Al.
Al.
They tried to change mine at 30K, and when they couldn't find the dip stick, realized that it was too early.
The nimrods at the dealerships appear to have no clue, or just don't check, when the real service schedule is.
I am done doing business with one dealership, because they flushed the radiator at 30K, (a 100K service), but didn't service the limited slip diff (which is a 30K service). After complaining, then complaining to Toyota, they never offered to correct the issue, so they lose my business for the life of the truck.
Next time, when I go in, I will take a copy of the service book in, and tell them to do what it says, anything extra they do, they can pay for themselves.
http://www.google.com/base/a/1559709/D1032592540090741305
You'll see either 000000 00000 0000 000 00 0 and then nothing, or it is dashes ------ ----- ---- --- -- - and then nothing. I always get mine and my wife's car confused. So you have to hold it down until the mileage is finally displayed, which is something like 10 seconds or so.
B
I currently have a 95 S10 2wd with the standard rear differential. If I go with the OR version I get the locking differential (which I assume locks via some push button?). If I go with the SR5 I would get the limited slip differentials. Can anyone tell me the pros and cons of both of these differentials? I live near St Louis MO so I don't really see the need for 4wd (and spending $3000 more) and I think either of these differentials would be a huge improvement over my S10.
Can anyone tell me if the TRD seats in the OR package are worth the extra money? Is the OR suspension quite a bit stiffer then the SR5? Is the suspension difference because of the shocks or also the spring rates?
I appreciate your input.
She just drove it to and from work, never saw a second of off-roading at all (lol, then why was it a TRD Off-Road, with a 6" suspension lift, 36" tires, and a winch)...
Since I do more on-road that off-road driving, I didn't really need the stiffer suspension (a little to firm for my taste) and I didn't think the seats were much different than the standard ones. Also, the SR5 has limited slip instead of the locker, so that wasn't a factor for me either.
In the end, I took some of the money I saved going with the SR5 instead of the OR and got the towing package which, IMO, a much better use of the money (oil & tranny coolers, heavy duty battey and alternator).
HTH,
Glen
(Now I love my truck again!)
I also only did it on the top, not the sides. It appears that the problem is that the flap against the glass ends up flipping back, and vibrating with the wind.
Thanks in advance!
Most likely, you have the AutoLSD, which does not have a button. If you want to just verify that you have one, you can usually look on the rear differential, and you'll see a sticker or label that says LSD, or only use LSD oil, something similar...
HTH,
Glen
Does anyone have any idea why this is happening?
There are two hex head screws on the metal covers (open the tail gate) that you have to remove, then you yank really hard on the light housing, towards the rear. Be careful not to move rearward too far after it comes loose. You should know what to do from there.
I changed my blinkers and brake lights to all 3W LED lights a while back.
IIRC, it's the two rear most screws, one on top, and one on the bottom.
I took it to the dealer a few months ago, and of course they said there was nothing wrong. I read in a few threads in this webpage about the same problem with 03-04 Tacomas (see message #1976 at the Toyota Tacoma: Problem and Solutions), and it was somehting about the "fuel suction assembly". Do you know of any TSB's regarding this problem for '06 Tacomas or do you know what could be wrong?
I checked out your thread on it (appears very popular), then checked out Hornblasters. I just want to know, did the cop write him a ticket after he blasted him while checking his signal??? If I was a cop, I wouldn't know if I would be ticked off, or ROFLOL...of course, I probably would have soiled myself if I was as close as he was! :P
Hmmmm, that sounds like a good idea. Where did you get them? Cost?
