Dodge Ram Idle and Stalling Problems
hodgepodge1
Member Posts: 1
I was driving my truck today and suddenly the engine died. It was as if I had turned off the key. There was no indication there was anything wrong prior to this.
I checked the fuel pump relays and fuses for the ECM. It just cranks without starting.
Does anyone have any ideas?
See also: (Video, 2:31) DIY Dodge Ram Stalling Fix
How many miles does it have on it.
considering what u said Id say it has something to due
with fuel pump or line
Dusty
I'm getting spark but no fuel. I can hear the fuel pump humming when I turn the key in the ignition. I'm thinking maybe its a clogged fuel filter??? However, I have no clue where that is located
Donna
I would check for a failed Automatic Shut Down (ASD) relay or an ASD open fuse (either 20 or 30 ampere) in the Power Distribution Center (PDC), first. Check the PDC cover for location of the fuse and relay. If you cannot locate a problem there, I would recommend performing the fuel pressure test first.
NOTE: If the engine has been shut down for some time, fuel pressure in the fuel rails may be diminshed and the test will be inconclusive. Then the fuel injectors should be checked using Noid lamps.
1. With the engine off and the ignition key removed, disconnect a connector from any fuel injector.
WARNING
If DC current is maintained too long it will overheat and burn out the injector coil.
2.Using two jumper wires and the vehicle battery, energize the fuel injector for no more than a few seconds.
CAUTION
Fuel may be under extreme pressure. Wear safety glasses and be prepared to absorb fuel with a large rag.
3. Locate the Fuel Quick-Connect on the fuel rail.
NOTE: On Dodge trucks the quick-connect is usually found on the fuel rail on one bank of the engine. The other bank will have a fuel pressure test port that includes a small metal cap. Do not use the pressure test port to relief pressure.
4.Disconnect the fuel line quick-connect. If fuel is discharged then the fuel rails are receiving pressure. If you've got fuel pressure then you've probably lost electrical power to the fuel injectors. Check for a failed Automatic Shut Down (ASD) relay or an open fuse (either 20 or 30 ampere) in the Power Distribution Center (PDC). Check the PDC cover for location of the fuse and relay.
If that's okay you might have loose connection somewhere in the harness or a failed Powertrain Control Module (PCM).
Good luck & Best regards,
Dusty
Well we lifted the bed up on the truck and replaced the fuel pump. My only question now is that the pump makes a constant humming noise which in my opinion is really annoying....I wasn't sure if this was normal or not?????
Donna
In-tank fuel pumps are quite noisy and when you're very near the pump (especially if you still have the box lifted) it may sound unusually loud to you. The test is can you hear it inside the cab? You shouldn't.
By the way, if you've lifted the box I'm assuming you removed the box mounting bolts. Please be aware that on Dodge trucks the box mounting bolts are a one-time tighten only. If you try to reuse the bolts they will loosen and the box will move around on you. New bolts are required when ever the torque has been reduced (loosed) on the bolt.
Best regards,
Dusty
I was finally able to get a Haynes manual. In the tune-up section, it states in several places not to clean throttle body with carburator cleaner.
I'd appreciate any suggestions.
Ross
My first suggestion would be to thoroughly clean the throttlebody, check for a clogged PCV valve, and also check for brittle and cracked vacuum hoses.
Dusty
ps. about a month ago, it would start real rough after a rain, but this seems to have disappeared? - not sure if this is related to the above problem.
it was running after a short stop,i got 300 feet then loss power it would idle fine but even in park could not get rpms over 2k & runs very rough when giving it gas.
checked fuel pressure ok. any ideas what to do?
The problem turn out to be the catalytic converter broke inside and blocked the exhaust.
Dodge gal
I think Ill just live w/ it this time around.
So, for now it seems to be fixed I have been driving it this weekend and no problems, so the battery seemed to be the answer for me.
It only happens 5% of the time on exceleration - just as up pull into a busy street.
The Dodge dealership though it was the fuel filter needing changed. They fixed every other thing on the truck except the stalling. Before I spend another $720 including
$60 and hour for labor - I want the check some easy things myself.
Would someone give me a few other easy parts to check.
Is this normal ??????????????????
Regards
Corkscrew
Corkscrew
