Thanks, Mike
Thx in advance
Khalid
they could not or would not say if i had a potential fire hazard , good luck probably be cheaper to get rid of it if it is that problem ,
96 08 07
August 12, 2008. Supersedes Technical Service Bulletin Group 96 number 06-01 dated July 14, 2006 to update SRT.
Vehicle Information
Ignition switch cannot be turned on; key may stick in ignition
Condition
^ Engine will not start.
^ Ignition cannot be turned on.
^ In some cases, the ignition key cannot be removed from the ignition switch after attempting to start the engine.
Technical Background
No communication with the Access/Start Control Unit (J518), which may be caused by capacitor and or transistor damage within the Access/Start Control Unit (J518).
Production Solution
Introduction of an improved Access/Start Control Unit (J518).
This applies to ALL 2005 and some 2006.
NOTE: Keep in mind that this is not a free repair if you are out of warranty.
The car is 2001 A6 Quattro 2.7T.
I can start the car and everything runs fine including locking/security system, brake switch / transmission interlocks etc. I simply can not remove the ignition key. Is this simply a mechanical problem in the ignition lock or something more sinister like a software problem in a steering column control module. How many reasons could Audi engineers have for not releasing the key?
I'd also be curious about the headlight TSB. My wife's A6 has given us that message a couple of times, though things continue to work fine.
-Paul
Mike
My 2001 Audi A6 has power steering issue. When the car is parked with outside temperature under 60F for a night, the second morning the power steering is very heavy. I have to drive it for a while and restart the engine to get back the smooth steering. If I just drive it without restarting the engine, it won't get better. Looks like a sensor issue. Is anybody having the same issue? How can I fix it. Thanks.
-- Yue
i hope that this is a isolated problem , but i doubt it and not to make you have a sleep less night , but see what your Lemon Law are in your state ,
i been there and sorry to say it was a real pain but my only mistake was for 45 days that my car sat waiting on a Audi Tech to come to fix it i did not take a loaner , that plays a part of paper trail , and there is nothing about audi and customer care
good luck
Any ideas?
I have to open the door or move the key out of my pocket and it will start.
Has anyone come across this problem before??
If not, I'd suspect corroded battery cables, and if they check out okay, I'd suspect a bad neutral safety switch. (presuming you have an automatic)-- or a bad clutch switch, if you have a manual transmission.
I need to replace this part but am unable to find th name of the component or where to get this part from. I live in France and am reluctant to take the car to an audi dealer as it looks like a job I can do myself.
I have 2 pictures, one a close up of the component and the second a picture showing where it is positioned which can be emailed if they are any help, I dont know how to add them to the post
Thanks in advance for any help anyone can give.
Kind Regards
I will keep you posted of what has been done.
Fixed under warranty.
-Paul
I would just take the bracket off that holds the caliper on the car, but there is a break line running directly behind the bolt that I don't want to bend too much. Has anyone encountered this and did you find a good way around it? Any help or idea's would be greatly appreciated.
If what they have done to my car appears to have corrected the problem, it is only a temporary solution. The dirty valves problem will come back.
That is my second Audi A6 and it will be my last one if they cannot find a permanent fix to this problem.
Honest opinions here, any reason why i shouldn't buy it.
The only other issue that has come up is the front rotors are warped because the place I took it for state inspection didn't torque the lug nuts down correctly. So...I'll be purchasing new rotors and putting them on myself (already purchased a caliper resetting kit). The car drives and performs wonderfully. We took it on a trip to Nags Head, NC (from DC Metro) and the car was terrific.
Honestly, take the car to a mechanic for a 2nd opinion. If it's in good shape, pay for an oil change (unless the seller/dealer is willing to do one for you). If you go with synthetic, you'll be good for 10k miles. Shortly after that, you'll be due for the 75k mile service visit where they do all the major stuff. I was told that visit will cost about $1000. I asked about the transmission fluid and with the Quattro...everyone in Audi says it's a lifetime fluid and it doesn't get changed. If you have anything other than the Quattro...you would have to get it serviced. Don't ask me why, but that is what Audi corporate explained to me.
As far as the turbo 2.7...jury is out on that. When I purchased mine, everyone I ran into with Audis said to stay away from the turbo model as the turbo is known for going out around the 120k mile mark. It was suggested if I could get the 3.0 to do so. Just something to maybe look into and do some research on before you pull the trigger.
Good luck!
Has anyone else experienced this? Does Audi need to run an ad campaign about how Audis are for everyone unless you happen to have a tree canopy over your driveway?
Does your car's cooling fan ever run when the car is off. I had this happened to me a couple of times and I cant figure out why. the fan is also LOUD. when the car stops at a light everyone looks at my green Audi not because it is cool looking, it is because the fan is running at full speed with the ac off. I had this car for one year and I just want to get rid of it. It is a fast, great handling car, but, it will take all the money out of your wallet. :lemon:
Honestly, the car drives so nice when it isn't in the shop, and Quattro is amazing.
Within the next year I'm going to buy an A5 or an S4, but I hope I get lucky this time.
Now...I know from what I was told by Audi Corp., if the tranny goes bad due to fluid breakdown...they will be replacing my transmission since everyone affilitated with Audi, that I have spoken to, has told me that the transmission on the 3.0 Quattro does not require transmission servicing because it has lifetime fluid in it. They said if I didn't have the Quattro or if I had a manual transmission...it would be a different story. Again...this is what folks from Audi are saying.
