Understandable why you are disgusted. 125K is still just a bebe. :P
Even the short block has been revised, as have the pistons, over the years.
You'll probably have to find something from the same model, and perhaps even the same year.
-juice
Best of luck to you. Vehicles can be quite the headaches, one just hopes it is not chronic. :sick:
Thanx once again...
Yes, it's a SOHC, and I think it's a clearance motor so the valves will never hit the piston.
I've got a bunch of 12 pt sockets, and it seems as if Subaru didn't go crazy with a large variety of sizes (seems like most of the car is 10 and 12mm), so I should be good.
Andy Plunkett's Glasair Project Library
Should the link break, search for part of:: 2001, 2.5L, SOHC engine EFI diagnostic trouble codes
Our 2000 Legacy GT wagon with 58,000 miles had a P0325 Knock sensor circuit malfunction. The knock sensor failed and cost about $97. Easy to replace.
keyword: CEL check engine light MIL malfunction indicator light OBD-II diagnostic procedure
..Mike Smith . Silver Spring, Maryland, USA
..Mike
Is the Loyale 'special' in this unique way, or is he just trying to win the argument?
S.C. :mad:
there's no air bubble in the oil. and yes, it is being damaged in a typical way by low oil level and pressure.
~Colin
-juice
-Brian
It could be your alternator. Test with the hood up and wifey or a friend operating the throttle in neutral while you listen. You shouldn't need load on the engine to hear it. It could also be a number of other belt-driven accessories. You need the AC on to hear the compressor if that's the problem.
A heat shield is possible, but they usually make a pretty distinct rattle. You're hearing more of a whine and it's not the turbocharger.
Your car is definitely under warranty so I wouldn't stress about this or work too hard at the self diagnosis. Assuming you have a competent Subaru dealer nearby, I'd have them look at your earliest convenience.
~Colin
Coolant, Oil level (mobil1), power steering, brake fluid, clutch fluid are all clear and at proper levels.
There are times it's easier to hear it, I'm not sure what those are. We'll see if the dealer can find it, or determine I'm just nuts. :P I am having them do the engine air filter while they're at it, figuring they'll likely have that open at some point anyway.
-Brian
if the noise is subtle unfortunately I wouldn't give you good odds at the dealer finding it right away.
~Colin
I can't imagine it going away, I bet it'll eventually get louder or more persistent.
-Brian
-Dan-
Timing belt, water pump, crank seal, cam seals, thermostat.
Brakes are at 5% (yikes! - but I got my money's worth) so they get done Friday. Good for another 105 thou!
Cheers!
Paul
..Mike
..Mike
My rear shoes (drums on the L model) are OK, though. Then again the fronts do 90% of the work.
-juice
As far as the whole service job, parts were $300: water pump, gasket, oil seals, timing belt, timing belt cover (it had a hole in it), coolant, conditioner, thermostat, gear oil. Labor was $518. Brakes will be in addition to all that, but they get done at the tire place, not the dealer.
Cheers!
Paul
I've been lurking here occasionally, but haven't posted in years--a testament to how reliable by 97 outback sport has been (knock wood)
Anyway, i do have a few problems that need to be addressed. Top on my list is the driver's window. I've been ignoring the wind noise and slight rattle since i bought the car. Only now the rattle is profound and the window isn't functional. I have to pull on it to get it into alignment and if i don't hold it as i close the door, the window falls back down.
I found the instructions for taking the door apart here (outstanding) and thought i'd try to replace the tearing gusset myself. A few questions if i may:
Does the door come apart with everyday tools?
Since the window is now so &*%^% up, how much more trouble am i going to have and might i need another part?
Any recommendations on where to buy the part(s)?
Thanks to each of you for your comments and to the site collectively, Grace
Brenda
I just had mine done on the 97. I can't tell from the invoice what the specific labor charge for just the timing belt was, but it looks like the belt itself (the part, that is) was 95 bucks. They also changed the water pump, front camshaft & crankshaft seals, thermostat, timing belt cover, coolant & conditioner. The differentials were both overdue, so they changed out the oil in both. My total bill, parts, labor, shop supplies & tax was $943.
Long way of saying $289 for the timing belt sounds pretty good.
Cheers!
Paul
Is it true that I need to pump up the hand break for it to work ? I don't want to take it apart and adjust it manually. Thanks.
My battery has died twice now in the past 12 hours & i just got it replaced but it was only after that that I realized this clicking/flashing lights problem. Also, the parking lights are on all the time even though that parking light switch on top of the steering wheel is turned off (so the red is showing). Since this happens even when the key isn't in the ignition i'm worried this is going to drain my battery again before I have time to get it looked at. it's evening right now so it will be at least another 12 hours or so before i could have anyone look at it.
does anyone know if there's something i can do to make this clicking/flashing lights stop at least until i can get it looked at so my battery isn't drained overnight?
i don't know anything about fuses, fixing cars, etc
thank you!!!
Consider disconnecting the battery until you need to drive again. Hopefully, that will give you enough time to get it checked.
Jim
Jim
Did the problem persist after disconnecting the battery for a period of time?
Darn electrical gremlins! :confuse: Good luck!
Cheers!
Paul
-Brian
I would appreciate hearing from anyone who knows where Subaru hid this little guy. It would be a plastic connector about 1/2-inch square with six female connections.
Don't recall handbrakes having a pump.
The cable probably needs to be tensioned.
IRCC the manual could guide you on that.
-Dave
What's IRCC manual ?
Is it the parking lights or turn signals which are on? That info would help.
You might need obtain the wiring diagram (part of the service manual) for your car. This can be downloaded from techinfo.subaru.com for the modest fee of about $30. If I had your wiring diagram I possibly could be of help.
As I understand it, your parking lights and dash lights are blinking with ignition off and parking light switch off. What is the position of your headlight switch (off, park, on?)
Have you been doing anything at all to your car that might be related?
The dealer put dye into the cooling system to check for leaks and pressure tested the system and they could not find any thing wrong. The dealer runs it for hours and the temp stays at the middle mark.
Took the car to a local mechanic two times. First time replaced the radiator cap and bleed the system free of air. They said the a air bubble appears at the filler neck. This does not correct the problem. Now the mechanic is saying there is a problem with the cylinder head gasket and it needs to be replaced.
Question - why didn't the dealer find this? they say they can't find any problem.
I just purchased this car back in May 2006.
My mechanic and dealer are telling me two different stories.
Does anyone on the fourm have any suggesting on what it could be?
Frustrated - afraid to drive the car.
"Ran it for two hours" -- does that mean they let it idle? With no load on it, a car with a blown headgasket probably would not run hot.
You have the classic Subaru blown head gasket. Under load, combustion gasses escape past the head gasket and force coolant out. (>100 psi vs. 13psi... no contest)
At 115,000 miles, I'd be tempted to find a lower mileage engine from a salvage yard. The all-aluminum engine does not handle overheating very well and you said it has hit H (past red) a few times. You could continue to blow headgaskets after this repair due to warping.
~Colin
My last Question - how much $'s for a new head gasket and would you recommend any additional work at the same time. I paid $6k for the car and cannot afford to junk it. I got screwed.
I think Dave meant "IIRC" or If I Recall Correctly. Dave thinks the (owner's?) manual might explain that the emergency brake cable needs tensioning.
..Mike
..Mike
If you have a shop repair, probably looking at $1800. But, like Colin suggested, overheating can be bad for those aluminum heads and, if the heads are warped, the problem could be a recurring one.
Question: can I use the mudflaps offered for more recent model year Foresters?
I just had to get my right rear wheel bearings replaced (71,000 miles). Now it makes me nervous about replacing my timing chain - this is what killed my previous Honda Civic. When should I do this? Is now too soon?
TIA
don
He also had the heads milled and tested for flatness before re-installing the heads.
Trouble-free since.
Jim
My mechanic also replaces the timing belt tensioner, thermostat, and waterpump at the same time. At the very least, I'd change the waterpump with the timing belt 'cuz you need to remove the timing belt to get to the waterpump anyway.
Jim
the water pump appeared in good working order with no leaks, etc., so they didn't do that now ... no extra labor charge for the 2 drive belts...
I'm ok with that ..
Combined with the bucking there is an intermitent clicking noise that seems to be coming from under the engine compartment which is rapid but fairly faint in nature. Not sure if the two are related.
Could this be an electrical problem?? Or could it be water in the gas tank? Something else? Any ideas? Thanks.
Steve
Check that coil pack!
Hope this helps.
Len
