Also, as I was flying back to Ca the other night, I realize the Delta skymall catalog has an oil change machine for sale. It's a machine that sucks the oil out from the dip stick hole. They claims Mercedes dealer change oil the same way. Has anyone else seen it or used it? Does Mercedes really change oil that way with a machine? It sure would make life easier and cleaner. But can it really get rid of all the old oil and gunk as good as the traditional drain from the oil pan plug bolt?
Here is one method.
I use this extractor.
Yes.
It's worked well for me as well as other BMW owners I know. I don't use it all that much as I can reach the drain plug on my E36 3er, X3, and Wrangler without jacking them up. That said, it was a lifesaver on my wife's E39 5er.
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
A little help here. Thanks.
The big bump thing? Beats me, but it sounds like a loose battery cable..
I remember reading somewhere that I can manually reset without needing a device. But I can't find that post now. Any suggestions will e greatly appreciated.
BTW, does anyone know a website that I can find out bmw club event in southern california? Thanks!
1. Key in 0 or off position.
2. Press and hold odometer button and turn key to 1 or acc. position.
3. Keep button pressed until any of the following words appear in display: "oil service" or "inspection", with "reset" or "re".
4. Press and hold button again until "reset" or "re" flash. If there is no "flash", minimum consumption value has not been met.
5. While display is flashing, press button briefly to reset service interval indicator. After display has shown new interval, the following will appear in display for approx. 2 seconds:"END SIA"
Perhaps the BMW CAR Club of America website?
Basically, I'm in the market for a real car after spending way too many years with a Honda. The 4 cars I am currently interested in from most to least are: E46, E36, Audi S4, Audi A4. Since this is a BMW post, my main questions pertain to the 36 and 46, but if anyone has any insight into the Audis I'd be interested as well. Since I'm finishing up grad school, my main concern is RELIABLE speed. I've heard some bad things about the reliability of Audis...
Most likely, I'd like to purchase a black, manual coupe (36/46) for around $25,000 or less. I know I'm pushing it with the E46, but I have found some E46 coupes hovering around 60k miles. Right now there is an E36 with 35K for under $23,000 in my area. I know the differences in speed/power between the two models, but how about reliability and maintenance?
Since I don't know as much about M3s, what is a reasonable amount of mileage I should consider? My plan is to wait it out until until I find a deal, then have the car inspected by a BMW mechanic. Obviously, that mechanic will know what to look for, but I would like to have an idea also. What are some common problems with the two models that I should consider? I know I want to look at maintenance records (ie- how often brake fluid etc.) My last question...what is to be expected each year for maintenance? I understand that BMW parts are very expensive, as is service at a BMW dealership. Is it unsafe to use non-BMW parts? Does anyone use a non-BMW mechanic? I have a very good mechanic, but working on a Honda is like fixing a simple lawn mower!
Thanks a lot for any help. I'm sure topics like mine have been posted many times before, but I have a 14 credit graduate school summer ahead and not much time. If anyone has any comprehensive M3 websites to suggest that would be helpful too. Given my financial situation, which of the 4 cars would you buy?
I had been modifying honda/acura for over 10 years. I've owned a total of 8 of them from OBDO and OBD1 and I'm still not done playing with the 4 that I still have :-)
But back to the M3. I got my 2001, 6 speed, with 74K for $18,100
I took it to the dealer for a complete check with compression test added to make sure engine is still strong before I purchased it. I've found out a couple of things that needs to be changed which is pretty much maintenance stuff when the car gets to ~ 80K All the stuff that needs to be changed cause me about ~$ 4,000 from the dealer. I'm slowly changing it myself with the help of advice from guys here and Save about $1000 so far. Thanks.Guys!!!
You can also check BMWforum.com is what I've been told
Where are you located BTW?
I'd set aside $50-$75 per month for maintenance of an E36 M3(including tires). The cars are pretty simple to keep running. Oil changes are a dead easy DIY task-$50 for oil and filter. At @60K I'd replace the water pump and thermostat, and the radiator at 100K. Join BMW CCA and find a good independent BMW tech or a reasonable dealer. There are several around, if you know where to look. Me, I'm in the process of dumping a 2007 Mazdaspeed3- I'll replace it with either an E36 or E46 M3. Right now I'm leaning toward an E36 as it is relatively cheap and easy run as well as to add a few more horses(it will be my primary track toy). Plus, I love Dakar Yellow...
:confuse:
he needs new shock and was wondering if he can save some money and use "Gabriel" suspension from autozone. Is alot cheaper than OE from dealer and is made for the 540 according to autozone. the only problem is that it is without the electronic control. if it will work, will the fitment be the same as OE without modification needed? or should he avoid possible headache and just pay the money for the OE? any insight will be appreciated.
No, please tell him/her not to do that. (see link I provided)
If I were him/her, I'd contact Bilstein and ask them what package they have to solve this problem.
I understand that replacing these shocks is very expensive, but that's a lot better than having a car that will be (IMO) significantly degraded with the wrong shocks on it.
Bilstein Corp
Hope this helps. It might be cheaper than the dealer, too.
i did speak to Bilstein already because autozone gave Bilstein as another option. According to autozone, their system sho electronic control for the rear only and not the front which didn't make sense. I called Bilstein and gave them autozone's part # and Bilstein said neither the front nor the the rear part # can be used for electronic control and they have had problem trying to make something that will work so they told me to go use OE from dealer. My friend now use the 540 as a grocery getter and was hoping he can save money using aftermarket without putting the car at risk on highway driving in normal condition.
but you confirm my thought that he should just use OE. Thanks!
But, I'm betting OEM is the only way, as well....
But I also understand that the OE solution from the dealer is murderously expensive.
good thing for him i get 20% discount from the dealer through my shop but is still 1/3 more than bilstein and almost 3 times as much from gabriel as my cost from autozone
well, safety is definitely more important than a couple of hunder bucks for him and other drivers on the highway.
thank you all for your feedbacks to confirm my thought. is just like racing, sometime you want to try to get away with it to strecth the dollar when you can. but sometime is not worth losing a race or worse by getting cheap parts!!!! experienced that too many times :-P
I've heard some really scary numbers here. We are talking thousands of dollars, right?
$831 each for the front and $542 each for the rear. $2746 for all four. My E24 M6 had the self-leveling rear shocks and it was a simple matter to switch over to regular Bilsteins if you didn't want to pay to fix whatever failed. I don't see why you couldn't simply replace the EDC shocks with Bilstein Sport or BMW M Sport dampers. As for bargain shocks, I have a friend who fitted Monroe shocks to his E39 wagon. He's a fairly hard-core enthusiast and he was pleased with the results(the Monroes are made in Europe, FWIW).
Well anyway, thanks for that. We seem to be drifting out of M3 territory, so maybe we should get back on topic, unless this also applies to M3 cars. ??
Rroscher
So can you gently urge it upwards with your hand? If it works with hand-assist, I'd say it's probably hydraulic. If it just jams up there, maybe there's a busted arm or bad bushing in the mechanicals.
You might check for a hydraulic leak, as that could damage the upholstery or paint surfaces back there.
I believe there are trouble codes that can be read on this car to help with diagnosis on the top mechanism.
Just need to know what is the right tool to use for the drain plug. The last time/1st time I change the oil, i used a hex key to remove and tighten the drain plug. Since there was no way I can use the torque wrench, I hand tighen the drain plug (using new washer) with the hex key as tight as I can without stripping it. After a couple of months, I saw oil leak from the plug. I realized that the drain plug looks like it can be torqued with a torx set even though the hex key works.
Now is time for another oil change, I used the torx to remove it but it started to slip. To prevent any damamge with a stuck drain plug that will require to be tapped out, I decided to leave it alone until I figure out the right tool.
If it does use a torx, what size am I suupose to use? It was either T40 or T45 that had the best fit but still slips. Or am I suppose to get a hex key to remove and use a hex key end that can go on my torque wrench to tighten down properly for seal.
Bentley manual shows nothing that I can find on that and i can't seem to find anything detail on other forum, aside from the fact that peole claim is a easy easy diy.
The dealer quoted a price of $1000 for parts and labor
any help will be appreciated
http://forums.bimmerforums.com/forum/showthread.php?t=92029
i have a 01 m3, will so will the e36 be similar to e 46?
GROUP 12
Engine Electrical Systems
Bulletin Number
12 04 00
Woodcliff Lake, NJ
July 2000
Service Engineering
SUBJECT:
Secondary Air System Faults
MODEL:
All models with M52 and S52 engine
All models with M44 engine produced as of 1/97
All models with M62 engine produced as of 9/98
All models with M73 engine
SITUATION:
Customer complains that the "Check Engine" lamp is illuminated and the following fault is set in the Engine Control Module (ECM/DME):
M52, S52 Engine:
Fault code 245 (F5 hex) - Secondary air injection, bank 1
Fault Code 246 (F6 hex) - Secondary air injection, bank 2
M62 Engine
Fault code 80 - Secondary air injection, bank 1
Fault Code 81 - Secondary air injection, bank 2
M44 & M73 Engine
Fault Code 80 - Secondary air injection system
CAUSE:
Failure within the secondary air injection system.
PROCEDURE:
The following diagnostic tips / steps should be followed if the above customer complaint is received:
1. For E36 vehicles equipped with M52 engine prod. 10/95 - 2/96 also refer to S.I. 12 04 96 regarding Recall Campaign No. 96E-A01.
2. Refer to the OBD II training manual for illustrations and explanation of system operation.
3. Perform test modules/component activation of secondary air system located in the "Service Functions" section using DIS/MoDiC.
4. Check operation of secondary air pump using instructions provided in DIS/MoDiC.
5. If pump is not operating correctly check air pump relay. For vehicles with M52 engine a modified relay was introduced into production P/N 12 63 1 742 690.
6. If the relay is operating correctly and the electrical connections/wiring to the pump are OK, check the condition of the pump.
7. If the air pump is seized it must be replaced.
Important note :If the pump is seized as a result of moisture (water in pump), an improperly operating non-return valve is the cause. The non-return valve may stick open and allow exhaust gases to condense within the air pump housing leading to a failure of the pump.
Non-return valve sealing / leakage check:
The non-return valve must be checked as follows any time a seized secondary air pump has been replaced due to moisture.
Disconnect the air pump feed line/hose at the non-return valve (line from the secondary air pump to the non-return valve).
Visually inspect the non-return valve fitting internally for carbon type contamination. (Twisting the corner of a clean shop rag into the valve fitting as shown will assist with this check.)
If no carbon type deposits are found on the rag, this indicates that the non-return valve is sealing correctly and does not need to be replaced.
If carbon type deposits are found on the rag, the non-return valve is not sealing correctly and must be replaced.
Note :A non-return valve which is not sealing correctly will cause damage to the secondary air pump as described above.
8. Check also for cracked vacuum lines going to the non-return valve.
-- For vehicles with M44 engine the vacuum line P/N 11 73 7 501 180 going to the non-return valve has been improved since 11/98.
-- For E46 323i/iA and 328i/iA vehicles produced 4/98 - 7/98 see S.I. number 12 04 98 regarding the vacuum hose to the secondary air non-return valve service action.
Thanks for the info
if you ever finds any DIY diagram or photos of the air pump or relay, I would appreciated.
I really don't know if these loopholes have been corrected or not. I'm just so used to being on alert with titles from New Hampshire and Alabama that I remain on high alert when I come across one.
Didn't mean to alarm you! Best thing for you might be something like
Auto Check
