I have a 98 S-10 2.2L with 199K+, and I've had the dreaded oil-drip for quite some time. I know that it's getting worse and it looks to be the rear main. (Dramatic pause)
I've packed my lunch and told everyone not to bother me for the weekend. It appears to be major surgery here. I was hoping that someone had some tips and tricks on making the process a little smoother.
Thanks for the help.
-Pete
-Pete
Distributorless ignition. Developed a clattering in the engine that sounds like it is coming from the valve train area. This has been going on for months and it is getting louder, now there is a vibration accompanying the noise. The engine has excellent oil pressure, runs cool and has new plugs and wires. While at idle the noise is minimal but increases when RPM is at 2000 and above. Has anyone had this similar problem? I have tried using high test gasoline, injector cleaner besides the new plugs and wires. Any advise would be appreciated.
Doc
belt, no change. The whine varies opposite load (ie quieter with acceleration). We had a
warm day during a cold week and the noise started for the first time. It went away again
with the cold. Sounds like one of those toy cars where you rip the cord to start a wheel
spinning then launch the car on the ground. Any thoughts on the source of this? I love this truck.
What I did to it:
Right away i had to fix a bad oil leak, changed the plugs and had to replace the water pump, it was backfiring out of the carb-fixed that, the linkage was all messed up so you had to jam it into park-fixed that, the previous owner had a lifetime warranty on a muffler from 91, so i had him sign that over to me, so that was free to replace. All in all i dropped about $300 into it.
My questions are:
I have quite a rough idle, im going to replace the distributor cap and plug wires here shortly, any other suggestions to help smooth that out?
My drivers side door window keeps braking the clip that holds it from falling forward, i've changed it numerous times, it will work for about a week, then it will just break again... and its pissing me off, what can I do?
Basically the only spot that is rusted through is a corner of the drivers floor panel, exsposing the carpet ans such. What can I do to patch that up?
As it is about to shift into third gear, it will make a odd sort of over revving noise, but it appears to only do it when it is about to shift into third, any ideas?
Only when at speed and trying to maintain, my engine stutters. A computer check says that #2 and #3 are misfiring. I've recently had a new fuel pump installed, new plugs and wires, a new #2/#3 ignition coil and had the injectors all professionally cleaned (not just fuel additives). My regular mechanic is stumped and I can't afford to give my truck over to a dealership for several days of diagnosing right now.
The stuttering does not occur at idle, acceleration or deceleration. It even stutters while on cruise, but not nearly as much. It seems that the instant you release pressure on the gas peddle (while maintaining speed, or during shifting) is when it seems to occur.
Any one have some ideas?
Second, if i "pump" my gas at all while driving at slow speeds in reverse it will act like it wants to stall out, and sometimes it will. Could this be a fuel filter issue? because that brings me to my next question, how do I change that?
My truck seems to be running very hot, coolant levels are good, oil levels are good, and my radiator is only like 2 years old. Even my hood will be to hot to touch sometimes.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Every time this happens, I install a new ignition module and everything is fine for another few months. This is a problem of the last two years or so, before it was perfect. I have replaced 4 modules in the last 18 months.
The plugs are relatively new, the wires the same. Have run the truck at night with the hood up, don't see any sparks or lights. The ignition module connectors have been cleaned and lubricated, they are tight when installed. The proper grease is used under the module, it is tightened evenly and snugly, but not overtightened.
Does anyone have a similar experience or see something I am missing?
No, I have not been using GM modules, although the last one was a standard, which was known as a good brand in the past. I will try a GM ($$) module.
Steve
Your symptoms sound just the reverse of most problematic engines. My experience with faulty primary or secondary ignition components have been that it acts up the most under load. Same with dirty fuel injector. Ordinarily though, when you have those types of problems, it smooths out to some degree when you let up on the gas.
Is it possible it’s got a faulty fuel pressure regulator?
Keep the faith.
