Subaru Forester (up to 2005)
My tires are also much quieter than the Duelers, again Touring tires like yours. The Duelers have at least a theoretical advantage off road. They were better in snow, for instance, but that's all.
Yesterday my sister asked me what that torx driver was for, I had to show her.
-juice
My quick second thought was that if I ever ended up going roof side down, I would probably appreciate having a couple of cross bars above my head.
If not, wouldn't it be worth the try?
Interesting comment; my wife says she doesn't like the way the Subie looks quite as much now that the roof rails are gone. I'll admit it does take away some of the SUV look and push it more towards the station wagon realm, but I don't care about looks that much. Combine that with my new blackwall tires, and you could make the claim that our Subie has an identity crisis and wants to be a car (it sure drives like one, which is one reason why I love it)!
Thought another benefit of removed cross bars may be better gas mileage, but I'd be surprised if I actually can see a noticable difference. Shouldn't make it worse, at any rate!
The way I see it, the major benefit of not having them on when not needed is easier snow removal, car washing and waxing. I did get a couple of painful bruises on my hands last time I tried to wipe/wax/polish underneath the bars and especially close to rail attachments.
K
There are reinforcement beams at the B- and C-pillars. The Forester is registered as a car and by default has to withstand 150% of its own weight on the roof.
The only roll over I've ever heard of was this guy from Australia who had a nasty lift kit and tall springs. He showed pictures and all. The unibody held up AMAZINGLY well. It was a total loss but the passenger compartment was completely intact. He walked away from it.
I keep the cross bars on. I use them occasionally at Home Depot, and you never know. If it took them off I'm sure I'd wish I had them the next time I went shopping.
-juice
I'm sure that's true for the closed-roof versions, but how can there possibly be a B-pillar crosswise reinforcement beam on Foresters having the huge sunroof? There's nothing but air between the tops of the B-pillars!
It seems to me that sunroof-equipped Foresters almost have to provide less structural integrity than those without. This would affect not only rollovers, but probably also side impacts, because the tops of the B-pillars would be more easily moved/dislodged without a crossbeam tying them together.
Which raises a question: In the recent side-impact tests where the Forester scored so well - were they testing sunroof-equipped Foresters, or closed-roof versions?
http://www.nhtsa.dot.gov/NCAP/Cars/2533.html
just kidding!
I'm sure they brace and reinforce the roof; it still has to meet the same 150% weight standard.
These agencies typically test the cheapest model available, so it was the X. They'll only do a 2nd test if the manufacturer pays for the vehicle.
For instance, the CR-V and Escape both scored poorly in IIHS side impact tests. Ford gave them a 2nd, with optional side air bags, to re-test. Honda did not. So Ford got better scores for those models (still not as good as the Forester), but the CR-V keeps its not-so-good score, even though the EX models with side air bags likely would have done better.
-juice
These models are then converted into blueprints for the manufacture tooling and programs for the cutting and assembly robots.
I can't imagine that there's a significant difference in the structural integrity of the Forester unibody with or without the moonroof. They modeled both, built tooling for both and tested both on the computer and in steel as well.
Although it may seem intuitively stronger to not have a gaping hole in the roof, the reality is that little bit of sheet metal in place of glass isn't going to matter much. The strength is designed in elsewhere.
As to the roof rails helping out in a roll-over, don't count on it. That's not what they're there for. The lateral forces on the rail will sheer it off the roof as you roll in a lot of cases. The cross-bars appear to be made out of some kind of carbon reinforced plastic (aka "carbon fiber"). They are very strong for their weight, but not designed to withstand the kind of load you're talking about. If overstressed, they'll crack or shatter.
Hope this helps,
-brianV
The point isn't that a little bit of sheet metal has been removed. The point is that the hole includes the space between the tops of the two B-pillars. Few sunroofs extend rearward past the B-pillars. On Foresters without the sunroof (and on normal vehicles with normal sunroofs), there is undoubtedly a structural roof beam welded solidly between the two B-pillars, connecting them. On the sunroof-equipped Forester, that becomes impossible. It may be that the sunroof models surround the opening with very stout reinforcing loop, and that the two B-pillars might tie into that; however (all other things being equal), it's tough to imagine how that arrangement would be as strong as the direct, straight-across connecting roof beam of non-sunroof versions.
If you plan on using a roof rack often, consider getting the optional Cross Bar Set-Square. This rack goes on and off very quickly without tools. It is compatible with all Thule components which are more varied than Subaru's offerings. This option is about $100 at subaruwrxparts.com. There may be an equivalent Yakima compatible rack.
In my opinion the factory Subaru rack with its Torx fasteners and proprietary cross bar shape is a blatant attempt to sell proprietry Subary rack accesories. These may not be as good as what Thule or Yakima makes. Your garage full of proprietary Subaru equipment will then give an edge to Subaru when you are considering you next car purchase. I like Subaru, but this is a rather blatant method of forcing brand loyalty on the customers they have already won over.
$100 for the square bar rack is a cheap way of not falling for this ploy while giving you a more verasatile rack that is fast and easy to take on and off. It is a no-brainer, especially if you already have Thule accesories.
I am a structural engineer. Any rack will provide some additional structural reinforcement during a rollover. Whether this will be enough to reduce injury or more serious damage depends on many factors too complex to predict. It will certainly absorb some impact energy even if it breaks away. If you knew you were to be involved in a rollover accident and had a choice, you would be a fool to do it without the rack. All this being said, I drive around most of the time without my rack on because the chances for a rollover accident in the Forester are not that great. Wearing seatbelts and having side airbags will provide the most significant benefits during a rollover.
The moonroof does add more weight - about 50 lbs more as I understand it - so perhaps this is the explanation. I've been told that the Premium package changes the spring rates and track width to counter the additional rollover risk due to the added weight, as well, but I'm not sure I believe that...
Stating that the moonroof necessarily makes the unibody weaker, however, requires more evidence than I've heard to date. I think we're speculating, sorry.
-envyabull: I don't doubt for a second that the roof rack adds *some* strength, or that it would absorb *some* energy no matter the circumstances in a roll-over. The question is whether its presence is enough to make a statistically significant difference, and that I strongly doubt. The other factors you mention will overwhelm whatever impact the roof rack might have, don't you agree ? "At the limit" you might see some benefit, but what are the odds of encountering just that situation ?
I wouldn't want people reading this board to conclude that their Subie is "less safe" without a roof rack on it. While it may be technically true, the difference isn't enough to matter.
Any more than we should be stating unequivocally that a Subie with a moonroof is "less safe" unless we have compelling reasons to believe that beyond mere speculation.
As to the OEM roof rack parts, they're manufactured by Yakima and fully compatible with their entire line. The crossbar cross-section is not a proprietary Subaru design. It's Yakima's.
-brianV
Also, when I had a moonroof installed I asked about it, they said indeed it gets removed but other bracing is installed in its place. Whether that makes it weaker is hard to say, you'd have to test the new bracing.
It's not factory installed, but the OE moonroof's bracing is, so who knows...
-juice
Where? Do you have a URL?
You could see the aluminum bumper beams, plus the roof reinforcements.
paisan took pics of the NY Auto Show, though.
-juice
I checked the pressure on my stock Yokohamas the other day and was surprised to discover they were, at 6400 miles, overinflated by 4-6 pounds front and rear, respectively. I had the shop bring them down to the proper levels as shown on the door frame tag, but I wonder why the dealer overinflated them so. Any thoughts as to mileage and handling issues? Which controls, tire mfr's or Subaru's instructions on proper pressure?
I see roof racks are in the news again - mine came off before I drove off the dealer's lot and have been lodging in my garage ever since. While I don't know that they improve mileage, their absence can't hurt it, and that's fine with me, since I like the cleaner look of the car w/o them.
Finally, I ended up taking my Power Acoustic 4-ch amp back for a refund. I found that it had apparently been blown by the installers in the installation process, which explains the problems I had with balance and sound. But their installation of an RCA plug kit to connect the new speakers to the stock AM/FM-Tape-CD appears to have improved sound measurably, and there's more than adequate power to crank out the tunes. So, my advice: forget adding an amp, put in some decent speakers, including the OEM tweeter kit, make sure your connections are proper and of good quality and you're set.
-juice
I agree with you that a Subie is safe either with or without their roof racks. I feel comfortable driving mine without its rack attached and I have the huge sunroof. More on that below.
However, increased structural adequacy due to the presence of a roof rack could likely be proven if enough testing was performed. I would stand on my roof rack, but I would never stand on my roof. So I do think for some types of impacts, the rack could make a difference to occupant safety.
I briefly checked the structure around my moonroof on my XT while going out for lunch. There is some additional compensating steel around the opening. I suspect the frame and sliding roof assembly also add quite a bit of stiffness. And lets not forget the glass itself. While not resilient, the sunroof glass is stiffer than the sheet metal used on the rest of the roof. It could be just as likely that the reinforcement around the sunroof is there to protect the sunroof from damage and leaking due to normal flexing of the rest of the roof while driving.
It would be shortsighted to assume that the presence of the factory sunroof results in a roof that is somehow weaker than a roof without a sunroof. There very well may be some incidents where the additional sunroof structure located more uniformly over the passenger compartment provides better protection than a B-Pillar roof beam made of formed and spot welded sheet metal.
Based on what I see, the aluminum roof rails and surrounding fairing/connecting structure on the new foresters will likely provide the most protection in rollovers. They are intimately connected to the A, B, C & D pillars creating two strong longitudinal roll bars.
So it is probably safe to assume that the roof of the Foresters are structurally adequate either with or without roof racks or sunroofs. I don't think there are any safety games being played by the Subaru engineers. If the roof racks were required, they would not be removable. The accident tests show that the new Foresters are at the top of their class. I suspect that the new dynamic rollover tests will show that the Forester has one of the lowest probabilities of rollover in its class. Certainly its car-like handling suggests that to me.
Be glad it's not a truck, those have loopholes big enough to drive...a truck through.
-juice
While I'm not a structural engineer, I am somewhat familiar with structural plastics, as my family has been in the molding and plastics forming business for over 50 years. Although the roof rack can no doubt handle static loads such as you describe, I am doubtful as to it's ability to handle violent impacts. I think you'd see abrupt catastrophic material failure in many rollover scenarios (especially in the cold), which would limit the rack's ability to absorb, deflect or dissipate the impact energy.
Most of the plastics that I'm familiar with experience a pretty steep increase in brittleness as temperature falls, and have relatively poor sheer strength to begin with. I'm envisioning a "rollover" as having a fairly large "slide" moment, which would induce large sheer forces that the rack would not tolerate. You'd just rip it off. YMMV, especially with aluminum rails.
I could be wrong though... Perhaps a rollover shouldn't be characterized as an "impact", and they might typically have more "rotation" than "slide". If so, I see your point. Regardless, the internal structure supporting the moonroof mechanism is an entirely different matter. That's a factor I hadn't considered.
It's entirely possible that the roof with the moonroof is actually "stronger" in some senses than the standard roof.
-juice: I agree. Not being a truck is a major selling point to me, and not because I'm just biased against trucks !
-brianV
We'll excuse Juice this time :-) Happy Anniversary!
Steve
http://moneycentral.msn.com/content/Insurance/P63955.asp
What happened to the Forester? I was under the impression that it was highest-rated among small SUVs.
I still need to test drive an XT Premium to gauge the differences in handling between it and the regular XT. Hopefully I will not get the opportunity to test its safety ion a rollover.
Ed
http://www.consumerreports.org/main/content/display_report.jsp?FO- LDER%3C%3Efolder_id=340571&ASSORTMENT%3C%3East_id=333137&- bmUID=1067615535434
don't know if it will go thru or if you have to have a subscription to the site.
Foreign cars used to avoid this dumbed-down Detroit "innovation" which is really unnecessary, since weather conditions calling for dehumidification occur much less often than those that don't. But the idea caught on overseas as well, despite its wastefulness, as another sort of "convenience" for drivers too brain dead to figure out how to run the A/C when required. Some justify it by claiming the A/C needs to be run periodically to keep it limber, but that can be accomplished much more economically with a few minutes of A/C idling every few weeks in the off season. But providing that intelligent option is apparently too hard for automotive engineers to handle, with the result that its absence ranks as my number one all time pet peeve of car design.
(No. 2 is fog lights that come on only with headlights as well, and not on their own or with parking lights.)
That means that they are not factoring in the IIHS Best Pick in front offset crash tests, or the IIHS class-leading side impact tests. Or the NHTSA quadruple 4 star results. Overall scores are now better than the Vue's or CR-V's, in some cases *far* better.
So basically that study is using outdated information. All those scores are better than the previous Forester. The side air bags also protect the head, before it was just the chest *and* they were optional, not standard.
Add to that EBD technology on the XS, better tires on the X model, bigger brakes on all models, the list of improvements for 2003 goes on and on and on. There's even one for 2004 - collapseable pedals.
I am confident that the Forester will easily climb to the top of that list once they re-test a 2003 or later model.
Want to feel even safer? How about heated mirrors, to keep those clear in rain and snow. Wiper de-icers. Front *and* rear? Guess who offers this, class-exclusive?
I'd tell you but you already know...
-juice
that's the topic I'd like to discuss more. This dumb set up exists on the CRV also, but there is a way to de-program it. It involves setting climate control dials in specific positions and starting the car while pressing recirc button (check CRV forums for the specifics). I was hoping something like that might exist on Forester too.
Besides, if heater control is set to "feet", certain amount of warm air goes towards the windshield. So, defrost position doesn't have to be used all the time.
For people concerned with the Forester's rating on CR, what's it to you? You know that our Forester is very safe vehicle, and who cares how CR or any other car critic rates it.
K
For reasons many others here have gone into in greater detail, I take anything CR says re autos with a grain of salt.
Ed
thanks,
Jim
It's 15 minutes job, done with just a screw driver.
Look here:
http://www.subaruparts.com/guides/Forester_2003MY_Tweeter_IxI.pdf
now when I re-red it, I stand corrected. It's a 5 minutes job. They should be doing it for free, as a courtesy to their customers.
K
"For people concerned with the Forester's rating on CR, what's it to you? You know that our Forester is very safe vehicle, and who cares how CR or any other car critic rates it."
At the risk of sounding thin-skinned, please understand that the feeling around here is one of being family.
Whenever the family name is besmirched, or is made the subject of misleading info, or is not given due credit as in the present case, it sort of riles.
Craig
Larry
I am not completely convinced that I received a correct diagnosis so I was hoping someone might be able to provide insight into whether this makes any sense or not.
This noise occurs regardless of gas brand or octane level. It occurs on acceleration and when climbing hills primarily, but has also been noticed when cruising at highway speed. I can only describe the sound as a rapid fire knocking noise from the engine compartment. The noise apparently is not loud enought to trigger the knock sensor.
The dealer was not able to find any diagnostic problems. Is it possible that this something I am just going to have to live with? The owners manual states that you should not be concerned if the engine knocks occasionally on hills or acceleration, but how severely or persistantly does an engine have to knock to cause piston damage?
We have to make an obscene profit somewhere!
Can you, or anyone else, please describe the location and explain the operation and purose of the "tumbler valve"? I never heard of such a item before.
Note that we typically shift early (3000 rpm) when driving around town, and routinely drive through hilly terrain in 5th going 40-45. Yes, I have burned premium (91 octane in these parts) in the past, but I've just switched to 87 with no ill effects.
I've also been known to drive cross-country at 85 for hours on end, to tow a 1 ton camper a couple of times a year into the mountains, or to push the Forester rather enthusiastically through the mountain twisties (not all at once, of course !).
Never a ping, and I'm watchful for any sign of trouble, mind you...
I'd get a second opinion. The 2.5 should purr like a kitten at idle, and growl pleasantly when challenged.
-brianV
FWIW, reset the ECU to see if that resolves it.
-juice
As a refresher, I'm the guy that complained about pinging on my wife's 2003 Forester during medium acceleration. It was diagnosed last year by the dealer as "spark knock" due to bad gas. After rotating gas stations and occasionally using mid-grade, the problem persisted.
I took it back to the dealer about 3 weeks ago. They reprogrammed the ECU and I have only heard pinging one time since. More importantly gas mileage over these last two tankfulls (I know, limited data points) has improved to 21 and 23mpg respectively. Right now I'm optimistic that the reprogramming has fixed the problem.
If in addition to what you describe hearing, you also notice a rotten egg smell and poor gas mileage (our average had been 18-91mpg), then it could be an ECU problem like Juice said.
Ron
I too am in the plastics business. I went from steel in nuclear submarines to aluminum for jet airplanes and now am in plastics for buried structures. While not as glamorous, buried plastic structures is the most complex and interesting of these disciplines.
I will need to look at the new factory bars on the XT to see what the materials are. Mine were never on the car since taking delivery. They are stashed in my garage. The optional square bar racks are painted steel, maybe galvanized in places. Their pillars are taller than the factor racks and probably more likely to buckle under compression or side force. Still they could help keep the longitudinal roof rails in column under some loads.
The plastic material you seemed to be describing was polypropylene (PP). PP is known to be more brittle than other more common plastics like high density polyethylene (HDPE). PP can become even more brittle at colder temperatures and some types even transition to a glass phase at colder temperatures not uncommon in colder climates. Despite these apparent shortcomings more PP is being used in automobiles including Subarus.
As you know, selecting the right plastic usually involves a compromise on properties. Even with the PP family there can be large differences in stiffness (flex mod), impact strength (Notched Izod), tensile strength and melt rate. I suspect automobiles typically use impact-copolymer polypropylenes. Furthermore, they probably blend in additional impact modifiers to increase the materials impact strength at lower temperatures. This will also lower the point of glass transition to temperatures well below those experienced by autos. Much of the plastic interior of cars is high impact PP. Also most battery cases are made of PP.
I just received my optional splash guards in the mail. These things will be in the cold getting pelted by rocks ice and snow. Those with just a basic understanding of plastics would never use PP for this application. However, they are indeed made of PP blended with EPDM, a common propylene rubber impact modifier. The splash guards felt more like a firm rubber rather than typical PP. The use of PP - EPDM was not the big surprise for me. I would like to know how they are able to spray on paint and make it stick. Paint and adhesives do not readily adhere to HDPE or PP.
One of our most successful products is dunnage bags for restraining shifting loads on a truck or train. The forces involved when a train is "assembled" in the yard are considerable - they roll a car down a slight incline and let it slam into a standing train to couple. I've seen multi-ton loads shift 3 feet.
It's amazing what they can do with plastics by adding modifiers as you describe. The early attempts to adopt plastics in cars resulted in a lot of cracked dashboards, if you recall. Today it's used in various formulations all over the place. Laminating various materials together is another option in some applications.
I think I've been underestimating the strength of the roof rails - you're probably right, they could offer additional (and in many scenarios significant) stiffness/strength to the roof structure.
-brianV
