That is how they should work.
Mack
No warranty, no apologies and major run around from two different dealers. I was quoted over the phone a $500 replacement part cost with $350 labour by the dealer (Piercy Toyota San Jose CA) where I bought the car. They looked up the van, then quoted me the price. Of course when I went back to them they apologized, they looked up the "older version" then upped the labour quote to $650. I found it interesting that both dealers had the part in stock. You don't stock a $1k part unless you use it regularly!
I am appalled that the formerly reliable Toyota has come to this. Problematic cars, (I've had several issues with it, and at 60k it's on it's THIRD set of tires) and low ball quotes.
I too will try to take up the $1500 repair bill with HQ, but I am not optimistic.
Rapid tire ware . We’re going on third set at only 55K (warranty extended by Toyota on first set of run flats)
Front door popping (covered under Toyota recall)
Sliding door got stuck, and then came off track $3000 damage, dealer claimed only one other instance that they knew of.... rrrriiiight (any word from Toyota on this wide spread and Toyota specific problem?)
I can’t wait for more Toyota Quality to rear its head!
I spoke with Toyota head quarters and they told me I was basically out of luck. I mentioned the report that had been left in my car and that I had been serviced for the same problem once before. They then told me that they would call the dealer and speak with them about it.
Five minutes later my dealership called and offered to give me a credit for half the cost of the earlier repair. I told them I thought that Toyota should cover the entire cost since this was a known problem. They told me they weren't able to do that unless Toyota issued a recall (which they recently did for the automatic back door).
So make sure you save your receipts and hopefully Toyota will do the right thing and issue a recall for these faulty side doors as well.
The battery issue is still a wait and see (on our fourth now in about 3 years). Again, they replaced the battery, initially only at 50% of my cost (prorated amount), but then gave a full refund because I raised such a stink about it. Again, no good suggestions on how to diagnose, just a "well, if it happens again, you know where to find us" attitude. After all this, they still had the courage to ask me if I'd still give them a strong score on their customer satisfaction rating!!!! Too bad I have great difficulty separating product quality from service quality at this point.
My 2004 has had trouble with both mechanical back side doors. Drivers side would not close all the way most of the winter, finally after 2 visits to dealer and cleaning tracks it does close, but bareley and seems like matter of time before it gives up and doesnt close again...
Now the passanger door slider doesnt open all the way without scrapping the back metal outside the door ripping the paint off. Dealer said its a bad center hinge and while they are in there a new motor needs to be replaced, for $1700. Then ??? for body work and paint! He told me to try to source a used hinge and motor?!?!? but where? this is Big money for what I assumed to be a bullet proof car. Has anyone had better luck or experience?
My steering is now going out on the car and I just cant believe Im having this much trouble. Any help would be appreciated!
Robert
Any how, peruse the local junk yards, maybe.
You can just turn off the power feature and use the doors manually, if they open and close OK that way.
bruce
Mack
cc: Toyota Motor Sales U.S.A. Inc.
From: Tetsuya Otani, Customer Relations Division, TOYOTA MOTOR CORPORATION
Thanks for your input.
Best of luck.
Well, yesterday my drivers door started to go for the second time (one of the other recalls for defective welds). We all need to start to call the NHTSB!
I had a similar conversation with Toyota but since we did not own any other Toyotas at this time, the said they would offer NOTHING!. Obviously if you own 20 Toyotas they will pay 100%. This is a discriminatory practice by the way which opens the door to talk with attorney generals office or my State's Dpt. of Consumer Affairs.
The Sienna is pretty but has SERIOUS quality issues which Toyota is not owning up to! Have talked with several other who can't get rid of it soon enough! People need to start speaking out. We're still under 50,000 miles and I will not own this car for the second 50!
http://www-odi.nhtsa.dot.gov/ivoq/index.cfm
If the NHTSA sees a pattern they will force a recall.
My doors are fine, knock on wood, but be sure to register your complaint if you have one, that's the only way it will ever be recalled.
I am writing a letter to Toyota. I am also going to call one of the local radio stations to see if they can help.
I am so unhappy and upset!
Tell you what, you never know, even with an extended warranty.
Mine's in the shop, and guess why? The wiring harness is all chewed up. Huh? That's right, by CHIPMUNKS!
$740 worth of damage, and not covered by warranty since it's not a warranty problem.
Insurance might cover it, but with a $500 deductible it's not worth the claim, so it's all out of pocket.
All due to some rodents.
Would highly recommend people with Sienna issues to report out on it. As the reader indicated below, if I knew that I would have had five door problems (rear hatch [1 event], sliding door [2 events], one in the first week of owning the car, and driver's door [2 events]) before 46,000 miles, I would not have walked into the dealership in the first place. They've got a lemon and it's time to own up to it.
I've also filed with DOT on-line yesterday. After reading numerous post and other websites. The below post and article in a Dallas Tx newspaper took the prize. It's the story of a Toyota sliding door falling off it's track and hanging by the hinges. Before I post the article I must mention that I also purchaseed my van from a Southern California dealer with 10K miles. At 40K miles the right passenger door which has a powwer motor started making a clicking sounds as it closed. The door is now out of alignment and is rubbing against the body and inside door jam. I bought the Platnum Care 7 year/100K miles and have contacted Extra Care. As most of you know you have to take the van for an inspection first, sign a work order for labor/inspection then the dealer will call extra care (Platnum Care) and if covered will fix the issue. If not I will need to pay for the labor/inspection and the common $1700-1800 to fix the door. I'm hopeful my door issue will be covered. Anyhow below is the post/article of the fallen door found on Toyotafans.com
The right door of my 2004 Sienna FELL OFF today! Scratched the paint. The left door hasn't worked for months now so I was waiting for this one to quit. Another lady was on Click and Clack when her 2004 Sienna doors fell off.
link to Click Clack article :
http://www.dallasnews.com/sharedcontent/dws/classifieds/news/automotive/cartalk/- stories/DN-cartalk_23emp.ART.State.Edition1.36a7af8.html
We need a group effort to get a response from Toyota! The more people that call and complain the better.
Customer Care Hotline: 1-800-331-4331
Feel free to reference my case # 200806060609 and tell them to build a file on this.
I'll let you know how the repair goes. 2 doors! Shouldn't the doors on a car OPEN even if it is out of warranty? Toyota is not willing to do anything... the dealers say they can't either. Meanwhile my kids have to crawl over the front seats to exit our van. Nice.
Time to shop for a better brand.
I looked at my my sliding door hinges for signs of bolt/nuts movement and can't tell if the bolts/hinges have moved. My door is definetly out of alignment. It rubs and click as it closes. It's to the point that I no longer open it to prevent further paint damage. Please post your quick fix and mention what hinges to look at ?
Thanks, Hector
Thanks for posting. I spoke to a rep.at DOT this afternoon who stated that every cmplaint would be looked at and investigated. I hope this prompts a recall on the sienna sliding power doors. I also e-mailed corporate in Torrance,Ca and attached a link about an article written to a Dallas, Tx newspaper regarding a Sienna door that have fallen off it's track and was hanging by an upper hinge. A five year old boy opened the door using the inside power button behind the front right passenger seat. :surprise:
After multiple calls to extra care, one visit to a dealer,e-mail and calls to corporate and toyota financial services in Torrance I still can't resolve my out of alignment/failing mid center hinge on my 04 Sienna right sliding door. I read a post where an owner obtained and exploded view of the hinge which contains bushings and other parts and was able to appeal her case through Toyota Financial Services. The hinge/parts wears over time and causes the door to clank and rub against the body of the van particularlly in the upper area :mad: near the rear bottom window area by the rear quarter panel. I'm going to obtain a service manual from my library to take a look at the center mid hinge in an exploded view. Hopefully I can build a case with Platnum Extra Care and Toyota Corporate in Torrance,CA.
http://toyota.justanswer.com/uploads/snd27613/2008-07-17_221901_sienna_door_inop- _tsib.pdf
I attached the file in an e-mail and sent it to corporate. My next move is to speak with relations manager at the dealership where I purchased the van. The first dealer referred me back to corporate.
I guess some people could have their kids hanging on/climbing the doors and abusing it, to the exclusion would be to cover cases like that.
Just try to show that you have not abused the door in any way (if that's the case).
a safety feature which prevents the door from opening when the gas cap is open
Actually, it limits how far the door opens, i.e. it will not open all the way, but it will open.
An important distinction.
The door will require you to remove the panel and other bolts/screws/clips to make the adjustment. This of course is if your cable and motor are in one piece and not broken or wrapped around any moving parts. I looked at an exploded view of a 2004 Sienna door and one has to be mechanically inclined to perform the adjustment or replacement of the motor/cable assesmly or hinge. It sounds like you cable is wrapped around something and won't let your door/open or close. Look at a service manual in your library for a detailed look at the inside of your door. Another option is to take your van to a body shop not at the dealer who paint and repair toyota's involved in accidents. They may possibly be willing to obtain parts or adjust your door for less than at the dealer. Make sure that you use Original Equipment Parts for the repair if needed. Good luck and post your results.
Of course Joe at Ernie Palmer is going to tell you that cable/motor problem is unusual. Toyota doesn't want to step up to the plate on this recurrent problem with hundreds of owners. You van is past the 36K factory warranty. The cable that snapped comes as a single part cable and motor. Price at the dealer is about $1000.00 plus 3-5 hours of labor your looking at $1500 to $1700 total. Many cables has snapped and mid center hinge/bracket have worn out causing the door not to open/close or rub against body of van. Believe me I been through the wringer on this one and still need to travel to the original dealer were I bought the van and negociate a repair price with the customer relations manager. I'll give you some hope. You may possibly find the motor/cable assembly cheaper through e-bay or a toyota original parts supplier on the internet. I found the right mid center bracket and hinge for 50% less than what the dealer wanted. Replacing the cable and motor is not easy and requires that the door be removed. Please report this problem to the Department of Transportation so that a recall will eventually be issue as the complaints continue to poor in. There is a link to that website in one of the earlier post. I have also posted a Technical Service Bulletin (TSB) in an earlier post. Look at it and see if your vin number matches. toyota put this out because of problems with the door. The dealer will argue that the vin # needs to match and Corporate Toyota will simply refer you back to your extended warranty people or the CRM at the dealer. Good luck and post your results. Don't forget to file with the DOT.
SoCal 13 :mad:
