Mitsubishi Montero Maintenance and Repair
mylimited
Member Posts: 2
in Mitsubishi
I do not have the changer in my vehicle. Looking for the stock one, but not at dealer prices. Tried E-bay,no luck. Any help appeciated. CS
I did a search & I think I am one of unfortunate ones to have a problem with the water pump.
Jeff
I have a 1999 that just started doing the same thing with the idiot lights and the 4 whell attempting to engage when I come to a stop. Did the dealer happen to get your problem resolved? If so, what was the culprit?
> may solve intermittent 4wd engagement problem. Is this complicated, and
> likely to solve 4wd issue?
On the previous model cleaning and lubricating the auto hubs is not
complicated althoug the manual suggests otherwise. It actually solves
most engaging/disengaging problems.
Don't know on the later model. Give it a try.
Good luck,
Erik-Jan.
http://www.fotograaf.com/trooper
===========My Story===================================
I purchase a $1.98 of chassis lube/grease in can with straw applicator from the local Mart store and then sprayed under chassis with light pressure soap and water including the front hubs outer and inner. I then let dry and then from underneath with skateboard I lubed (sprayed) every possible moving part I could fine concentrating on the inner hubs, driveshaft U joint and axle gears close to wheels. So there you go after 150 miles still no problems and I am still waiting on the dealer to contact me with any answers or suggestions from the Mitsubishi tech line. The below website shows picture of driveshaft U joint and other moving parts I did not open or remove anything I only sprayed what I could see that was a moving part.
http://www.procarcare.com/icarumba/resourcecenter/encyclopedia/icar_resourcecent- - er_encyclopedia_driveshaft1.asp
Would someone help me please 'cause I am running out of option.
"this is usually sorted out if you dis engage the 4x4 to 2x4 and then reverse your vehicle back for approx 10 meters. "
Try this and see if it helps. Thanks
I CHANGED THE SHOCKS AT 70000 MILES AND THEY WERE WASTED ALL 4 WOULD NOT SPRING BACK UP. I HAVE TRIED MONROE FLEX, AND TWO OTHER BRANDS FORM THE LOCAL CHECKER AND AUTOZONE AND IT IS EXPLAINED TO ME THAT THEY WILL GIVE A GREAT RIDE, I DONT THINK SO. PLEASE HELP I LOVE THIS TRUCK I DO NOT WANT TO TRADE IT IN. DO I NEED THE ORIGINAL SHOCKS. DO I NEED SPRINGS AND BUSHINGS. I HAVE 87000 MILES AND DRIVE 2MILES ON A WASHBOARD DIRT ROAD TO GET TO THE HIGHWAY AND WHEN IT RAINS THE ROAD HAS 8 INCHES OF MUD THIS IS WHY I NEED MY MONTERO 4X4.
#22 of 22 Re: 4x4 dummy lights blinking [rtsco] by mujman Oct 04, 2006 (7:13 am)
Did that work? Does anyone have any other suggestions? I also have not had any problems... is there something to fix? Should I expect a problem?">
Is this symptomatic of these truck ... Am told that it will require 5 hours of labor to replace these gaskets ...
The good news is: It's just the gaskets and you could just do it yourself (it might take you double the time[ouch]& you'll save some money.
The bad news is: It's really not such bad news...5 hours labor is approx. $60.00/hour plus parts. If you ask me it's worth the money, time, and if you don't have the experience/tools a simple gasket could become a nightmare!
BTW, if you try and randomly punch in the codes, you have three tries, after the third time with the wrong code the radio will lock up, you will then have to leave the key in the on position for 1 hour.
I do not know if any of this is true or not, however, I did try 2 random codes and the screen indicated that it was the 2nd error, so I will wait until I get the radio out before I try it again.
I also found a site where a person had a 2000 model, and they said that if you are real careful you may be able to pull the cup holders half way out and gently pry the top plate off of the radio, they stated that the code was on the front top of it, I tried this but no code, although I did locate the serial numbers.
Good Luck.
A few days later, the belts started squealing real loud, we then took it to my mechanic to have them replaced, which I could have done them myself, however, I am glad I did, with 130k miles on this vehicle, none of the belts looked like they were the right ones, so I had him go ahead and change all the drive belts, fan belts etc as well as the timing belt, and while we were that close to it, the water pump. It is a good rule of thumb to change the pump any time you are replacing the timimg belt or vice versa.
This trip cost me $684.72, parts and labor, the one good thing is that it was all mitsubishi parts, where before, who knows. You will definitely pay for the named brands, but what the heck, use what's called for, when you try and just get by, your only asking for trouble.
My only regret is that I did not let my mechanic do ALL the work, I may have even saved some cash by doing so.
This vehicle looked as if it hadn't had any servicing on it at all, other than the original owner taking extremely good care of the exterior and interior, it seems they forgot about the motor.
Something to remember about the timing belt, if you do not service it or any other major functioning part for that matter, you just may wind up with a real nice boat anchor.
Good Luck.
Also, where can I find a basic repair manual for the same vehicle?
I checked the alternator fuse (100 amp)and it is good. The cables check ok, and the battery is putting out 12.9 volts. The only other thing I can think of is the battery relay. Any others have a similar problem?
I am new to this forum, as I just picked up a 2001 XLS 4WD. I drove it off the lot at 12:00 this afternoon. I took a 10 mile drive to the local hospital for an appointment for one of my kids, and when I backed out of the parking stall two hours later , I am now having the same problem that everyone here is describing. Sidenote: the four wheel drive was not even touched today. It had only been tried out during the test drive, with no problems, of course. In fact, the car was flawless during the test drive :confuse:
I am presuming that I am having the same problem as everyone else. I did notice, though, that I am only getting noise from the right front side, so I'm guessing that maybe that is hub that is hanging up? And, can you clean out those hubs by taking it to one of those self - service car washes and spraying the living crap out of the hubs and associated parts? I am really concerned about making the problem worse, to the point that I am afraid to drive the vehicle to a Mitsubishi dealer. (I wish I'd bought the car from a Mitsu. dealership now) I am not very mechanically inclined at all, so I am forced to deal with mechanics and/or dealerships on all of my car issues. If anybody is in the Salt Lake area, and can recommend a good Montero mechanic, I could sure use one. Thank you all in advance for replies.
So the code should be on the back of the radio?
I hope cause the dealership will charge me 77.00$
About a week ago, my trucks battery was disconnected when we wanted to put a new battery. As a result, the radio locked up. Not knowing that we had the code, my brother randomly punched in codes. After about 3 tries, the radio started displaying "OFF".
My question is, how do I get the radio back to a state where its ready to accept the 4 digit code?
Thanks for helping.
autobuyer1.
How to restart a Honda stereo that has lost its code
Anyone know the Mitsu way?
1995 Mitsubishi Montero
142K miles
3.0L engine, 6cyl
Joe/San Jose
spark plugs are good and wires to
i also have spark but it seem like its not fireing..
can anyone help??
