2010 Equinox Trailer Harness
You can also get just the harnesses, P/N 10364351 for $51.72 and P/N 20807039 for $29.30. List price is about $120 for both.
You've got the correct part numbers fstumpy.
Before you order call your salesman and ask him to get you a price for the harnesses and programming. Some dealers have been offering prices below list (not as low an GMPD, but not retail either) and including the programming. It helps to sound a little upset (just a little so you don't turn him off) that Chevy has to program the harness. The service and sales guys will agree with you.
P/N 19244244 is not a known Chevy part.
Apparently the hitch is different than an 09, so that was the first issue and had to be returned for correct unit.
Incorrectamundo, the same hitch fits all Nox 2006-2010.
Then the GM wiring ordered was not correct plug. They claimed no plug lead available for 4 cyl
El shoppo probably didn't know the '10 takes a new style plug, probably tried the '09 style or something else that didn't fit, and ultimately found out the harness can only be bought from GM for $100+ which just shot their profit margin out their exhaust.
so I authorized to splice into the lead in back of vehicle. then they wanted to charge extra for programming.
The ol' spliceroni - shop saves profit installing gypsy brand after market product.
As for "no towing" with the 4cyl, try reading the towing section in your manual.
http://www.thehitchstore.com/hitches-trailer-hitches-c-20_22.html
I fit perfectly. The bolts that come with it thread into nuts already welded into the body. It can be installed in half an hour, but you will need a big torque wrench to do it right.
I am still trying to get the wiring harness I need, but I did get the dealer to program the computer to power up the connector. They had it for two hours one day and all day a few days later. They had to download new software to their service computer in order to work on the 2010. The first time they sent me home with the trailer lights working, but my cruise control had been disabled. My guess is that they really struggled trying to figure it out.
The hitch fits right under the bumper and if you buy the right hitch, it will be hidden except for the receiver.
Curt MFG just came out with an after market harness that supposedly has the unique fitting to the wiring behind the driver taillight. Fits the Terrain also
P/N CT56094.
http://cgi.ebay.com/ebaymotors/2010-Chevy-Equinox-Trailer-Tow-Hitch-Wiring-Light- - -Kit_W0QQcmdZViewItemQQhashZitem27ac2b98c9QQitemZ170392262857QQptZMotorsQ5fCarQ5- - fTruckQ5fPartsQ5fAccessories
There's one up on eBay for 19.00 and included both sections.
OK. I have a dealer installed hitch with a 1" receiver. Maybe the 2" receiver is rated for more than 1500 lbs.
It's not the size of the receiver that determines the load, it's the design and construction of the hitch. A Class 3 hitch will be rated for 3500-4500 lbs, far in excess of the Chevy suggested towing capacity. What Chevy is saying is that the vehicle tranny and brakes are not designed for loads over 1500, and 100lb without trailer brakes.
Just show the dealer the manual and tell him to forget the waiver.
Thanks a lot.
as fstump says its easy.
The factory connector needs to be enabled/programed by the dealer to become operational. the system made by Curt tee's into each tailight plug and sell for 19-39 bucks on ebay. There is no need to go to the dealer. Whole job is a bout an hour. Tailight removal is easy. The 2 inch hitches start at 90 bucks.
Regardless, enjoy your new Nox. Car and Driver may have preferred the Focus, but it's pretty obvious they weren't interested in overall vehicle utility. The Nox rolls right over the Focus as Car of the Year.
Took out the little instert in the bottom of the bumper and it tucks right up under there, looks slick as can be. I did confirm with the shop that they did not have splice anything, they confirmed it would be plug and play and 100% compatible.
My receipt shows my dealer ordering it and paying for it, so I am happy. Cost them $312 installed, and the harness showed as a $23 part.
I doubt that splicing into the tail lights would affect air bag deployment. If this were the case, one could imagine a defective bulb or a burned out bulb causing an airbag malfunction. It hardly seems likely the engineers would have designed the system allow such a deadly situation to arise from such a trivial cause. If they did, they're going to get sued somewhere down the road, that's for sure. Still, I like to do things as the engineers intended, so I went with the factory connector system.
As for the dealer, he was unbothered that the cable harness was missing, as you note.
In the manual, it states 4 cyl towing is limited to 1000 lbs capacity trailer, tongue and and load combined. The GM factory hitch is 1 1/4" style. If you want a 2" for a bike rack, then you need to get an after market hitch. There are plenty of 2" hitches around that fit the 2010 4/6 cyls. and they'll cost as low as $125 shipped.
Please, any info will help.
Just need it for bikes/ no wiring needed.
Thanks-
Pam
You have a couple of options for the trailer hitch. The GM model is 1 1/4 inch. Aftermarket versions are wither 1 1/4 or 2".
The GM factory trailer hitch has a post for attaching the GM harness. You will see the pin attachment but no wiring. The hitch itself is fairly well hidden with just the receiver showing not the full bar. Some of the aftermarket hitches are also hidden.
The bottom of the rear bumper cover has a little clipped in door. To install the hitch you remove that little door. On mine there is just enough clearance that if I want to replace the door to hide the receiver I can and no one knows I have a hitch.
Mine has just enough cleaance tha
They are a little cheaper.
The GM receiver is 11/4", not 2". If you have 2" equipment, you got to go after market for the hitch assembly.
The 2010 Equinox must be reprogrammed to for the brake lights to work and only the dealer can do it. These vehicles have a finicky electrical system, so don't even think about splicing an aftermarket harness into the brake lights. I know of two dealers that refused to program the vehicle because the brakes electric had been spliced.
I installed a Curt 2inch receiver and there wiring harness.
There is no programing needed for this installation.
The only time you need programing is if you have a GM wiring harness installed.
Hope this clears things up.
The service technician told me himself.
Will this hitch allow for this?
http://www.thehitchstore.com/class-iii-receiver-hitch-p-1084.html
Also, any other 2" hitches that will be hidden/allow the cutout to be replaced when not in use?
Finally, for the wiring, what is the deal with the Curt Mfg harness? How can it not require any programming yet still be not a modification to the vehicle's wiring system? It seems like the GM harness is the only option as to not "illegally" modify the wiring and void warranty.
As far as I an tell you would need to bore new bolt holes in the frame to move the hitch back far enough, then use a receiver extension to maintain your turning radius with a trailer.
"On mine there is just enough clearance that if I want to replace the door to hide the receiver I can and no one knows I have a hitch."
That's what I want to do. What hitch do you have? It's not a huge deal for me, but if this is possible, I'd prefer to do it this way.
http://cgi.ebay.com/ebaymotors/2004-2010-Chevy-Equinox-Trailer-Hitch-New-Receive- rHitch-_W0QQcmdZViewItemQQhashZitem27b080957aQQitemZ170464941434QQptZMotorsQ5fCa- rQ5fTruckQ5fPartsQ5fAccessories
Gang, I need your help to clarify a few things for me.
I ordered a 2010 Equinox (2.4l 4-cyl) 2LT, and with it I ordered the "trailering hitch package" (Part 19202502, according to the website) as a "dealer installed accessory." (It is on the invoice!) The car is due to be received at the dealership in the next couple of days, but the salesman at the dealership is now saying that they (the dealer) can't install it. WTF? How can I order an OEM Chevy part from the dealership that cannot be installed...by the dealership? Also, from what I have read here, dealer programming is *required* to make the wiring harness work. Is that correct? When I called Chevy's assistance line, they said it should not have been possible to order a trailer hitch for anything other than the V6. Why, then, is there a "Dealer Installed Accessory" option for the hitch even available? No one seems to be able to answer that for me.
Has anyone here had the "dealer installed accessory" version of the "hitch trailering package" installed on a 2010 4-cyl? If so, was it by the dealer? If the part I ordered actually arrives with the vehicle, and can't be dealer installed (for whatever reason,) will installing it void the powertrain warranty? (I only occasionally pull a very lightweight little folding 4x8' trailer...no way will it ever be more than 1500 lbs.)
Obviously, if the part isn't going to arrive with the car, and/or can't be installed without voiding the warranty, I am sure as hell not going to pay for it!
I want to know exactly what is salesman/dealer BS, and what is actual fact. Any help would be appreciated.
David
HOOOOWEVER, upon delivery I read the car manual as a good little Noxoid will and found this little paragraph: Section 8-62 Driving and Operating
"Use the following chart to determine how much a vehicle can weigh
based upon the vehicle model and options.
(Note:it's a Table that I can't replicate here, but will assimilate.)
.....................................Maximum Trailer
....................................Weight with Trailer
......Vehicle...........................Brakes**...................GCWR*
L4 Engine, FWD.............680 kg (1500 lbs).......2,625 kg (5,787 lbs)
L4 Engine, AWD.............680 kg (1500 lbs).......2,000 kg (5,952 lbs)
V6 Engine, FWD...........1588 kg (1500 lbs).......3,600 kg (7,937 lbs)
V6 Engine, AWD...........1588 kg (1500 lbs).......3,700 kg (8,157 lbs)
** For trailers without trailer brakes the maximum trailer weight is 454kg (1000 lbs) and the GCWR is 2,300kg (5,071 lbs). See towing equipment on page *-64 for more information.
* GCWR - Gross Combination Weight Rating is the total allowable weight of the completely laoded vehicle, and trailer including any passengers, cargo, equipment, and conversions. The GCWR should not be exceeded.
My point here is - GM has defined a specification that allows trailering in all of the 2010 Equinox, L4 OR V6,with FWD or AWD, even though the weight is limited to 1000 lbs without trailer brakes.
I installed my hitch, because I wanted a 2", not the GM 1 1/4 hitch. I bought the GM harness from GM on line and installed it myself. Neither were difficult to install. My dealer programmed the hitch for no charge. Also, I do not intend to haul a boat around. I have over a hundred trees and do not like piling downed branches and sticks up on the property. Ever since the town refused to issue burn permits anymore, I have to haul the waste to the town compost center. I'm not coming near 1,000 lbs including the trailer weight.
Next time you go to the dealer, ask him for a copy of the Equinox Manual and show him the page. I have heard of a few dealers are not willing to install the hitches and have steered buyers to after market installers in the area.
Thank you for the info!
It turns out that the whole "dealership cannot install the Chevy hitch ordered directly from Chevy" thing was a complete and total brain fart by the salesman. (Shocking, I know.) Apparently, they don't have / cannot install an after market hitch on the Traverse. SOOO, they will be installing the hitch ($267) on my NOX this Friday, as well as programming the hitch (no additional charge).
I am perfectly fine with the 1.25" hitch as that is what I already have on my Subaru, so I already have all the accessories I need for it. I don't pull much weight either. As mentioned, I very occasionally tow a lightweight 4'x8' trailer I bought for my motorcycle, but have used more for suburban errands than anything else (hauling bags of mulch, etc.) As a result, the 1000lb limit for the 4-cyl should still not be a problem.
I had gone to the dealer this evening to get my Subaru appraised for trade in, and SURPRISE, my NOX had been delivered just today! So I got to inspect it and take a quick test drive while they appraised my trade. They totally low-balled me, but I fought until I got within 800 of my target, which was a little optimistic, so I probably did "ok" on that.
Tomorrow, we handle all the paperwork, and I will pick up my new baby on Friday. I am excited!
Thanks again for your help!
David
Anyone following the spec and keeping the load under 1500 lbs, is not likely using a trailer with brakes. Ergo the effective towing capacity is 1000 lbs.
This is the total allowable weight of the completely loaded vehicle and trailer including any passengers, cargo, and equipment.
The Equinox weighs 3770lbs. So 5071#-3770# = 1301 lbs. left for everything else.
Be careful how much you load up your Nox.
Including your own fanny.
