They also will be facing liabilty suits for every accident in a 2007 v6 Camry and unspecified punitive damages which could reach astronomical proportions.
The NHTSA is now investigating toyota.
Toyota is like a sinking ship. The result will likely be a 50 plus percent loss of U.S. auto sales.
They deserve what they're going to get.
No, all Toyota needs to do is install the engine/transaxle ECU control firmware from the Camry version just prior (2002??) to adopting DBW. You might then experience premature transaxle failure prior to 100k miles but at least the transaxle will always be reasonably, MORE, responsive when you hit the GO pedal.
And if you browse around the internet, or even just here at Edmunds, you will discover that almost all marques with FWD products are going through the very same evolutionary phase in order to make FWD's just as safe as their RWD counterparts while still maintaining the FWD advantage of additional "GO" traction.
Insofar as I know only Ford has come up with a reasonable solution. The new Ford Edge has a variable displacement ATF pump so pumping volume at idle can be HIGH but non-wasteful at high engine RPM by running at low volume. Ford also seems to have the "edge" with FWD hydrids given the US patent that was granted them regarding same.
The patented techniques involve significantly reducing the level of regenerative braking available if the OAT is near, at, or below freezing, and INSTANTLY disabling regenerative braking altogether if ABS activates during actual braking.
"bashing" the '07 camry....that will probably get you an e-mail from the host.
The above is just a polite way of saying what I said.
1. The breaks: It’s making a weird noise, like something is stuck in it. Even when I brake softly.
2. The air filter. It goes off a lot, especially when I go from Auto to a lower fan speed.
3. Gas: It is averaging 20.4 miles per gallon. Also, it all the sites that I’ve gone, the tank seems to be 18.5 gallons capacity. Mine gets 15.5. The sticker on the car said 24/33. Even on the government website, fueleconomy.gov; the revised mileage for it is 24.5 mpg.
4. The defogger. It doesn’t work very well, even if the fan is all the way up, it takes a long time to start clearing the back window.
5. It seems not aligned; the car goes to the left or to the right super fast.
6. The car stalls or idles completely if I drive in low speed (up to 40), instead of doing it gradually.
7. The wind-noise is very high. It seems like a window is open.
8. In 2 occasions it hesitated to start.
9. It is starting to have stronger vibrations when I’m in a red light or I stop the car. I expected that in years to come, not with less than 3, 000 miles.
10. I’m starting to feel a little overheating where the pedals are. Even if I put the AC down there.
11. In the back passenger door, down in the middle is always leaks a rusty liquid and leaves a mark on it. I can be easily be wiped down but I was wondering why it does it.
I know these are little minor things, but I want to make sure I don’t want to know if someone else has experienced similar situations with the Camry XLE 2007.
Do your own research about the lemon law where you live. If you have a strong case you can win in Arbitration without paying upfront money. Good Luck
#1. There are two Technical Service Bulletins (TSBs) regarding a front brake and rear brake squeek. (BR008-06 and BR010-06)
#5. There is a TSB related to the alignment pulling to one side. (ST005-01)
#6 & #9. I think these are related to TSB ED036-06 "Fuel in Evap System (Revised)"
#11. This may be related to TSB BO005-07 "Water Leak at Headliner or Floor Area (Revised)".
I have heard you can find these TSBs online for free. I subscribed to www.tundrasolutions.com. I pay a yearly fee and get access to all TSBs for all Toyotas and Lexus.
- My car pulls left all the time. I noticed this when my arm got tired trying to keep the car on the center all the time.
- The best mileage I had so far is 23mpg with 80% highway driving. I have 3700km on my car. I kept all the receipts from gas stations. 23mpg is the average of all so far. 24/33mpg does not seem to be right !!!
- When I stop on the lights the car hesitates to accelerate when I try to move it again. It uses the highest gear but the car does not take it and shakes. This is when the transmission is at D.
- At high speed, transmission again does not respond. It put me in very dangerous situations a few times when I was trying to merge in to the highway.
I am not going to be surprised if I see more problems. I wish I could read all the reviews before I bought this car. I just relied on my years of experience with my old Toyotas.
Toyota will probably correct some of the defects on camry after all these complaints. Then we will be debuggers who payed the full price to own this junk car.
And keep in mind that engineers designing FWD automatic "transaxles" vs RWD automatic transmissions have a lot less space to work with. I keep wondering just how they have managed to fit a 3.5L V6, torque converter, diff'l, and a six speed automatic into the available "sideways" space.
for approvel. The modern day transmission dose alot more then just shift a few gears to move the car. Hang in there Toyota did not get this big by hanging customers out to dry don't worry thay will get it fixed.
.............or your one year period for claiming :lemon: is up.......or your warranty runs out. Either way you lose :sick:
out of the wrapper, a certain number of vehicles are hesitating or shifting excessively or vaguely, and a few have had uncontrolled acceleration events.
this isn't customer abuse. this is engineering which is suffering from part / manufacturing quality, or lack of software quality assurance or design robustness, or similar.
they are trying to patch a HW problem with SW, and in the meantime, they are giving customers a ride that is anything but "moving forward".
that is all a potential customer really needs to know. :lemon:
is this an integrated multi-functional display including seatbelt warn light, clock, outside temp (LE/SE), and on the higher trim (XLE), fuel economy and stuff like that?
if so, i suspect the module or wiring to same is defective and may need to be replaced.
then again, does this have some form of steering wheel control switch? possibly, it is a clock-spring problem in the steering wheel, a device that maintains continuity in various circuits as the wheel is turned from one extent to another.
anyway, you'd expect that the dealer should be able to call the manufacturer and they should be able to tell them exactly what is likely to cause all the behaviors you are describing.
Doesn't make any difference to the owner, though, if it is not working right, it's not working right.
650spx, it seems that many here have a problem. In the real world, what percent of Camrys do you see come through the door with these "problems"?
Let me get this straight: you are saying that 95% of the people here with transmission problems in their Camry with a few hundred or few thousand miles have ABUSED their transmissions and CAUSED the problems.?
> It is all in the softwear.Sometimes manufacturers, in seeking that last ounce of gas mileage or emissions created shift schedules and torque converter clutch strategies that were not successful for all drivers in the real world.
This sounds like another excuse. If the transmission doesn't work right, it doesn't work right. Software; smoftware.
>But it takes a very long time to rewight a pcm program alone nevermind the fact then it must pass through the goverment for approvel.
What can you tell me about the process of tweaking an already written program to control the computer? It doesn't take a long time.
did they trace the power from the fuse block to the clock? the clock isn't likely to fade, then come back because of a clock problem, it's more likely a power supply problem to the clock or the clock back-light. it is absurd that they didn't do ANYTHING / any diagnosis.
it's also possible there is an issue with the vehicle's alternator, that possibly it isn't regulating voltage to clamp it from extremes, and a few electrical circuits are going into shutdown to protect themselves. the dealership should be able to test both the alternator and battery for proper operation.
Now as far as you saying a program is easy to fix or rewright. I would assume by your statement you must know how to do this so let it be known.
Imidazol97 is so smart he is going to fix all the trans program problems. So send him your ecm. It is so easy he will do it for almost nothing. All you have to do is remove the ecm box it up and ship it. Oh make sure you put a little automotive knowledge and experience in the box he will need it.
Now I am not saying that these people don't have problems with there cars. I actualy feel bad. I here horror stories about cars just not getting diagnosed or fixed correctly at all.
I look at these boards to see the complaints,repairs,strange quarks,and problems because I am a concerned tech who likes to fix cars right the frist time. Also being very technical reading these boards sometimes help me explain the way a system on a car works in a way a customer can understand.
I also think that Camry (and all Toyotas) quality has slipped slightly since 2000, but then again other makes that are also high in quality have had similar issues, because all manufactures are trying to cut costs. I base my opinion on the fact that we had a few rattles and squeaks that had to be fixed under warranty. By the way, the problems were not at all major, and the TSB's applied by the dealer completely fixed the rattles and squeaks.
But there is one manufacturer that has by far more cash than any other and that is Toyota. And they have admitted that they are going to re-focus on quality, so my opinion is that Toyota will remain at the top, because they admitted the problems and because they have the finances to fix them.
My '07 Camry still has zero problems, and I bought it knowing that there could be a few minor issues. That is why I follow these forums. Again, I am glad to have an expert on here to set the record straight.
Has anyone else experienced this problem?
Take them with you on a drive. The main thing is "duplicating" the problem.
Sumnerc posted that with many people experience problems with flares and shift quality and delays that they're not fixing they need to have to recall Camrys. #3779
650xpx replies that 95% of those who have problems have them because they're abused their transmissions. #3799
Imidazol97 responds that that is not true. I respond to 650xpx's statement that "seeking that last ounce of gas mileage or emissions created shift schedules and torque converter clutch strategies that were not successful for all drivers in the real world." (which is an understatement!) that it's not just the software. It's under=engineering of the transmission. #3807
650xpx responds that he's seen two trannies torn up at 700 miles (underengineered for motor size sounds like the problem) and that is all proof that 95% of problems are customer-caused problems. And you in a very smart manner suggest everyone send me their PROMS for programming. #3813
As for programming, that's Toyota's job. The transmissions appear to be insufficiently built to handle the shifts from a safety standpoint (wwest). I probably have been programming a lot longer than you have. I probably tore down auto motors long before you did. So I suggest you have your employer do their job. You mentioned training so tell them when you're back for training. It's Toyota's job.
A Toyota salesman in another discussion stated that the problem has been fixed for a long time and it was all software. If that were the case then the TSBs would be fixing everyone's computer when they reflash the ROM. That's not working by reports here on Edmunds.
650xpx says: "Oh make sure you put a little automotive knowledge and experience in the box he will need it." for imidazol97. Does Toyota offer some of those school courses on politeness for their mechanics?
1.I was wondering how many newer camry or avalon transaxles you have driven,diagnosed,removed,then torn down for inspection and found a internal problem or under engineering of the transmission.
2. I have never wrighten a program for a automobile. I was wondering if you have ever wrighten a program for a asian automobile lets say from the years 2004 to 2007 due to these years are the ones we are talking about.
3.You most likley have torn down a motor before I did. I have been a professional tech for 16 years. But I would most likley think that I have torn down many more motors for many different problems them you have. We also have to rebuild the engines when ever possiable. With the least amount of parts possiable. Anyone can tear one down. It's the reason you tear it down and how it runs when it gose back tegether. I have done about 400 or so how many have you done? For this question any year make or model can count.
4.What kind of car do you drive ?
5.What do you do for work?
6.I have just one more. I was woundering how many automatic transaxles and transmissions you have rebuilt. I have probley done a 150 or so. For this question any year make or model can count.
Thanks very much respond when you can.
I know you like your big Buicks; I like my Camrys. No hesitation, harsh downshifts, squeaks, or rattles, thank you very much. Nothing but oil changes, tire rotations, filter and fluid changes for both (46K on one, 21K on the other). One recall on the older car (no problem found), and no warranty work at all.
Oh yeah, one set of tires on the older one, plus a nasty hit-and-run in L.A. that cost me a $1,000 collision deductible. But we were still able to drive the car back across the country to get it fixed right by a local body shop.
Same here. I thought about that downshift lag today when we went downtown for lunch and I squeaked into a merge ahead instead of behind someone by hitting it and knowing I'd get a quick 2nd gear.
As for the info it doesn't match the imput data that people have been showing up with. Wwest had it diagnosed early in one of the groups here on Edmunds as lag in the ability to supply enough fluid to downshift while aborting an upshift. I believe it was he who mentioned that some other transmissions have variable capacity in the pump systems for just that problem.
You can place however much credibility as you want but when someone says 95% of the people reporting lag and flare caused it themselves by abusing their transmission, that doesn't make sense as Judge Judy would say.
As for the rattles and squeaks my cars have none and one's at 150K. Pretty good for a 98. As for a car for my kid who gets a driver's license in November, I'd pick up a used Camry if I came across one but it would be before the current and the previous design. In fact the 98s are an aethetically pleasing car overall. When I ask people parked next to me how they like their cars, that era always gets a rave review.
I'd still recommend the next generation, which I have now, because you can get side curtain airbags to protect the head. That's why we gave our son the '04 we bought for ourselves originally, and then bought a new '05. (Now we have both back; he's now in NYC where a car is a liability.)
Only problem is finding used Camrys with side airbags is going to be hard. We tried and failed when he needed a car (and looked for other makes as well).
what I said was
The trans it self is not the problem. 95% of the ones I see fail is from customer abuse.
Then the host made it crystal clear what I was saying
I think what he's saying is that it's not the transmissions that fail, it's the software that fails and that if a transmission physically fails, 95% of the time it's from abuse.
You realy need to get your facts stright.
I would still like you to answer my questions. I am sure all the board members would like to see your answers.
He's the tech; he's reporting what he's seen. Give it a rest, please.
Inappropriate transmission behavior in the Avalon at least is evidently far from all software. It's both HW and SW, and in the case of the TSB cited, it's not the Transmission. Go figure!
