In my case, it was the EGR, in your case it could be the same or something else. One way of solving this is to get a diagnostic. Consider that the replacement cost for an EGR including labour could be several hundred dollars, you wouldn't want to waste the money replacing it if that did not solve the problem. The check engine light is just a warning signal; a diagnostic pulls up the trouble codes (likely OBD1 codes considering the age of your truck). Good luck!
I doubt anyone is reproducing these emblems.
Now if it were a Mustang, you could order the entire car out of a catalog.
Also check Hemmings Motor News for Ford Parts providers.
Lastly, when parked, if I pump brakes up there is a clicking sound under right side of dash.I've had a rattle in center of dash for two weeks,then these problems stated to occur.
Do think a wiring harness is loose,or a computer is screwed up? :confuse:
Yes you need a deep puddle and some back luck for this to happen, but it's a real risk.
We just purchased a 2004 Mazda 3 and the engine light came on yesterday.
The code was the same as yours: PO128
Coolant thermostat condition- low operating temperature
Probable cause
low coolant
open or short circuit condition
faulty ECT sensor
Car drives great and shows no problems at all.
Probable cause
low coolant
faulty ECT sensor
Any one else have this problem or any advice?
by mazda tech
What is a reflash?
Does this mean there is a power train problem?
Thanks for your help!!!
Any suggestions?????
What should I do to ensure the engine hasn't suffer damaged? What signs should I be on the look out for?
I'm pretty handy with cars and have given it a good once over. Everything sounds fine, drives fine and seems to be in sound order.
I was thinking maybe an O2 sensor replacement but other than actually changing it I am not sure how to rule it out along with MAFs and so on.
I'm guessing my best bet will be to bring it and have it scanned but I would like to try and rule out everything I can before resorting to that.
Any ideas would be much appreciated.
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
Thanks!!
See the Mazda press release: http://www.mazda.com/publicity/release/2011/201105/110518a.html
http://www.mazda.com/mazdaspirit/skyactiv/engine/skyactiv-d.html
and with this transmission:
http://www.mazda.com/mazdaspirit/skyactiv/transmission/skyactiv-mt.html
:shades:
- No engine code, but all the lights turned on during the stall.
Did you find out the problem? The dealership mentioned water in gas but that does not make a lot of sense to me. it starts up immediately after the stall.
At 112,300km I noticed an engine noise that led me to believe it could be a sticky valve or lifter so I immediately checked the oil. It was down 3 quarts (this in the less than 1500km I had driven since I performed the self check) with not a drop of oil under the engine or any smoke from the exhaust.
After a visit to the dealership I found out that running it so low on oil threw a bearing in the crankshaft and as a consequence I am now in the process of replacing the engine.
After speaking with the service manager I discovered that the 2.3 engines are known to suddenly start burning oil without any warning or evidence, as much as 1 litre every 500km. Searching through numerous on-line forums I confirmed that it's a prevalent issue with an abnormally high percentage of these cars, some having experienced the problem as early as 80,000K. The apparent cause is a collapsed oil seal inside the engine and the only solution to address the oil consumption, according to the service dept (outside of an outright engine replacement as it's too costly to fix) is to change to heavier oil. This will slow the rate of consumption but it won't stop it. The 2.0 and 2.5 engines do not seem to have this problem.
Mazda Corp apparently knows about this (the service department I deal with told me that numerous delerships across the country have brought it forward to them) but fails to recognize there is an issue. What puzzled me most is that when looking into the cost of a replacement engine, the Mazda factory rebuilt engine was only warranted for 1 year or 20,000K when all their other engines are warranted similar to what would be provided on a new car power train.
I am not laying blame on anyone anyone but myself for my predicament. Had I checked the oil every fill-up, as is recommended, I would have a car that burns oil but would not have had to replace the engine; however, IMHO, any vehicle made in the last 10 years with less than 200K on the odometer, and maintained regularly, should not be burning oil at all, let alone at the rate I and many other owners have experienced.
Heads up to all owners with Mazda 2.3L engines.
what did you do with your engine issue? I have just purchased a mazda 3 with 80K and now it is using oil .. one spark plug is black - oily all others normal. thanks
So, there was no documentation of the oil burning issue in the last 7 years? Did you contact Mazda head office?
Oddly enough the new re-manufactuered engine also burns oil, about 0.75L every 1500km although now that I am aware of the issue I check the oil more frequently (every fill up).
Generally I love the car and the way it handles; however, as I stated previously burning this amount of oil in an engine should not be happening with cars designed and constructed in the last 10 years. Being as Mazda apparently does not acknowledge this issue as being design flaw and flips the onus of responsibility onto the Owner, I doubt I will ever buy from Mazda again.
Cost to replace the motor was insane even from corner mechanics that do engine swaps. Interior materials were were not great, the car didnt hold on the interior either, the cloth material on the drivers side door was peeling off. The paint on the car was super thin too, I had scratches on the car that were down to the primer that should have never happened.
That was my first and last Mazda.
Both of mine happened after extended driving (1 hr and ~2.5 hrs highway)
If I let the car sit for ~15 minutes, it will start up. Almost like it needed to cool down. the temp gauge reads normal.
The battery is fine, only 5 months old. My regular shop did not find anything wrong with the starter motor and a transmission fluid flush was done between incidents.
It has been driven without issues many times in between these incidents, including several other 2+ hour highway trips, and during a week of 90-100 deg temps.
I'd put this one in the simple coincidence column.
I would like to comment on the 2.3 engine - lack of oil issue . We have had the car new since day one and has been regularily serviced at the same dealership . The last oil change was less than 3000 kms ago , last week we heard a knocking noise in the engine compartment , when i checked the oil - there was no oil to be checked . Took it to a local garage and they added almost 4 litres of oil , there where no signs of leaks or blue smoke from the tail pipe . Then took it to local mazda dealership - they could not explain the disappearance of almost four litres of oil in less than 3000 kms - they would take no ownership of the problem whatsoever . Now i need a new engine . I would NEVER buy another Mazda , this engine should have been able to go for at least 200,000 kms . Lesson learned - stick with a reliable Toyota product .
I'm thinking it was likely a problem with the service department rather than the car. I had a similar experience about 5 years ago. I had been having my vehicles regularly serviced at the dealership I have been buying cars from since 1979, and they'd always been great. The dealership got sold to new owners and they made some personnel changes in the service department. I had regular service done on my one car that had 150,000+ miles on it and less than a week later it seemed to be running a bit hot and noisy, so I went to a friend's shop and the oil was VERY low. I sort of chalked it up to the possibility that the old car had started to burn oil... UNTIL... I had our brand new car serviced shortly after, and about a week later found the oil level was also VERY low. As I knew the new car wasn't burning oil, the only possibility was either incompetent service or a problem with their oil dispenser. I switched my regular service to my friend's shop, and never had the oil level problem again. The high mileage car made it to 238,000 miles with no oil issues, so I'm pretty sure I figured out the problem correctly.
The dealer's service department lost my trust, so I take that business elsewhere. But I still buy my vehicles there.
Of course some Mazda owners(like me) resort to that onerous and archaic habit of checking the oil at every fuel stop. The dipstick is there for a reason, you know.
At 132,000 miles my MS3 has only required one oil top-up between 7,500 mile oil changes- and that was after a three day HPDE...
Yea, I'm a dinosaur too. I always pay attention to what my cars are telling me and take note of any changes in how things are operating.
