Chevy Silverado and GMC Sierra Brake Problems
I own a 2003 Silverado that has intermittent brake failure problems . The dealer has repaired this time and time again but the problem persists . The dealer and now GM say that this is a normal function for this vehicle , but now the brake pedal goes to the floor and although they are telling me it is safe to drive I am refusing . This truck sits in my garage .
I found over 100 similar complaints on the NHTSA web site , some involving accidents with injuries and deaths .
Does anyone have any advice . This truck has 48000 KM on it .
See Also: Finding the Causes of a Low Brake Pedal
here's a picture of a slotted rear rotor where you can see the internal drum surface.
' book(Dealer "tech." manuel)includes pumping the pedal and cracking open and closing in succession, each fitting on all hydraulic components, working your way back to and including the master cylinder, untill all air is bled out. Don't forget to use something to prevent brake fluid from sraying all over the paint and yourself."TRY IT! YOU'LL LIKE IT!
I have a 2003 sierra slt
Conserning your brake problem whit the truck,I had the same problem whit the brake pedal going to the floor and after (quite a few trips to the garage) Finaly they changed the "Brake Booster" It did fix the problem whit the peddal going to the floor but still today I have problems whit the anti-lock not working properly...it takes the truck an exagerated distance to stop on a snowy road whit me pushing like crazy on the pedal whitch is as stiff as pushing on a cement wall(and you can just hear the anti-lock humming wide open)...And you know what! All of this is just normal operation of these trucks,everything is normal if you ask a GM Teck.And this is litterely the very tip of the iceburg whit my truck....lots and lots of trips to the garage and lots of headakes and frustrations to go whit it(major lemond) Hope you have some luck getting to the bottom of your problems.
I`m getting rid of mine in about a year when the worth of the truck is equal to what I owe...and never again will I even buy a Delco Spark plug. Gm has a very bad quality system and it shows and they dont back up there product after its sold,I had to fight whit gm canada and garages since i got this 60 000$ piece of junk on wheels.(what a waste)
sinceraly,
:lemon:
The kicker is I had a recall service performed on my truck not more than six weeks to clean the front wheel sensors. The recall dealt with a problem where the ABS would turn on during low speed brake applications between 3.7 mph to 10 mph. I am not sure if they did the cleaning properly, but it was similar to the consequence that was listed in the recall of the braking distance increasing as a result of the ABS being activated. If I would of been on flatter land then I do not believe I would have had this problem with my truck.
Has anyone else had a similar experience? I am currently waiting for an official GM investigation of my brakes. I will report back after I get the results.
Just like post # 14, my ABS has been kicking in just as I'm about to make a complete stop (on dry surfaces) Thankfully, it won't do this on higher speeds. Before I send my 4WD 2000 Silverado in for repairs, is there something I can do to remedy this? Perhaps a simple sensor replacement?
(FYI)I got the recall done on this about a year ago.
In the meantime, I went to the dealer and (of course) they wouldn't honor the recall that was done back in Feb 05 for the same problem. They (at the time) took 15 minutes to "fix" the problem. Whetever they did, they did fast only this time, they want to charge me for 1.5 hour labour and (get this) $300.00 CDN for each sensors!!
Needless to say that this is a total rip off. These sensors are not even available in other part stores. It's a part reserved (so I'm told) exclusively for dealers. I don't get this one bit.
Anyway, I will not pay $600.00 + for this repair that I believe is useless to start with. I never believed in ABS and I still don't. MY work around, I unpluged the stupid things. However, If I remove the fuse, both the ABS and the emergency parking light stay on. So by unpluging the sensors, only the ABS light remain on. To fix this, I removed the dashboard, and removed the LED light for the ABS. End of story. My truck now stops on a dime and no more pulsating pedal.
It's shameful to have to resort to such a drastic so called "repair". I'm not satisfied but at least, I'm $600.00 bucks richer.
I'm out $600 for a new bumper should I decide to fix it and $155 for the dealer to R&R the wheel speed sensors. Without ABS (Hooray!) I won't hit anymore immovable objects and I'll never have this problem again. Geez - I wonder should my next truck be a Silverado or a Toyota Tundra??? I have to agree GM has been absolutely shameful on this ABS issue. I've been a GM guy for the last 41 years but I'm a little embarrassed for the company over this nonsense.
The brakes work fine, just very annoying to have the truck beeping at you while the fan is set to more than 1. The wheels have been pulled and brake pads checked, they are fine. Brake fluid level is fine. Brake lines have been bled.
Any ideas? The local dealer is stumped, but willing to start swapping things out on a trial and error and high $ basis.
too much friction on the front rotors is caused by lack of brake pressure balanced between the front and back brakes 70/30(is the likely cause)
You could have MSRCylynder issues...?,
I know from personal experience from yr2000 and on, GM has always had warping issues, I now have 34K miles on my after market SSBC components and no more warping, SSBC.com is probably your best bet, they have rotors that are coated that resist rust.
I now have about 45K on my truck and bakes and rotors are fine, dealer serviced said their 10% used, means I will get about 150k miles before the next brake job... see my photos http://www.carspace.com/ttaupier1/Albums/2003-5_3truck/
I have rotor warping problems also. I own a 2000 GMC Sierra 1500, 2WD. Last July/2006, I experienced brake pulsation. Dealer determined that all 4 rotors were warped. They were machined and this fixed the problem.
Milage at that time was 67338 miles. Today after only 7723 miles, I again have brake pulsation caused by warped rotors - this confirmed by dealer. Rear rotors must be replaced since not enough metal to machine them; front rotors need to be machined again. I don't feel I should have to pay for this since it shouldn't have happened after so few miles. I think I need some kind of official proof to show my dealer before they will give in to my request. I've searched the Internet but can find nothing that appears 'official' You mentioned you've seen many instances of people with GM truck brake problems. Do you recall anything specific that would help me here?
Thanks. Clark
Googled: "GMC truck brake problems":
1) http://www.consumeraffairs.com/news04/2005/gm_silverado_brakes.html
2) http://www.consumeraffairs.com/automotive/gm_silverado_brakes.html
3) http://www.detnews.com/2005/autosinsider/0505/27/C01-195410.htm
4) http://www.carsurvey.org/modelyear_GMC_Sierra_2002.html
Anyone out there have similar braking problems with their 06 Sierra? Any advice as to how to proceed with convincing them to fix it, at their expense?
Am I asking for the moon here?
Signed,
Perplexed
So now, when coming to traffic lights and stop signs, I start braking well before giving myself space.
I’ve already replaced the rear pads and rotors about 12,000 miles ago because of squealing. Bought after market parts from local Autozone.
I took the truck to the local mechanic who said he thinks it’s the speed sensor. When I picked it up, he said “the speed sensor is fine and the computer shows nothing wrong. When it gets worse, bring it back and we’ll put it back on the computer.” Not a very reassuring answer.
Only thing I can think to do is replace the front rotors/pads, but don’t want to waste my money/time if that’s not it.
Any ideas what I should check/replace?
Whith this said, the front rotors warp due to too much heat..the back brakes were not pulling their weight. This i suspected because my wifes old car.. Honda Accord ex stopped on a dime. i actually felt the difference in the rear wheels having more stopping power on the honda.
I saw the on line forums and notices everyone having stopping isses, however the front brakes on the truck created tons of dust, non on the back wheels, I use a little logic, my wife's rear wheels always had to be cleaned disk brakes. Hmmm can you see where this is going..
a friend had a 2500 silverado..had to do a complete brake job, noticed the rear disks not being used and rusting over, a friend of his the mechanic, in his army unit repairs chevy's, told my friend about the rear break caliper defects, it was talked about in a chevy trainig class....hmmmm ..well here comes rear SSBC calipers...there i go. have you guys noticed the Toyota emphasis on heavy duty breaks...stopping the truck before it goes over the cliff...that is not an accident in Marketing.
new rear calipers should fix the back brakes, and front, and the warping...not sure the dealer will pay for it...since they have had training for their mechanics for 3-4 years about the issues .... Until some folks die the NTSB won't get involved which means GM will only loose money by assisting the repair. Why loose money when the public will pay for it, and add service revenue to their bottom line.
This was more than .02, maybe .03,,,was i sick to buy $1500 in brakes...all i know is when i drive my 20 month old son around..i would pay 10 times that for peice of mind.
MY OLD POST>>>>I know from personal experience from yr2000 and on, GM has always had warping issues, I now have 34K miles on my after market SSBC components and no more warping, SSBC.com is probably your best bet, they have rotors that are coated that resist rust.
After looking through my receipts, it appears I’ve already replaced the Rear Rotors and Pads ~15000 miles ago. So I went to the local Car Quest and bought after markets Front Rotors and Ceramic brake pads. Lady behind the counter told me any pulsation on the brake pedal is the rotors. Also talked me into ceramic pads (no brake dust on the rims). I hate cleaning my rims
So yesterday I replace the Front rotors and pads, and took the truck for a ride. Still have the same problem.
However, it does this less now. For example, it only used to do the “brake pedal pulsation/shudder” on soft stops under 20 mph maybe 9 out of 10 times.
After changing the fronts, it seems to be doing this only on soft stops under 10mph. And maybe only happening 7 out of 10 times.
So the short version is, it’s still doing this, but by replacing the front Rotors and Pads, it seems to be doing this less.
Could there be an ABS problem?
What are the symptoms of ABS problems?
Not sure what else to check.
Should I need to replace anything after warranty, I will probably go with SSBC parts if I can get them.
I’m also hesitant to take it to the GM dealer. Had an issue with them a while back on a recall that they said they would fix, then decided it was my fault (faulty tail gate cables).
So I’m still a little bit upset with them right now.
I remember that you had to do almost complete stops from a variety of speeds. BTW, the instructions came enclosed with the pads. Raybestos I believe.
1offroader
The Chevy and GMC (GM trucks)trucks have had break problems since 2000, see my other posts...I am assuming you have read these.
My take is that the front brakes are okay, its the back brakes that are not functioning properly. This issue "not really great breaking" has to due with the rear caliper manufacturing process and overall design of the rear calipers. They are either not assemble correctly at the factory/supplier or not tested for stopping distances.
It seams that this issues only effects a few hundred out of thousands, the rear calipers are probably not squeezing their share of the load. This is the exact problem i had and, like you was told to get used to it...
Thats when i selected SSBC calipers for the rear, and replaced the rear calipers (at my expense)...I have no breaking issues, my wife is 5,7", 130#s says it feels like a nascar and stops better than most cars she has driven..
Take the car back and ask them to take the vehicle back....hmm i would be interested in hearing their response when you tell them the Toyota-tundra comes with heavy duty brakes...and that's the vehicle you want to be driving
I jacked up the front end and checked for looseness, shakes, etc and no problems.
Then this past weekend, I had my buddy in the truck with me (he owns a 1997 Silverado).
He heard the noise and asked what the heck that was. I told him my story on how I already changed the Pads and rotors and still have this problem. Not sure what to do. I said I might have a Caliper, ABS, brake line problem. Not sure. So he says, I have ABS problems on my truck. I just took out the fuse and it went away. No ABS, but no brake problems.
So I took out the fuse 3 days ago and the problem hasn’t been back since. Bunch of idiot lights on my dash, but no brake problems.
So on top of that, I had to have my truck inspected. I never said I had a brake problem (sticker was already expired), but started throwing “what ifs” to the kid doing the check.
He told me Chevy’s have a history of brake problems. Then he tells me a story about how he is in Tech School and at that time, his dads Silverado starts giving pulsating vibrations on the brake pedal on warm dry days at slow speeds. Sounds familiar, right?
So the dad takes it to GM, and they can’t fix it. They say nothing is wrong.
The kid takes the truck to Tech school the next day and the instructor shows him how components on the ABS get corroded, but it doesn’t show up on the computer check.
They clean the components, and problem gone.
Here’s what makes me mad at my friend. He’s been in my truck at least 5 times before this past weekend. And every time he’s been in the truck the problem happened and he asked what it was. How is it that his ABS problem slipped his mind each time? Could have saved me some money and a bunch of head aches.
So now I’m going to take it to GM and TELL them I have an ABS issue.
Who knows what next
thank you in advance for your help
Steve
