Acura MDX 2007
Many suspect that Acura intentionally leaves some content out in the first years. It helps them keep costs in line. While the vehicle is hot off the presses, most buyers don't notice these omissions. Then they can add these features later in the model cycle when sales begin to drop as the vehicle gets long in the tooth.
(Interestingly, some companies begin remove such niceties over the years and instead increase incentives.)
But Acura seldom makes big changes to their packaging. Even the RL, which is the slowest seller on the lot, has not been changed much. It has been critized for having too many items at too high a price. You would think that Acura would break up the packaging, but what did they do? They added a second package which bolsters the content even higher and to a higher price point. :confuse:
Based on these reviews, I doubt Acura will have any trouble selling the new MDX. If this thing is as good as I'm hearing, you can expect wait lists for the next 12-18 months. Until sales slow down, nothing will change.
Look at competing vehicles like Q7, GL or current model MDX, which all have larger windows back there. I'll have to see in person to determine how bad this is.
In comfort mode, the average current passed through the coil is relatively weak. Thus the suspension is soft. For the sake of discussion, let's call it level 3 tautness.
In sport mode, the average current is increased and the suspension tightens up. Call it level 7.
While in either mode, sensors are used to determine load on the suspension and they can adjust accordingly. So, if you're driving in Comfort mode and you make an emergency swerve to avoid.. I dunno... a moose... the suspension will still tighten up to level 10.
When the event has passed, the suspension will default back to an average of 3 (Comfort), but will continue to modulate higher or lower based on conditions. Had you set the switch to Sport prior to the moose event, it would have defaulted back to an average of 7.
As for maintenance, we'll have to wait and see. But I see no reason why the fluid would need to be replaced any more often than the shocks on a regular vehicle. The fluid is housed in a closed system and does not perform any lubrication function. Nor is it exposed to mechanical actions like the clutch plates in a transmission or the action of an engine piston.
I also think the MDX will sell well, but I do wonder if the pricing structure might not alienate people that were just on the border of affording the previous model. They might have to step into a Pilot (I wonder what the new redesign will look for that one), since pricing in the mid $50s is a step up from what you pay for a MDX today, or if not a Pilot then something from a competitor (the Pilot does look a little dated, imo). If Acura loses these buyers, then it might be wise to separate out some packages to make it more attractive to the base buyers. Does that make sense?
But in any case, it's all subjective right now: I don't know what the pricing will be, and although the MDX is still on my top 3 list, I might get sticker shock once I see what it costs with NAV + entertainment package. Maybe I'll be one of the guys stepping into a loaded Pilot!
At $41k, the MDX would be $4k more expensive than the outgoing 2006 model. I hope the increase is reflected improved sportiness (i.e. handling, etc).
Also, the engine will likely have a smaller displacement, don't you think?
What's with the blonde? You got a problem with my moose? :shades:
The active dampers are not limited to 2 settings. They are infinitely variable and can "adjust from minimum to maximum damping force in as little as five milliseconds (0.005 sec.)." You do not need to throw the switch to get these dampers to go from soft to rigid. They will react automatically to sensor inputs through a dedicated ECU.
So, you're driving down the road before the hottie in the sports car passes you. At that point in time, the dampers are running at a "neutral" setting. This neutral setting can be biased toward comfort or sport. Consider those two options the settings for when the vehicle is simply cruising.
Once you decide to chase the hottie through the mountains, the system will react to driving input and road conditions. It will automatically tighten up the suspension, effectively ignoring whatever neutral setting you had selected prior to the start of the chase.
When the chase is over, it returns to the neutral state.
Here's a link that might help you understand.
Active Suspension
Scroll down to the sections labeled "Real-Time Damper Control" and "Sport or Comfort Mode." You can ignore the first section, "Active Damper System," as that's just PR fluff.
No, I don't think it makes sense for Acura dealers to be competing with Honda dealers.
Acura has been trying to boost their image into the realm of the stuffy, triple mocha latte-buying, CEO named Biff crowd. They do not want to be compared with Honda, Toyota, and Ford. They want to be seen as legitimate contenders with Mercedes, Lexus, and BMW.
While targeting the affluent means a lower volume in sales, it means higher profits per vehicle.
So, yes, they do want to dump the Pilot buyers and instead pick up a few of the more wealthy customers.
On the subject of the RL, yeah, it looks like the MDX is back to being the flagship vehicle for the brand. That slot should belong to the RL, but the MDX has stolen it for the second time.
Yea, their usually big and have a bad attitude; now as for the moose..... :shades:
Not for the upcoming generation of Pilots
you won't get the SH-AWD, will you?
Good question? I dont know if Honda will put SH-AWD in the upcoming Piot. I guess only time will tell.
AudiQ7 - 70dBA, Escalade - 68dBA, QX56 - 67, Navagator -67dBA and Mercedes GL 450 - 66dBA. The average for the group was 68.
Granted this is going 70MPH vs the 60MPH in the MDX. Should be very quite and much improved.
My wife cares little about the handling around winding turns but would be interested in a smoother ride on the straight roads. If the comfort setting still resulted in a rougher ride, that would be the death knell of the damper/sport package.
The 2007 Honda Pilot is on Honda's website.
SH-AWD is not available.
It offers the Variable Torque Management® 4-wheel drive system (VTM-4®)
I doubt the Pilot will have the SH-AWD, since this might be a premium option for Acura only, to keep the models differentiated. In any case, the difference in traction will only be felt when you're at the track, and I somehow doubt people will be taking these SUVs to the track.
Thanks! Yes I meant the 08 new generation re-skinned and re-engineered 08 Pilot.
For my part, I kinda doubt the Pilot will get the 3.7L engine. It doesn't really need it. I see the Ridgeline getting a detuned version of it before the Pilot. And I see the RL getting it before the Ridgeline.
Honda has announced plans to build a V10 engine along with a V8 variant if they determine it is cost effective. I'm thinking the Hondas may not see the J37 until the V8 is ready for the MDX/RL.
Your view on the upcoming Pilot is a bit too staid. The Pilot wont survive future competition if it does not improve substantially with a new 3.7 engine. SH-AWD in the Pilot at this point cannot be ruled out. Honda will give the Pilot the best technology in order to compete with new generation Highlanders.
This is what I've been wondering for the past few weeks now, which is why I may hold out on my purchase until I see the Pilot and its specs. No need to pay more for the MDX if the Pilot will essentially be the same vehicle, but cheaper.
You can apply the same logic to RDX and CR-V, as well as Accord to TSX/TL.
The bottom line is that Acura has never truly outshone Honda in terms of luxury. Lexus, on the other hand, truly has vehicles that are steps above their Toyota counterparts in terms of quality and options.
So my point: the 2007 MDX better be steps above the redesigned Pilot before I plunk nearly $50k.
Between current MDX and current Pilot, the quality difference still exists. The Acura, however, has to deal with the fact that it has been on sale for over six years now, while Pilot is relatively new.
The new MDX will change that. And next Pilot should indeed be better than the current version, but I just don't see it being comparable in feel and touch to the Acura. These duo will be not unlike the RDX-CRV duo.
Whether we like it or not the MDX has become (big if) a sport/performance SUV. My question is if someone is in the market for this type of SUV, should you take the plunge and buy the MDX or wait until the Audi Q5 is released in the Spring of 2008?
If you value image, more luxury and better "fit and finish" then the Acura would be your choice. But basically an MDX is a Pilot in a tuxedo.
Personally I dont like tuxedos.
The MDX will be at the very top end of what I'm willing to spend (based on prices people have suggested here). So I guess the questions I've been asking are based on value at that particular price point: as you've mentioned, would it be a better value to buy the Audi Q5 if the MDX is just a Pilot in disguise? i.e. would I get more for my money in the Q5 than in the MDX?
Probably a little early to ask these questions, but we are looking to buy early next year. Unfortunately the Pilot won't be released by then, so I won't be able to compare it with the MDX. Hence all my whinin' ;-)
Nope.
"Your view on the upcoming Pilot is a bit too staid."
Isn't "staid" what Honda is known for? My view stems from this... Back in 2002, many were predicting that the Accord would get the 3.2L engine from the TL. Then the TL would get the 3.5L engine from the MDX. Then Honda would build a larger 3.8L for the new Ody. Then it was the Ridgeline that was supposed to get a larger V6. Back in 2001, posters here and elsewhere were hyped about the CR-V getting a V6 "in order to compete with new" (or new at the time) Escape. Up until two weeks ago, many folks were holding out for a V6 in the CR-V. Or, at the least, a 200hp I4 like the one in the TSX.
Were I a gambling man, I could make a good living betting against larger engines for every new Honda or Acura.
Take a look at the mission of the Pilot versus that of the MDX. The MDX is meant to be sport-oriented. At least, as much as a mid-size CUV can get. The Pilot is meant to be a family hauler. Both the 3.7L engine and the SH-AWD system are performance upgrades. They are not family-oriented tools. Honda would be better off spending their dollars on things like cupholders, an over-sized moonroof, a 3rd row of seats that converts into a play pen, increased fuel economy, and a new stain-proof ceiling fabric.
Personally I dont like tuxedos."
I can see your point, but from the perspective of a car manufacturer it's not a big deal. Some of the best selling vehicles on the market are tux-jobs. The (Accord-based) Acura TL sells as many copies as any other vehicle in the segment. The (Camry-based) ES is also at the top of the sales chart. The best selling luxury CUV is the (Highlander-clone) Lexus RX. Even though it's 6 years old, the (Pilot-clone) Acura MDX is the second best seller after the Lexus.
For a unique-chassis vehicle to come close to the sales of the aging MDX, you have to add the sales of the X5 and FX together. This despite both vehicles being newer.
So, while I can certainly understand your preference for a dedicated platform under your tush, it would appear the mass market doesn't share your view. So, as a business case, platform-sharing isn't a problem.
Somebody's buying the LS!
For those who are interested, the remaining colors are Nimbus Gray Metallic and Steel Blue Metallic.
I placed a deposit on one today, but I don't know when it will arrive....
I would prefer a hybrid but the only 2 hybrid mid size suv are the highlander and lexus rx400h which my parents already have adn dont want the same as them.
so the best non hybrid mid size suv mpg would be good.
already i'm not crazy about the styling of the mdx if it looks like rdx though pics look a little better and will have to see in person. Mostly interested for the superior tech and the increased horsepower etc (250 for the Tribeca, 300 for the MDX?) but now i hear the nav is not touch screen but rather joystick so that is a concern, though it is voice activated so might make up for not being touchscreen now.
but if the mpg is worse then teh tribeca then its not worth the hp it has over the tribeca. the other benefit was the price i might get when my wife gets a TL if we get at same time from same dealer. but her lease up in jan and 07 mdx will prob still be too new and no good deals quite yet.
I was thinking about the Audi Q7 but it might be actually too big and i saw someone here say Q5, was that juat a typo or are they calling the v6 version Q5? i'm afraid it will be the same case as the VW Touareg where the V8 was too expensive and too much of a gas guzzler while the v6 wasn't enough for the heavy vehicle, which with the Q7 being larger i would think is the same problem though i think its a stronger v6. I'm just worried that coming from a Subaru with the industries best AWD, that the only thing that will be equal is Audis AWD.
Also someoen said why get a Lexus LS when you can get a camry xle. LS is much bigger you might have been thinking Lexus ES based on teh camry. I see the arguement in that a lot of these models are rebadged luxury version of their non luxury make vehicle.
That is one thing i always didn't like about the MDX that it was just slight luxury version of the Honda Pilot. But, you get Acura for the technology that they seem to be best at. The Acura TL while being basedon the accord platform was consumer reports #1 car in its segment and you may think you are just paying for luxury options on an accord but the whole thing that seemed great with the TL was how much was standard.
I just dont understand why Acura hasn't made any hybrid versions considering honda has hybrids and even honda hasn't made a hybrid suv yet. Hybrid MDX would be great and finally compete with the Highlander nad Lexus RX400h.
The success of the Mazda CX-7 shows that people do want a CUV that behaves somewhat likes a sports car, so what Acura is doing makes sense and it might be worth a slight premium over the Pilot. It's a shame that it is going after overpriced CUVs like the Q7 or X5, because the slight premium then becomes a "high premium" in order to keep up with the Joneses!
This should make things easy for you. The estimated EPA mileage for the MDX is 17/22 mpg (City/Highway) running on premium fuel. The Tribeca is supposed to return 18/23 on regular.
Don't bother with the Audi if fuel economy is really that important to you.
