thank you jeardm
If the current transmission is displaying a lazy engagement in reverse, it could be any of the following:
*Low fluid level
*Partially clogged transmission filter, cooling lines, transmission cooler (in radiator), etc.
*Rear band out of adjustment
*Rear clutches badly worn
*Input Shaft or Rear Clutch Seal Rings worn/damaged
*Weak pump/low hydraulic pressure
*Stuck regulator valve/dirty or clogged valve body/valve body filter plugged
If there is no delayed engagement from neutral to drive, I would more suspect a rear band or rear clutch problem, but a dirty valve body could cause the same symptom.
Dusty
i am sure that as i get into this project i will have many more questions if u dont mind
oh yea thanks for the input
Unless a vehicle sees exceptionally hard service, regular fluid and filter changes will usually prevent this from happening.
Dusty
This is a 5.2 liter
Yes my this was my fathers truck up until about a month ago, he has been working on trucks all of his life. He has done regular maitnence on this truck.
but if u think of somthin to narrow it down i would appreciate it i am no tranny man
by no means so like i say i can handle droppin the valve train an a sensor there aint but one i think an i can handle the filter an fluid i try leave the rest alone what is ur thought i have a guy at home to replace just what needs to be replaced but i am tryin to do it myself if possible an the thing with any 318 the one i am gettin i beleive is comin out of a 67 68 69 somthin like that i dont know that it is original bbut it suppost to a 318 single barrel the man drove it home an took the cab off 4 his perssonel project he dont need the motor so he give it to me he is smart with 440s an such big blocks but as far as dodge dont know nottin thats where i come to u with high hopes
Here's my list of possibilities:
*Cooling system corroded or clogged.
*Coolant loss (leaks)
*Radiator cooling fins have lost their bond to the cooling tubes.
*Loose water pump impeller.
*Clogged catalytic converter
*Bad head gasket/cylinder head
Best regards,
Dusty
Transmission lengths are a different story. Overdrive versions are longer.
Dusty
After re-reading your post it sounds like you were speculating on the problem and hadn't actually found a band lever in the pan (its usually the rear band lever). Your symptoms can be attributed to a bad Kickdown Band or a broken servo, an inoperative 1-2 shift valve piston (valve body), or an electrical problem with the transmission governor or governor circuit.
Sorry for the follow-up post.
Dusty
Has the transmission ever been serviced (filter, fluid change, any repairs)?
I need to understand the symptom. You state that the transmission won't shift out of first gear sometimes and that it slips. Does the engine RPM raise considerably when it slips? Do you perceive that the transmission slips when it tries to upshift to second gear?
Dusty
the engine i have in their now i put it in an it fired up fine then suddenly got to where it is hard to crank an wont run over 30 35 oon the floor board could the timing of jumped
Dusty
*Throttle Pressure cable stuck or binding, throttle linkage binding or out of adjustment, Throttle Pressure Pivot stuck, return spring broken or missing.
*Gearshift linkage binding or out of adjustment.
*Stuck or binding 1-2 shift valve in the valve body/defective shift solenoid. Both indicate an excessively dirty or clogged valve body.
*Inoperative Transmission Govenor or governor circuit problem. Remove the transmission electrical connector and check for contaminated or corroded pins. Clean and reseat connector.
*Front band broken or out of adjustment.
Dusty
Probable cause:
I was manually using first gear to examine a high RPM engine noise. I brought it to around 3500RPM then went into second, manually. When I parked the vehicle I noticed the lever would not fully engage park. I moved the lever around and it finally engaged in all gears. However the indicator in the dash no longer lines up.
Symptoms:
The truck will not shift out of first gear under normal throttle until 3K+RPM. Under extremely light throttle it will hang around 2K RPM then shift. Sometimes, most notable on an uphill onramp, it will slip and spike around 3.5K RPM. It will not shift manually. It will shift if I back off the throttle and let the RPM fall. Second gear seems to hang around 2K RPM a little too long. I also noticed this morning that a shift from neutral to drive produces a jolt (Cold engine, external temp around 36F). I had not noticed the latter before today.
History:
I don't believe this truck has seen any significant service, if any at all to the transmission. It's also been used to haul very heavy loads (Read: 1 ton in a 1/2 ton truck).
Questions:
Based on your post I would suspect something mechanical failed under the strain of my pushing the RPM then manually demanding a shift. I've checked and reset the linkage. I find no indication of loose parts or excessive play There is play in the lever but it doesn't transfer into the linkage. Inspection inside the column revealed the play was in the mount. This leaves me to believe it's either a broken band or defective valve/solonoid. Would you agree?
How difficult are these to replace and do I need to pull the transmission to do it. Chilton's is pretty vague on the matter. But for $20 I didn't expect much from it.
Thanks in advance.
Edit: If you could point me to a good site with instructions and/or diagrams I would also appreciate it. I can google a ton of them but have no way of knowing which are the better ones.
Do you have reverse?
Dusty
I do not believe that manual shifting at a high RPM has cause this problem either. The fact that you were at full throttle might have pushed the Throttle Position Cable into a bind area or the Throttle Pressure Lever is stuck in the wide open throttle position. This would definately cause the exact symptoms you are describing, except for the gearshift alignment problem.
You may have two problems at once in this case.
Dusty
I checked the throttle lever on the transmission and it was in full idle position with the vehicle off and in park. I didn't check for proper sync. between that and the throttle cable. I'll look for a bind tonight.
Thanks for all of your help. I appreciate that people like you are willing to spend some time to help people like me save a lot of money and learn something in the process.
Dusty
Dusty
Edit: How do I tell if the band is burnt?
Dusty
After some further research I'm pretty sure it's something to do with the front band. That would explain the bad 1-2 shift and the poor handoff between the front and rear bands during the 2-3 shift. I just hope it's adjustment. I didn't have a chance to look last night.
What is far more common on these is a broken servo or a band lever that's fallen off.
When a band lever falls off it's usually because the servo is stuck or broken, but I hear techs say that sometimes on high mileage units they'll come off if the transmission's never had a band adjustment. You'll need to pull the pan down in order to see this, of course.
Then again, at this mileage they are often judged by transmission shops to need a rebuild. Many times when they don't need it. Mopar trannies are about the easiest to work on and the basic architecture hasn't changed since the original A727. Shops don't make as much money on transmission repairs, but they do on rebuilds and they feel more secure about a satisfactory repair by tearing it down and rebuilding one. A lot of independent shops hate Chrysler because they were the first to go electronic, which disabled them for many years in properly diagnosing problems and effectively shutting them out of repair business. This is still quite prevalent in the industry, I'm sorry to say.
If you take this Dodge to an independent repair place, I'll bet the chances are they'll tell you it needs a rebuild. Be interesting to compare the old bands and clutches with new ones. There have been some upgrades to the 46RE since '98, so I'd advise inquiring about what they will do to modify and install and revisions.
Best of luck,
Dusty
Thanks again!
Best regards & Merry Christmas!
Dusty
Thanks, Berry
Thank you Popieswhip
Popieswhip
Do you experience harsh initial engagements when going from park or neutral to another gear?
Dusty
Dusty
Berry
The transmission contribution to stalling would have to be something like a locked torque converter, a stuck front or kickdown band, or excessive hydraulic pressure. Excessive pressure could be caused by a defective Govenor Pressure Sensor or even a dirty valve body. A locked torque converter would cause stalling in a forward gear and probably also present you with some harsh overall shifts. A stuck band (applied mode) could be caused by a stuck servo.
My apologies, that's all I can think of at the moment.
Best regards,
Dusty
If the converter was bad you wouldn't have a first or reverse.
Because of the age of your vehicle, I would first check the electrical connections at the transmission for corrosion. If you loose the circuit to the valve body or electronic governor it will cause this problem. This is very common on older vehicles, especially those in high moisture/snowy environments.
Beyond that you could have an inoperative front servo (broken or stuck) or a bad kickdown band.
Dusty
frank
Dusty
Thanks drew_blue
Sometimes trying to work on them laying on a bench horizontally puts side forces on the end of the shaft and makes removal difficult. If need be, make or use a tool to grab onto the Low/Reverse Drum to move it outwards.
Dusty
Thank You popieswhip
Thanks drew-blue
