dubinsc, you're speaking of the V6 Mustang, right? If so, probably the reason for the seemingly lack of mods for the 2003 V6 could be the different engine Ford started using that year. Until 2003, Ford used the 3.8l Essex V6 for the Mustang. In '03, Ford moved to the 3.9. That said, with the exception of some engine mods, stuff like exhaust, etc. should work just fine on an '03 Mustang, even if the catalogs only say 1999-2002. It's otherwise the same car.
bob121, no difference whatsoever. The two years are in all major ways mechanically identical.
sc1977, good question. Have you checked the Differential Pressure Feedback EGR (DPFE) Sensor? Sometimes when they go bad, the car shudders and surges when driving. Are you sure the head gasket is okay? That year's engine is notorious for head gasket failure. Also, have you checked the thermostat?
Most Mustang people like this, as it moves your power band down to where you use it more. However, make sure your speedometer is properly calibrated for the change, otherwise it'll be off (there's a pop-in eletronic module that does this).
The dealer will be able to tell you if you still have the stock gearing (3.27) or something else, and if you have the speedo recal.
That error in judgement along with parking it outside has really taken a toll on the top. The back window panel is disentigrating and has a huge tear in the middle right below the window. It seems time to replace it.
So, I called the dealer to get the "high" price. They want about $3000 just for the parts! So, I looked online and found a place that has the whole top, glass and all, for about $300. Of course that has me suspicious. I really don't know what to expect for a reasonable price for a quality replacement. Does anyone have any suggestions, advice, opinions? Any leads on a reputable convertible top dealer? I really don't want to just pick an online store at random.
I'm a regular at stangnetdotcom (I can't directly link to the site due to Edmunds' policies)...doing a search of its forums might turn up some good suggestions (the people there are big online shoppers...)
Junkyard is selling me a 99’ Marquis engine ($800) all included.
Main difference between the 99’ 4.6 Mustang engine and Grand Marquis?
Are PI heads the same?
Intake manifold?
Crankshaft 6 or 8 bolts?
Compression ratio I think is not same.
Can I do the swap with confidence?
Would I get same HP? as if, I do the same swap with a 99 Mustang engine.
Thx!
Of course, fuel injection and computer stuff out of discussion. Just engine block, heads, and intake.
I believe they do have the same heads and intake manifold. As far as the crank bolts, I think some had 6, some 8. :confuse:
Any higher performance rwd car is going to give you a greater chance of losing grip in the snow with out, traction control and all the other electronics to help you out. The best suggestion is to buy a second set of 'winter wheels' with the best snow tires you can afford. Then pay about $15.00 for cat litter and keep it in your trunk. This helps put some weight in the back of the car, but also gives you a good material to help with traction in the event you get stuck with wheel spin.
Hopefully someone can provide me with some info.
I spotted a half cover that went over the down part of the conv.top and went to the back of the front seat.I thought it looked real neat I assume its fibreglass and definitely an aftermarket thing.If anyone knows what I'm talking about can you provide me with some info.Where can I get one,how much do they cost,is it practical, and whatever else.Thank you for your time.Duwop1
Chintan Talati
Corporate Communications
Edmunds.com
i bought a 1994 mustang gt black on black convertible and i love it.. but on my pink slip it says lemon and i cant find out why it is a lemon... and what was wrong with it to be come a lemon.. can someone help me... thank you need to know because i can keep track of it just in case it was something that could be dangerous.. thank you
I like those years of the Pony. - Loren
targa top mustang
I like the look.
-Loren
The 'verts do have strengthed a-pillars.
That car must have body flex worse than a '80s Fox body convertible...I notice for all of his mods, he hasn't done anything to stiffen the subframe to compensate for cutting out a significant part of the unibody.
Any thoughts? :confuse:
If the Sebring has the 2.7 V6, it could be prone to sludging. Be sure to have someone in the know - as in mechanic look it over. Both the Stang and the Sebring are good looking autos. I assume we are talking hard tops. NO convertibles for teens. And change oil at 3K on Chrysler.
Some links for ya: link 1
link2
You will find both are relatively inexpensive for repairs / parts. Roam around on the site link above for more info. about the cars than simply repair costs.
-Loren
To be sure, we're talking about a V6 Mustang right? If not, a V8 GT is probably a bad idea for a teenage driver.
On the Mustang, some of the 3.8 V6s had head gasket failure problems (expensive to fix), so be sure to have it checked out by a mechanic.
The only factory-made V6 special edition for the 99-04s was the "pony package", which provided special trim, wheels and a very odd tape graphic of running horses...
Try to find out what dealer the car originally came from, and you can call and discuss with them.
What color is she? What are the special options?
Interesting about the "Sundowner" logo. That's not a Ford designation, so the factory wouldn't have put it on. The dealer must have gone to a lot of trouble to professionally install it.
Manual or automatic? Anything different about the interior?
Dealer upgrades can be any and all things, but usually take the form of different wheels, trim elements and exterior graphics. It's rare these days for dealers to offer performance mods.
As far for other dealer-added stuff you might have, if you have anything made of metal/metal colored in the interior, it's from the dealer...Mustangs from the factory are heavy on the monochrome plastic.
The interior has no other upgrades that I can see. They did upgrade the stereo but otherwise it seems to be factory.
I called Ford but they were limited as to what information they had on it. I would love to find out what the promotion was or whatever made them upgrade it to the point they did - I found out from Carfax that the original owner was a rental car company (I'm the 2nd owner) and that it was shipped to a dealer in Burlingame California with 5 miles on it. But the only Ford dealer I could find in Burlingame California is no longer in business. Any suggestions on where else I could get more info whatever the promotion was? It seems unusual to put so many upgrades on a car intended to be used as a rental.
Yeah, not surprised that Ford was unhelpful. I've had trouble even getting them to even answer the phone, much less provide useful information.
Sounds like the original owner was hoping to develop a unique rental that he hoped would stand out in the pack. It's impressive that they went to such trouble to apply the "sundowner" logo correctly...most places would have just slapped a sticker on it.
In any event, looks like your car may have been a one-off sort of thing. You might want to try posting on some Mustang fan sites...stangnet (dot) com is a good place with people who have scary amounts of knowledge about Mustangs...
So enjoy having a unique, probably one-of-a-kind Mustang. Red convertible with a white interior is a classic Mustang combination, and the white leather interior was particularly rare for that year as well.
