Pontiac Grand Am Maintenance & Repair
Hi, I'm new here but I really need some help. I have a 1993 Grand Am V6 3.3. It started misfiring.. slowly progressed and now does not start. Replaced Ignition Module it ran (out of time) for about 5 minutes, replaced that ignition module, ran a diagnostics at chev. dealership came up crank sensor, I replaced that, does not run at all. I'm a broke college kid!! Tryin to fix it myself I can build things from the ground up but this problem is beyond me. Does anyone have any ideas ??
I have a 1999 Grand Am. Just yesterday, the blower control stopped working. It doesn't blow on the two lowest speeds. Works fine on the highest three speeds. It's the same, whether I have the AC switch on or off. Any advice would be appreciated.
Bob
It is located under the passenger dash area near the floor.
I had to work upside down to get to it as it is right ontop of the floor. very little space to move around.
Not a big problem at all to fix. the smaller your hands the easier it is to get to.
total time of 3hrs with nothing more than a socket wrench and a screw driver and some jack stands.(tank almost empty)
Much better than going to the dealer who wants $500 to fix this kind of problem
2nd thing we noticed when we opened the hood was there was a watery oily mixture lightly covering everything under the hood, then we looked to the left and there was fluid that gathered right under the front left tire.
Does anyone know what this could be? I know its some sort of oil leak and I know it's hard to tell where exactly it's coming from without having it psychically in front of you. Will this cost a lot to get fixed?
Thanks a lot for any help...
That watery oily mixture all over everything under the hood was probably sprayed on by the dealer to make it look good, that's very common on used cars at dealers, and in my opinion is stupid, but so be it.
That fluid under the left front tire would be my concern, but what is it? Oil? Coolant? Transmission fluid? Or just water left over from a wash?
Also, what's the mileage? That should be the #1 factor in determining the condition if the maintenance history isn't known.
Having owned a 95 (still own it technically), a 99 (relieved of that one by someone futzing with their cell phone), and currently an 04GT, my experience has been that these are inexpensive basically reliable cars, not trouble free by any means, as long as they're maintained well.
I asked other mechanics and seems to be truth about reset.
It is hard to believe about the ignition switch because I'm smelling gas which is not normal. Another thing is that when the car is not starting and I have to wait and then to try start it over and over, looks to me like is not providing gas. Is someone who gave you an better idea?
Please, let me know.
Also, Listen for the whinning sound of the fuel pump when you turn the ignition to the "on"(not run/start) postion.
You should hear a good pump fairly easy from the driver's seat. the pump is in the gas tank behind the back seats.
I just did mine for $60-, but you may be better going easier for $115
B
Like many of you we have trouble with our security light coming on randomly and then we have to wait 10 minutes before it will start again! We have been doing a lo">t of research and trying to figure out a cheaper solution than the dealer gave us of $400 and no garentee fix!
We noticed this started close to the time we replaced our battery in the car. My husband could not find the exact reccomended battery in the manual so got the closest one he could find! We noticed that when we have the air off, radio off and so on we hardly have problems with it, BUT if we have any of those on we often have trouble with security light! Could this be connected to the battery? Has anyone heard of this?!
If there a for sure way to fix this?! How about installing a remotw :confuse: start - doesn't that override the passlock system! HELP! We did have a guy look at it, a local mechanic, after hours and he hooked it up to read the codes and said it said the "passlock system was invalid" he reset the computer. For out a month and half - no issues. Now we are starting to have issues again!
I have the same exact problem with a recently-purchased 99 se 2.4. Any luck with this?
The symptoms your having are pretty normal, at first only occasional problems then steadily getting worse.
Another poster here a while back came up with a way of disconnecting it but I haven't tried it myself so can't recommend it.
I commented about this to another person with the same problem recently - do you tend to have alot of weight hanging on your keyring? I read a GM tecklink article recently that commented about this being a possible reason for premature switch failure, the weight puts stress on the lock cylinder and causes the contacts in the switch to wear out.
The front blinker works but is twice as fast as it should be(but normal speed with hazard lights), and the rear one doesnt work at all. I have already checked my bulbs and even replaced them for good measure. I also had a look at the fuses and they check out ok. im not sure what to do now. I read something about a flasher in the forums but the person at autozone doesnt think that is the problem.
If anyone has any suggestions or has fried their car in a simmilar fashion i would greatly appreciate your feedback!
