Good luck
They all do that. I believe what you are feeling is the electric pump for the brakes.
T
1- The portion of the pad now wearing through is heavier in metallic content at that point causing the scraping noise you hear (mostly the cheaper the pads that have been installed the louder they can be/usually stopping power is ok).
2- Sometimes in high humidity or wet conditions a patina rust can build up on the rotor as quickly as overnight, It can "sing" at slow speeds and give a slight "grind" type noise and slight slipping sensation on pedal application. It's annoying but not really problematical.
Anyway, just thought I would post this. Good luck on yours.
I did a search through edmunds.com and cannot find an answer;
Where did Toyota put the dip stick to check the auto trans fluid?
The owners manual doesn't mention anything about location of this so my fear is that Toyota has made this a "serviced only by dealer" operation.
I hope not since I like to do my own maintenance.
Any ideas???
TIA
Diagnosis revealed a system leak. They claim the gas cap was loose, (which I seriously doubt, but whatever), but that didn't solve the problem. They also did a smoke test and found a big leak from the "charcoal canister", that a "chunk from the canister was found to be missing, and that it had "a big hole."
This was a $500 part that was replaced under warranty, however, what the heck is a charcoal canister, and why would a chunk of it be missing, leaving a big hole?
Since this (charcoal canister) is mounted in a low location, it is very possible and likely that a hole or "chunk" could happen. Due to a rock or other road debris.
BTW, it is important that when you gas up, tighten your gas cap completely as a loose cap WILL cause a fault and thus turning "on" your check engine light.
Hope this helped!
I've noticed on my 2006 4Runner that the exhaust manifold does appear to be rather "thin" thus producing the exhaust tapping noise.
I'm curious to know if anyone has taken their 4Runner or other Toyota vehicle with the V6 engine to the dealer and what they said/did. I plan on driving another '06 4Runner this weekend and will see if it produces the same sound.
Or if anyone has fixed (replaced) the manifold, what you used?
And I doubt that the car was bucking violently due to a hole/crack in a charcoal canister.
Purchase a bottle of Chevron Techron Fuel Injector Cleaner (at Target or auto parts store). Run your tank near empty and add this (per instructions) and fill with a good premium gas; Amoco Ultimate works well. Run that tank near empty, then fill with a 87 octane.
Also, if a majority of your driving is city, take your 4Runner out on the highway and "open it up". City driving can cause deposits to form in the combustion chamber and cause a "ping" or pre-detonation condition.
Good luck!
While I don't doubt that a loose gas cap can cause the check-engine light to come on, what I seriously doubt is that "I" left the gas cap loose, hence I thought it had to be something else.
Either way, it was fixed under warranty, (otherwise a $750 bill). I also took the opportunity to get the slip yoke and propeller shaft lubricated.
what is a slip yoke and propellar shaft? ???
all your lights probably do go on for a moment when you start your engine (how else would you know the indicator was working), but then should immediately go out.
i'm honestly confused by your post. what does the repair bill say they fixed?
The Revo's have only tackled rain, and have done so admirably. But I feel like I'm riding in a paint can shaker, even though the tires are aired at minimum 32psi. These are 'P' tires, not 'LT' tires. I feel every imperfection in the road. And yes, the tires are balanced and track straight.
I didn't think much of the Cross Terrain tread pattern, but I was looking at LTX MS 255/70/17 which would be a close fit for the stock 265/65/17 tires.
Unless my Revo's break-in and soften the stiffness over the next several thousand miles, I'll probably opt for the Michelins next time around. I may lose some traction, but I'll probably have a nicer ride. BTW, the factory Dunlops I had also took several thousand miles to get comfortable.
If you want comfort and handling, Cross Terrains are probably for you. If you want an LTX tire, you'll have to change tire size (spare too).
