Cadillac STS/STS-V: What's New for 2007?
libertycat
Member Posts: 593
Anyone interested in the upcoming Cadillac STS which replaces the Seville? I doubt Cadillac will make it an ultra luxury sedan as the current one is mid-level, but I hope they do since they already have the mid-level Deville. I can't wait till Edmunds has some pictures.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
kirstie_h
As a side note - I think traction control on FWD is silly. I find it worthless as the FWD is pretty solid through the slippery stuff all by itself.
As has been cited on the Catera and CTS boards, The 2005 STS is built on the same Sigma platform as the CTS and SRX vehciles. That will bring the considerable benefits of double a arm suspension geometry to the front and rear,
At first glance, the STS appears to be a slightly larger CTS, but with some subtle styling improvements to reduce the jarring surface juxapostions so characteristic of the CTS.
In profile, the STS presents similar volumn proportions as the CTS.
From the front, the four stacks of vertical lights are very similar to those seen on the SRX, as is the grille treatment.
From the rear, the appearance is more similar to the XLR than to the CTS.
Overall, I found the exterior appearance to be more appealing and less challenging than the CTS.
The STS features vented rotors at all four corners, but I was disappointed to note that they are single piston units as opposed to multiple piston units; I have recommended the use of 4 pot Brembos instead, particularly on the v series.
The interior is a mixed bag. The instrument panel is a noticeable improvement over the gimmicky "home computer theme' CTS center stack arrangement and other odd bits. The proposed STS dash has more traditional appearance.
The proposed STS instrument panel is a more coherent design than the bizarre BMW 745 arrangement (oh goody, gimme column shift again ! How many computer mouse wheel clicks to change the radio station? And unlike the silly 745 will all of that shiny brushed metal stuck to every edging, the STS was tastefully restrained. Let BMW try to recreate the 54 Mecury or the 58 Buick with their love of metal decoration. Overall, the STS did not strike me as being up to audi 8L standards in this specific area.
The door panels on the STS were my least favorite parts: They appear to have the same shapings as the CTS panels, but with slighly improved plastics. Wood trim is applied to the horizontal sufaces surrounding the window controls, but not to the doors as is the case on the current STS, the new audi 8L, the Jaguars, etc. Instead, the use of wood trim had an unfortunate low rent Toyota / Lexus appearance. Room for improvement, but then again, this was a prototype.
The seat tracks are improved over the current STS's exposed tracks, and the grab handles are the damped type that one finds in VW's Golf and other cars cars.
My overall reaction to the interior is that it's a bit improved over the cheap and cheesy CTS interior, but it's far from class competitive in terms of fit/finish and material quality. The French company that supplies VW's higher end interiors should be consulted on the matter of the STS interior.
Styling issues aside, GM's interior designers, should spend a couple of minutes inside VW's higher end products, particularly the Toureg and the Audi A6 and the new A8L, to understand what is the current standard in this price class of car. Even some lowly Toyota and Nissan products offer rear window sun shades, why not the CTS, STS, etc?
Positive features are the possiblity of awd and a V-12 engine for the STS-V.
considerable thought has been given to some interesting systems interfaces, including the possiblity of linking the high-beam circuit into the adaptable cruise control distance measuring system to produce a simple means to automatically dim the high beams when approaching slower cars from the rear.
The proposed Bose sounds system will again be class leading, so that's another terrific feature.
Seat shaping has been given some careful thought. The seats are wonderfully contoured, and have a very similar feel and multiple density cushioning as found in the Catera (!) and in the new Maybach sedan, and to my rear end at least, more comfortably shaped than in the BMW 745 or Toyota's Lexus 430 (Having spent some time in all four of those cars last weekend).
As is the case on the Catera, (not the CTS), the current STS, the 5 & 7 series BMWs. the E & S class Mercedes, Toyota's larger Lexus products and Renault's higher end Infinity products, The STS offered rear ventilation with a rear compartment control panel for use by rear seat passengers. Unlike the E mercedes, the vents are limited to under seat and the end of the cener consul; there are no B pillar rear vents which are becoming a class standard. Unlike Toyota's LS430 product, the STS did not appear to offer the sort of sophisiticated rear control panel accessible in the center armrest. Rear seat cushion and seatback adjustments did not appear to be offered, which is a curious absence in this class.
To be confirmed is the availability of fold down rear seats, but they are expected in this class and likely given that the Sigma structure permits their provision on the CTS.
Unknown at this point is whether the awd version will employ the sophisticated and effective awd software that Ford developed for use on the Volvo R sedan and other upcoming higher end products. That software permits rapid changes in torque distribution front /rear and side / side based upon multiple measurements including speed, rate of longitudinal acceleration / deceleration, rate of lateral acceleration / deceleration, rate of yaw acceleration / deceleration, speed of gas pedal release and brake pedal application, and rate of steering wheel movement. As a result, the car will seamlessly transition from an oversteering mode at corner entrance into an understeering (and yaw acceleration damping) mode upon throttle application at corner exit. Terrific stuff, and if Ford's using it on a $38k Volvo, GM should be using it on a $50k Cadillac.
Overall, I thought that the STS is off to a very good start, with some obvious room for improvement in the areas of brake caliper design, and interior materials / fit / finish.
I consider the revamped STS to be the key product of the Caddy revitalization. If they get it right, they'll have huge momentum behind them with what will finally be a broad enough base product line to compete with the Germans and Japanese. If they come out lackluster, they could really stumble. The shortcomings of the initial CTS were forgiven because the expectations were so low. With the very positive reviews the XLR and SRX are getting, as well as the sales momentum of the CTS, the bar has been raised. The STS should not leave the factory until it has been nothing less than perfected to the point where it is class leading in every respect.
Cheers.
M
M
I want Cadillac to concentrate on performance, not maximum wood content.
At the very least, maybe Caddy could do like Mercedes and its AMG varients and offer a wood interior on the base model and pure metal and plastic interior for those of us who pay big money for cars because we happen to like machines.
Depending upon the mpgs, I would probably also want the 3.6 with the 6 speed auto. RWD only please. I love being able to push the rear end out when the mood strikes.
The STS should be the perfect replacement for the Seville. Wonder if the DeVille will keep it up or get replaced (leave Lincoln in the pond alone Cadillac, there Town Car is still a boring vehicle). The STS will include V-6, V-8s, and probably a V-12 (no surprise, if Caddy Escalade is coming out with a 500 horsepower V-12, which will let it regain the power of being the most powerful SUV IN THE WORLD). I haven't got any pictures yet, only the same one that Edmunds.COm has. If I do, I will update.
That's easy in a Jag, a little tougher when your car looks like a stealth fighter.
http://www.thecarconnection.com/index.asp?article=6161&sid=17- 8&n=158
The accompanying text says things that are contrary to what I've heard from other sources about the car to date (e.g., saying it will be built on the Epsilon platform), so YMMV.
http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat- _code=carnews&loc_code=index&content_code=06802167
According to the article's sources, the STS is being positioned as a 5-series competitor, not a 7-series competitor. From what I have read, there is still a big debate going on about whether or not to make the DTS part of the "new Cadillac" or to keep it as a luxury boat for existing customers. I can see the tempation for the latter as the DeVille is Caddy's best seller and a new S-class type car would likely sell far less units per year (even MB sells less than 2K per month - though surely at obscene profit levels)
Interesting that it sounds like Caddy is not planning on doing a V12 based V-series, given the "400HP" figure quoted. The CTS-V already has that, no? Oh well, it is too early in the cycle to debate this. I remember the will it be the LS6 or LS1 for the CTS-V discussion. (I admit to having ulterior motives for wanting the V12 - I want Caddy to start production on the XV12 which puts us a step closer to the Cien).
Leave the DeVille FWD with the Art & Science treatment.
As long as it had a HALO car that could rival the E class or Sclass
its looking up with the XLR CTS and SRX though, things are looking good.
but cmon, why doesn't the new CTS motor have the manual available.
Unfortunately, GM has not given much to go by on the new Buick sedans, so it is hard to judge whether the strategy will work.
Edmunds review of the new Buick Ranier is encouraging. Apparently the SUV is quieter with noticeably softer driving characteristics than its less pricey Chevy and GMC cousins. Not for me, but arguably in line with what the future DeVille type buyer will look for.
M
M
