-September 2024 Special Lease Deals-
...under NO CIRCUMSTANCES should you use ANYTHING BUT VW-APPROVED SYNTHETIC OIL, e.g., Mobil 1 5W-40, and KEEP ALL OF YOUR RECEIPTS in case you end up with any sludging problems.
I think you meant to say Mobil 1 0w-40 since it meets VW's specs.
Maybe one of the folks more fanatic than I am can find out what else is changed with this engine.
So, i'm no mechanic, and it seems it's hard to find info online (vehicle manuals/diagrams) that would help me become one.
First:
Does anyone out there know where i could get a bootleg FREE copy of the 1999 Volkswagen Passat 1.8 turbo REPAIR MANUAL?
Second:
While i was driving my Passat turbo (automatic w/ tip tronic) there was a blow-out of my exahust intake manifold (where the exhaust attaches to the engine). So, naturally, of course my car sounds very loud because of the disconnection. Does anyone know what the exhaust (the part under the hood, near the engine - not under the car near the Cat) is made out of - cast iron ??
I have thought of welding it back, but am leaning towards a replacement of the part.
Any feedback/knowledge sharing is appreciated!! Thanks for your time!
Do you know of a list of approved lube oils by VW?
Chuck Hanson
Would appreciate some advice....
I'm looking at a 2006 4motion with low miles (20,000) Certified Pre-Loved and was wondering about any long-term reliability and maintenance issues. I tend to keep my cars for a long time. My previous car (a Ford) lasted for 13 years and over 150,000 miles. I've read through the forum and it seems that earlier vintage Passats (and most VWs) from the 1990s-early 2000's have a pretty spotty reliability record. Should this year/vintage/model VW Passat be on my shopping list? Granted the Ford had problems too, but they were the kinds of things you would expect as a car ages (a fuel pump @120,000, oxygen sensors and a minor computer issue both at about 85,000). So, obviously, I'm not expecting a trouble-free car, but I am hoping for average or above-average reliability and below-average costs. Any input is appreciated - thanks again.
2005 VOLKSWAGEN PASSAT 2.0L 4-cyl Engine Code BHW Turbo Diesel
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SEO[1]
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFLQT)
All TEMPS......5W-30, 5W-40
[1] Only use engine oil that is formulated
to meet Volkswagen Oil Standard 505 01 or equivalent.
The AMSOIL European Car Formula is $6.75 a quart or $35.05 for a 5 liter bottle wholesale.
I notice you say 10,000 miles. I have changed the oil every 5,000 since new at the dealers recommendation. I will look at my maintenance manual and see what it says.
Thanks again,
Chuck Hanson
cr_hanson@yahoo.com
Krzys
True. And also don't forget that there is no warranty requirement in the USA and Canada that an oil has to be certified to meet any spec. Just that it meets the spec. Also don't forget that AMSOIL provides a free parts and labor warranty should the oil ever fail in a recommended application, and that it never has in 37 years.
Good luck!!!
I'm a U.S. military officer stationed in Seoul, Korea and I ended up buying a 2003 Passat 1.8T from another servicemember. At the time of purchase, the car had 36,000 miles and now I've put another 8,000 miles in 22 months. During that time, I've had to replace the ignition coils (all four cylinders for $200), brake pads (normal wear and tear for $250), and Transmission Control module (or something like that when rain water overflowed into the passenger compartment for $1500). Just last week, I had the transmission fluid (ATF) changed out for $550, because my transmission was downshifting very roughly at times. If you have the money, I'd recommend you look at a Honda or a Toyota. This is my second German auto and I'll never anything other than Japanese.
Just say NO!
I'd seriously look at other vehicles before I'd recommend a Passat for you. In fact, I have never recommended a Passat to anyone, ever, and I like my car! Look elsewhere and spare yourself some grief later.
I'd look at Honda, Toyota first. I'd even consider some of the domestics like the latest style Malibu or the Ford Fusion.
As far as coils go, I've had 2 replaced on a recall several years ago. A third went out on me last year, but the car still ran well enough to get to Auto Zone where they ran a scan and identified the dead coil. About $25 and literally one minute to install and I was back on the road. That is really the only 'problem' i've had with my car.
Every time I ride in my father in law's Camry, I'm reminded of how much I like my VW. But like I said above, you have to be willing to invest a little more time/money in service and maintenance. If that isn't you, you should buy something else.
VWDawg and tsf7 - just curious, do you guys routinely recommend buying a Passat to your friends/families?
I'm a car guy and I certainly agree with all the enthusiasts that the Passat is a much better ride than a Camry or an Accord, but the exhilaration of driving a finely tuned machine is immediately sapped out of you when these unexpected maintenance issues rear their ugly heads. Having been stranded twice by my car in less than two years, I'm dearly holding on to the belief that this car is much safer than the Korean used cars available in Seoul. That's been the only saving grace, but there's no way in hell I'll let my now 15-year old daughter eventually inherit this car from me, like I've had originally planned.
Any thoughts?
VW COIL PROBLEMS
Chuck Hanson
http://www.volksbloggin.com/2006/03/11/how-to-replacing-a-tail-light-bulb/
Chuck
also see http://www.myvwlemon.com/ubb/Forum2/HTML/000676.html
This too http://www.autoblog.com/2007/05/17/vw-passat-being-investigated-for-fires/
Those are my thoughts.
GIve more details. What's the road geography like? Going uphill? What's the frequency of the event? Every time you drive, once a week, every ten minutes? Manual or automatic transmission? Does it happen at the same spot everytime?
aa
