Mr. Shiftright, thanks for the response. I bought the car. I have the service records that include a major tune up incl. valve adj. 3 months ago. Last year all the shocks and struts were replaced and it got new brakes. I have all the receipts. I have the records that go back to 1994. So the car is indeed in "great" shape. I will replace tires. I am really impressed with the car. Also after all the bad things I hear of the A/C systems I just presumed that it would not work. To my surprise the climate control works just fine and the interior is still a B+.
So, now I just have to learn about this car a little more since I intend to do the maintenace, most of it at least. What do you recommend? Are there service manuals for these things. I think I read somewhere that they exist and are pretty complete.
Any tips for maintenace are appreciated. Where is best place to get parts??? Thanks so much. Glad to join the club!
Oh. There is a lever in the left side of driver's seat. What is it for? I think it would adjust the height of the seat but nothing happens when I pull it. Ideas?
Diesels needs more frequent maintenance than gas cars. Some things I do religiously area:
Oil and filter every 3,000 miles
Flush coolant once a year
Flush brake fluid once a year
Always use additives in the fuel, both cleaner and cetane booster
Change fuel filters (there are two) often (see manual).
Adjust valves as per factory recommendations (I think it's every 15K)
It would be a good idea to get the factory manuals. There are 3 I believe. One for engine, one for maintenance and one for chassis. I have the whole set.
That is an interesting question. I just realized that it only works sometimes. That will annoy me. So what is the secret to making it work?
Also the speedometer vibrates when starting to about 20mph I guess. Is that the tires or is it just normal?
I was always under the impression that Diesels required less maintenance. I guess I was wrong. How often should I change the ATF and Differential oil? On my old Honda I used to do a major tune-up once a year and was pretty religious about the 3K oil changes.
Only one thing. Please help. How easy is it to adjust the valves? I can do everything on the list. I have seen the valves adjusted once on a BMW. And it seemed so darn easy as long as you could tell difference between intakes and exhaust.
Do the Manuals show how to do this?? I would love a picture or any info on this. I think that I should be able to do it.
I had a 90 Accord and even though it said you should adjust the valves, I never did. At 170K it was still running perfectly.
The valves are easy to adjust but you need a special "crow foot" wrench to loosen the adjuster nut on the valve. A normal wrench can't get it. Mercedes will sell you this tool or maybe you can borrow it. The manual should give the tool #.
Most people are confused about diesel maintenance. The general rule is:
Diesel maintenance is less costly per service, but you need to service them more often. So it's really a wash in terms of expense.
Also a diesel engine will generally cost more to rebuild than an equivalent gas engine, as it is built to a higher standard.
What is the Spedo head? Also, can you tell me precisely where I would find this Tac sending unit? Everyone mentions these rebuilt parts. If I went to the dealer is there any chance that they have a new part? Sometimes the new part is not much more than rebuilt.
Also, where is the Speedo cable located? And how do you grease the cable? Isn't it self contained? How do I get the grease inside the cable?
I presume when you say grease you mean general lithium grease. I imagine that will do.
I bought a Hayes manual just so I can look at some of the basic stuff. I hope that I will get a chance to learn this stuff before it breaks down.. Thanks for all the help and tips.
You mention the importance of changing oil and filter every 3000 mi. for diesels. I assume you mean traditional oil. What about synthetics like Amsoil, Redline and Mobil 1? Both Amsoil and Redline claim extended intervals between drains but what affect do these longer intervals have on the oil filter? Any suggestions? Thanks.
Given the cost of a Mercedes diesel engine replacement, I don't see the wisdom in saving a bit of time and money using extended oil drains.
I realize that the Big Rigs probably don't change their oils every 3,000, but these engines are monsters and also have masive filtration systems. You really can't compare them to dinky auto diesel engines.
Thanks so very much for all the tips. They come in handy. I will look at those 2 items soon. The Tac works sometimes. I think more often than not it is not working. I will look into the sending unit.
I replaced the tires on my car today. They needed it so bad. I kept one wheel as the spare and put a new tire on the spare since it was flat! So instead of unmounting a tire from one wheel and remounting it on the spare they just swapped wheels.... I guess this is not a problem since it is a full spare.
In doing so I noticed that the rear driver's side brakes are not wearing out evenly. I presume a failing caliper. Should I just replace the caliper? Also I have to press hard on the brakes. Most likely a bad booster. I should be able to do these repairs.
Paul do you know any good place to get parts? Also, how do I remove the Speddo component? I don't think that will be covered in Hayes manual.
Again, thanks for the tips. Oh! What oil do you use?
I realized that there is a rebuild kit for Calipers that costs 1/10 of a rebuilt caliper. Should I just do that. I think all you do is remove the pistons and seals clean it all out and put in new seals. How hard can that be?
How can I know for sure if I need a new brake booster. I tested it as follows. Pressed the brakes several times with the car off and then turned the car on. Sure enough the brakes went down closer to the floor. But it was very slow. I guess in my newer car as soon as I turn the car on they drop right away and faster.
How hard is it to replace the oil cooler hoses? The last service invoice said that it needed them and the cost was 275. Seems a lot to me to replace some hoses.
Glow plugs. It seems more expensive to have them tested than to just replace them. Should I replace them as preventive maintenance? And how often should I replace them going forward?
Mr. Shiftright/Paul??? I would appreciate tips.
Also, it seems that there is an excellent Mechanic in Walnut Creek. So may use him for major stuff!
I agree, I don't think trying to rebuild the calipers yourself has much of a chance of success unless you are very very lucky.
WOW! Great stuff. I will not rebuild the calipers. Thanks for the advice. It is only the left rear that has uneven wear.
What do you think of the Booster question? The brake pedal is a bit hard, but I am comparing it to a 2001 Subaru Outback that is known for Squeeshy brake pedal. Is there a way to test the thing out.
Thanks on the oil cooler hoses. I will have to look for them. I am not sure where they are yet. I am just going by what the last invoice of service recommended.
Paul, my clock does not work either, is that part of the tach sending unit? I presume not! But one never knows, one thing can screw up the other. One last thing, when I turn my key to let the glow plugs warm up the antenna goes up. And then when I crank the engine it goes back down and then up again. Is this right?
Where are you located Paul? I am in Bay Area!
The 300D has a big booster. Your brakes should stop on a dime. If the booster were defective, you'd have to literally STAND on those brakes to get the car to stop. If you have a bad caliper or two, or glazed rotors or pads, your braking efficiency will be very badly compromised.
I suppose you could disconnect the brake booster vacuum feed and plug it up and then see if there's any difference. I'd be very careful how and where you do this, and am not officially recommending it.
I think that I will also have to replace the CV boots. I am sure that will be time consuming. It seems that you have to take off the cover of the differential to release the axles. Euffff! Maybe it is not as complicated as I think. I just have to remember that when I get the CV boot kit to get a new gasket for differential and new 80/90.
Are the Mercedes CD's really worth it? I need lots of pictures to help me spot these things. Like the oil cooler hoses. I will look for them now. Paul you said oil filter is in left back of the engine. Driver's side? There is a filter in the front of engine Driver's side that looks just like and oil filter. So what is that?
I am taking a big exam this Saturday. After that I will have time to fix all these little odds and ends and my 300 will be in tip top shape. I will let you know how it goes! And am sure that I will have more questions.
Most people don't understand that what makes Mercedes different from most cars is that they are made to be taken apart and repaired. Most components are very well built and also built to be disassembled and renewed and even adjusted for best service.
I presume that with the CD's you can print out the pages you may need. Is this the case? I just did look in EBAY and they have a set of Manuals (Printed Copy) up for $60. I am not sure if that is a good deal or not. Also I see a lot of ads for the CD's and they are much cheaper. Any reasons for this?
Also I saw an alert with one of the parts about the Flex Discs on the driveline. The guy mentions that in a few cases they break and cause a lot of damage to the car. Is this true? It is the first I hear of this.
For example, I've never had another car with a drain plug for the torque converter, so that you can fully drain the transmission without having to flush it. Or the oil filter and oil drain are so nicely laid out, that it is possible to perform an oil change without getting a single drop of oil on the floor.
Or take my instrument cluster. It is just a perfect and tight fit into the dashboard, no fasteners whatsoever. It just sits in place. The electrical connectors to it use small handles to release and reconnect, so that it is essentially impossible to bend the pins of the connector itself. This extreme focus on detail is just very nice.
Compared to GM, the "taking apart" of the Mercedes is optional for about the first 10 years of its life. With GM it is mandatory, all the time...and not as much fun.
That was very well put. I guess another difference between Mercedes and GM is that you have to take apart a Mercedes if you want to. A GM comes apart whether you want it or not. Ha ha ha.
But hose clamps are just an example, electrical connectors are really more important. I remember replacing a throttle position sensor in a Ford. One retaining clips of the electrical connector broke immediately. It was just cheap. The sensor itself was attached to the throttle body with plain phillips screws, torqued beyond reason. Why not spend 50 cents more on TORX bolts, so that the unit can be serviced ? (I ended up removing the valve cover, so that I could put my whole body weight against the electrical drill that finally removed the screw.)
You just don't find that kind of stuff in a Benz. Sometimes MB's solutions are a little bit odd, but always thought out.
I have not looked yet but, I don't think that I have the Original MB tool box. Is it literally a box with tools? Or just a few wrenches and screwdrivers? Thanks. Still thinking of the comments and laughing.
Please tell me if there is really a need to replace the flex plate in the driveline as a preventive measure? Thanks
If you don't have it, I'm sure you can find one on E*Bay very easily.
It is crucial on my car, as it contains the wheel mounting pin. Since my vehicle has lug bolts, and not lug nuts, it is a major pain to change a wheel without it.
The oil filter housing is on not in the left rear of the engine.
Ha ha ha. I appreciate that correction. English is my second language and I do that all the time. So am learning two things at once. Good to know that is the fuel filter. Knowing me, I probably would try to untighten it like an oil filter.
Once I find the oil Filter housing I will then see the oil cooler hose pipes. Great! I will look to see if they are leaking!
I am extremely interested in the car as it fascinates me quite a bit. Also, doing work with my hands is a great stress reliever and break from looking at a computer all day as my career demands. I very much look forward to doing the maintenance on it. Only one thing that scares me is valve adjustment. Would like to watch someone first, but can't exactly ask my mechanic for that.....
I spotted the Tach sending unit. I unscrewed it and then put it back in and VOILA! Tach works again. I presume this will only be temporary and it will stop again. But at least that tells me that it is the sending unit not the Tach itself. I might try taking it off and getting some wire cleaner/dryer and cleaning it all up. Sometimes that works.
Can you do me a big favor and tell me what speed your 300 is going in the Highway when the rpms is exactly at 3. I am curious if my speedometer is well calibrated. It seems that when I am going only 65 I am passing a lot of people. So just let me know what the speed should be.
I also saw the oil filter casing. And attached are the hoses but they are aluminum and I thought that they were just rubber. In any event, I don't see any leaks at all. So am not sure if it was fixed and the Mechanic just forgot to delete that from the suggestions box in the invoice.
Soon I will test the brakes and booster. If I find glazed pads or something like that I might just do an overhaul and replace rotors pads and flush the fluid. Then I'll be sure it is all good!
I wonder if the new entry level Mercedes is as cheap...
I can definitely say that it doesn't have the old Mercedes "tank feel" to it. But that is merely a personal preference.
My issue is rather, that for $30K, you a have a pretty decent set of competitive products.
In three of my power windows when I close them all the way and hold the button the motor stops working once the window is closed. However, one of them and the sunroof, the motor keeps going as long as I hold the button down. What do I need to do to fix that. Since the other 3 stop I suppose the fourth and the sunroof should do the same. Anyone have tips. Thanks.
Not sure about the power window...it SHOULD stop but I don't know if it can be adjusted to do so or if that's a defect in the motor itself. If adjustable, you'd need to look at the factory manual. If it's in the motor, I'd just live with it, it's a bit of a pain to change all that out.
Thanks. I guess it is a delicate balance in knowing when the roof is fully closed and overdoing it. I am always afraid that I will burn out the motor. But perhaps there is really no damage since after 20 years it is still working.
My Tac has been working all weekend and I am going to lube the speedometer to see if eliminates the vibrating from 0 mph to about 30mph.
I see some 300D's and the rear of the car is sig. higer than the front of the car. And some the rear kind of sags a bit. I like the higher look since it looks peppy. My car just got new shocks 1 1/2 years ago. Could it be the Springs?
Finally, at 75mph my tac reads 3500 rpm's. That seems a bit high. Is this about right?
Mr. S. I really appreciate the info. I think I will eventually get the CD manuals! But that doesn't show you how to test for things!
I have realized that my CC does not work. Or perhaps I don't know how to operate it. I was on the highway and simply moved that lever attached to the steering wheel. I tried up and down and nothing seemed to work. Is there a button that I have to press to turn it on? On new cars there is. Am I not doing it right? Also, I see that there are a bunch of CC components. What do I look for to get it to work?
I hope the answer is that I am not operating it right. Since the A/C works excellent. Only that when it is on automatic the fan seems to stay at high. I thought that as the car cooled it would slow down.
I know I ask a lot of questions. Curiosity!!! And I enjoy working these things out. So I am always most thankful for tips.
That may be the key. Pull it towards me first to turn it on! I will check it out again.
BTW, the CC lever in my wife's 1977 300D operates exactly like the one in my 2000 E320. The only anomaly is that in the older car, the speed seems to slow slightly after the lever is used to set the CC. When I'm driving the 300D, I normally hold the lever for a second or two to ensure that the CC maintains the speed I want. Also, the E320 CC will cause a downshift to maintain the selected speed when the car is going downhill. Nice!
Hope this helps!
I think I tried moving it toward the windshield and also toward the floor. It did not hold my speed. So I am not sure what is wrong with it. Do you do your own maintenance on the car? I am hoping that I can learn enough to fix most problems myself. For now the most important thing that I want to fix is the brakes. I think they can be a lot smoother. In my 01 Outback I just touch the brake pedal. In the MB I actually have to aaply force to it.
Also when I open my door lock, the other door locks come up slowly! Is this ok? On a previous BMW they would pop right up.
Actually, CC on a 300D is a bit of a joke anyway. It's an optimistic notion to say the least.
Yes, the door locks are slow since they are vacuum.
