Warren
-wdb
-Dennis
Needless to say it is disconnected until I find a safer way to install it again.
And yeah Craig just goes to show what can happen even when you think you are doing the right thing.
Cheers Pat.
-juice
Think of it as additional chassis rust proofing.... ;-)
Steve
I dont have to mention the name of the dealership, but if the matter got worse, I would let everyone know so you wont get screwed.
Greg
Greg
Greg
I've had my front & rear rotors turned. No shaking while braking but I still get shaking in the steering wheel while driving at highway + speeds. Tires have been balanced numerous times and two alignments have been done.
Do you feel the shaking only while you are braking, or all of the time? When my front rotors warped you could feel it through the brakes. The shaking occurs while you are in motion. No connection to being on the brakes or gas.
-Eric
Portland, OR
Warren
My dealer is doing a "special" on an oil flush. It's all part of an oil change, and they say it extends the life of the engine as well as improves mileage. Has anyone ever heard of this, and is it worth while or os it just a method of their making $$ on an oil change?
Mark
The oil flush sounds like an opportunity for the dealer to fatten their margin. If you have been changing your oil on a regular schedule, I'd skip it.
Ken
A while back I spoke with Ed Barry (shop foreman) about synthetic oil. He said that boxer engines don't develop sludge as bad as other engines.
I'm going in Saturday. Do you have an appointment soon (assuming this is Flemington)?
-Dennis
Actually I am dropping it off tonight. I'm having them check out a couple of things that they want to keep it over night. Since I repalced the battery almost 3 weeks ago, the engine keeps revving at around 2500-3000 RPMs when I start up after it sits for several hours. Also, the blower some times doesn't switch from vent to defroster, or to floor. Just little things that would take too long on a Sat.
Maybe they'll have an XT for a test drive?
Mark
what are the highways like in your neck of the woods? (you've got nothing in your profile, so I have to ask.)
around here in Kansas, brakes actually are stone cold on highway trips because they're never ever used. if you have anything at all similar, then I suspect you've got something else going on AND warped rotors. tire balance & runout would be the first thing I'd check, followed by wheel bearings --which should be making a lot of noise, kind of a roar, if they're failing.
-Colin
--jay
I recalled more details of an SoA conversation I had after reading a letter in Road & Track about rotors.
-Dennis
If you feel it ONLY when the brakes are being applied, it is rotors (assuming a car with 4-wheel disk brakes).
I used to fix cars for a living; I see no reason whatsoever not to cut rotors, in fact it has been being done ever since disk brakes have been put on cars. There is a minimum thickness beyond which the rotors should not be cut, and that too has been in place ever since the beginning. This is old, old, well-known technology. There is nothing whatsoever wrong with cutting rotors, so long as the limits are followed.
rgds,
-wdb
Start at the arm rest, I think there are 2-3 screws, lift it up, then work your way forward towards the shifter. Things basically snap in/out. Unscrew the shift knob before lifting the surround.
On my Forester, which is probably similar, there's a nut and bolt that holds the shifter in place, sort of a fulcrum. The one on my STi short shifter rattled loose after a while (my fault, I installed it). Tightening it stopped the shaking I was feeling on the shifter itself.
-juice
I must have the 1 in a million brakes, because I just rotated my tires today and did a brake inspection. They're perfect, no big grooves on the rotors, and the pads are not even half worn, at 52k miles!
-juice
Craig
Greg
-mike
Don't get crossdrilled or dimple drilled. I recently had them crack on the SVX after a hot track day. Solid Brembo Blanks should work well IMHO.
-mike
It's funny. My car must have known it was going in about the rough idling- for the last day and a half everything has been normal. Figures.
Mark
Well, the whole thing started when the dealer called about $1500 worth of repair work, but I said everything is fine except the cold clutch shudder, then I contact the Subaru, Pat called the dealer the same day, she told me the dealer said the transmission is fine (?????).
Mark, try to get the rough idling on video. I did that for a clutch problem I had. :-)
-Dennis
Good point, I never thought to put it on tape! I just wanted to have it documented, just in case anything ever happened. Diane and Ed at Flemington tohught it was just the ECU settling down after the new battery, but I thought 2.5 - 3 weeks was way too long for the learning process.
Mark
You paid $45.00 for a road test is cheap, one time my dealer asked for $86.00.
Luke
BTW: I'm swapping out the unit because the OEM CD player died. It was one year and three months old - bought new from the dealer when I purchased the used 1999 in early-2002. My dealer wouldn't fix/replace it under warranty (one year parts and labor only). They wanted $280 (and four weeks) to fix! The '02-'03 WRX units are going for under $150 on Ebay/I-Club.
Does anyone think I should pursue Subaru to get it fixed? I could probably file a claim with AMEX under their extended warranty program, but is it worth it?
http://forums.nasioc.com/forums/forumdisplay.php?s=&forumid=9
The Tire Rack is a fantastic resource, not only for the wide range of tires and wheels they offer but also for technical specifications such as tire circumference and recommended wheel width.
rgds,
-wdb
Luke
suggests that the closest fit would be 225/55/15's at within .2% of original. However, I've heard that 215's are about the widest Subarus will handle to virtually "guarantee" no rubbing.
Jim
John: I'm in MD, too. If you're interested, I have a complete STi shift kit linkage. I'm not sure if it fits the Forester (it was made for the Impreza), but if you feel adventurous and want to try e-mail me...
There are rubber bushings and there will always be some play in the system, but yours sounds like more than that. Maybe yours hit a rock or something and was damaged physically?
-juice
-juice
1) I'm ashamed to say that I'm happy to hear that others are now experiencing the exhaust "pop" that I've had since day one (2002 Forester, 5 spd). My dealer has been NO HELP WHATSOEVER (..."yeah, all manual trannies do that...")! Is anyone getting close to solving the "why" of this mystery?
2) Someone posted something about an upgraded clutch. Both my Forester and OB have a tendancy to chatter, but I've learned to work with it (and now only swear uncontrollably when my daughter is out of earshot). Lately, its been a bit more problematic with my OB (perhaps because it is a bit older, 2000 MY). Is Subaru finally offering a remedy?
Thanks in advance for your help, I'll try not to go missing again.
YetAnotherDave
The backfire might be unburned fuel? Anyone?
-juice
If it is the latter, my OBS did that all six years I had it.
If it is an honest-to-goodness backfire, there has to be something wrong there, all manuals do NOT do that.
TOok it to the dealer. THey said they found a bad Hold Valve related to the Hill Holder and would order the part. In again a few days later for the repair. NO HELP WHATSOVER. I still have the jerky drive, and shudder mmost notably in first gear shifting. I do not think it is limited to cold weather, as I have noticed it later in the day and not just morning. So back to the same dealer now? OR try another Subaru place? Anyone else had this problem . I told them both times I went in I thought it was the clutch.
Lower on the list: Timing belt tensioner (some have had them replaced), although that has been reported as usually a cold startup noise. Even bad bearings in the drive (fan) belt tensioners can give a repetitive tick noise. Also on the list might be actual rod knock or piston slap.
Each has a telltale sound, so all I can do is throw out possibilities. Hope this helps,
Steve
It may just take getting used to. Let us know if it ever becomes a problem though.
-juice
