SUVs and Smart Shopper
> $1000+ per MMI failure due to spilled coffee from a cupholder which is ABOVE the
> eectronics for the MMI !!!
> They made a stupid design error and should agree to fix it and not penalize the
> customer !!!!
No offense meant here, but...You spill coffee onto the MMI controller causing it to short out and you're blaming Audi? Yes, it might not be the best location of those electronics and the replacement costs are [typically for Audi] ridiculously high, but how about taking some responsibility?
> Put a 20W50 oil
> Do not overfill ( 6 liters enougth)
Just an FYI to anyone tempted to do this, note that there are NO Audi 502.00 approved 20W-50 oils. For a complete list of approved oils, you can download this PDF from Audi's site:
Audi approved engine oil listing
> if/how they can reset the service reminder light without having to go to the dealer.
> Has anyone figured this out?
Unlike some other Audis (e.g. B7 A4), the Q7 doesn't, AFAIK, allow for the resetting of the service interval without either visiting the dealer or without the use of a scanning tool such as a VAG-COM. If you have a VAG-COM (or access to one), it takes about 10 seconds to do.
> in the '08s? Anyone know? About to take delivery of an '08 4.2.......I know it is a
> great engine, I believe it is the same one in the A8.....?
According to the TSB, this problem was restricted to only 2007 3.6L V6 engines from VINs 000001 - 062000
LOL. Hardly. Any mod can check my profile email address and IP.
> It is common sense ye of double digit IQ (offense meant) .
none taken.
> Liquids and electronics so not mix. Explain why all the electronics in the engine are
> sealed from the RAIN !!!
This goes without saying. I already stated that it wasn't a particularly good design. But again *Audi* didn't spill liquid into that area. You (or your family member) did. I still fail to see how it is *Audi's* responsibility to pick up the repair tab
> Did you go to school in a short bus?
Nope, but I don't particularly care for the typical mentality in the US that thinks that everything is someone elses fault
I think there is enough blame to go around but I also think it's a valid complaint. Imagine that your computer came with a cupholder attached to the keyboard. If you use that cupholder, you will inevitably and eventually spill liquid onto the keyboard. Yes, you are to blame for actually using the cupholder feature but the design cannot be defended.
At the very least, placing the MMI controls in such a vulnerable position would have required proper insulation to protect against the inevitable spillage.
Liquids and electronics so not mix. Explain why all the electronics in the engine are sealed from the RAIN !!!
f you have electronics in a Car do not put them BELOW a cupholder without ensuring the unit is sealed so trhat when a liguid spills it sdoes not short out the whole system and cost the CUSTOMER a $1000 !!!.
It really is that SIMPLE!
AUDI messed up and won't admit it.
For a $55+K car a customer should expect more!
So as far as taking some responsibility I think that "To Do" is for AUDI .
Tidestar nailed it ! It really is common sense....
Agreed. And that's already been pointed out so I think it's safe to move on now!
That's a bit over the top. And, BTW, the bickering stops here. We'll stick to the topic and drop the personal jabs.
On the other hand, if you spill a drink pretty much in ANY car onto the seat and spoil the upholstery, you wouldn't expect a dealer and/or manufacturer to honor the warranty in that case and replace the seat, would you?
Did you consider filing an insurance claim?
Only an AUDI employee would have even read page 126 and 127 of the manual!!!
Most people who buy Audis are VERY busy and do not waste time reading car manuals....
Audi messed up !! No other car has this issue !! AUDI does not have cupholdres in german version of the cars and the design was an after thought and VERY poorly designed...
Is this another 1980's phantom gas pedal accelrator issue that AUDI will try to sweep under the rug? Have they not ;learned their lesson .. RESPECT your customer !!!
They need to steo p to the issue !!
> drinks on our cupholders, they may cause irreversible damage to MMI"
This is not a bad idea provided that they don't use the same type of labels that are used for the airbag labels on the sunvisor (e.g. permanent). Audi should also consider instructing the salesmen/women to point it out during delivery.
Regardless, you'll find on pages 126 and 127 in the cupholder section of the owner's manual that Audi has printed the following disclaimer 3 times accompanied by a yellow circle with exclamation point:
"! Note:
Only drink containers with lids should be carried in the cupholder. Liquid could spill out and damage your vehicle's electronic equipment or stain the upholstery, etc."
but if you go to the basics... spilling liquids in a car happens... I wipe it up immediately but it still shorted the MMI... The unit should be sealled and it was NOT...
They should do a RECALL ...
Most are too busy working in high pressure jobs whose renumeration is such that they can afford a Audi Q7...
thx...
I must admit that I am amused that you think that I'm an Audi employee. In actual point of fact, I work in IT for one of the hospitals in the Boston area. I am very technical in nature and in training. As such, I read the manuals for pretty much everything I own or buy -- even the toaster manual (believe it or not). To not read through the manual of a $61K car is not something in my nature. Do I expect my wife to read the manual? Not a chance. I'd actually be somewhat surprised if she even knew where it was. In any case, it literally took me less than 5 minutes last night to find those paragraphs.
> poorly designed...
Off hand, I can't think of any German car that truly has good cup holders. They always seem to be afterthoughts -- storage bins too (which the Q7 is sorely lacking).
Totally unrelated to the MMI design flaw, but the "phantom gas pedal accelrator [sic]" or unintended acceleration issue was a total media fabrication. It is similar to the NBC Dateline 'expose' on exploding GM gas tanks. In the case of the Audi 5000, 60 minutes' 'expert' actually doctored the car by drilling a hole in the transmission and pumped in compressed air (or fluid). After studying the problem for years, the NHTSA fully exonerated Audi. Don't believe me? Just google "60 minutes audi 5000".
For what it's worth, the Audi owners I know do read those manuals - cover to cover - and likely more than once! And they don't work for the company.
That's true.
I just got '08 Q7 with Audi Care program for $600.
Does anyone know if brake pads and windshield wipers are part of free replacement as well?
Not sure about wiper blades.
No, AFAIK, Audi Care stopped covering wear and tear items around the 2006MY. However, I believe that wear and tear items are covered for the first year / 12K miles under the normal warranty. Check your warranty booklet or try giving your salesman a call.
Wondering if it is a common occurance for you. We love ours otherwise.
I opted out at the time, but now, 3 + months and 5K miles later, I am worried that the brakes are all worn out and I somehow missed it.
Should there be a light on the dashboard when the brakes are worn out?
I had the air suspension failure that ONE time & it never recurred. I don't even recall going to the dealer after re-starting the car & finding the air susp reset itself back to original.
I did learn something from tail-hatch snafus around Oct 07 - there's about a million lines of software code that's running all this stuff. So, the dealer reproggred the tail-hatch & presto, it worked neat for the most part (unless it bumped across an obstacle). They'd even listed this 'tail-hatch not closing' fault as a 'known' bug with fix (sounding even more like a bad os on a laptop )
The best bet is the reprogg, which it sounds like you're doing right - I've even done the dynamic change setting while sitting in traffic (just trying to check how far it compares with the monster truck in the adjacent lane) & it worked reliably.
Your Q7 air susp episodes appear to be a one off deal - just ask the dealer to give you a replacement equivalent mileage Q7 with air susp Hell ...even Hondas seem to come with some air susp technology these days, so they've gotta keep you happy.
Cheers,
Didn't Audi used to have this probelm? Anybody had an experience like this?
Does your wife, by any chance, drive with 2 feet? Could you report back when the dealer diagnoses this? As for the 'unintended acceleartion' reputation of older Audis, please be aware that that is/was a total 60 minutes media fabrication. Their so-called expert doctored the test car and Audi was cleared after a 2-3 year NHTSA investigation.
My entire family loves this card, and I was going to keep it after lease is up in one years, but I am having a second thought...
:surprise:
Which dealer "hosed" you for $2,5K???
I looked on the Audi site and the approved motor oil for Castrol is a 5w-40. Does he need to get an oil change now or does a 5w-30 work even if it isnt synthetic.
Q7 has a similar "feature"
On the other hand, my brand-new at the time Q7 had "brake issues" where they squeaked and did other "weird" stuff that I would not expect from a new car - the dealer explained it as a "break-in". After a few weeks and a few hundred miles everything became "normal"
Just did the 15K on our Q7 and had none of the wear issues you have. Because we had purchased AudiCare, our out of pocket expense for this service visit was covered. New tires and brakes @ 15K seems a bit extreme, but it all depends upon the tread wear on your tire. Check the depth on your tires. Are you at the wear bars? If so, time to replace them. Did the wear sensors go off? (i.e. warning in MFI?)
However, do not get all excited - there are only 3 or 4 service visits covered in the Audi Care, and brakes, tires, etc are all explicitely excluded from coverage.
5K miles service is included with the car I believe.
So it only covers 15K, 25K and 40K or something like that - and only the "recommended" maintenance - so read your manual and do the math.
Call the National Highway Traffic Safety Authority at 888 327 4236. Follow the prompts, and you will be able to register your concern with a very helpful person. If enough people call in, or register thier complaints at www.nhtsa.gov, they might be able to force Audi into a recall situation. They need to insulate these consoles better, it is thier responsability. These inconveniences can lead to disasters, we can't just sit around and throw our money at the problem. Audi needs to own up to this, and only the squeaky wheel will get the grease.
I will call the National Highway Traffic Safety Authority at 888 327 4236. Follow the prompts, and you will be able to register your concern with a very helpful person. If enough people call in, or register thier complaints at www.nhtsa.gov, they might be able to force Audi into a recall situation.
THANKS !!!
I called the National Highway Traffic Safety Authority at 888 327 4236. this morning and they were very professional . They indicated they would have their engineers look into the complaint and get back to me with a questionnaire in a few weeks. The NHTSA guy asked me when my MMI goes out while I am driving does it effect the other power/electrical systems i.e. steering, brakes etc.... It had not BUT who knows what can happen with this system. He also indicated other complaints were filed and that the more complaints filed the more likely they will require AUDI to do a RECALL. Not sure if that would get me my $1000 back.
Then, after about 10 minutes highway driving, the light went away.
The situation pretty much repeated itself next day.
Took it in to my dealer - they found the car to be "a quart low" and added it - problem solved!
Well, correct me if I am wrong, a quart of oil should not just disappear in a car like a relatively new Q7. I am worried there is another problem somewhere, especially considering that after several attempts to fix the "OIL PROBLEM ON ENGINE START" issue, it is not really "fixed" - it still shows its ugly face - although not as often as before the latest fix. The dealer just took the easiest way out with this.
Has anyone else experienced this problem?
My audi dealer suggested placing a towel near the shifter so that the MMI is protected from any moisture or impacts. Sounds crazy for a $50K+ car but that is what they suggested. I cute a hole in a small towel and placed it over the shifter and it seems to work. It is a black towel so it does not look too bad since it matches my interior.
Also I would suggest documenting all failures and conversations with the dealer and letting AUDI USA know ASAP. They tend to have selective memory on problems and strive to blame most issues on user error.
Good luck !
