Best Regards,
Shipo
Hmmm, I'm pretty sure you wrote:
"I was set on getting 335xi or 330xi..." and that you said nothing about considering a 328xi. Did I miss something?
Best Regards,
Shipo
I'm in Southern Cal. I tend to drive reasonably sanely, but I do enjoy feeling the excellent handling of the car. That is why I am getting a 3 Series. I'll put on mostly freeway and highway miles, with some canyon carving thrown in for fun. Are the "new crop" of RE050 RFTs on the zsp cars lasting anywhere near 30K miles in this kind of driving?
If not, I am wondering if, for this short term and reasonably short number of miles, it is worth dealing with the hassle of removing the RFTs after 8K to 10K miles, installing GFTs, storing the RFTs for lease return, and rigging some kind of spare, compressor, etc. I'd probably only have one set of GFTs that might not be worn out when lease return time comes. Maybe in this specific situation, it might make more sense to just replace the RFTs with another set when they wear out, assuming I can find a set (my tire dealer has them back ordered for months already).
Any thoughts? Thanks.
So, that means that you're going to have to buy a set of tires somewhere along the line. Your two options are to wear the first set out and have a second set of RFTs mounted, or to buy a set of GFTs at about the 10,000 mile mark, store the RFTs, and then have them remounted just before you return the car.
The benefit for buying a second set of RFTs when the time comes is that you don't have to mess with storing the tires and don't have to pay for two sets of tires to be mounted. The benefit for buying a set of GFTs is that you'll likely find that they ride and handle better, you'll save as much as $500 on the tires themselves, which will easily cover the cost of having the factory tires remounted before turning the car back in.
Best Regards,
Shipo
Thanks for your thoughts, Shipo. Somehow I knew that you'd answer back quickly.
Regards and thanks for your years of good advice. Boomer.
I was looking at tire rack and found the ContiProContact Run Flats in the following size 225/45HR17 I believe these fit the specs of the 328i with the sports package and should fit the OE rims. Is this correct? Any experience?
Best Regards,
Shipo
Specific questions.
First, I will be getting the Contis as they are on the 08 328 xi Touring. Seems this should be fine for the local driving this car will see, and a improvement over the EL 42 that are on the 07. Yes?
Seems conflicting reports from earliet versus later. Is the ride with Sport package better or worse using the RFT's? Did this change as the tires were altered?
I will need real winter tires. I can get factory rims and Blizzak RFTs on special promo. (Still ridiculously expensive) I think but can't confirm that the 08 uses the internal sensor so I can't just use any rim. Correct?
Big question here is how compliant the Blizzaks are. Our local residential streets are rutted and ice covered 5 months of the year. Think gravel road to the cottage for comparable bumpy ride. If the winter RFT's are still very stiff I will run 16's with regular winters. This is a new car principally for my wife and she won't be happy with her teeth rattling. She is quite happy driving my 04 WRX in the same conditions if that helps for reference.
Any replies or ad-hoc comments appreciated.
Clearly there are issues around tire life, noise, reliability.
My question is: how do these tires perform in terms of over all handling--cornering, straight ahead tracking, etc? Sorry if I missed one of the many good emails that addressed this.
Thanks much.
I have heard that some others have had this same problem. One link that came up for me was http://www.bmwtirenoise.com
Apparently this is a large problem and it occurs at the 10,000 mile mark
Hopefully you can garner some information from that site as well.
I have heard that some others have had this same problem with the BMW tires making weird noises, often after 10,000 km.
One link that came up for me was when I was researching it was www.bmwtirenoise.com
Is the ZHP,when equipped with the Michelin Pilot Sport,the only 3 series not equipped with run flats ?
Nope, not buying. Unless there is a complete ground-up reengeneering of the product and unless the new version of the truth is rim compatible with GFT technology (i.e. NOT the lame Michelin PAX system), I seriously doubt that RFTs are a foregone conclusion.
Best Regards,
Shipo
This is good advice provided you live near a place that can do the actual work and that you don't work or travel far from a place that can actually change a RFT.
The RFT's were a total deal killer for me. I would have bought BMW but not a chance on RFT's and to make it worse they eliminated the storage in the car for the tire. A bungee cord in my trunk is old school. If I was going to use bungee cords I'd have no issues with GFT's. most are designed far better than GFT's which all the problems surrounding them should tell people they are not ready for prime time.
OW
No spare...no dipstick...no oil changes for 15K...no temp gauges....just bluetooth link, premium fuel and a flashlight!
No pain, no gain. This is life at the bleeding edge!
OW
I've driven many miles out here involving Nevada, Eastern CA & OR and a number of other places where finding tire repair of ANY KIND WHATSOEVER is marginal in the daylight and impossible otherwise. I prefer non-Interstate roads because I love to drive (as opposed to travel), so I end up in places those of you east of the Mississippi probably only read (& have nightmares) about.
I need four full-size real tires at all times when I'm doing a road trip. Doing road trips is the only possible excuse I've got for owning a car that actually performs, so compromising there defeats the whole purpose. I've carried a spare for many, many miles over the past 35 years and have needed it much less frequently over that past decade or so. That said, I had a flat on one of my favorite NW Nevada backroads a few years ago & stuck on my (full-size) spare with no further thought. I was home in AZ late the next day & got the tire fixed the following week, amongst going to work & back every day. It was a total non-event.
With RFT, that trip would have been a royal nightmare, and expensive to boot. This whole RFT debacle, along with the dipstick thing, has moved me from a "I'm getting a BMW next time" person to, "well what are the alternatives?" I can't get just what I want, so if I have to compromise, why not go for an appliance?
Especially if the appliance has real tires, a dipstick, and no history of overheating its oil.
It seems ridiculous that when you purchase a car for over forty thousand dollars you still have to go out and buy a spare and jack just to be secure on a long cross country trip. Sorry BMW, but until you at give us the option of go-flat-tires or at least the choice of paying extra for them and a spare tire, I will not purchase another BMW. I'm sure there are thousands of other old guys and gals and probably many young ones who feel the same way.
By the way, put in a dip stick!
We are working on steel tires and no-entry engine bays for no-maintenance care-free ease of ownership. This includes a 200K miles end to end warranty with absolutely no maintenance necessary during your ownership term.
OW
Dude. Dude. You are out of control! Someone think of the children!
P.S. Also "lifetime" lubricants in the transmission and differential
I have a 328i with SP, and the tires tramline, have bump steer, and have other poor steering characteristics. Since on the test drive I preferred the non-SP steering, I may install 16x7 wheels or the 17x7 wheels from the 1-series. But I'm planning to change to go-flats at the earliest reasonable opportunity.
OW
What percentage of 3's are sold in North America vs. Europe? I'm thinking the relatively urban-centric (I just made it up) mindset of the Germans may be at the root of a lot of this.
Very interesting, I would not have guessed this.
I had an '06 330Xi, and even after replacing the OEM Bridgestones with the Continentals, the car was still too harsh for me over the roads I drive. I gave up and traded it in on a 535Xi, which is much smoother over the same roads.
Bruce
The Conti RFT's are a vast improvement over the B/S and I have 17K on them now. With the old B/S EL42, at 10K the road noise was high and uneven tread wear was abnormal.
The '06 330xi suspension is tuned more aggressively, IMO. I concur with the difference from the standard '06 330i and '07 335i I drove which proved to be softer than my car.
Best Holiday wishes and a Happy New Year!
OW
Although I really liked the looks of the optional 18" wheels and tires that were available (on top of the sports package), I declined to order those because they included RFTs and I was gun shy of both RFTs and extra low profile tires.
Instead, I stayed with the standard 17" wheels and all season tires (it came with Goodyear RS-As). One difference from my '06 330Xi is the standard a/s tires on the 535Xi have a higher speed rating and the car has a higher top speed than my 330Xi with it's standard a/s tires.
We've had one bad weather day so far, a combination of snow and ice, and the 535Xi was great.
Getting back to the 3 series, that is good news if BMW has tamed some of the harshness in the 335Xi compared to the '06 330Xi. Firm is fine, harshness is horrid.
MC and HNY,
Bruce
I have been reading these boards (and others) since before runflats were introduced. I've read a lot of posts from people that switched from RFT to GFT, but I've never read that.
I could be wrong, so.... source please?
Best Regards,
Shipo
I purchased 2 front tires (225/45HR-17) and 2 rear tires (245/45HR-17) for my 328i SP from Tire Rack and had them installed at a local Goodyear tire center.
The installation took about 2 hours and the total cost of tires/shipping/labor was about $900. The tires are all season and handle very well in the rain/snow.
Only issue I have had was when I parked on snow with ice hidden underneath but that's not so much a tire issue as it is a 328i and not xi.
All in all this setup works great in almost any condition (I live in New England). I followed advice from both Tire Rack and my BMW service advisor.
