My $.02 -Bob
Is it worth to pay $24,500.00 for the 99 Discovery II with 45,000 mileages? The car is in a good shape with all packages that we need. I just do not know if the central differetial is included or not. The sales has been told us that 02 or 03 Discovery II has a lot improvement than 99. We should not trade in 99. Is there any opinion/suggestion for me?
It will be going to the dealer tomorrow and I'm sure it will be taken care of under the warranty - but it makes me wonder for the future. I live in an area that gets some snow (Illinois) but not a great deal and I shouldn't be getting any body corrosion at this point. Aren't all of the doors supposed to be made of aluminum anyway?
Anybody out there have the same problem?
-Bob
A few things the dash/windshield had some sort of wind noise or something loose ? any ideas ?
Passenger seat seemed a little loose, like rocking up and down a little ..
With the pending 2003 released, anyone thing this deal is a bad one ? If we like it might up-grade in 2004 . But for now this one is about 8500.00 less than new with low miles ...
o yeah LR web site i cant find how much the Disco can tow ? im talking a boat here.
opinions appreciated please
DL
Trailers w/o Brakes
1,650 lbs both on and off road
Trailers with Brakes
5,500 lbs on road High Range
2,200 lbs off road High Range
7,700 lbs on road Low Range
2,200 lbs off road Low Range
Max tongue weight
550 Lbs
If I buy an extended warranty from Land Rover do I have to buy it from the dealer that sold me the vehicle or can I just go to any Land Rover Centres? Also, will extended warranty be honor at any Land Rover Centres or only at the place that it was purchase? Another note, my car was purchase at Cadillac dealership is Sacramento, CA. that sales Land Rover. I am debating if I should go back to the dealer in Sacramento or just to my current bay area Land Rover Centres that have been servicing my vehicle for the past 2 1/2 years.
I want to get the best price for the policy.
Thanks in advance
Daniel
yeah carmax deals, they wont budge on price but offered me 2k OVER book on my car..I dont know if im uncomfortable buying from them or not ,they cant tell me where the cars came from, but have ran carfax reports the cars are clean.No Houston flood cars..
Think i would take a soaking if i traded the 2001 in a year or 2 ?
DL
I bought my '96 Disco used, and it turns out (discovered after the fact) that it came from a car rental place! Holy smokes, would I have bought it knowing that? Absolutely not. But these dang Rovers are tough... I had some teething problems but once sorted they've stayed fixed. Absolutely ZERO trouble in 3 years now, with much much hard use. And that was with God-Knows-WHAT kind of break-in and abuse.
Gotta hand it to the boys at Solihull, they build a tough truck.
Regards, -Bob
My truck also began showing some rust this winter on the inside of one of the doors. My dealer is going to fix it no charge. They said the truck is covered through the company for any rust up to 6 yrs old.
Kim
Ill obtain some VIN's and run them.Also they mentioned that since they are owned by circuit city they can install a CD changer for about 299, Any one have a price on the part ? or dificulty doing it myself ?
DL
Did I just get smoked out of $575????? Part of the great thing about buying my Disco II was that scheduled maintainance was included and I didn't expect to shell out this soon. I do understand that I didn't just buy any old car and this thing needs special attention but this doesn't seem right to me.
I guess the good news is its a simple procedure and i can purchase the parts for my car for about $150.00, So i dont know if u got soaked or not....
DL
I agree that regular changing of the pads should prevent changing the rotors but in this case the LR service director was trying to explain to me that both need to be replaced each time the pads wear down.
Seems a little excessive to me. I would also have done the work myself but it was one of those things where my truck was up on the lift and dis-assembled when they explained it and I said go ahead and do it.
I replace my pads every 13-15,000 miles (when they wear thru), I'm on my 4th set, and still have the original rotors. They're fine, no warps, and the thing stops like it's got the anchor from the Titanic. However, it's prudent of me to get a gauge on the rotors soon and measure their thickness. If they're worn thin then it's time for new ones. But not until then.
If you're told to replace the rotors AND pads at every interval... something's wrong. If your rotors were indeed warped or badly scored then it's another story. Perhaps that's what happened?
You can/should do the brake jobs yourself. It's simple, and gives you an understanding and appreciation of your truck... these things are tanks! And it's very gratifying to be able to say "I did that". All it takes is the provided lug wrench, a pair of pliers, and a box wrench to fit the brake bleed nipples. Simple.
Good luck! Talk to your service manager and see what was wrong with the original rotors to demand their replacement. If you don't get a good answer... find another shop.
Regards, -Bob
Your rotors should not need to be replaced. If worn a little, or slightly warped, they can be re-surfaced at least once if not twice. Re-surfacing is about $100. 30K miles isn't the worst, but I think your service provider was not being honest with you. You shouldn't need new rotors, and at that low of miles, at a minimum (unless severely warped, you would know by squeaking with good pads), they could be easily and cheaply re-surfaced. My trooper has 27K and both rotors and pads are in great shape. Your dealer mentioned heavy off-roading? I buy the soft pad bit, that shouldn't effect the rotors, how much off-roading do you do? Some shops have different "gauges" for measuring thickness. Try MIDAS vs. a local "reputable" shop. I have heard, everything is shot, pads and rotors (MIDAS) to all you need is new pads (local shop) $25.
Modendahl: Congrads on the 3er its a great car ! looks like you will have best of both worlds now.
DL
Thanks a bunch...
Any information is appreciated.
MT
happy hunting,
DL
Steve
Not to worry. Just go around with a socket wrench and an assortment of sizes and torque up the cover bolts. Most likely they're a little loose. You may have degrading cork gaskets but probably not. Use wrist torque only to tighten, like around 15-20 ft-lb. Any more might deform the cover being sealed.
As for the coolant leak... it may be a hose or freeze plug too. Have them point out where the leak originates. Does it make a puddle? You can chase it down yourself.
Remember this is not a rocket-science engine. Any good mechanic can work on it.
Good luck! -Bob
Did a lot of research and it came down to this. This vehicle has character...in spades! There are SUV's that are more sophisticated, more powerful, better riding (at least on road), better ergonomically, and get better gas mileage. But most of them are extremely booooring with an identity crisis, is it a car, a mini van, or an off road vehicle?
The Discovery is unique in it's design and character. Yes it's quirky in some ways, but that's part of the charm. It's also solid, fun to drive and knows exactly what it is....a Land Rover.
You either "get" them or you don't!
Still having problems with that pesky ACE light. Intermittently, a steady yellow comes on. Three trips to the dealer and it is still coming on now and then. When it comes on, I stop and restart and it may not come on for another 500 miles or so. The dealer says it can find no problems and is going to have a factory rep look at it when in town later this month. The system seem to work fine even when the light is on. I personally think it's old Lord Lucas just letting me know he is still around; it's like a ghost thing.
On a lighter note, there may be a simple solution to your ECU light weirdness. Granted I have a SI Disco and it's doubtless laid out differently than the SII... but under the bonnet (quaint, eh wot?) on the SI there's a fuse box. It's on the passenger ("off", starboard) side, about midpoint of the engine, level with the intake manifold, it's perhaps 6" by 2" black plastic. Coming in the underside are myriad large electrical cables. This is where the BIG voltage/currents come into the electrical system. From here they distribute to the ECUs etc.
Being under the bonnet it's exposed to frequent large temperature swings, dust, moisture, muck, you name it. Expanding/contracting with temperature allows nastiness to get into the connections inside that box, which produces poor "noisy" electrical supply to the ECUs, which makes the ECUs very unhappy. Ever see a home PC without a filter in its power supply? Of course not. They RELY on clean power to operate correctly.
The solution is shade-tree-mechanic simple: pull the cover of the box, remove/clean/replace each fusible link (I use a pencil eraser to clean down in the holes) and all electrical connections. Reconnect everything, button her up, drive away happily with a cheery wave.
It took me THREE YEARS to find this trick, and it fixed all my electrical problems.
Good luck, -Bob
It may be that they moved it somewhere else on the DII, but that could still be the culprit. You might have to hunt for it... but if it's under the hood, you might do well to clean it just for grins. It only takes about 15 minutes on my DI.
On a seemingly separate issue, the rear windows on my DI refuse to go up and down until they get happy (after driving a ways). Someone sent me photos showing where the circuit board is that controls them; it's behind the glovebox. They sent photos showing where there were cold solder connections on their board, and a touch with the solder iron sorted it. Perhaps... the same could be true of your ACE circuit board?? Just a thought.
It seems these are still simple problems and easy to fix. It just takes electrical skill now, not only a screwdriver and dwell meter.
Best regards, -Bob
