving. How does the saying go???: A liberal on health care is a conservative that got mugged by a catastrophic family illness.... Well, a corollary could be that a liberal on automotive safety systems is a conservative that got mugged by an epiphany of a car crash.
This is doubly true in my mind in the case of 400-500HP cars like the C5 or Viper or Porsche. If you can't handle it you shouldn't be driving it. Bada-bing, bada-boom! I'm sure a computer could be built to allow a 10 year old to drive an 18-wheeler or even fly a 747, but......
I treat cars like a C5 with a tremendous amount of respect for its capabilities. I can drive a Porsche pretty fast (I know them better than C5s). Why? Because I learned some things with a rear engine high powered car: You brake in a straight line, you turn in slowly, and you let the car set out of the turn before you punch it. Now how am I ever going to learn that with Active Handling unless I shut it down?
Why do you think AC Cobra replicas are so incredibly popular? It's the rawness. Even young guys jumping out of modern expensive cars CRAVE IT.
So while I agree there can be a lack of respect for these very powerful and sometimes not so powerful machines, using my rear ender example; the actual policy and execution (practical reality) does not make this happen.
So add to that; say I am DUI,
(why DUI? 40% of all yearly fatalities are in some way shape or form have alcohol related fault)
and rear end you with such force that you and I wind up in high probability of injury. I being DUI (and the cause of the accident) will in all likelihood by the force of me hitting you will almost assuridly deploy my airbag cushioning me from injury and all I have to do in the future is to make sure I chose an air bag equipt vehicle so I dont get hurt when I get DUI !!!??? You? well your airbag was not designed to function in a rear ender?... Why do I use rear ending as an example? Because it is probably the most common accident type.
It would be interesting to find out why he used a C-4 vs say a C5 chassis? Of what I have read about the C-5 chassis, it is theoretically and practically a 400 # wonderkin. This is not to say the C4 chassis is not a stellar performer.
About letting people experience the results of bad judgement, not very far sighted, IMO. We are all out there on the roads together and saving me and mine from mistakes by others that don't have to be fatal seems like just the slightest bit enlightened. Look up I680 SB at Treat in Walnut Creek about 10 days ago, 4 teens dead and one went to Hosp. critical. Spin which ended under a parked semi rearend. Too bad they didn't have stability control, the computer might have done the driving, to some extent.
