Chevy Silverado
Mike
-David
I loosened the hose clamp, but couldn't get the intake pulled back from the throttle body. Any advice on how I can get to the intake to clean it would be appreciated.
Are you sure the cleaner you are using is the right stuff?
Also be careful - there are some sharp edges in the throttle body.
Thanks again!
I'm not happy with the firestone tires that came with the truck any suggestions?
Yokohama Geolander AT tires.
I have had BFG's, Pirelli Scorpions and the Yokohama's on my trucks in the last 3 years.
I would reccomend the Yokohama's over the other two. The BFG's were a little squirly in the rain and wore faster the the Yoko's.
I have had my Yoko's in dirt, snow, ice and rain and absolutely love them.
But I will check out the Yoko's
Thanks all, I will check them out !
Ray T.
Well I looked alot I went with BFG All terrains, I believe its the same road noise as my Firestones but I actually stay on the road.
265 75 R16 Installed with tax , road hazard, life rotate , balance etc was $604.00 USD.
I got 50,000 miles out of those white knuckle Firestones, NEVER again. I also found a Tire store that will buy your factory tires off your new truck and up grade you. I do not know how much depends on the tire, Just a heads up.
The tires were definately BFG A/T's
I would say that your truck with the sheer weight of sand, spreader and plough will definately make things more stable.
I live in the mountains here in Southern Cal.
I have to drive down the hill every day to commute to work. So i get to drive the gamut of road conditions, including ICE. When I had BFG's on my 97 GMC Sierra 1/2 ton, these tires were scary on the So Cal wet pavement. I an not one of those kind of people that like to drive a truck for looks, I use it. Every opportunity I get I either go play in the snow, desert or anywhere else off of the beathen path. Comparing the BFG's to what I am currently running, I will never go back.
Especially after seeing a 10 inch cut in the sidewall from minor rock crawling hold up for a 80+ mile trip home.
BFG All-Terrain T/A's: Very happy with mine despite minor problems. Only one bad incident to report, and that on another truck, a '76' F250. Lost control in a driving rain in a panic stop on the interstate. I'm more inclined to blame the technology of the era: Drum brakes, non-ABS, faulty adjustment. The Silverado's with 23K have performed very well in similar conditions to gator's, except less snow. We live in close proximity. No squirlyness to report.
Also to consider is the presumed improvement of the current version of the T/As (the KO) over the old. The '76' has the old, the Silverado the KO. If you compare them side by side, the difference is clearly apparent: The KO has deeper ribs at the outer diameter of the sidewall ( better traction in deep snow, sand, or mud) and more sipes across the tread ( better braking on wet pavement). Gator, you don't indicate which version was on your '97'. But knowing you pretty much know your stuff I'll be checking out the Yokohamas at the next opportunity.
-David
Okay 2000 miles with them now, still happy.
Handle great compared to those Firestone Wilderness,.
Regarding the YOKO's I still have not seen them in person, Is the price around the BFG's ? If so maybe next time. But anyway if anyone does not like the way their 1500 4X4 ext cab handles, get rid of the firestones and go with a heavier side wall ! It will bring tears to your eyes !!!
I am starting to hear squeaking from the steering
wheel when I am turning it. Does anybody know where and how to grease what is squeaking?
Thanks in advanced,
Mark
Tires
I got about 45K out of my Wilderness. I changed 6K miles ago and opted for the Michelin LTX M/S. Look great, ride nice (a little stiffer than the Firestones), quiet, and wear great. I did notice in rain they blow more water out the wheel well.
Problems
About 3 months ago my fuel guage started swinging back and forth between E and F after a fill up, and if I come to a stop at a light. I checked and the sending unit can be changed alone ($125) or with the pump assembly ($350)should I just change the sending unit and hope that fixes it or change both? If you change the send unit and it does not fix it you have to buy the pump/sending unit together and canot buy the pump assy separate.
Next, my mileage has dropped lately. I ran fuel injector cleaner (STP) through it and no help. I was getting 15-16 around town, 18-20 on the highway. Last tank (rural highway driving) I only got 13. In the past when I pull my camper (4,000lbs) I got 12.5 and I am only getting 1mpg more than that unladden. Any ideas?
-David
Ed
Thanks for any responses.
step 1: attach 4 wires from adapter plug to 4 wires on brake controller
step 2: plug adapter into wiring harnes to the left of the brake pedal.
no drilling, no wires to run all over the truck
good luck
extended-cab, two-wheel drive truck. The vehicle
we drove had excessive noise at speeds 60-64.
At 70-73 the vehicle was perfectly quiet.
I drove four additonal vehicles similar to the first one I drove. All of them had the same
problem.
My hod-roding days are over so I do not want the
extra noise. Have any of you experienced this
problem with your Silverados? I read the message
board posts for a ways back and did not see any
reference to this problem.
Thanks for information.
Orville
Ray T.
Report Your Local Gas Prices Here
PF Flyer
Got a Quick, Technical Question?
...might be a good place to start!
PF Flyer
Rumors are that some of the factory installers torqued the intake manifold too tight.
The intake on this motor is torqued in inch lbs versus the normal ft lbs.
