According to the bottom of page iii, my Owner’s Manual part number is 25919686A First Printing.
In this example, you can see the Owner’s Manual part number is 20923540 A First Printing.
The Vehicle Personalization documentation begins on Page 4-38 and runs through Page 4-43.
There are discrepancies between the manual documentation and what actually displays.
Documentation Comparison
For example:
The manual lists seven menu items under Climate and Air Quality but only six display and they are worded differently.
The manual lists four menu items under Comfort and Convenience but only three display.
The manual lists Personalization by Driver under Comfort and Convenience but this does not display. This seems to be a major problem in that, according to the documentation, “This allows the selection of if [sic] the personalization settings are specific to each driver or the same no matter which key [sic] (fob) was used to enter and start the vehicle.” Whoever wrote the documentation is, most decidedly, not an English major.
The manual lists Collision/Detection Systems but this does not display.
The manual lists five menu items under Remote Lock/Unlock/Start; however, seven menu items display.
Questions:
1. What is the build date for your vehicle?
2. What is the part number of your Owner’s Manual?
3. Does your manual documentation match what actually displays?
4. Is the Delayed Door Lock documentation in your manual different from mine?
5. Does Personalization by Driver actually appear as a menu item on your vehicle?
So far I have no issues, knock on wood. The car is fast but has a slight lag between when you depress the accelerator pedal and the car’s response to it. I am having a ball with all these technology features: The Xenon headlights are blindingly bright and has brought confidence back to my night driving again. I would advice all future owners to get the Xenon because it is a small price to pay for such an improvement in night vision.
Two things I care strongly about are the navigation and stereo systems. The navigation system works fine but the map is not as refined or clear as my Magellan portable device. So, I rely more on the voice prompts than the visual cues. When using the eNav feature with MapQuest the volume decibel is much higher than in the regular mode. By the way, does anyone know how to adjust the volume in the eNav mode. On the other hand XM traffic is great and is well worth the extra $3.99 monthly fee.
The sound system is very good but the bass sounds a little muffled, certainly not as clear as the JBL in the Avalon. I’ve tried resetting it but it does not seem to make much of a difference. I don’t have an iPod (yet?) so I have not yet used that feature but recording my CDs directly to the hard drive make a CD changer look primitive by comparison.
On the road the car gives me pleasure as I drive each mile. The handling is crisp, the car soaks out road bumps and the adaptive suspension really does work. The adaptive suspension can be best explained by walking barefoot on gravel. You feel every pebble under your foot so you adjust your walking accordingly. I am averaging about 19 MPG because I do a lot of stop and go driving as well as I left the engine running idle on a couple of occasions for well over two hours.
Final verdict: The CXS is an alluring and great car! I like the looks of the 19” wheels but I hate the ride on rough roads.
The Bluetooth, OnStar & computer aided feedback --tire pressure, mileage, o/s temp, diagnostics readings to e.mail account monthly and service data very friendly. The interior is "to die for" per the wife (primary driver). Beautiful car.
General Motors supposely are working on a fix.
I have contacted Lemon Law here in Penna.
I'm worried about a saftey issue even though General Motors said there is none.
The Toyota gas peddle comes to mind.
Good luck with improving AM reception on modern cars due to decline of AM stations and market for these antiquated stations limited transmission fields.
Do you have a case number for your problem?
I'm not sure wether I'm learning to avoid the problem by the way I drive or it's curing itself, somehow. Every so oftem when I get in a tight spot it comes back but otherwise it is only an annoyance.
However I can imagine GM having to replace my whole front steering system at some point.
Dealer may check antenna hookup for reception or replace radio unit (may not fix).
good luck
THanks.
I have had this checked out by the dealer and they said Buick service indicated that this was the normal operation of the BT. In order for me to disconnect BT, I had to go into my phone settings and turn BT off. And then when I wanted to use BT, I again had to go into my phone settings and turn BT back on.
I contacted the Buick help line by phone and asked for this "problem" be escalated. After a couple of days, I was informed that the dealer had it right, this was the way the system is programmed and cannot be changed.
I also informed the Buick rep that I have an 08 Explorer with BT. This vehicle works exactly as it should. When I turn off and exit my Explorer, the BT disconnects and I am able to use my cell phone normally. When I re-enter the vehicle and start the engine, the BT automatically reconnects. Great.
Is this a design/engineering flaw or error that Buick is not able or willing to correct? Has anyone else experienced this problem or am I the only one?
Thanks for any help or insight to my problem.
Have you tried with another phone?
My wife has a Samsung and I have a Motorola cellphone. They both work the same in the LaCrosse and in the Explorer. The LaCrosse keeps the BT connected even if you are outside the car.
I'm sorry, but I have trouble believing that the car is maintaining a bluetooth connection to a vehicle that is no longer under power. The more likely scenario is that your phone is not successfully detecting that the bluetooth connection has been severed and is therefore staying in bluetooth operation mode even when the related device (the car) has been powered down.
The cellphone is turned on with the BT turned on.
With the car running, there is a BT connection.
I can turn the car off and exit the vehicle. The BT connection is still maintained. I cannot use my cellphone from outside the vehicle.
If I get far enough away from the car, about 50 to 60 feet, the BT connection is broken and I can use my cellphone. However, it I then again come close to the car, the BT connection is re-established and I am at the point where my cellphone is not usable. This all takes place with the car turned off.
Although my two phones are from different manufacturers, they are both Verizon products. Maybe that has something to do with it.
I will attempt to borrow a non-Verizon phone and see what happens.
When I step out and the car is still running. The BB asks where I want to take the call, in-car or out. Pretty smart. I think the Buick may have a newer BT protocal that isn't recognized by your older phones(?).
Just remember they sell Onstar so why would they want you to be too happy with your own cell.
OnStar is good backup IF you forget your phone or need Onstar specific service
other than the phone. The BT & OnStar systems work off the same basic system and are very compatible with certain smart phones. Great for convenience, safety and security in our opinion. Have fun.
"The end result, of course, has been staggering. July sales of the LaCrosse were up 362.3 percent, driving up its year-to-date performance to a 228.3 percent increase over the first seven months of 2009.
And at this stage, the volumes for the LaCrosse are really starting to pile up. Last month sales crested the 7,000-unit mark, hitting 7,047 to be exact. The sales of its key rival, the Lexus ES, were down 10.3 percent last month, at 4,093 units. The Lincoln MKS sold a meager 969 units, a decrease of 19.6 percent.”
By comparison in November 2009 Buick sold about 3,000 Lacrosses
http://www.autotropolis.com/research/buick-lacrosse/
The lacrosse sales performance for July is even more impressive when compared to the Avalon and the Acura TL. I hope the momentum carries into August.
The all-new Avalon sedan posted sales of 2,815 units, up 42.1 percent over the year-ago month. (Hmm! and this is a model that sold over 106K units in 2001)
Acura sales for the performance luxury TL sedan tallied 3,123 units, a decrease of 9.1 percent from year-ago month.
By the way, I am yet to see a Lacrosse on the road. I saw one in a hotel parking lot a few months ago and that’s it.
Now that I have had the updated drivers seat module replaced and the seat is working as it should - I am happy.
Since I ran over a rock (about the size of a red brick) and destroyed both the aluminum rim (a six inch gash) and the tire (19" rims) at a cost of $1000 I am very careful what I hit. However with the streets, roads and highways in such disrepair I worry about hitting a pothole. With the 15"/16" rims one never worried about damaging the rims because the wide side walls of the tires would absorb the hit - not true of the 19" rims with tires with very narrow side walls.
All in all the combination makes one's butt feel every little bump in the road and I believe the tires are more noisy. In the past (15"/16" wheels and tires) you could lower the tire pressure a little to make a more comfortable ride. Afraid to do this with this combination.
One additional find is the tires seem to lose a few pounds of pressure very quickly.
2 points:
They need to check for any type of power steering line ground out to the the body by following PIC5235C.
Check to be sure noise is from steering gear. If this is the case do not repair as it won't do any good - maybe. They are "working on a slution" which is supposed to be released shortly.
My read is they know what it is but don't know how to fix it yet. :mad:
American cars were unfashionable when comparative quality of design and build were not there. Perceptions can change fast if you have good product that is also attractive. Witness Kia and Hyundai's rise in the world by revamping their line-up. Look at the great perception Ford brand (not Lincoln) brand products have now.
The driveability is also much improved to us. Smooth, quiet and efficient with 29 mpg on the hiway at 75 mph. Safety, convenience and hi-tech features are at a level with any available model even near the selling price.
Only remaining factor is the long term quality that places like Consumers Reports will report on down the road. The basic components are tried and tested on previous models but the overall model will report on itself over time.
Great car so far after 2300 miles!
As far as perception and what is fashionable- the same can be said about the Chevy Malibu, which I compared to the Accord and Camry before purchasing a new 2010 Malibu last year for one of my kids.
I originally posted this in the Malibu forum today but hope it is not out of place here.
John, like you I believed in the Malibu until this happened:
"Just as we started having problems with the electric power steering in our 2008 Malibu about three weeks ago we received a recall notice from GM. On Monday it died and the car was rendered undriveable.
So for three days they've been working on replacing the electric power steering motor. First, they did not have the part on hand, and now, the fix is such a big job they have to remove the console. I asked the service manager if they had the proper tools to do the job. He said yes and promises there will be no squeaks and rattles when the job is done.
Up this point the Malibu was bullet proof and we bragged about its quality and reliability incessantly. Now, I am not quite so sure. Nonetheless, I hope they extend the warranty on this new electric power steering motor because I would hate to have to replace it in two years time down the road.
With the rash of problems involving the electric power steering in the Cobalt and now the Malibu I hope GM reverts back to the hydraulic power steering set-up."
Check your RPM's and final drive ratio. Ours runs below 2000 rpm at 70 which is the key to higher mleage IMO. Only one guys view but seems to explain results.
good luck
Last week I started driving in the manual mode. I love the ride and handling but not necessarily the constant gear shifting. So I decided to try the Sport Mode and voila...driving nirvana. The car handles great and the steering and ride are perfect: not too soft or not too taut.
All I can say is Wow! as I drive the streets of New England with a big grin on my face. But I am beginning to believe my mileage is worst than in Sport Mode than in the Touring mode. Could it be that I am unconsciously driving more aggressively or does the Sport mode inherently use more gas? Your thoughts and experiences are appreciated.
The compression in those Classic body Aurora, at least on the 96, was around 10.5 and anything over 10 pretty much says premium fuel. I know that requirement was done away with on later Aurora engines. I know some that used regular in early engines and got away with it. The knock sensors were good enough that you could do it without getting ping, but power was lower because of the retarded spark. I wonder if there were other effects that occured because of running a high compresion engine in that state.
Did they lower the compression to remove the premium requirement?
Or possibly go to direct injection?
Does yours require premium? Have you tried it and noticed the difference between regular and premium?
What do you see with heavy local/city traffic?
With a lot of stop and go, I'd be around 16, but lighter traffic and taking advantage of driving the lights I'd get in the 18-19 range. The Aurora body was quite heavy. No thin steel panels on it and a fantastic suspension system for its time.
Quality is a lasting impression and more likely to create repeat buyers. I would have to give that to Ford when compared to other Detroit.
Perception is what it is. Sometimes reality.
I know someone at KIA. Before the Toyota blow-up, they circulated internally to be on the watch for government influence. Can you think of a better way to prop up ailing Detroit than destroying competition sales?
I'm not saying Toyota problem did not exist, but news media went after it like a politician they did not back.
Either way, it is a chance for GM to shine or be Titanic.
I'm not sure of overall picture, but key fobs that fail for a specific reason, at least 15 years running, is definitely showing a problem.
Lots of little things that speak to quality of design and build.
Only one year old and dash is warping in the middle. Usually I drive alone, no load, and recently the back end has started with a bounciness on some roads as if the shocks are not working.
These are just new items that I could add to a long list if you've seen my prior complaint list.
BTW, I have not yet seen the recall on this vehicle, but son-in-law got one for his. He had gotten rid of it about 6 weeks earlier.
This is one of those perception things that GM needs to work on. Too many years pass before fixes are done and when they do a major redesign they build the same mistakes in as previously done.
Example: Early Auroras (95 & up) discovered a problem that was eating electronic components including things such as ABS/TCS computer and controls. The problem was tracked to the radiator cooling fans circuit. As the relays turned them on and off, voltage spikes were sent down the wiring which could damage electronic components, shortening life, or kill them. The fix, add a short jumper harness which included a dampening diode at the fan harness disconnect.
Surprise, same issue with some 09 Malibu according to TSB. Guess what, the same exact fix. That is 14 years of stupid.
