nah. it sounds like a very clear radio station, which is fine with the maybe 7-10wrms the stock deck can put out.
~c
BTW, wattage has absolutely nothing to do with the quality of the sound! Just ask the guys with $10,000 7 Watt mono single-ended triode tube amps.
Sly
it's just my opinion. I have a pretty sophisticated system in my car right now, and have had stock stereos for the life of a vehicle as well... good stereo is good enough for me when the rest of the system is stock!
~Colin
It really does -- it's like the difference between CD and FM, and that's extremely noticeable. Just the frequency response alone is a huge difference to my ears.
I can still remember the first time I heard a CD playing back in 1984 or so. Made a lifetime impression on me as to what "CD-quality" sound means.
Craig
Sly
Can anyone tell me what kind of head unit is in the 05 Outbacks? Mine is the "non-luxury" H6 model. The reason I ask is that I'm told that some units have RCA plugs for auxiliary input on the back. I'm thinking that because it's a six CD stacker, it won't be likely, but ....
Incidentally, I spent a happy couple of hours reading over the various message boards connected with Subarus on this site. Learned more about Subarus and people's biases that I needed to, but interesting nevertheless. I've had my new Outback for a couple of weeks and would agree with others that the 05 is a great re-work of the last generation of Outbacks...the six is very nice to have as well. Don't have to plan ahead for overtaking on hills! I must say that the new one gives a rather disconcerting "wiggle" when hitting bumps though....my 02 Outback seemed more stable on the bumps. Anyone else care to comment? I'm actually wondering whether this "wiggle" might have something to do with running 16" rims and winter tires instead of the stock 17" ones. I only drove with the 17" rims from the dealer to the tire store, so have nothing to compare to!
that wiggle you're experiencing is due to the rear suspension of the 05 Outbacks being underdamped. This is particulalry evident when passing over large (long period) bumps at highway speed. The same thing happens on my OBXT.
I'm hoping that we will have some aftermarket options for coil-overs or shocks with better damping.
Sly
Only the 05 has the new type of persistent chime (it will forever chime every few seconds until you fasten the belts). That is what gets disabled by the trick. The initial chime stays.
Craig
None of the 05s have RCA inputs or aux-in plugs of any kind.
I had an 02 LL Bean, and my 05 XT handles much better and corners a lot flatter. The suspension is a bit stiffer, however. And of course the 17" wheels/tires have a ride penalty too. However, I have not noticed any "wiggle" problems. Make sure all of your tires are properly inflated per the specs on the door jamb -- that would be something to check on. AWD cars will get tail happy if the rear pressure is too high. And of course, any side to side variations could cause a yaw effect when you hit bumps.
Craig
This only happens on large amplitude bumps at highway speeds. I don't notice it on my daily commute, but I have noticed it on a stretch of bumpy highway nearby. This is most definitely caused by underdamped shocks.
I've also occasionally noticed the rear kicking out a bit when hitting a bump in the middle of a sharp curve. This however, I have only felt this twice in the 3 months I've had my car.
Those two issues notwithstanding, I do think the OBXT has outstanding handling for such a high car. It will run circles around an XC70 and pretty much any SUV.
Sly
Knowing that there aren't any RCA plugs saves me some money in labour having the head unit removed....big thanks for this info!
The "wiggle" is happening at low speeds (50 km/30 mph). Good example is when going over a manhole cover....I will check tire-pressures, though.
Mine were also leaving tell-tale signs in the garage - a tiny drip-drip each night on both sides. My guess is that the trip on the truck was a bit too snug and damaged the rear struts.
-Brian
Got this from the Toyota Pressroom, but its sweet news for the Subaristi here!
· All-Star Family Car: Subaru Legacy – The Legacy beat out the competition because it can be all things to all people: a refined, high-quality, comfortable freeway cruiser and a sporty back-roads car, with fine steering and brakes and a sweet shifter.
All the All-Stars:
http://pressroom.toyota.com/photo_library/display_release.html?id- =20041220
Best,
Joe
I agree, the seatbelt chime can be very irritating for those few times that I move the Subaru without using the seat belt. Ken and Craig are right on with their replies...but I would like to add the following. I asked my dealer to disable the chimes and was told that they legally could not disable them, but they did "accidently" leave a copy of a page from the service manual on the front seat explaining how it could be done. The repeat click/unclick of the seat belt must be completed 20 times within the first 30 seconds after the seat belt indicator stops the initial flashing.
Regarding the manuals, I can offer one solution. I purchased the complete set for my 2000 Legacy (8 manuals. They were not cheap. I am not going to do the same for my 2005 Legacy. What I will do is subscribe to Subaru's documentation web site and download the manuals. (I think the subscription is $20 per week). I would post a link, but I have been trouble reaching the complete Subaru web site since last week.
Good luck!
Jim
Ken
I am back from my long trip in my OBXT 2005. Power is plenty and more than I can handle, so was very satisfied at that end. The heating is great.
However, the car seemed a little unstable at high speeds (even 70) many a times. There were times when it cruised along smoothly at 80, but there were also many times where it seemed to do the "WIGGLE" act and did not seem surefooted (I don't know how t describe it, but it seemed as if it will 'fly off into the other lane'). The freeway did not have any noticeable bumps and therefore it was very disappointing. I checked the tire pressure to ensure that this was not because of wrong pressure. The tires had correct pressure and the left side and right side tires had at most 0.5 psi difference.
Please let me know if you experience anything similar. Maybe I should talk to the dealer too.
Craig
Most cars I've ever owned or been in, there was a way to turn on all the interior lights by either turning the headlight switch all the way... or whatever.
The new Legacy/Outback doesn't appear to have this feature.
Can I change that?
What is your dealer's name? I want to contact them?
DC Steve
Craig
I will try driving it on the freeway here a few times again and see whether I get the same feeling and if I do, I will perhaps ask an independent mechanic to test drive it and see what he thinks. If he thinks there is some problem then I will contact the dealer.
I bought my car from Van Bortel Subaru. I do not know whether they will sell it to you for $64 since you did not buy the car from them, but I am almost sure they will sell it to you for less than $100.
DC Steve
I was going to suggest the same thing. I find my '05 OBXTL-5MT extremely steady at highway speeds...even above 90+mph...until you hit some cross winds. Having been driving an Expedition and old, boxy-era BMWs the last serveral years (both which succumb easily to cross winds at highway speeds), and I still find the OB more than acceptible, and better than what I'm used to.
And I'm with Sly re: the rear shock dampening issue; I'm 6'3" and 210 lbs, and with nothing/no one else in the car, I can go over some slight/moderate rises and feel the rear suspension compressing/bottoming out as if I had the car loaded to the hilt. This is not a good thing, and I have no interest in spending thousands for a coil-over upgrade to correct it. Is this issue specific to the OB's only?
Tim G.
ps: got to try my RE-92A's in the slippery stuff on Sunday...DEATH TRAPS. They will be changed out for the winter months--mark my words!
That makes me feel a little better. At least that means I may NOT have not a defective car.
Is there a simple way this can be tested? Is asking an independent mechanic to drive it on the freeway the best thing?
Sly
In Japan, there is apparently a replacement "face plate" that lets one use an aftermarket stereo but retains climate controls. We just may need to keep asking Subaru to bring it over to the US.
Ken
My Outback does wiggle slightly on grooved pavement, if that's what you guys are referring to. It's more a function of the tires than the car.
Craig
If you want to hook up an MP3 player (like an iPod) to the radio, there is a direct line-in hack for the brave, or you can use an FM modulator or FM transmitter. I listed these in order of decreasing sound quality.
Craig
Craig
Sure would beat the hords of clueless phone operators they currently employ.
Sly
Ken
Craig
http://autodeadline.com/detail?source=Toyota&mid=TOY20041220&- amp;mime=ASC
Bob
Thans!
You mentioned that there is a mp3 cd player that you can put in that has those climate controls integrated and it costs $600. Which one are you talking about? Is it an aftermarket one, or something that you would request at the dealership?
Thanks again
Ken
