-mike
Steve
I have checked more than one timing belt in my life.Give me credit for having a little sense:-)
Cheers Pat.
~c
My fincee's 99 Forester had both head gasket replaced at 30 then at 70K one side failed again. Also for some reason my GT is better in snow, even with wide tires.
1. Drop in coolant resevoir level
2. Moisture at and below where each head meets the engine block. Coolant doesn't evaporate very fast, so you should see a green, slimy build up that will collect dirt.
3. Engine operating temperature spikes (pull over and shut off the engine IMMEDIATELY)
If the leak is interal, look for the following:
1. Oil inside the coolant or coolant inside the oil.
2. Drop in either the oil or coolant level with a subsequent level increase of the other fluid.
3. White smoke out of the tailpipe (burning coolant).
4. Engine operating temperature spikes (pull over and shut off the engine IMMEDIATELY).
Engine oil on the spark plug is not an indication of a failed headgasket. It could be as simple as spilled oil during an oil change. I'd recommend simply checking the oil and coolant levels periodically, and watch that specific spark plug for awhile. Chances are you won't see further build up. If you do, then further checking of the cylinder needs to be performed.
In a multivalve design with a centrally mounted spark plug, the boot must pass thru the valve cover into a galley filled with engine oil. In most engines it is kept dry thru the use of a plastic tube with rubber grommets on the ends. I assume Subi's are similar. One of these is probably leaking. As long as it is minor, no real issue. I really don't know how conductive used engine oil is, but a lot of it might eventually lead to grounding of the spark down the plug ceramic, and misfiring of that cylinder.
Steve
But the real wear on a timing belt is on the inside that you cannot see. 9999 times out of 10,000 the belt will fail between the the teeth where the belt is running on the cam sprockets or gears. This is where the cracks usually show first.
Cheers Pat.
-juice
Steve
I have seen belts taken off that looked new until you actually turned the belt inside out and bent it at the teeth then the cracks showed up.
But yes Steve you are also right a dedicated DIY. will probably do a closer inspection.
But then again Subaru must be confident in their belts when the recommended replacement is 105K.
Cheers Pat.
Many thanks to Patti and everyone at SOA for all your help!
-Chad
I called a week ago and was told that it was taking a while to get a district manager/rep freed up to take a look at the vehicle. Three weeks seems like a long time to me. Too long!
Is this common?
Also, head gasket leaks may cause coolant to leak into the chamber(s) & turn to steam literally eating the aluminum heads resulting in coolant loss - may or may not be visible from the tail pipe. If caught early enough, the head will be decarbonized...
I posted a number of times on this excellent board regarding a persistent CEL problem on my 03 Forester (first on at 70 kilometers, and then on about another 20 or more times during a year long period).
The dealer worked on this problem several times, but now apparently has fixed the problem. It was a sensor in the gas tank-- they said they had never seen this before, but I thought I would post this in case anyone else has this problem. The fix involved removing the gas tank and replacing the sensor.
I did not get any paper work yet-- they were going to mail it to me, but have not yet done so. Does anyone know what this sensor is, and what, aside from triggering the CEL, driving for a year with a faulty one might have done to the car? It may be my imagination, but I feel that the car is driving slightly more smoothly now-- but not sure about that. At anyrate, this does seem to have solved the problem-- so am most pleased as it was the only problem with this great car. Thank you. Tim.
I wonder if that's the same sensor which triggers the CEL when the gas cap isn't tightened far enough? If so it's the emission control sensor (I think) and it shouldn't have affected the operation of your Forester at all. The corollary is that it shouldn't be driving any smoother now but as you pointed out that might be your imagination.
-Frank P
Where can I buy these clips?
Thanks for any input.
QL
Mike k
Steve
Some of the other sites are East coast and may be more convenient based on where you live.
Jim
So, you know, I just picked up my brand new forester XT with automatic tranny. It had 2 miles on it (not used for test drives) and now has 100. I have been noticing that when I'm accelerating, usually up hills when it's under more load (2000-2500 RPM so no Turbo) it makes a noise I'm not familiar with. Its' still in the break-in phase so I'm not pushing it passed 4000 and I think that means the turbo hasn't kicked in yet either. The noise is VERY quiet and I can hear it with radio off. It is coming from under the hood, is high-pitched and reminds me of a squeaky drive belt slightly as it has the same pitch. Is that normal??? The noise goes away if I let up on the acceleration. All gauges appear normal. No other strange behavior although the auto tranny shifting from 2-3 @ 20MPH is a bit more pronounced then I'd like. Any comments VERY much appreciated! I'm all new to this turbo thing - but lovin' it so far! Can't wait to use it! - Elissa
-Frank P
Subaru's is actually fairly quiet. Check out VW's 1.8T. I can hear those even when I'm mowing the lawn, I don't even have to look up to know that it's a 1.8T motor.
-juice
-juice
Funny, I've always considered myself a bit of a car geek wrt doing all my own maintenance and knowing my own vehicle's specs, but I've never had a car I've considered "performance" ('84 subaru gl, '93 civic, '01 forester s) so this turbo thing is ALL so NEW!
The reason I was so concerned about my noise is that during my test drive on another F-XT, I heard the turbo in the form of a hissing sort of hydrolic noise - I knew right away that was the turbo. But MY F-XT makes a different noise - a high pitched whistly/rattly noise. Does the turbo noise really vary that much within a model line? Or could the noise I'm hearing at 2K-2.5K RPM be something called the wastegate, related to the turbo?
Anyway, does anyone think I should be concerned with the noise I'm hearing as described (like a very quiet fan squeal under hood when under load/acceleration at 2500 RPM)? Thanks so much!!! And yes, I'm paranoid. :-)
As for the rattling, I think bluesubie and others had observed that on their FXT and will chime in with some enlightenment.
-Dave
All this info about the timing belt sounds good, as I've put off doing an inspection of mine as I've passed 60k now at 61k or so.
Anyway, my 00 OBW is having a steering problem. Whrn I bought the car from its previous owner he stated that the front diffy had some play in it, but was within subie specs, according to the dealer. While somewhat annoying, now when I come into a hard turn on the gas, the steering feels like its slipping or like it wants to jump off the teeth.
My gut feeling is that it's probably the front diffy screwing it up with the excess play. Any recommendations as to inspecting the front diffy and steering interface?
Eric
with crappy tires and really enthusiastic driving it's very possible. with top-notch summer tires you have to be driving in the "please give me a ticket" mode.
:-D
~c
Not that Colin would know anything about that ;-)
-Frank P
Nicholas
Step 2 = HPDE
Step 3 = Road Racing
-mike
PS Check your e-mail.
Nicholas
I also seem to feel the steering weaker when driving on a gravel secondary rd (FR) at low speeds. Any mods to beef up the steering?
Eric
Our 2002 Forester had this symptom along with pinging under accleration and poor gas mileage. First the O2 sensor was replaced and then the cat. So far, after 3 tankfulls both the smell, pinging and mileage have improved. I chalk this up to the presumably "bad" O2 sensor. Only time will tell whether it is fixed but I'm optimistic since the pinging has virtually gone away.
I only relate my situation just in case it is NOT a case of bad gas (high sulfur content). My experience might give you areas to look at down the road.
Ron
Gravel roads are probably not the steering, probably the tires need improvement, unfortunately the only thing to give a better steering feel is to put on the poly bushings for the steering rack.
-mike
