I noted the next morning a significant oil puddle on the garage floor and I called her at work and told her to check before she went anywhere at lunch. She reported back a large puddle of oil under the car. Called the dealer and was told to bring it in anytime and they would look at it but they were pretty sure it was not related to any work they had done. My wife took it immediately to the dealer (I told her to check the oil level first to make sure it wasn't running too low). Upon arrival she was told she would have to make an appointment to bring it in. After an exchange of phone calls they agreed to look at it. They reported back that a couple of "screws" were not tightened. They topped up the oil, gave her a certificate for a free car wash and oil change. Like I should trust them to do it right next time.
When she got home I checked out conditions and from oil residue on the splash pan it was clear oil had been leaking from both drain plug and oil filter. Then last night she got the follow-up call from the dealer asking how the service was. She gave them a four stars out of five. But she did express our disappointment with the service. I'd have given them a one, at best. Just another reminder of why I rarely take any of my cars back to dealer for service, unless a warranty repair.
Still have the original Firestones, and will make another 10K before I replace them before winter. Original brake pads are also in great shape and should easily make another 20K to 30K before replacing. Needless to say I will probably do it myself.
-juice
I personally think you let the dealer off to easy. They should at least offer to have your garage floor cleaned, replace the splash gaurd (which is probably also soaked in oil) and even offer a huge discount on the 90K service interval.
If you're not satisfied with the way the dealer handled their error, I'd call 1-800-SUBARU3 and make sure someone at SOA knows.
Ken
Well, now they're testing all the cars in neutral again, so you can take any lane.
I think they stopped because it took too much time and people complained about the lines. Last time, my Miata went on the dyno but the Forester didn't. This year, neither had to go on a dyno.
-juice
You can take your OB to any inspection station in NY, just make sure you tell them it is AWD. I go to a local place and the only thing they don't do is Dyno it.
Mark
However, I can't remember the last time I had a vehicle dyno'd. They just plug in the OBDII connector, do a test with the vehicle idling, and it's done.
-Brian
-juice
Of course it could be SOA just trying to cover their liability in case the bag fails to deploy properly.
I also read somewhere, and I don't know if this is true or not, that the side airbags are the reason we can't get side rails for the 03 Foresters.
Anyone know for sure on that?
Larry
-juice
Larry
At my first oil change, I asked my local dealer to take a look at the problem. They found that the alignment was slightly off, and corrected the problem under warranty (the car had under 3000 miles and I haven't even hit a rough road or gone off-road yet).
Problem solved? Not quite. It still pulls somewhat, depending on the conditions. And, I still generally have to drive while steering slightly to the left. I took it back today, and the tech's brilliant conclusion is that the car does not actually pull to the left. I am imagining it.
What could the problem be? (Since other drivers have also noticed the pull, I'm fairly certain I'm not losing it). Still the alignment? Could the steering be improperly "calibrated"? An AWD problem?
This is my first Subaru--and I love the car. The problem is really minor, but I am getting tired of always having to steer left to stay on the road--especially when the wind picks up.
I suppose it's possible that resistance in a portion of the drive train sending power to the right front wheel could pull the vehicle in that direction. However I wouldn't think it's AWD related since there's no front LSD.
Pulling to one side is usually an alignment problem. However if that checks out, here are a couple of possibilities:
- The crown on some roads is sufficient for the car to want to drift to the right.
- I've heard that even when perfectly aligned, some cars are designed to pull slightly to the right. Supposedly this is to reduce the chances of a head-on if the driver becomes incapacitated (or falls asleep).
You've already brought up a 3rd possibility, which is wind direction. The Forester has a fairly significant profile and a decent wind will noticeably affect the steering (this would be especially true if you're coming from a smaller more aero-dynamic vehicle). Of course some drivers are more sensitive to steering inputs too...
-Frank P.
The idea that this helps avoid oncoming traffic makes sense though.
Thanks for the imput.
-Frank P.
George
I have almost always found that a slight pull is tire induced. Try making sure the pressure in all tires are the same. You might also try rotating the tire(s) front to back to see if it changes the pulling (one side at a time for OCD folks). Recent pull in my Sienna went away with the new Harmonys installed. Also, a fairly large pull developed on my OB when I had the Sport A2s cross rotated. Definitely tire related.
Never thought of designed in pulling to prevent head on collisions. Interesting.
Greg
99.9% of consistent pulling problems are from alignment, tires and/or road conditions.
Dealers don't always know how to do alignments. I've found Subaru dealers that have had all their alignment specs calibrated off. In other words, each tire was in perfect alignment relative to each other, but all four tires were off by the same amount. I would only trust a dedicated alignment shop to do this right. I highly recommend trying to find a reputable shop in your area.
Next are the tires. Quite often, manufacturing inconsistencies in tires will cause them to drift off center a bit. Again, a good alignment shop can identify this and remedy it by rotating the problem tire to another wheel position. Tire pressures can also play a role. Make sure the left-right pressures are not way off.
Finally, even the most seemingly flat roads are crowned. Try experimenting on various roads to see if it persists. Sometimes freeways are built on separate stretches of asphalt so you can drive in the "fast" lane and have the crown dip to the left. Again, a good alignment shop will always take your vehicle out for a road test after the alignment job. They will know which roads in the area are flat.
Moral of the story: Trust an alignment shop to do a proper alignment.
Ken
Do you have a copy of the alignment results from the last time it was in? Sometimes the shop will give this to you to 'show' you the car is aligned. Maybe we can identify a possible source of the slight pull from that spec sheet.
But, the easiest thing to check is tire pressure (mentioned above). Maybe try 32 psi all around if you're not already at that?
-Brian
Steve
-Colin
The motor on the OB is kind of noisy (makes a loud humming noise).
-Dennis
Colin: I didn't realize you changed out the gaskets twice. So was that in addition to when the dealer worked on it?
Ken
discovered a burning smell in the car - like burnt rubber. though it was a belt problem.
no sign of low oil 3k miles after the last change.
looked under the hood - looking for drips, stains and leaks - nothing.
ran the car pretty hard to see if I could get the smell again, and looked underneath. Sure enough smoke coming from where the exhaust system joins and head to the rear of the car)
oil must have been dripping on it - in very small amounts I assume.
warranty repair work was done - replaced a "cam-shaft seal or perhaps a crank-shaft seal" cant remember what exactly was done.
Jury is out on whether they got to the cause...
thanks to all who posted similar threads on this same issue - helped a lot.
TC
I got a few bolts stuck when doing the cams and pulled both heads then.
The next time was only the left side, when it was blown and leaking like crazy. That's the time corresponding to the pics on my imagestation gallery...
-Colin
Greg
I guess the other 0.1% is from cell phone usage.
Greg
"Harris (the defendant) had been awake for more than 30 hours at the time of the wreck, having just moved his fiancée and their children from Baltimore. The defense attorney said Harris had one drink at a restaurant while waiting for a to-go order he'd called in for his family. On the way home he got lost and was dialing his cellphone and driving down an unfamiliar street when he crashed."
-Frank P.
In your case with a new car I would insist on a full -front- and -rear- alignment. The dealer should do this at no cost to you. Also check tire pressures; they pump them up to 40+ lbs for shipping and a lot of times the dealer does not reduce the pressure prior to delivery to the customer. Finally, it is not unheard-of to have a bad tire.
But remember the basics; Subies are sensitive in this regard. If you are new to AWD cars in general and Subies in particular this may take a bit of acclimation on your part. If the dealer aligns the car and the tire pressures are right and you still feel 'pulling', check to see if it happens only on certain roads or surfaces. If so, and if it is a minor effect, welcome to Subie-land :-)
Cheers,
-wdb
LOL. I was going to mention chassis problems, but you make a valid point.
Ken
I would guess that the machine shop bill probably ran a few hundred by itself. I would think that you would have to remove the valves & cam so that you could tank the heads to remove all residual metal after planing. That would also be the right time to check valve guide, etc., for wear before re-assembly.
And some of the assembly labor is x2 - the dealers probably only remove the offending head and only what has to come off to get to it.
Steve
jim
Bore: 3.917"
Stroke: 3.110"
(pi x r squared x stroke)="volume one cylinder"
Compression ratio: 10.0
Assume compressed volume is one tenth of "volume one cylinder"
Final volume reduced by 0.005" = 0.06 cu in
New Compression ratio: 10.16
They can bring it back to normal w/ a thicker head gasket...
Jim
OK, I will crawl back under my rock now.... ;-)
Someone on i-club did say that the new gasket was 4 layers vs. the original 3 layers, and was thicker. So the net may be virtually identical to a stock motor.
Steve
I find it is a good idea to get an alignment with every new set of tires, or at least every other set depending on the mileage you get from them, as the $75 for the alignment will pay you back in the extra wear you will get from the tires, not to mention giving you a better drive in the meantime.
a. He'd been awake for 30 hours so his reactions were no doubt slowed
b. He'd had at least one drink, which further slowed his reactions and impaired his judgment
c. He was driving in unfamiliar surroundings
d. It was dark
e. He was talking on his cel phone
Except for the fact that he was talking on his cel phone, I would have readily believed that he had simply fallen asleep at the wheel. However, the cel phone pretty much rules that out. Given that his car wasn't out of control, what other logical explanation is there for running head-on into another vehicle?
-Frank P.
-juice
Steve
Greg
Well, depending on the driver's skill and experience. Zillions of relatively inexperienced teenage drivers have cellphones, and most of them THINK they're already great drivers - but they clearly are not yet. Their chronic overconfidence leads them to THINK that they can drive 1-handed, talk on the cellphone, yak with passengers, and listen to rap at 150dB, and do it all without endangering anyone. No way, Jose.
As for the guy these messages are about, he may technically not have been asleep, but trying to drive and use a cellphone after 30 hours without sleep is not conducive to concentrating on anything.
Jim
There is a recent California study which reports that of a large number of inattention to driving accidents in that state only ten percent were attributed to cell phone use. This would make it seem that cell phone usage is not as dangerous as some would make out. Nevertheless, I have watched drivers use these phones when I have been a passenger and I contend you can't dial a phone and drive -----at least not safely.
My wife and I both have cell phones and I always pull over and stop before using the phone.
Our accident driver ended up killing a lady and injuring the other occupants of her car. I hope he gets 30 years to life, but I'll bet he doesn't, and all the care we try to take in maintaining these Subarus ends up just being the luck of the draw.
It was only when we slowed to exit on an offramp that It registered that the haze was from the Titan because of oil getting on the hot exhaust.
I lost over 2 Quarts of oil by the time we stopped, still had oil pressure so no damage but it could have been so easily a major repair.
Cheers Pat.
-Colin
Craig
