First, my ABS light (along with hill desent and traction control) comes on every so often (avg. a couple of times per week) for absolutely no apparent reason (nothing seems to be common to each occassion except for perhaps rain - generally goes out as soon as I turn the vehicle off and re-start). The dealer has cleared it once ($90), but I am hesitant to keep bringing it back since I am out of warranty and because it does not seem to represent any sort of catastrophic problem.
Second, the service engine soon light comes on every so often. The first time, I put catalytic coverter cleaner into a new tank of gas and the light went out shortly thereafter. Now it is on again, but I am hesitant to keep using the CC cleaner since it is recommended for only every 3,000 miles. The dealer says not to worry unless the light starts blinking, but this, along with the ABS light, is driving me nuts (maybe because I cannot figure it out more than anything else).
Finally, I have a small leak from the valve cover that drops some oil from the middle of the vehicle every few days. I can live with this. My question is whether anyone recommends products like "Stop Leak" engine oil additive to help.
I love my Land Rover, but compared to other used SUVs I have owned, i.e. Mercedes ML320, I am encountering a lot of what I hope turn out to be nuisance problems.
Please help if you can. Maybe one day I will be able to contribute something as opposed to just asking questions. My apologies for the length of this post.
Thanks!!
Not really! Just kidding. Seriously, see if you can get a long extension on a ratchet and tighten up the bolts holding the rocker cover on. I suspect you'll find they're a little loose. It's not uncommon to have to tighten these 1/4 turn every so often. I certainly would NOT put any kind of oil stop-leak in your engine. I've gone that route over the years with cars long since gone, and it's just not worth it.
About the electrical weirdness, open your hood and see if you have a fuse block about midpoint on the engine, topside, passenger side, laying parallel to the engine. It will be black, about 10" long with a bunch of heavy cables coming in the underside. If so, go back thru these posts and read up on taking it apart and cleaning the contacts inside. That's the first place I'd look.
I hope this helps! -Bob
Question to all: Can you explain the reference to "Lord Lucas" in previous posts? I notice that the engine fuse block has the word "Lucas" on it. Is this the manufacturer of that part? Is this bad?
Last question to all: My dealer wants $350 to fix what they term a valve cover oil leak. Does this seem reasonable?
So to avert looming catastrophe we give deference to His Darkness once in awhile and it seems to keep our electrics working better. We also each have come up with our Lord Lucas Disclaimer, that we post as necessary, like before long road trips. It seems to keep him happy.
Lord Lucas Disclaimer: My Land Rover is the most miserable, leaky, quirky vehicle this side of the La Brea Tar Pits, and equally repugnant (wink). It sparks and pops like fireworks on the 4th of July and leaves trails of expensive parts everywhere I go (nudge nudge). Women fear it, and mechanics love it. It fails constantly (smirk) and I cannot be more than 100 yards from home and have any hope of it running on more than two cylinders. (wink wink) I wish I had NEEEEVVVERRRR (hint hint) bought it.
(think that will keep me running another month?)
Seriously, does the sound go with wheel RPM, or is it higher frequency... like 3x wheel speed? That would point to a Hookes joint in the driveshaft. Is it rumbly while it happens? Maybe a failing wheel bearing.
How about your tires? I had a road noise and vibration that drove me nuts till I replaced my tires; a big soft spot had developed inside one tire that let it deform under weight, but looked normal from the outside.
Good luck!
If it's a driveshaft problem then likely it will be high-frequency squeaking instead of low frequency whoomping, and it will squeak at about 3x your wheel rotation speed. If a hookes joint has worn to where it could be producing deep pitched rumbles then it will be (painfully) obvious climbing beneath and looking. It will be all gnarled and possibly blued at the end where it's failed. Believe it or not that happened to me out 75 miles from the middle of nowhere. I doubt it's the driveshaft.
Wheel bearings will "grind" or "rumble" or might even "Whoomp" but they'd do it forward or reverse, on or off the throttle. Try kneeling beside the offside front wheel, then grab it right at the top (12 o'clock position). Jerk it HARD toward you and away from you, and see if there's noticeable looseness that sounds like metallic clacking. Try to ignore other sounds like suspension bushes or tie rod ends, listen for noise from the hub area and watch for looseness. Try the other front wheel and see if it's the same. If the wheel bearing is failing it will get looser and looser before it fails. And, believe it or not, I had THIS happen to me 140 miles NW from the middle of nowhere.
My bet is on the tires. Try rotating the tires on that side front-back and see if the noise source moves to the rear.
Good luck!
Cupping takes months to develop, so that sound would have come on gradually.
I am curious about the tire cupping that you mentioned in the post by kb28. My tires are also pretty loud, making a definite speed related noise. I recently went in a local tire shop and they told me that my tires are cupping and that even rotating them would not help.
I was wondering if this issue is one that LR has given some "relief" for in the past since I have previously read/heard about tire cupping having been a problem with the Goodyear's.
I have only owned the vehicle (a 2001 DII) for 14 months/23K miles - with very little tread wear beyond the cupping. I first noticed this several months ago but didn't think much of it until recently when I decided to have the tires rotated despite LR's recommendation. I have gone into the dealership at least five times for scheduled maintanence and other maintenance but they have never mentioned it nor have they ever suggested a tire rotation -- both of which I am obviously disappointed in!
If the Goodyear tires themselves are bad then I certainly don't feel like we owners should be forced to bear the burden of premature replacement! Any help would be greatly appreciated.
All bravado aside, I have no interest/skill to be a weekend mechanic even for the slightest leak and wouldn't know what to do anyway. It will be used solely for my commuting. My wife drives a Yukon XL for the rugrat shuttle. However, I have, and have had, an SUV for the last 6 years. I deplore minivans.
I really like the looks and ride of the '03 Disco and likewise on the '99-'01 RR and I will be purchasing by mid-August; either the '03 Disco or the RR.
I have read this particular message board for over a year and value your opinions.
If you feel that either of these would not be good choices I will resort to a 2001 530 Beamer.
Thanks in advance for your responses!
I looked back and there was the mother of all squirm marks on the road where my tires were clawing for grip, and I was impressed at how straight the tracks were. I never locked them up or slewed sideways, the back end didn't try to come around, I just had massive straight line braking.
Continuing home we remarked on our good fortune and how our guardian angels were with us once more, and I commented on how well the truck performed.
Coffee? Who needs coffee when your blood is pumping 50% adrenaline?
Incidentally, I can't wait to hear your advice to mlamman. A lot of people who are into the benefits of Discos and Rovers share his values. We don't have the time or inclination to perform roadside repairs on an SUV. I think that price wise he established a level playing field with the different model years for the the Rover and the Disco.
So, Nanug, what is it going to be? Fresh styling, probably better assembly quality, 4.6 engine, but instant and significant depreciation when the revised MY2005 appears (will there even be a 2004?) vs. the plusher, more English men's club -like interior, although air bag equipped ("sorry, Mr. Mlamman, we need authorization to fix your air bags for $3000 or so"), by now depreciation proof, better sterio, longer wheelbase Rover?
If the money was the same, I guess for a daily commuter the Rover would be preferable until the first service visit.
Please advise.
Nanuq - quite seriously, I am impressed by your writing style. Have you ever thought of a career change?
As for The Eternal Question, Disco vs. Rangie, I gotta say I really don't know enough about the two to give a valuable answer. My basic opinion is that simpler is better, so I can work on it myself. BUT, that violates one of the initial conditions: no roadside maintenance. I also want a truck that's great offroad; the onroad manners really don't matter to me. I'm gonna drive it like a cat in a room full of mousetraps: on tiptoes.
An observation: Rover needs to stay in business so they have to make trucks that sell. What sells is something that's great onroad. So, from my little corner of the world it seems they are tending toward a central capability of roadworthiness and "some" offroad ability. Consider you used to be able to buy hardcore (Defender) or cushy (Rangie). Then they filled the gap with the competitively priced Disco and guess which is the winner? It has most of the Defender's capability (and the same running gear) and some of the Rangie's comfort. People voted with their pocketbooks and Rover paid attention. Now, we've got the Freelander, the new Disqueax and the new Rangie... all fine trucks, but all far removed from a Defender (sigh).
(You notice I still haven't answered the question)
IMHO the new Disqueax is very close to the older Rangie in comfort. Probably they are the same offroad. One will take a big hit when you drive it off the lot, the other won't. Rover styling is pretty darn classic, so I don't think the Disco facelift will really affect previous model years that much. Parts are expensive to replace, and the newer truck's initial build quality will be wonderful.
All this has been said before, so you gotta ask yourself what's most important to you? If it's peace of mind, get the new Disco. If it's the ability to go offroad and bash it a little and not cringe at every impact, get the one that's a couple years old. If you want to go offroad a LOT and keep your Significant Other happy, and laugh at people who stand with their mouths hanging open because your quaint little Brit truck does amazing things, and you don't mind the occasional scrape or repair, get an older Disco (like my '96). And if you want to cut the wheel openings and Go Big with your Rover, get an OLD Rangie, upgrade the drivetrain and go bonzo. If you want to do this and retain some measure of cachet, get a Defender. If you want to poke around at walking speed and tiptoe over obstacles and like the sound of dripping oil and the ability to hose it out, get a Series Rover.
Whew. How's that? Nice tiptoeing? Sorry for the LONG windedness!
When I talked about capability being the deciding factor instead of price, I was still thinking ca. the mid 90s and the advent of the NAS Disco vs. the venerable Rangie. Cush vs. crush, viscous vs. hard lock, etc. It's the decision I made back then, looking at the well-loved Rangies sitting next to the year-old Disco I eventually bought (which even shares some of the body panels!). Now, the Rangie is MUCH MUCH more expensive than the Disco and I'm sure that's what drives most of the purchase decisions. I guess it's completely off my radar scope to consider a "new" purchase so I didn't consider that.
I've read some of the New Rangie tests and it sounds like LR did it right again; it excels when compared to all the other new trucks. BUT... if you put it up against what I like to do, I think I'll hang onto my poor old ragged Disco. *wink*
Cheers!
I, for one, find that laudable, respectable, noble and inspiring! :-)
Cop: Do you know how fast you were going back there?!!!
Heisenberg: No, but I know precisely where I am.
PS-My tires are still whoomping and if anyone knows if Goodyear is offering any relief, I would appreciate you letting me know.
It won the Car and Driver road test (lr included) and was called a 4-wheel swiss army knife.
http://www.caranddriver.com/article.asp?section_id=15&article- _id=1798&page_number=1
It may not seem like a worry, but I've been in the middle of some 30 minute hard climbs and just cringed as I listened to the engine ping and smelled the cats roasting. When you're doing that you can't always turn back and trust me, you'll wish you weren't doing that to your truck. High octane gas solves the problem. And remember to park away from combustibles when you reach the top... your cats will be glowing red by then.
wkrebs ... I bought my 99 Disco (only 32k miles!) in Feb. Came with the 1 yr certified used vehicle warranty. No problem in three months of Mississippi outback driving. Do your homework though ... get at least a carfax report.
It seems difficult also to find low mileage s1.
Thanks for any insight,
Francois
Kernersville, NC
With '96 came the advent of GEMS4 and the sticking exhaust valves problem. A search by VIN ought to show if the problem was addressed on your potential truck. It's a big ticket item, make sure it's been done.
'96 also had a Rotoflex rear coupler (instead of Hookes joints) and those can fail.
'97 came with a new release of GEMS that should prevent the sticking valves issue... but make sure it's not a '96 *called* a '97 because it was built in December or something.
I believe the '94 and '95 had the 3.5L engine, and as far as I know they don't really have ANY issues other than those common to all Rovers: keep your lubes fresh and clean and you'll run nearly forever with some regular maintenance.
Lucas vs. Bosch: I'm happy as a clam at high tide with my Lucas electrics (take THAT, Lord Lucas!) they've never failed me, and the weirdnesses are manageable.
SI vs. SII drivetrain: I prefer the SI drivetrain with its quaint swivel housings and zillions of moving parts. Call me twisted. I'll never lose a wheel bearing or CV joint either. The '96 has the strong halfshafts and you can pick up Detroit and TruTrac lockers for not too much money, and make it unstoppable...and still driveable on the street. Plus that cabin-selectable center diff lock is sure nice.
Don't worry too much about the miles. At 82k miles my '96 still drives, feels and operates like a new truck. It is simply unbelievable how nice and tight and clunk-free everything is, considering the HARD life my truck lives.
Alternators, ABS pumps and power steering pumps are all big-ticket items on Rovers. They seem to go about 80-100k miles and then die. See if those have been replaced before you buy your potential truck.
If your seller will allow it, drain one of the swivel balls (have some 90w with you to refill it) and see if it's milky white. If it is, the breather is plugged and likely your diff and swivels have moisture in them... not good.
Check the brake rotors for gouges and to see if they've been replaced. They're pretty soft and will last 80-100k as well, and will develop some impressive plateaus where the metal wears down relative to the hub. How are the pads?
Good luck!
A good engine with few faults.
I want an early '95 specifically myself.
Here is my situation. I posted a short post a few back but don't feel that it really expressed and depicted my scenario.
I have been driving a 1989 Toyota Land Cruiser FJ62 for the last 5 years. I bought it used from a friend of mine and the truck has been beyond all of my expectations. It has 201k and drives like it has 80k. All I have done is change the oil religiously and replaced 2 starters. That is it. It starts every time and is very good offroad. It does get miserable gas mileage. That is the only downside. I don't mind that at all though.
I am ready to upgrade and move up to a newer truck that is more roadworthy on longer trips and just plain newer. If you have ever driven an FJ62 for over a few hours you know what I mean. I had been sold on a 1999 TLC, but I stumbled across a LR Disco and my loyalties have started to sway. I drove a 2003 Disco and a 1999 TLC the other day and walked away liking the Disco better. The best way to describe it is that the Disco has a soul, just like my FJ62. The newer TLC was nice inside and drove well, but it lacked the character or heart of the older ones. It was just a nicer Tacoma or Camry inside. It left me thinking that this vehicle would start and run for a long time, but I would have no excitement every day when I drive it. I want a little passion.
The Disco on the other hand. I love the quirks, misplaced items, little cubbyholes, strange seating position and all of its oddness. It has character. I don't care that it drives like a truck. Trust me I will be taking a step up. The Premium gas with bad mileage isn't great but I don't drive many miles a year anyway. I don't care about the turning radius. I like the more powerful new engine and headlights. The cargo space sure seems to be plenty big to me. I don't know what others see that I don't.
My concern is that the thing will stay in the shop constantly and that the dealer will be a nightmare. Basically, I am scared to death by some of the posts I have read.
If it were up to you after reading my post and knowing what you know about the 2003 Disco's which would you get? they both cost about the same, the Disco will have a 4yr/50k warranty & the TLC won't.
Also, do you know how to check on Dealer Satisfaction ratings for a dealer?
Thanks ahead of time.
Most of the sticking valve issues result in no loss of power or driveability as it doesn't take more than a couple of misfires to set the light off, they just make the check engine light come on and store the misfire code in the ECU.
Tincup, when my valves started sticking it was VERY noticeable, as if someone had pulled off two or three spark plug wires. Enough RPM would make it perform, but it sounded funny and smelled as if it was dumping raw fuel from the exhaust. It had no power down low. None at all. I knew it was a misfire, or loss of compression.
I understand the new head design and the advent of GEMS with the 4.0 is the culprit for the sticking exhaust valves. I've never heard of it on a pre-96 Disco, and it only rarely recurs on '96s that have had the carbon cutting replacement valves put in.
William, most of the horror stories about Rovers are anecdotal. Yes British vehicles have a well earned reputation for terrible reliability. But Rover has spent untold mountains of cash to rectify the situation. Most of the stories you hear are from someone who really shouldn't be driving anything other than a Camry or Accord. These people scream "LEMON!!!" at the first hiccup or drop of oil. The rest of the world has nowhere near the fixation with perfection that North America has, and I know Rover spent WADS of money trying to meet those expectations.
Considering the sticking valves issue, Rover values their customers and they will replace the valves (and gaskets and springs and ECU PROMs) for free when it happens. They seem to operate with integrity and they will darn well make it right when you have a problem.
Seriously, take a look at the topics here on Townhall. "Unhappy Explorer Owners." "My JGC is a POS." "Dead Durangos." etc. etc. etc... and these people are talking about BIG problems, like blown transmissions and engines. My mechanic buddy here at the Rover shop says he has NEVER replaced a transmission in a Rover, except the one (ONE) that came from the factory with no lube in it.
That's the kind of truck I'm looking for. It's got a soul, it will surprise me, it is not predictable, and it will last as long as I want it to. The hard parts beneath the surface are what matter to me, and I can live with a drop of oil or a window that only goes up and down on warm days (grin). And if I want to fix that window myself? I go to Discoweb.org and read up on it, I get a soldering iron, and she's fixed in 15 minutes. It's a simple job, but it's part of my truck and I kind of like that wart on her otherwise pretty face.
Rovers are a love/hate thing. No getting around it. That's because they're visceral and you get attached to them... they have a soul. If you're prepared for that, you'll love having a Rover.
Take a look here... Matthew said it all.
http://www.nanuq.net/Arnold's/Bob/LandRover.html
Best regards, -Bob
Thank you for your reply. That was the kind of reply I was looking for. As long as the major components are strong and reliable then I can live with the little things.
The Discovery is the closest thing I can find to my FJ62. I'll let y'all know how the purchase goes.
William
How does one drain a swivel ball? Maybe I should get a shop manual before I actually go and buy one of these...
Regarding mileage, I was hoping to find one with about 60K. Most vehicules in the area seem to be over 100K miles. And Disco SI from 1999, I haven't found one yet. A few SII.
I was also hoping to find one with some additional equipment already on, like a roof rack and bull bar.
There is one in the area for sale with a 5L engine, 33" tires, high lift with something like 12K miles etc. But that's not what I'm looking for. I want something I can drive in town and that my wife and kids can get in without using a ladder
I'm not in a hurry so I guess I can keep my eyes open until the right truck comes by for sale.
So what should I expect to pay for one, is the Edmunds TMV actually acurate?
