Did you test drive the GM? Or anything else?
Started a new forum, covering GM vs. Toyota, with Chrysler playing the "X-Factor", check it out at:
http://townhall-talk.edmunds.com/WebX/.f11c385
DrFill
1. 1995 ck1500 4x4 =good truck
2. 1999 ck2500 4x4 =good truck
3. 2001 ram2500 4x4 diesel =great truck
4. 2006 siverado 1500 4x4 crew cab LEMON. I put 25k on this truck in 5mos = new water pump, new transfer case, new transmission seal, new tires(recall), "beam shake" vibration, 4wd fron differential made horrible noises when engaged.
5. 2007 TUNDRA SR5 DOUBLE CAB 5.7
I never thought I would own a Toyota, however the last truck ended my relationship with the "American" brands. I drive 1200 miles per week for work and have a farm on the side. I USE a truck. My Tundra already has dents and missing paint inside of the bed and I've had it almost 2 weeks.
MY OPINION OF THE TUNDRA:
DISLIKES:
-ergonomics of the cab, radio/climate controls hard to reach
-keyless remote will not allow doors to be locked while engine is running, therefore I have to use the key to lock the door while it warms up in front of the hotel in the mornings
-auto healights are not standard... did not realize this until after I purchased
-the sheet metal in the bed is waaayyy thinner than the big3 trucks, this is fine if you do not use the bed for things other than labradors and golf clubs
-the cup holders are too deep for standard coffee cups
-the tilt/telescopic steering does not tilt down far enough compared to the chevy
-headlights/interior lights do not shut off auto like the chevy if you forget to turn them off
-off road package rides like a road wagon compared to Z71
FOLKS, THESE ARE THE ONLY BAD THINGS I CAN SAY ABOUT THIS TRUCK AFTER 1700 MILES!
WHAT I LIKE
-Handling in the snow/ice in 2wd, drive sensibly and the traction control is awesome on treacherous roads
-POWER! waaayyy plenty power, I have towed three loads of hay thus far and have no complaints whatsoever
-handling on curves and in freeway traffic=excellent, very tight steering
-transmission w/ manual gear selection, I'm in the TN mountains this week and being able to use the console shifter to hold gears 3 and 4 going down hill is awesome
-the 6spd auto is very smooth
-the back section of the cab has plenty of room for a clothes bar, file boxes and luggage
-cubby holes everywhere
-power plugins everywhere, I can charge my bluetooth device, phone, laptop and gps all at the same time
-GAS MILEAGE!!!interstate 17.5-19.8, in town 15-16,
this is even better than my last 5.3L gm. VERY HAPPY!!!
However, this truck has soooo much unloaded power, is is very, very tempting to take off hard and fast... not good for fuel economy. It is worth it every now and then just to feel yourself glued against the seat... with the pedal only pushed 1/3 down at take-off. I have yet to make this vehicle spin tires on take-off. THE TRACTION CONTROL IS GREAT. Hook up and go!!!
All in all, at this point, this is the best truck that I have owned. When driven sensibly, the fuel economy is unmatched for a 381hp truck. please feel free to email me for any other questions you may have.
So, you do have the 4x4 Tundra? And getting that kind of mileage? Wow!
Hey, as far as your cup holder is concerned, measure and cut you a piece of wood that will fit down into the deep cupholder making a kind of pedestal, woahla! I have done this before and it works well. Then, suddenly you need the deep cup holder back, just take out the wood plug.
Alot of talk about the "cheap silver dash", curious about the wgrain option.
Today I drove about 185 miles and noticed a slight vibration at 72mph for a short stretch. I was unable to duplicate it later. The steering wheel would vibrate back and forth... I hope it was just the road. I dont have time to jack around with another truck like the last chevrolet I had.
Keep in mind though, the target consumer for this truck probably doesnt care what the dash looks like as long as it is functional.
As for your comment:
What thickness are you talking about and how did you figure this out? If a person puts lawnmowers/lawn equipt in the back do we run the risk of puncturing or severly denting the metal?
Tundra Crewmax has a power rear sliding window that you can lower down. Standard on the Limited and availabe on the crewmax.
Does this sound correct? :confuse:
now we are down to faulty fuel gauges and steering vibration?
lol,
Salient features of his steering vibration experience:
1) slight vibration
2) short stretch
3) unable to duplicate
Diagnosis: It was the road!
On the issue of fuel mileage... driving 80mph most of the way with traffic from Bristol, TN to Nashville, TN did not seem to alter the avg mpg. Just above 18mpg when I filled up in Clarksville, TN.
In the 5.3L Chevy 4x4, this rate of speed would have me in the low teens... even with a 3.42 rear diff.
To answer your question inthemarket2, you probably dont risk a puncture wound from lawn equip, but definitely sever denting. The sensible thing to do is get a bedliner or spray-in liner... if you are worried about pretty that is.
I usually dont get too upset over the first dent/scratch, but caving a section of the bed in about 1" from the back of the cab made me a little sick. It could have been prevented.
I only have 2100 miles on it now. Its scary to think what it will look like in 15000 more.
I only put about 1K mi. on my V10 F250 last year because of the fuel mileage. 11 MPG empty (didn't seem to matter how I drove) and 8-9 towing a 3 horse trailer. Not to mention that the thing was huge and hard to park. Are you getting your mileage loaded or empty? Thanks again for your posts.
i am not going to pass up on this quality of a truck because of possible fuel gauge problems.
it is very good to see that most drivers of this new truck out there have put to sleep the myth that they are getting poor gas mileage. Poor fuel mileage is difficult to fix. Poor fuel gauges are easy to fix.
have you had any more experiences with the steering vibration since last post?
By all of your previous posts, it seems fair to say that you are not the "average" example of style of use for a pickup truck. i may be wrong, but to me you seem to be a guy that really puts a truck to the test. that is good, you are a value to guys like me that dont really put the truck through "heavy use".
i will most definately get my bed sprayed immediatly upon delivery.
Question: when you experienced the steering vibration, did you have a load in the truck?
thanks.
me, on the other hand; i don't need a truck that will withstand the beatings you put on them. i just need a truck, a good, quality chick magnet. One I can tool around in, and occasionally load up a bunch of material at Lowe's to build a deck and stairway into the hot-tub in my back yard for the chicks to hang in while i polish my truck.
Good luck in your search. thank God, my search is over. It's time to party!
1. MY fuel economy postings are unloaded driving
2. have had no additional steering vibrations
btw... the heated windshield wipers are NICE.
good news on no more steering vibrations.
kcram - Pickups Host
i always thought it was 'supposed to be' in the first catagory. t and c must be double walled on the sides you can see from the outside, right?
Well said , I have been trying to put into sentences exactly what you mention. All these useless bickering .
I remember when a forum used to be a source of information now it has become a forum of defamation.
Thanks again.
Lou
I wanted the Tundra 4x4 Double Cab Standard Bed Limited with 5.7L V8, Tow Package, DVD Navigation, and 20" wheels. All the local dealers told me there were only 4 vehicles like that in the whole region in the color that I wanted. My favorite dealer didn't have one initially but they got one a few days later. After the usual haggling I got them down to 7% below MSRP sticker price but this was still 3.4% above invoice. Initially I felt this was not the best deal but then none of the other dealers would touch it and some even laughed at me for asking for a Tundra below MSRP. Normally I negotiate to only $500-$800 above invoice but this didn't seem possible while the Tundras are so new and popular. It didn't help matters that they just had a Bass Pro Shops test-drive event in my area a week ago so the dealers were flooded with orders. I hope I got a fair price and didn't get robbed by my enthusiasm.
I had started out looking for a 2007 Tacoma to replace my 2002 Tacoma which was recently totaled in a wreck. The Tacoma was nice but the seats sit too low to the floor, which makes my legs stick up too close to the steering wheel and is uncomfortable especially on long trips. Of course the dealer had me sit in the Tundra and WOW - no comparison - leg room and comfort were 300% better, sort of like comparing a metal folding chair to a lazy boy recliner.
I read some reviews online about the 20" wheels not riding as smooth as the 18" wheels. After test driving both I couldn't tell the difference but I am not a performance driver so I would appreciate more comments in this area. If the ride is similar then what is the benefit of the larger wheels? 80% of my usage will be casual driving to/from work and home with the remainder being mostly light hauling and an occasional trailer towing. I didn't really need this huge work truck for my needs but the comfort and features were so much better than the Tacoma that I had to have it.
The drive home was the most fun I had in a vehicle in a long time. After the recent wreck I am so over-protective of the new Tundra that I try to keep a 1/2 mile no-drive zone around me at all times. :-) Despite my best effort some sleepy old lady in a little chevy sedan swerved over into my lane so I laid on the horn. I was surprised that it wasn't louder but she jumped about 12" and moved back over promptly so maybe it was loud for her and just quiet for me inside the Tundra. I will have to test it outside and if still not loud enough then I will have to get one of those awesome horns from hornblasters.com.
I was able to synch my mobile phone to the nav package with ease and made a few calls through the handsfree kit - amazing quality and so much better than all similar kits I have used in the past. The GPS functions are great but the legal disclaimer after every startup is very annoying already so I will certainly be looking for a hack to disable that if possible. The backup camera is simply amazing - just wish it would allow me to switch the camera on when needed and even provide other cameras as an option for help when parking in tight spots or backing up a big trailer. I can rig up a camera switch and add my own small bullet cameras but it would be nice to have a factory option to save me the time.
Storage compartments are everywhere. So many that I will have to seriously plan out the usage of each one and then take a few weeks to memorize the layout. The carpeted floor mats were typical but not as nice as they should be for the price and they don't seem to match the richness of the limited package. I replaced them with extra-large black rubber mats that look better, hold more water and debris, and are easier to clean. Dash instruments are great and all the data available on the DVD NAV screen is amazing, such as maintenance reminders, personal memos, calendars, etc. Much more than a NAV system. I didn't even know that the truck has voice command until I got it home. "Nearest Italian Restaurant, ATM, Gas Station" etc. all promise to become favorite commands when traveling. The emergency mode seems helpful to take you to the hospital, police, fire department, etc. but I wonder if it also sends off any special signals for vehicle locator service (doubtful since this would be dependent on your cell phone).
Must have accessories for me over the next few months will include brushed stainless steps, bedliner, hard multi-section bed cover, hood protector, and possibly front and rear sonar if this can be added and is worth the hassle. I am considering a Line-X liner but have never used spray-in products before. Any comments on the comparison and value vs. traditional drop in liners? I have always ordered my bed lids from Sport Truck Solutions. in So. Cal. but wonder if there is a better lid option out there? The Top Dawg model looks like the ticket but I am open to ideas...
Will share more after driving the Tundra for a month or so.
Rocky
anyway, you can't go wrong with Line-x. I have had it done on many trucks and always liked it. Very durable and keeps things from sliding around in the bed of the truck. Just don't watch when the install it cause it ain't fun watchin them strip all the paint out of the bed of your truck.
thanks for the Sport Truck Solutions site. I'll check them out.
I traded in a 3/4 ton long bed dodge diesel, and this one rides so much better and of course turns on a dime compared to the dodge. My first tank of gas was 16..mainly around town so I expect it to do a bit better over time.
I bought and installed a set of black nerf bars from the dealer for my short legged wife. Nice stuff and not too far off in price.
The only thing I am not wild about is the wheels. Mine came with "styled steel" Hopefully I will get used to them.
I have ordered an access roll up cover for the bed and will get it mid march. Finally, I had the bed line xed and it looks great..
Great truck !!
Exterior Paint Sealant - does this peel over time?
Toyo Guard Sealant Cleaner
Interior Fabric Protector
Undercoating/Sound Shield
Glass Etch Theft Deterrent
The dealers all try to sell you this stuff. In the past I have bought the package, but really I have never noticed any difference. You can buy scotch guard and do your cloth seats and a good wax for your clear coat and be good to go. I don't have any experience with the glass etch theft deterrent.
