Toyota Prius Software Problems
It's a little bit like the aerospace industry. In 1994 a Boeing 737 suddenly turned over on its back and crashed straight into the ground for no reason. Everybody was puzzled what had happened. Finally it turned out that all 737s had a design flaw related to the rudder. The 737 came into service in 1967, and every day thousands of 737s are taking off and landing safely, so it is very weird that the flaw went unnoticed for all those years. Still it did. But finally, when all the external conditions were met, the accident happened.
I am also very interested in learning that answer, as well, particularly after reading no less less than 15 pages, at the National HighwayTransportation Safety Board site (NHTSB) devoted to complaints, defect investigations, and service bulletins, on the 2004 Prius.
The problems cited did not appear to be trivial and let's face it, repair costs are only part of the dilemma the owner has to deal with when malfunction happens--and often at the most inopportune times.
While it is impossible for a consumer to dodge all the problematic auto "bullets" out there, it is outrageous for a manufacturer to remain silent/not respond to consumer complaints on cars that have been out in the market for close to eight years now.
Welcome to the forum. At least the Service people were honest about the occurrence of the problem. Many act like it is a fluke and have never seen it happen before. Did the car quit or just all the Warning lights came on? Did you buy the extended warranty? How do you like the car? Would you buy another one? Good luck with getting an answer. I am sure that Toyota is aware and working on it. It does not hurt to make the NHTSA aware of the issue.
The dealer mentioned there might be water in the gas. Sounds unlikely after everything that I've read here. I'll give them this website. Thanks. It's really scary when your car just dies in the middle of the road. I couldn't even push it out of the way until I managed to get it into neutral. It's a really neat car, but if you can't rely on it, it's not worth much.
Anyhow, thanks for the advice.
If not software, then maybe faulty inputs due to moisture (hood seal). Or perhaps due to the pine pollen that coats everything like a green dust this time of year in North Carolina: I wonder if it is conductive? :sick:
namely, a stuck "Climate" button may be all that is causing the "Screen Failure" and "A/C not connected" as described in my posting in 76 and that of eprupis (68)
John does not describe any fix other than unsticking a Climate button. Since it's happened a few times to me, I think I'll try to clean around the button and lubricate with a litte wd40 or dry-silicone drawer-glide lubricant to try to prevent the button from sticking in the depressed (down)_position.
For those interested in parts prices, apparently the touch screen new costs around $2K and a remanufactured one costs around $400 if you were paying for it yourself.
If you have access to it, the TSB is EL002-05 "Multi-Display Functions are Inoperative"
Warrantee time to replace the display is .2 hours so it's not a biggie.
I'd post a link to the TSB but it would be deleted. However, if you search around you can find it posted a number of places.
NOTE FOR THE HOST: Would posting a link to a toyota website violate the Edmunds link policy? (of course, he may have been thinking of posting to a different forum).
So we don't derail this discussion - please don't respond to this message about policies or the Membership Agreement. If you want to discuss it, email me.
I bet you now have a new feature too.
See if the Info button on the Steering wheel doesn't now toggle between the two Info screens.
On the Pre-TSB screens it didn't, but on the Post-TSB screens it seems to.
I was driving on a Freeway (not fast just about 50mph) and all of a sudden all the warning lights came on (red exclamation mark in a triangle , engine failure with exclamation mark, another exclamation mark in a circle and some other scary signs). I immediately pulled over on the shoulder of the highway, and stopped the car. There was also only one bar left for the battery( again in scary red color).I checked the owner's manual to make sense out of those signs and it said "DO NOT drive and contact your Toyota Dealer immediately", so I did. The car was towed to the Toyota dealer and the Dealer had it for a day. The dealer had it checked and told me that the software needed to be upgraded. He told me that Toyota was aware of the problem and the upgrade was already out. I think It is a very serious problem. Now I was searching on the internet for more information on this Prius software problem, I found that there are many incidents of this type where all of a sudden the software crashes.
Thanks for the information about NHTSA, I already reported the problem.
Yes, but the Audi 20 years ago didn't have a computer program transferring power directly from an electric motor to the wheels. I suppose that (in theory) modern throttle-by-wire systems could also be subject to this kind of software problem, but those are far simpler systems - turn on the power, turn off the power. The Prius computer has to merge the two power sources together - much more difficult and complex. Complexity leads to more potential programming errors.
I'm not saying this was a programming error - it could be mechanical - but it is possible.
Of course, the likelyhood of someone finding out how the Prius is programmed is remote, but I doubt that Toyota put in any protections against virus programs...
Highly unlikely, but an interesting if troubling concept...
Given all these "upgrade" problems, Toyota should implement a simple and well known Software SCM process targeting its customers.
It should identify software version on Prius screen so owners know when to upgrade. Toyota should announce upgrade to dealership or direct mail to owners so people know to go in for upgrade.
Trying to hide software problems never works and will only hurt customers. If Toyota is doing this to avoid litigation (by not admitting anything) or control cost, it will eventually end up with a big class action anyway and have its thus-far stellar reputation drag through the mud.
I think Toyota does not yet realize hybrid system relies on what is called "MISSION CRITICAL SOFTWARE SYSTEM". This sometimes means if it fails its mission, people die. There is no way to hide and to shirk responsibility in such system. Toyota, just like it learnt from Chrysler about how to make minivan, should learn from Boeing or Lockheed or Airbus or NASA on how to produce, manage and maintain mission critical software.
I am now nervously waiting for our new Prius.
In mission critical application, such as flight system, everything has a back-up. When the fly-by-wire system fails, there is normally something mechanical that serves as back-up. The 747's have up to 5 main systems on-board backing up each other and 20+ for everything. In the end, the pilot can still fly the aircraft by hand if necessary under "flight control jammed" conditions.
May be hybrid auto manufacturers should consider such a back-up.
Yes, but it has mechanical flight linkage controls. Newer airliners have all electronic controls ("fly by wire"), and if the computer goes, and the backups go, you'd better hope you have a parachute, because that plane is not staying in the sky.
The Prius is also all software controls.
Great news! Can you please provide a URL so that we can all see the study that was done, and examine the methodology?
I'm surprised to find that Toyota doesn't include a software version number on the screen at startup...
http://www.f-secure.com/weblog/
Your article confirmed my fears: I noticed that the Prius did respond to cell phone commands at one point (to reject them), which means that the software is open to manipulation by someone simulating a cell phone attempting to synchronize.
As I said in my original post, it is not likely to be a big problem, since it would require in depth knowledge of how the Prius computer is programmed. That is Toyota "inside" information.
In any case, I don't think hackers are into this kind of thing - too few cars to make it worth their time. So it is not worth worrying about...
http://www.thecarconnection.com/Industry/Daily_Edition/Daily_Edition_May_16_2005.S173.A862- - - - 4.html
"Are Priuses Stalling Out?
The National Highway Traffic Safety Administration (NHTSA) has not launched a formal investigation yet, but it is compiling complaints from Toyota Prius owners that the cars can stall or shut down while on the road. The agency has logged 13 reports in which 2004 Priuses have shut down at highway or slower driving speeds; a TCC staffer's personal car experienced the problem late last year. ....."
http://www-odi.nhtsa.dot.gov/ivoq/
Toyota Attributes Prius Shutdowns To Software Glitch
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I just found out about this Forum in an article in the Wall Street Journal entiteled "Toyota Attributes Prius Shutdowns to Software Glitch". The article describes incidences exactly like what occured to me, and you; driving home from work my Prius came to a halt, and I stopped and started it numerous times until I finally creeped home (luckily, I was only a few miles from home). All the dash lights went on during this incident. I had also had two prior incidences where the car was dead in the morning and needed towed. I have had the care for 9 months and it has been in the dealership at least 5 times for this. I am getting the runaround from the dealer, and no one seems to have any technical expertise. I am going to report this to nhtsa, but I have lost confidence in the car. I want to return it. Does anyone know what legal recourse we have?
Your best legal recourse should start with documenting your concerns by writing a letter to the manufacturer. Send it via Certified mail, Return Receipt Requested. Here are two possible addresses:
Toyota Motor Corporation
25 Atlantic Avenue
Erlanger, KY 41018-3188
19001 South Western Avenue
Dept. WC 11
Torrance, CA 90509-2991
Does anyone know how to reset the software/computer in the Prius in case of lockup? I'll let her know about the software issue but would also like to be able to show her how to get the car running again if it does happen.
Does anyone know?
Thanks for your consideration,
Jeannine Fallon
Corporate Communications
Edmunds.com
Although I would love that 2 second of fame in a magazine, the truth is we still do intend to purchase our Prius which is on order and should arrive in 1 week. We are even looking at the Highlander Hybrid now.
If the Prius is experiencing a failure rate the same as that of a certain domestic manufacturer's minivan (1995-1996), I would cancel the deal. Thankfully, that is simply not the case. As a long time buyer of domestic cars (Dodge Charger, Chevy trucks, Mercury and Ford cars, trucks and vans), we are recent convert to Toyota (Sienna van) and have had no regrets after 100K miles.
Yes, we are still looking forward to joining the Prius "generation" and will remain prudently optimistic that Toyota will take care of its customers before something really tragic happens.
Toyota:
A) stands by their cars and
has sold a few hundred thousand of these cars since 1997, so the "software failure rate" is about as low as it can reasonably get, considering the complexity of the hardware on board.....
Good Luck !!!
It's obvious this isn't that frequent of an occurance but does seem to happen enough that until she gets the software upgraded, I want her to have a way to get going.
It's also my opinion that every Prius owner needs to be made aware that they could suddenly lose power just so they could be prepared and not be caught totally off guard.
So the question stands - anyone know how to reset a Prius?
That is a good question. I was corrected in my thinking that it is a computer reset that is done by Toyota service techs. It is a software reload that is done. Making it nearly impossible for the car owner to do anything but return the car to the dealer.
