The movement of the free cylinder tops in the open deck, like the wine glass here, is what does the scrubbing of the gasket :
http://www.liveleak.com/view?i=87c_1186734605
As explained here:
http://www.subaruforester.org/vbulletin/f88/2006-head-gaskets-problem-64464/inde- - - x2.html#post716946
On the turbo and diesel engines, Subaru eliminated the problem by bracing the cylinder tops in a semi-closed deck. But this required expensive single-use sand-casts.
So for the new 2011 engine, Subaru retained the open deck made with economical reusable die-casting, but eliminated the leak problem by not allowing the block coolant to go to the cylinder head. The cylinder head is a separate closed casting with its own coolant supply. Instead of sealing the thin rim of a cylinder, the head gasket now seals the large flat underside of the head casting.
BUT NO! I contacted Homelink by email, and they said they don't deal with end-users, I should work through Subaru. At my next service appt I asked the Service Manager to find a solution. He's a good guy and took the question all the way to Subaru Corporate. The answer was that Subaru doesn't repair these 3rd-party units, and I would have to purchase a whole new unit. Yeah, right.
Occasionally I see Homelink mirrors available on eBay, or owners selling them on other auto sites. But I would still be paying $100+ for whole units, then have to hope it is the same Homelink model as mine.
This Forester has over 100,000 miles, and I've managed to keep it's looking good cosmetically. Now I have a prominent cabin instrument that looks bad, apparently with no easy, inexpensive remedy.
Does anyone have any suggestion? I've given Homelink's parent company, Johnson Controls, a bad review on Yelp, but that doesn't solve my problem.
Anyone have any suggestions
The only other thing I can think of is a temperature gauge malfunction, but the car is very hot so I guess that wouldn't matter. One thing I thought of was after I changed the alternator, I did go to a cleaning station and used the engine cleaner and power washer, maybe I knocked something loose. I don't see any loose connections though.
Any thoughts, I am stumped?
Question 1 Is this a head gasket problem?
Question 2 Is Subaru finally acknowledging they have a problem?
Question 3 Who do I contact at Subaru?
I am not a happy camper. The car only has 72K miles and I take very good care of it. Head gasket problems was the reason I stopped buying Chrysler products. My Toyotas have never given me a days trouble. I also had a major A/C problem this past summer which, thank goodness, I was able to repair myself, so Subaru is not on my good friends list right now.
First of all, I am not a mechanic at any level...so I would need a lot of information if you need me to add coolant or cleaners. Plus, I am in 5 degree NH so probably not going to get under the engine anytime soon.
I wish you all lived near me to check it out!
First, the car has smoked lightly TWICE since early December. Just a trickle of smoke with normal temp gauge readings. NEVER overheated!!! The temp gauge went up *slightly* one day last week after stop, start, go, start again driving. I just turned up the heat again and all was good.
There is NO VISIBLE LEAKING of any kind. They told me that there will be no leaking as it only drips when the car is warm and then runs along the car.
I drove the car for about 150 highway miles on Wednesday and the temp gauge was perfect and the car ran fine. No smoking at all. No sweat smell.
Honestly, I just accepted a new job and will be working from home with limited traveling. My partner has a Lexus RX and all our long trips are in that car. I may just let it go for the time being. Just get my normal oil changes , brakes, etc.
Pathomax, that is correct. The leaking will be more noticable after the car has been running. Look for where the oil may be running onto exhaust system parts and then look up! Yes, this is an under car ordeal. All it has to do is drip right down and hit that pipe before it hits the road. After a trip, when you get home, park the car and leave engine running either on ramps or hill. Look underneath and try to find leak. Make sure you do this procedure safely. Get repair manual to learn that. Another old trick is to put cardboard under the car and see where it drips while parked. Once you find the excess oil, clean it off with engine cleaner. Wal-Mart has best price. Get the Gunk, the Wal-Mart brand has a nasty smell to it. If you are running synthetic oil, it will come out more easily! Try a blend. We consider that cleaner a normal maintenance item and do it about every 10K miles on all engine makes.
On a final note, Brother in MO is not buying any more new Subies. New car will most likely be a Toy. Meanwhile, he is running these till a motor can no longer be rebuilt, replace or whatever. says a lot about the 94, 97 and 03 unit designs. This forum has raised some questions on our end about reliabilty.
As for distance and questions, brother uses a digitial camera with high resolution to show me what he is talking about. I also have him keep a Consumer grade Haynes or Chilton's repair manual which explains a lot to newbies who own cars. Exactly how I learned this trade! A wrench turning nerd!
Yes, you will seeing higher temps on your gauge with stop and go driving. That is because of a lack of airflow thur the radiator. Like I tell my students at church, good ears, eyes and communication with someone who knows something cuts your costs down a lot. No stupid questions.
One recent question was about smelling gas, then not. We checked out the car, it passed. I told him to keep nose going, but I think he smelled someone elses car! So far, that appears to be the case. Sure beats blowing up!
Each gauge may be a little different but it should be in the same spot on your car once it is at operating temps. The only time I would say it *might* be different is if you were to drive in say sub-zero temps but even that is questionable.
The reason is that the gauge does not work linearly. It is a glorified idiot light on the subarus, where the middle where it rests is a representation of a RANGE of temps that is acceptable. Same is true on my CTSV, on the needle it goes to center and doesn't move. However my digital temp gauge on that car moves from 180-230 degrees.
-mike
Subaru Guru and Track Instructor
I think the poster is referring to the plastic undertray under the engine that he removed to see the HG leaks. He is probably not referring to the plastic oil separator plate in the PCV system that is buried between the engine and the transmission and that can appear like a rear main seal leak and only leaks oil onto a clutch.
"... you will seeing higher temps on your gauge with stop and go driving."
You will only see that if you have a digital ScanGauge plugged into the OBDI port, like:
http://i49.photobucket.com/albums/f280/vintagefortytwo/Forester/Forester%20ScanG- - - auge/4SGcoverday.jpg
The ScanGauge shows that the needle gauge is an idiot gauge. The needle stays level and normal from 150F up until the normal range is exceeded. The normal range must go pretty high. I have seen 210 FWT (Fahrenheit Water Temp) displayed on my ScanGauge while idling in traffic at 100F ambient with the AC on, before the fans kick in. But I have never seen the needle rise.
As for temp gauges most are just that idiot gauges. I will add that I have seen a few rare OEM cases out there that actually moved! One of them on our 89 Mazda 323! So I do not discount when someone appears to have a sensitive gauge and complains about running hot. Your points should also help put our fellow poster in NH concerns to rest about overheating. On the other hand, as I point out to my fleet people, you see that gauge higher than normal, investigate! Call me! And....they do!
So far, normal maintenance and excellent diagnosis skills have kept me out of buying OBD II equipment. How do you like that AutoEnginuity? I have been considering The Auto Tap version market equivalent. Problem is, Subaru is not listed as being compatible last time I looked. Now we have a growing Toy fleet to consider as well. We look for auto equipment that has good electronics to buy up front to help avoid future trouble.
Best example I can think of is the story of a nurse who bought a new Chrysler from my brother only to return for another after discovering the traction control would not bail her out of a sudden 90 degree turn at 50 mph on a gravel road!
In other words, there are a lot of "I dots" aka idiots out on the road and no government mandate will get rid of them! Avoidance is the best policy! Sometimes, we are our own worst enemy! I always remind myself to slow down think about what I am doing before I become too unlady like! It is cheaper and takes less time to repair. Like an old mechanic, probably deceased by now, told me, " It takes a split second to screw it up and eternity to repair it." It is even more of a pain when it is my stupidity that did it and I have to fix it!
Yup, that best piece of safety equipment has bailed me out of some crazy stuff.....and it is not even government mandated. Maybe it should be?!?!LOL
Performance has been OK, mainly limited by my Subi's older ISO interface, which is simply slow. Faster laptops help with multistream data, but the delivery from the interface can be chunky. I suspect that CAN would probably be much better. Also, my early unit had a serial interface, and I am running it thru a serial to USB converter. Direct to USB might be better.
The Auto Tap does look interesting, and might be better. In some of their 'white papers', they talk about monitoring things like tranny temp, something I don't see available on A.E.
The OBD-II standard is positively ancient (over 15 years), and automakers have added hundreds of proprietary codes each, some thru other ports. You can get additional interface modules with some of these scan tools to read these (like ABS / Stability Control, advanced tranny functions, etc.).
Two years back I attended an auto electronics industry panel discussion where some of the proposed features of OBD-III was discussed. Telematics and other new technologies will change everything! Good luck with diagnosing a performance issue by ear without the right tools in the future.
Dealer confirmed oil leak and it is the head gaskets. $1100 repair estimate. Service manager told me that if he had service records that Subaru might help with some of the cost. Well the only work done at the dealer was tranny service. I do the other work on my own. I did add the Subaru "magic elixer" into the cooling system whenever I did a coolant changes. I have no or little records so I guess I am screwed.
My problem is that this is an oil leak due to defective head gaskets, not a coolant leak. The "magic elixer" in the coolant would have nothing to do with this. It is plain head gasket failure and no matter how much Subaru recommened crap you add to the coolant, it was piss poor design that caused this problem and Subaru should step up and admit it. All Subaru has to do is read this forum to understand the scope of this head gasket issue. If there is a class action lawsuit against Subaru, I will join it.
This is my second Subaru and I was hoping that this one would give me as many problems as my first one, which was none! This will be my last Subaru. Keep listening to the bean counters Subaru and keep "cheapening" things up, and you will be joining GM and Chrysler whose reputation for making junk is well known.
I am now the proud owner of a 2011 Outback. Traded-in the Saturn and kept the Forester. Not sure when I will replace the engine in it.
The Outback is like a luxury car for me. It's fantastic.
The head gasket is not defective. When it fails, the leak can be either oil, coolant or both. And the coolant conditioner is supposed to minimize both kinds of leaks.
The defect is in the open deck design of the cylinder block:
http://www.grindstonemotorsports.com/tech/blockdesign.jpg
The tops of the cylinders are not well braced, move slightly, rub on the gasket, eventually ruining its seal. The gasket sealing area around the top of a cylinder is little more than the rim of a glass. On one side of the rim is a cooling passage with coolant, and on the other side is a piston with oil. Sometimes the coolant leaks, sometimes the oil.
The more braced semi-closed deck used on the DOHC turbo and diesel engines does not have this problem. But such a deck cannot be cast with reusable die casts, and must use expensive single use sand casts.
Subaru solved the problem with the new 2011 engine by not having the coolant in the block to go through the gasket and into the head. The head has its own coolant supply:
"Cooling has been optimized by using separate engine cooling circuitry for the block and the head..."
http://www.fhi.co.jp/english/contents/pdf_en_60853.pdf
Kudos.
The goal, so I have heard, is that the speed variation results in engine load variations, which helps to "seat" the cylinder rings, etc., so that the engine receives an optimal break-in. That (presumably?) results in less oil use and potentially longer engine life.
Not only do not use cruise control, but do not hold a steady speed at all. On the contrary, the ideal is frequent accelerations and decelerations. And do some hard accelerations to 4,000 RPM, which I think is the limit the Owners Manual sets for the break in period.
The varying is the essence of a break in for the engine. See my reply to Lone Ranger in the Forester forum:
http://www.subaruforester.org/vbulletin/f113/break-technique-mpg-39420/#post4484- 31
My round trip commute to work is 76 miles. I drive 30 miles each way on the expressway. For the past two days in one direction, I pump the gas pedal. When traveling the reverse direction, I do cruise. For 10 miles, I do speed A, then B, then C. I have 204 miles on the car since I picked it up Wednesday. It will take me 10 days to get to that 1k mark.
How much trouble am I in? It is tough to ride the gas pedal (acc/decc) and stay under the posted limit. Unless you guys are suggestion driving local streets to work.
That is not an ideal break-in, but probably average, and better than some. You could improve it by not using the cruise control, and not holding the same speed for so long manually. Change speed up and down by 5 mph every mile or so. Or not.
It really does not matter. Engines don't really need break-in to run fine and make it through their warranty period. Many a dealer trade has been taken off the lot with 0 miles and delivered on the Interstate to a distant city on cruise control.
But a perfect break-in does help minimize oil consumption. If you really cared, and most people don't, you would stay off the Interstate for your commute during break-in. You would take city streets and 2-lane roads. Ideally, you would spend a weekend in vigorous driving on country roads, letting the curves and hills do the "varying" for you.
Subaru has been doing that for many years. For long after the warranty period, Subaru has been sharing in the cost of head gasket replacements. But they do favor original owners, who had their cars serviced by dealers, or otherwise have records. Subaru has no obligation in the matter and is reciprocating the good will they received from the customer's loyalty to the dealer.
Recently on another forum, someone was unhappy that Subaru was not going to share in their head gasket cost. They had bought their Forester 9 years ago off a used car dealer's lot, with 25K miles and had put another 50K on it without ever having gone to a dealer except to buy coolant conditioner.
Subaru has admitted the shortcoming of the open deck design in this article:
"The BOXER DIESEL adopts a semi-closed cylinder block deck to improve the rigidity around the head gaskets, following the precedent of the semi-closed type used in the Subaru EJ20 turbocharged gasoline engine."
http://www.boxerdiesel.com/engineering/en/03.html
main break-in considerations seem to be not holding steady speeds for too long so I avoid cruise control during the break-in period and consciously vary speed ...
I thought about local roads (I hate traffic lights), but since it is raining and three previous collision were attributed to the other guy I will wait for better weather. But for the sake of a good break-in, local roads here I come.
Though on my Forester, I did not pay as much attention to proper break-in. It didn't have any noticable oil lose until about 250k after the idler pulley went. Search on "Bad Idle 2"
FWIW we have about 5 Subies in the family from that era and none had the gasket issue.
Utterly amazing... statistically unlikely... but obviously possible. :surprise:
From some discussions with a local resident and former regional mgr, there were several running changes in head gasket design intended to better cope with the difference in coefficient of expansion between the material stack. There may have also been some changes in the flatness specification and surface finishing (machining) of the sealing surfaces along the way. When SOA extended the warranty, there were some VIN number exclusions within the 2000-2003 period and a hard cutoff after a certain point based on the belief that they had a handle on the situation.
Unfortunately, neither the use of the conditioner or new gaskets at 15k miles on my '02 prevented a second failure at 62k miles. The kicker for me was that my VIN supposedly fell into the 'fixed by redesign' category, and I was technically not eligible for the extended HG warranty! Fortunately SOA heard my pleas and felt my pain, and was kind enough to do a courtesy repair with the car some 18 months beyond the normal powertrain warranty.
Three of the guys in my department bought OBW's based on my recommendations. Two of them (both 2003) have had HG failures within the past year. So far, the 2004 is OK. Time will tell...
I changed the oil about a week after arriving home, with 2,500 miles on the car, and used 0-30 synthetic. So far, with 23,000 miles on the car now, it still doesn't use any noticeable amount. My first oil change, which saw about 11,500 miles on the oil, there was no discernible difference on the dipstick between start and finish. On this oil change (about 9,000 on it now), I can't say for sure because I had an oil filter come loose, which resulted in significant oil loss (about 1.5 quarts) and required make-up oil. However, I did not see any dipstick change before that and haven't seen any change since then.
In short, be conscious about it, but don't fret over it. It's tough having a new car again, isn't it?! :P
My 91' Sentra (229,000) and the 00' Forester (206,000) were great on the highway. Service tech's made notice of that.
After my first free oil change, should I switch to synthetic?
Absolutely. Never look back.
I advocate the use of premium filters such as a Purolator Pure 1, and full synthetic like Mobil1 or Syntec. However I don't see any value in the ultra-premium synthetics like AMSOil or Royal Purple. I do not dispute their technical superiority over Mobil1, but I dispute whether they add any meaningful value, considering how good Mobil1 already is and that your oil changes are driven by filter life, not synthetic oil life.
My brother just totaled his 2004 Legacy. 123k miles trouble-free!
Sis still has her 03 Forester. Only problem? A damaged tire sidewall.
Dad's got his 01 Outback. My brother is driving that now that he's without any car, while he shops.
Wifey's 09 Forester is also trouble-free for 2 years. That and my old Forester were both v1.0, too.
Knock on wood!
Edit: forgot our 2002 Legacy, and here's the funny part - I just got call from the guy who bought it from us last week. Uh-oh, gaskets, I thought. Nope - he wanted to know which shop installed the aftermarket moonroof (Adler & Mandell). So that's 9+ years old now.
I think it's because I use dead dino and Fram filters in it. :P
Unless you do an oil analysis to verify the oil's integrity, I don't recommend an interval longer than 10,000 on the initial synthetic fill and 15,000 thereafter.
Depending, of course, on the oil you use! If you go with something like Mobil1 Extended, Amsoil Signature, or similar, the above would apply.
I put 15,000+ a year on my car. If I ran 3,000 or 3,500 mile changes five times a year, it would cost me more for the basic stuff. Plus, I'm not wasting the resources and I am not changing oil at -30F on the snow pack in my driveway!
The mail-order analysis is up to $25.
If I drove fewer miles, I would go with the most appropriate oil for that usage.
There's only two roads out of town where I live too - I really don't know how you manage to mile them up so much. Of course, I actually hit a highway intersection in 20 or 30 miles. :shades:
We are an Amsoil dealer and carry Motul, Redline, Rotella, and Subaru. We have had several customers who used Mobil 1 in their subies and the UOA (Used Oil Analysis) on them have come back poor at best in Subies at least.
As for 25k changes, we suggest that if you have a non-turbo subie and use Amsoil, with the Amsoil Filter, you can safely go 10k miles on a change, however make sure to check the oil every 1500 miles to make sure you haven't consumed any.
On turbo cars we don't suggest going over 7500 miles with Amsoil & Amsoil Filter.
Here is a link if you'd like to order AmsoilAmsoil as well as the application guide Application Guide
-mike
There was this change to the NA head gasket in 2010, says it can't be retrofitted to previous year engines, and is not applicable to the different new 2011 engine.
http://allwheeldriveauto.com/subaru-changed-there-head-gasket-for-the-2010-25l/
Larger gasket photo at:
http://www.subaruforester.org/vbulletin/f66/head-gasket-design-changed-2010-n-mo- - dels-69170/#post766275
Discussion of why the redesigned gasket only fits 2010:
http://www.subaruforester.org/vbulletin/f66/head-gasket-design-changed-2010-n-mo- dels-69170/#post766541
Wow... :surprise:
That's the manufacturer-recommended service interval for most cars, using dino oil..
It is a single piece of steel with a gasket material bonded to it. This is the updated gasket used to correct the vehicles that fell under the WWP-99 campaign and is the gasket used in production of all of the N/A 2.5l EJ 2.5l from 2003 until 2007.
Unfortunately, while those engines have held up better with the revised gasket, they still seem to be subject to a higher than expected failure rate.
The cooling hole changes reminds me of a situation I faced back in the late 1970's with my old Mercury's 302 cid V8. Ford made running gasket changes, with different size and distribution of cooling holes. They were biased in size from one end to the other in an attempt to force more flow to one end to address a known hot spot issue. I used a punch to modify a non-conforming set. If that is all it would take to make the new 2010 multi-layer sandwich set work on the older cars, I'd say go for it.
My Evo is 3750 miles severe and 5000 standard. I do 7500 and add about a half quart at the halfway point. 98k and not the slightest hint of a problem, running 21.5 psi.
