If u go to Huntington Hyundai, ask for Bob Awn. Very nice salesman. Their Service Dept is the best on the East Coast. I've been dealing with them for over 10yrs. Good Luck!
I just purchased a 2011 Sonata Turbo before I heard of this issue. I experienced the pulling to the left as soon as I drove off the lot. I brought it back to the dealership and it has been there for a couple days now. The service department said they performed an alignment and an adjustment, but it still pulled to the left. They talked to Hyundai and Hyundai claimed that it needed a new front strut with the proper pitch. This all sounds like it should be a recall to me.
I also have a 2011 Turbo SE that started to pull left but it wasn't until I had 5000 miles on it. I did notice a slight drift left but just discounted it as the road or slight alignment setting. But now it will change lanes at highway speeds in a few car lengths. HOWEVER, no one on this forum as said anything about brakes being at fault. I was on a right turn on ramp, road slanted to the right, and the car still wanted to drift left! When I applied the brakes it pulled LEFT even more! As if the left caliper was grabbing more, sooner, or the right brake wasn't coming on! Take your pick, causing the left pull. If the brakes are faulty, even at highway cruise, the dragging caliper will cause a pull. That's what I'm looking at when I take it to the dealer! Anyone else notice this? Also there are probably more complaints but not everyone is posting here.
A caliper on any vehicle that is dragging hard enough to cause the pull you describe would in short order warp the rotor and literally burn up the brake pads. You would smell it every time you got out of the car.
That being said, any pull caused by alignment, tires, etc. is exacerbated by applying the brakes. In other words, if a vehicle is pulling, braking will make it worse, in some conditions a LOT worse.
Not only is the car still under warranty at 1500 miles, it is reasonable to assume the problem existed when the care was purchased since it happened the first time I accelerated hard and the car downshifted ok but would not upshift and stalled. There would seem to be a difference between selling a car with a defect and a defect occurring later during the warranty period. I never had to accelerate in that manner prior to the problem becoming apparent. Yeah you are right I'm not walking and I appreciate the loaner even though I would rather be driving the car I bought and not making multiple trips to the dealer. I suppose you could argue that I should have done a hard acceleration test before buying the car but I broke the car in IAW the owners manual. I argue that Hyundai should have tested the engine prior to shipping it to the dealer. I am pissed and really don't really care about anyones past Honda problems right now. Sorry
there are a few things . . . side miorror turn signals, leather and heated seats, rear vents for heat/air, auto dimming mirroe with compass is standard and the limited without nav has a 6-disc. Those would be all the differences!
Does anyone experience seat discomfort? i recently bought preowned 2011 GLS cloth seats, 14000 miles, and find the seats to be uncomfortable after about 30 minutes. Any solutions? Will Hyundai do anything to fix this? Also, I have sony mp3 player, the stereo will not read the player, or sometimes it does but shuts off in middle of song, trying to read usb. Is there a known problem with connection? I do not have the cable supplied by Hyundai. Do i need it to make it work?
Seat comfort is not the best with the 2011 Sonata. I have become used to the seats, but it took a few months.
The USB input is not 100% compatible with all players. Hyundai offers an iPod cable, but for any other mp3 player a standard usb cable should suffice. Refer to page 4-116 of the manual for specific USB device requirements:
• To use an external USB device, make sure the device is not connected when starting up the vehicle. Connect the device after starting up. • If you start the engine when the USB device is connected, it may damage the USB device. (USB flashdrives are very sensitive to electric shock.) • If the engine is started up or turned off while the external USB device is connected, the external USB device may not work. • It may not play inauthentic MP3 or WMA files. 1) It can only play MP3 files with the compression rate between 8Kbps~320Kbps. 2) It can only play WMA music files with the compression rate between 8Kbps~320Kbps. • Take precautions for static electricity when connecting or disconnecting the external USB device. • An encoded MP3 PLAYER is not recognizable. • Depending on the condition of the external USB device, the connected external USB device can be unrecognizable. • When the formatted byte/sector setting of External USB devices is not either 512BYTE or 2048BYTE, then the device will not be recognized. • Use only a USB device formatted to FAT 12/16/32. • USB devices without USB I/F authentication may not be recognizable. • Make sure the USB connection terminal does not come in contact the human body or other objects. • If you repeatedly mounting and unmounting the USB device in a short period of time, it may breakthe device. • You may hear a strange noise when connecting or disconnecting a USB device. • If you disconnect the external USB device during playback in USB mode, the external USB device can be damaged or may malfunction. Therefore, connect the external USB device when the audio is turned off or in another mode (e.g, Radio, XM or CD). • Depending on the type and capacity of the external USB device or the type of the files stored in the device, there is a difference in the time taken for recognition of the device. • Do not use the USB device for purpose other than playing music files. • Use of USB accessories such as rechargers or heaters using USB I/F may lower performance or cause trouble. • If you use devices such as a USB hub purchased separately, the vehicle’s audio system may not recognize the USB device. In that case, connect the USB device directly to the multimedia terminal of the vehicle. • If the USB device is divided by logical drives, only the music files on the highest-priority drive are recognized by car audio. • Devices such as MP3 Player/ Cellular phone/Digital camera can be unrecognizable by standard USB I/F can be unrecognizable. • Some non-standard USB devices (METAL COVER TYPE USB) can be unrecognizable. • Some USB flash memory readers (such as CF, SD, microSD, etc.) or external-HDD type devices can be unrecognizable. • Music files protected by DRM (DIGITAL RIGHTS MANAGEMENT) are not recognizalbe. • The data in the USB memory may be lost while using this audio. Always back up important data on a personal storage device. • Please avoid using USB memory products which can be used as key chains or cellular phone accessories as they could cause damage to the USB jack. Please make certain only to use plug type connector products
I have been watching this Sonata forum for 6 years without participating. I have a 2006 Sonata Limited with 105 K miles. My most important advice is to buy that extended bumper-to-bumper warranty to 100k. It has been a very satisfying car to own, my favorite. Anything I wanted to be replaced was done by my eager dealer, so the warranty more than paid for itself. I paid $900 in the beginning. The parts replacement over the entire life (so far) was not unusual, but to be expected. I also have a policy on my washing machine, and it has paid for itself multiple times. What if the North invades South Korea? All parts would be cut off unless the Hyundai company has been quietly lining up other sources of parts in China, Europe, and the USA. I have asked this question twice to the Hyundai on-line survey, with no response. Imagine an Elantra, Azera, Equus, Accent without a flow of parts from Home !
I would hazard to disagree with you. Extended warranties cover cars during what is arguably the most reliable time in a cars life.
Seriously I have owned close to a dozen new cars and bever had anything go rong with any of them that an extended warranty would have covered. I had a 2000 Elantra Station Wagon that went over 175K miles on just routine maintenance, I am hopeful that my new 2011 Sonata does as well.
If you had an extended warranty that paid more in repairs than it cost you are in the minority. Think of it, the provider of the extended warranty would go bankrupt if it paid out more than it took it in. Out of that $900 you paid the company needs to pay out claims, overhead, operating costs and commissions.
I don't think that would happen anytime soon. North Korea simply doesn't have the might.
N. Korea does not have the might, but the little dictator has the madness to do it. 25% of the North's population is predicted to be on starvation rations this year (last week's press release).
My extended warranty paid for door lock replacement, window roll-up replacement, both front struts, front rubber bushings above and below to stop squeaks, auto a c repair, windshield washer repair, shift interlock solenoid. That is more than $900, but I do not have receipts to prove it.
The powertrain warranty paid for throttle body replacement and leaky oil gasket. I paid for sewing up my frayed leather drivers seat at 95K.
At 105K, I paid $360 for spark-plug change. Each plug costs 17.77, NGK IR, IFR5G-11. I also paid $320 for a second throttle body replacement, FP 35100-3C200. Also at 105 K, I replaced rear brakes for $140. Front brakes were replaced at 96K.
Lack of power and damage in Japan will demonstrate to all what a disaster can do to an auto industry, including american assembly lines.
I have had a lot of vehicles in my 70 years, but they were American. They all had severe problems around 70 to 80K, such as Transmissions, oil pumps and timing chains, so they were replaced as unreliable.
I see one cannot make statements in this forum without backing them up. People react emotionally. That is why this additional statement was offered to you.
I wonder if I am the only one who was thinking that there were some excessive repairs for a car in that number of miles? (I'm not referring to wear or maintenance items). No wonder you appreciated that you bought the extended warranty. The 3rd throttle body surprised me the most. Sorry you had to have all that trouble with it though. Even if repairs are covered without question, it is still a big inconvenience dealing with them each time.
Sounds like you had a lot of stuff done on that car. Seems like way to much for one car under the 100-125 mile range. I have taken may cars well beyound 125K miles with little more than routine maintenance and replacing wear and tear items.
But the fact is most cars will need less in repair costs than an extended warranty costs. If not offering extended warrantees would be a losing proposition. Granted there will be the occasional car that covered repais will be more than the cost, but thats the exception rather than the rule.
In short if an extended warranty costs $1000 you can bet that the average car for that make and model will incure less than $500 in covered repairs. Those are odds that only a Keno player would love.
As for North Koria, if they start anything there would be limited interruption as they would quickly be pushed back.
Now thats all I will say for this as it is off topic.
Back to Sonatas. I got one a month or so ago and loving it (or at least she who must be obeyed is loving it).
Doesnt anyone have problems with their seat like i am? My hips, butt, and hamstring are so sore everyday after driving. The dealer service manager looked at the seat, compared it to another vehicle, said its normal. I seriously think there is something wrong with the seat. The dealer didnt take the seat out of the car, he just looked at it!! What the...? I contacted Hyundai, said " sorry about your frustration with the seat, thanks for contacting, we will forward your case to department responsible for future changes" I think they should at least pay the dealer to fully inspect the seat. Opinions anyone?
What? are the springs protruding? Exactly what could the dealer determine by removing the seat? As long as it is correctly manufactured e.g. no lumps, no padding misplaced, no broken frame or springs which can pretty much be ruled out by what they already did (compare it to another car) what more would expect to find?. Did you spend any seat time in this car, or one like it, before buying? So, since you solicted opinions here is mine, you either don't fit the seat or the design doesn't suit you. Both should have been evaluated before spending $20,XXX only to find "you don't like it". On the slim possibility the seat itself is defective in some obscure way the best shot at determining that would be to try to find one to rent and use it for a day. By the way how much time do you spend driving daily? Maybe it is a matter of seat adjustment?
I have had my 2011 Sonata Limited for about a year. The only thing I would say about my seats is that they are very firm and seem a little hard, but really it has never really bothered me. I have driven it on a trip and it doesn't seem too bad.
There have been numerious comments about the seats not being soft enough, but that seems to be the intended design for this vehicle. I have also driven the Genesis Sedan and the seats are more plush but the cost is also much higher as it is more of a luxury car.
The dealership tells me the seats may soften a little over time.
Targettunning, Hyundai needs to hire you as their PR man.
Unless you can keep a car for few days, test driving hardly allows long term or long drive experience. I found them to be fine, but I have read comments from reviews that the seats are not the most comfortable, but it's very subjective. My nephew right away rejected Sonata on basis of seats not being comfortable but till you sit in them for few hours it would be impossible to determine that.
How about the seat cushion with massager? That may be the short term fix!
R U a plus size person? there's not much redress when the seats are hard. I believe the seats were not made softer to keep the car low priced. I guess U may have to trade in and get a car more comfortable. I normally rent a car for a day to try it out for road and engine noise cuz that's a big problem for me. I like quiet cars. I test drove the Kia Optima EX (200 HP) and I drove on Sunrise Highway on Long Island, NY and a lot of road or tire noise protruded into the cabin. I know folks are raving about this car and the Sonata but too much noise for my liking. Now the Buick Regal is a pretty quiet car in both trims but the experts keep finding hosts of problems. Just read Inside Line on edmunds.
Tell me how to evaluate a seat. Alot of cars i test drove i could tell right away i wouldnt like the seat. As for the Sonata, i test drove a few times. I actually didnt have this problem for the first couple weeks of driving it. So unless i can test drive a car for weeks then there is no way of knowing if the seat will fit me. I think there is something in the design, something small, that over time just built up and now i am feeling pain. I tried all types of adjustments on the seat, nothing works. Its possible it is not enough lumbar support, and going to look into a cure for that.
While I will admit that the seats are a bit firm but they really aren't that uncomfortable. They seem to give me the support I need, don't have any real issues with them.
Installed new cabin and engine air filters this morning. After 13,000 miles the cabin filter was absolutely disgusting. Black with large pieces of debris embedded in it. Replacing it was a 5 minute job. Used a Wix cabin air filter, part #24013. Based on the condition this filter was in and the ease of replacing it, I intend to start replacing it every 6,000 miles instead of letting it go 13K-15K miles.
Also replaced the engine air filter. The original was very dirty. Again, a very simple 5min job. Used a Wix filter, part # 49540. 12K-15K miles seems to be the useful life of the engine filter.
Ordered the filters online and saved a bundle over what the dealer was going to charge. Paid $30 total for both filters, including shipping. My dealer quoted me $30 just for the engine air filter. The cabin filter was going to be another $40.
Interestingly enough, both of the Wix filters are stamped "Made in South Korea", and appear virtually identical to the OEM filters. Perhaps the OEM filters are Wix filters?
These filters are very simple to replace, and I recommend people try to do it themselves instead of paying the dealer inflated prices to do it.
I have a 2011 Limited and have taken 2 trip of over 1700 mi. and have not had the problem with the seat. I am 75 so I think I would have had a problem. I did have a problem many years ago but after I took my billfold out of my back pocket and put it into my front pocket I have not had any problems with any seats.
I believe I may have transposed the digits on the engine air filter...it may actually be 49450. The Rock Auto site has a great interactive catalog and will return the correct parts based on the vehicle model and year.
I just got my Limited Turbo today and when I got home after about a 35 mile drive, I had the burning smell. It's the reason why I came to this forum - sounds like others have had the same.
Most, probably all, brand new cars have some burning smell for awhile after purchase. It's just the factory coatings and stuff being burned off the parts that get real hot. Often test drives don't get the parts that hot so you don't notice the smell or the demo you drive may have already been through the initial burning smell thing. Don't worry about it unless it continues for quite awhile or you see smoke.
I can not get my Ipod touch to work. I am using the cable that came with the Ipod. Do I need another cable or should the one I have work? How do you get it to work?
Well, I simply tried to apply some common sense. Sure, you don't usually get to keep a car for a very long test drive BUT seats are, as you say, one of those subjective things that everyone takes a chance on when they buy any car but this person wants to have the dealer remove the driver seat to check...what exactly? That seems silly and pointless and that is what I pointed out. I wish Hyundai would hire me, I'd probably be making much more than I do now!!
I am very happy with the seat on my new Sonata. However, I have run into problems with seats before. My Hyundai let me take a Sonata for 2 days to make sure the seat was okay for me. I have done that with other dealers, as well.
What Hyundai Dealer do you deal with?I don't think it's in NYC?I didn't buy my car yet due to alot of problems with sickeness of my girlfriend.I'm looking to buy one next month I hope.I've seen the 2011 Elantra limited and it looks great without the engine pip.I'm looking for a good dealer,I had one Atlantic but the guy left.They still seem pretty good?
You can check for the availability of any upgrades for your navigation system at :
Hyundai MnSoft HYUNDAI MNSOFT provides updates on regular basis once a year. Customers can order their updates using our secure web site directly or by ordering from our customer service representative over the phone.
I bought at Atlantic Hyundai because the price was the best. I am not happy with the Service dept. My car has been in 4-6 times for a bluetoth pblm. Finally I was told by Atlantic service that California Service, says there's nothing they will do. I have also been through the North East Regional Service Mgr who says go back to the dealer. The NE regional mgr says CA did not say that. Who's lying? My car is still not fixed. Person on other end hears echo and misses every 2-3 words? I was told that on Long Island, Huntington has the best service dept. I will use them for new issues, but I can't for the current ones since it will void out the Lemon Law issue.
Have you tried a different phone? Most bluetooth problems are related to the phone or carrier. I bought my first car in 2002 from Atlantic. Next 5 I purchased from Huntington. Best service and best price when trading in!
When you are using the Bluetooth try turning down the volume on the radio. The echo can be from the microphone picking up the speakers. Turning down the volume may reduce the effect or even eliminate it. That might also cure the missing words.
BEWARE OF KOREN AUTO IMPORTS In March I ordered a S.S. Chrome metal lower level door trim for a 2011 Sonata. What I received was Chromed plastic trim piece. ( They subsequently changed the web site to read chrome plastic trim)
My Son thought he would do me a favor and mounted this trim before I got home. I called their U.S. representative Sherwood automotive to advise them that their description was wrong and I wasn’t happy. They offered me a $20.00 credit against another purchase and said they could not issue me a credit against my credit card because they changed companies who handle these transactions. I decided to use this credit for another purchase a graphite overlay for the door switch panels ($59.95) For a 2011 Sonata. Received the overlays and guess what they did not match the cut outs for the 2011 Sonata. Called again and gave them the information on what was wrong about the fit. They said I was wrong and all they would do is give me RMA # and would deduct a 20% restocking fee and I would have to pay postage to return their error. Oh but now I could a refund check they didn’t offer this before only credit DO YOU WANT TO DEAL WITH COMPANY LIKE THIS? I’ve learned my lesson “A word to the wise should be sufficient”
I called them ( mnsoft ) and they told me it will cost me $220.00 for the new upgrade. You wll have to pay everytime you want an update. Out now is version 3.07.06, I have 2.11.13. At that price I think I will wait until next year or the year after.
OK I took a day trip yesterday of 250 mile round trip. Seats weren't bad at all, didn't feel any adverse effects from the seats.
Funny thing is according to the computer we got better mileage once we got off the interstate driving around in town than we got on the highway. Of course driving there we were driving into very high winds (at least 25 MPH based on observing flags). Got much better gas mileage on the way home.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I have a 2011 black sonata with black interior and I am getting the windows tinted this week
http://www.hyundai-forums.com/index.php?showtopic=54868&pid=408266&st=700&#entry- 408266
Can you share the differences between SE turbo with the nav package vs limited without nav package.
In reality i see only difference is leather/non leather. IS there anything else
starting up.
electric shock.)
WMA files.
8Kbps~320Kbps.
recognizable.
be unrecognizable.
to FAT 12/16/32.
device.
a USB device.
Radio, XM or CD).
device.
cause trouble.
of the vehicle.
unrecognizable.
unrecognizable.
connector products
Sam
however she is the main driver of the car so its not that big of a deal.
After several hundred miles I broke in the leather/it molded to my butt...
After 1 year there must be updates. I have version 2.11.13.
Hyundai MnSoft
