Chevy S10 - GMC S15 and Sonoma Electrical Problems
Here's the place to talk aboutr yuour S-truck's lack of electrons
Thanks in advance,
Anne
Maybe your wiper arms got lose on their spindles and got out of kilter.
:confuse:
I am new to the forum...I have a 2000 S-10 and just my dash lights went out today. I check the fuse and they are all fine..Anythought???
:mad:
s-10. did you get it resolved?
Driving lights are fine however, when I switch on the headlights I lose everything. Any help would be greatly appreciated.
When you turn on the ignition key the Daytime Running Light (DRL) Relay back feeds power to the headlamps in series. This means that the power is fed backwards into the left side head lamp "ground" circuit and power flows through the left head lamps into the Right side head lamps to ground. When you turn on the head lite switch it provides power to the DRL module that turns off the running light function. This power line feeds the Head lite dimmer switch to direct power to either the high or low beams.
Your description would seem to indicate that the DRL Module and Headlight switch may be working but power is not getting to or through the dimmer switch.
Mine has since gone from staying on all the time to just being on when the car is running, to not working any of my blinkers, to last night everything electrical just died when I pulled in my driveway. i am not sure exactly what it is, but if you find out let me know.
The wiper motor may is probably wired with a hold in circuit. Once the wipers begin a cycle, a seprate/other switch closes and remains closed until the wipers complete the cycle and then the hold in switch opens (and Wiper motor stops). This is so that when you manually shut off the wipers in the up swing of a cycle, the wipers complete the swing and stop at the bottom.
I'd guess that this hold in position switch is bad, mis-adjusted or bent/damaged. I'm not sure exactly where iti is - but I guess on or in the wiper motor or linkage. If it's in the motor - you may need to swap it out. ...
LEt us know what you find ???
Canufixit
Good Luck :shades:
Can someone please help? I do not know where to start with this one. Anyone had this problem maybe with the boxes making this loud noise? Truck worked fine before I did the work..
Any suggestions?
Also my factory radio will not illuminate.
And..... now my reverse back up lights will not work?
