My friend has the 2005 6.0L PS, and says it's a dog compared to the 7.3 liter diesel they had in the older models, so you made a good choice. He tells me his next truck is without a doubt going to be a V-10.
Thanks, David
I was wondering if anyone has converted to veggie oil yet, I am thinking I might. I was also wondering what chip works the best to improves millage.
By the way for all you ford owners out there I average 22.5 on a flat surface driving 58. In town I average 16. I drive alot in the summer with the truck and on 300 mile trip I average 20-21 with out a chip. I have been told that the 6.4 has plastic injectors and the 6.0 block cracks around 130K; my cousin works at a ford dealer. I know alot of people where I live have kept the 7.3 because the 6.0 is [non-permissible content removed]. If I where to buy a new truck I would get a Dodge, But I love mine to much to ever get rid of it.
ANY HELP WITH THIS PROBLEM????????? :mad: :confuse: :sick:
The computer says it is overtermp. exhaust temp. module. was changed then got 35 miles down the road and it quit. The days of the mechanic is long gone all they have now is parts changers. Whatever the computer says is the problem!!!!!!!!BS to that. :mad: :lemon:
I'm currently RV'g throughout Washington, Idaho, British Columbia.
While our Lariat is a great truck in most respects, it's a PIG when it comes to economy ---------- averaging less than 8MPG with a 10,000lb 5th, while trying to do everything to "go easy" on fuel economy. 80PSI in tires, easy starts, 55MPH, TowHaul on where needed, etc.
My brother (after 9 new F350 Diesels in the past 10 years) is trying Dodge's "equivalent" with the 6.7 Cummins. He consistently gets 40>50% better economy on the same trip. BUMMER!
RUDY
Very concerned F-250 owner
I was wondering if maybe the computer has more fuel going into the #8 piston which causes the firing of the diesel fuel to wear a hole in the piston.
I have been driving fords for years but now I am begining to think about changing over to something else.
Also was told that the radiator was the cause of the engine blown, said they had a hole in the factory seam of the radiator. Talked with the service manager, he said they were not any fluid in the radiator. But the gauge didn't show hot neither did the smell of antifreeze show up at anytime. They put a rebuilt engine and a new radiator in the truck. He said the coolant does not get to the back of the engine and that since it is tucked up under the firewall that it why the #8 piston area gets the hottest and burns a hole in the piston. Will wait 13 to 14,000 more miles and see if it does it again.
I cannot find the plug in under the dash but I found the ones out under the hood.
There are 2 plugs that plug into the brake box but cannot find the one for the switches.
Help.........
'' What is the issue?''
''Your vehicle may exhibit drivability concerns, including elevated idle during DPF regeneration,minor cruise control speed fluctuation,automatic transmission shift quality (if equipped) and a false check engine indicator light.''
I thought the cruise control fluctuation was caused by a lack of power. It doesn't flucuate until you hit a hill. Maybe, hopefully they will turn the power up closer to what they said it is supposed to have. I have a Ford Performance Trucks magazine that dynoed the 08 F250 and showed a stock 292hp. and 286lb-ft torque. That is a far cry from 350hp and 650lb-ft they advertised. By comparison the old 7.3 liter powerstroke showed 184hp and 388lb-ft. It takes a heavy load to affect the cruise on it. This should not be!
