When I started doing alignments, I got the Hunter alignment machine guy to teach me how to use the quipment and figure the front ends out. The dealership that I was working at didn't send me to training, I went and got it myself. (The same applies to my electronics training, and quite a lot more of what I learned to do)
So I started aligning cars. I studied a lot and learned the ropes the hard way like every technician had to.
Chevrolet Cavaliers, Buick Skyhawks, (any GM "J" body) didn't have elongated holes for the strut to knuckle bolts to allow for a camber adjustment like the Celebrity, or Citation did. ("A" or "X" bodys). The official routine was to measure the front end. Take the equipment off if a wheel needed adjusted, remove the knuckle bolts and tilt the knuckle clear of the strut to ream the strut attachment holes out. Then the tech would re-assemble the front end and mount and re-compensate the heads. Then they could make the necessary adjustments. They paid about an hour a side "extra" on top of the alignment fee to do all of that. By design, the car was essentially a "toe and go" alignment.
I did the first one, and of course figured that there had to be a better way. The next one I went to the body shop and borrowed the port a power with a duck bill attachment. I put the duckbill between the strut and body and put just enough pressure on it to hold it in place. Then I removed the lower bolt from the knuckle, and loosened the top bolt. By doing that I was able to use the port-a-power to move the wheel in or out depending on what I needed to do for my camber adjustment. Now I could I tighten the top bolt, remove the port-a-power and check to see if I was in spec. Now all I had to do was ream the lower strut bolt hole just enough to re-install the bolt and tighten it. It took me about five minutes a side to adjust the camber.
The next couple of days, the service manager gave me one of these to do and of course I completed the whole operation in about forty minutes. He gave me another one, and the same thing, about forty minutes later it was done. The other three guys were taking over two hours to do the same job, and the guy who just started doing alignments was doing them in a third of the time. Do you know what he was thinking? He thought I was lying about adjusting the camber. This was before the days of the alignment machines that had printers. So he gave me another one and stood by the alignment machine and watched me do it. Do you know what he did then? He stopped paying us extra to adjust the camber on those cars.
This forum is titled "A Mechanics Life", I have several thousand stories just like this one that will show people what it has really been like to do this for a living. I was making around $7.50/hr flat rate back then. Before my trick that alignment would have paid me about $21.00 to do if I had also adjusted camber both sides. After the manager saw how well my idea worked, it went back to $6.50 for the whole thing just like a toe and go. ">
" BTW, a GM four wheel steering truck is much more complicated to work on than a Porsche or AMG is"
That wasn't my point though. My point was that setting up a high performance car requires skills and experience outside the limits of your basic alignment school. (note: I'm using the general "your", not referring to YOU). Even if you knew how to perfectly align that Dodge truck, you'd be totally lost working on a Porsche 4S unless you had a very good handle on vehicle dynamics. Let's call this debate "Classroom knowledge versus Life Experience".
Anyone can be taught basic alignment, especially with today's equipment. This is not rocket science.
My post was much more about the dedication and intellectual curiosity necessary to differentiate between a set of numbers in a book and actually taking a car out on the road and feeling what happens when you make various adjustments.
Doc, you have made this very point yourself---a machine is only as good as the person using it.
I once hired a guy who was working at a "well known" tire chain.
He said that if the customer was watching them do an alighment they were to
" Open the hood, bang on the fender, set the toe and let it go"
He said they also would use what he called "show shims". These were those ultra slim shims that really did very little but when the customer opened his hood and saw those shiny new shims he knew that his car had been "aligned".
>reason why I source the lion's share of my vehicles from ..., Munich,
A friend is trying to get to the thermostat on a 315 BMW he's working on. Seems you have to remove the fan and housing to get to it... :grin. OTH, on my 3800 it's two bolts and I'm done in 10 minutes at most. :grin
On the other hand I can't go around the large flyover on I70/I75 rated at 40 mph at 80 mph instead.
315? Do you mean 325i? What year? In most all cases the fan simply unscrews from the fan clutch(it's reverse threaded, BTW). My 2009 3er doesn't even have a thermostat, BTW.
Mine: 1995 318ti Club Sport 2020 C43 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
$20 rotors? Maybe on a go kart. Not on MY car, thank you very much. Are they made out of old Italian TV dinner trays?
I replaced the front pads and rotors on my 2000 Intrepid around the 98,000 mile mark, and paid about $89 for the parts at Autozone. Never had any issues with them. Now, I did have to replace the pads again at around the 130,000 mile mark, so I only got about 32K out of them. But, I only got 39K out of the OEM pads that came with the car. So, I'm not complaining.
FWIW, that car needed front pads at 39K miles, 69K, 98K, and 130K. It needed rears at 50K and 102K. It got totaled at 150K, so I dunno how it would've trended beyond that.
I took the your suggestion to him. That seems a lot easier than his plan! I appreciate your help.
Glad to help. I did mis-speak a bit. The fan clutch threads on to the water pump pulley. Here is a pictoral DIY article. He doesn't need the official BMW thin 32MM wrench; a bicycle shop should have a suitable(and relatively cheap) tool which will work. Just keep in mind that it is reverse threaded(righty-loosey lefty-tighty). Let me know if he has any other questions.
As far as trying to remember which way the fan comes off, simply look at the pitch of the blades. The fan is going to be turned by the belt in the same direction that it must be turned to be removed, drag from the pitch of the blades would cause the fan to tighten onto the pulley if it were loose. So you simply have to "turn the blade faster than the belt is driving it" and you'll always be turning it the correct direction to remove it. As mentioned, some are left hand thread, while other cars are the conventional right hand thread.
Naturally if I don't drive our BMW for two weeks, the battery go's dead and that is the case right now.
Is there a trick to hooking up a charger to the battery in the trunk where I cn disable the two trunk lights? I tried using duct tape on the button but it's way too strong. It looks like I'll have to pull out the battery unless there is a trick that I'm missing.
Still trying to get is through emissions so I can e register it.
:sick: So much for innovation.
When innovation is not rewarded, the end result is that you don't have innovators.
positive terminal located under the hood for jump starting;
Shoot, if I had known that perhaps I could have saved a guy from unpacking his trunk at a rest area last year when he was trying to get a jump in his BMW. It was pretty obvious he was on a long vacation - lots of duffle lying around.
Since then I've learned that our Chrysler owning friend has her battery buried in the fender well, and her car also has the remote terminal deal.
Oh that's a point---venting---best to leave it open.
Don't those trunk mounted batteries like in the BMWs have a vent tube that passes through the fender to the outside? I think the one for my '87 '325 was that way.
They are supposed to, however many people improperly choose to install a cheaper battery and ignore the vent hose.
I know that Advance Auto, Autozone, and Interstate batteries come with a vent tube adapter if you are buying a battery size that is designed to fit a BMW(91, 48, etc...). The problem is -like you said- the nitwits who buy the cheapest battery that will physically fit in the tray.
My only concern with using the engine-bay jump start connection (I thought of that, since my MINI has one, too), is I'm wondering if the long road back to the battery will steal a fair amount of current away from that dinky charger. Sure, a heavy jumper cable, no problem, but pushing 1 amp through a 12 foot long connector cable might result in the charge taking a very long time.
On the other hand, the slower the charge the better---so maybe it's not such a bad idea.
Couple of things to consider. That "long road back to battery" has to be able to supply whatever the cranking current that's needed for the starter motor, with acceptable voltage drop, right? Whats typical cranking current? 50 amps? 100 amps? 200 amps? So that 12 foot cable from the battery to the engine compartment has to be able to pass that amount current with only a volt or two (or three) of drop. So the resistance has to be pretty small, say less than 20 milliohms for a 2V drop at 100 amps (from V=I*R).
Now, what is the charging current fromr your charger? Say it's 10 amps. Through that same cable, you would drop 0.2V (10 amps * 20 milliohms), probably not enough to affect the charging of the battery.
Just for reference, 10 ft of 8 gauge cable only has a resistance of .006 ohms (6 milliohms), less than the 20 milliohms I used in the above example.
Lets start with the statement about pushing one amp of current through the cables. Whether they are 12", 12', or 12 miles, your statement set the condition that one amp of current is flowing. As the resistance of the conductor increases, the voltage applied to the circuit would also have to increase to maintain that one amp of current. The question then becomes how much more potential would be required for the extreme length of the cable? We could figure that out if we wanted to.
Now back to the reality of the BMW. At 1 amp of current, that conductor's resistance would only create a voltage drop measurable at the most in the thousandths of a volt (it may be in the millionths, but we will use thousandths to keep the math simple). Easily negligible. Raise the current to ten amps, and your voltage drop is now ten times larger. Go up to 100 amps, and your voltage drop is another ten times larger, and is only now into the tenths of a volt range.
It has been years since I was at Dad's shop (it closed in 1986)...the big lathe we had (6 foot bed) was a South Bend...the drum/disc lathes, I have no idea of the brand, but they stood about 4 feet tall, much larger than the units in service stations...
We had a milling machine for warped cylinder heads, and we had a valve grinding machine to grind out the grooves in valves, and, boy, did they look beautiful and polished when we were done...
We used the big lathe to grind down grooves on flywheels, beautiful smooth surface when we were done with them...also cut the copper on armatures so new brushes had full contact when starting...
About 8:30 I expect to hear from someone who called me last night right before the training class I was presenting started. Her car broke down last friday in the parking lot where she works. Then over the weekend she lost her keys. Its a 2003 Taurus and by her description she has had a lot of problems with this car in the two years that she has owned it. First a freind borrowed it, wrecked it that took a few months to be repaired. Then it wouldn't start a few months back so they replaced the battery, then when it didn't start again it got an alternator, and then someone else replaced the starter and now it's broke down again.
She wanted it towed to the dealer, but everyone she called has said that with where it is sitting, they can't get to it. She has been told it has to go to the dealer because while they can make replacement keys, they have to program the PATS system to make them work.
But, the car wouldn't start before she lost her keys. So this is now a minimum of two unique operations. She has already had what sounds like a half of a dozen attempts at fixing a fundemental issue without success, and she has managed to add an entire layer on top of that. I have up until 10am to solve every facet of this vehicle issue and then I have to hit the road for where I am teaching tonight.
Does this sound like fun to you? Someone has to completely solve this and get the car to be reliable so that she can simply use it for a few years. Sometimes it's really dissapointing how we would have found and dealt with the primary problem months ago and yet we never got the chance. We can handle her theft deterrent retrain right in the parking lot where the car is at. I will have to open up the locked car, and if necessary I have tools that I can use to lift the car and roll it out of where it is at so that I can put it onto my flat bed.
BTW, reflect for a moment the $$$$$ investment that we have in place, just to be "service ready" and solve this problem for her in an efficient manor.
I'm really curious as to what the problem is with the Taurus. After I sold my Escort, which was quite reliable for me, the lady that bought it said the alternator failed and then later that it "wouldn't start." I had replaced two failed alternators in the time I owned it (exactly one year apart from one another) and had recently replaced a failed starter. Aside from those, though, I had no issues with the car starting and had no reason to suspect it might act up at any time in the near future.
Well, she ended up moving out of state and sold the car. Oddly, I happened to spot the car (with new owner) at a gas station about "five minutes" after he purchased it. I gave him some extra keys and a repair manual that had been toting around in my car for two months waiting for the other lady to pick up, and we chatted for a little while about the car's history. I noticed that the car did, indeed, have a new alternator, along with a new battery, but didn't see anything else that looked different from two months prior.
I'm curious what the problem on this Taurus ends up being, as it sounds like maybe that could be the root cause of the Escort's issues, too. I could chalk one failed replacement alternator up to a poor rebuild, but two within only 2.5 years? It might be something more....
You cannot associate the problems that one car has to generate the repair answer for another. Your Escort may only have been suffering from substandard repair components, or a lack of proper testing and maybe there was never anything wrong with any of the alternators.
As far as the Taurus goes, she was a no-show. On our way out of town I drove past it and saw where it is sitting. I can get it out of there, but only after hours when there are no-other cars in that driveway that serves as the parking lot that goes all the way around the building. My flatbed probably cannot make the turns at the corners without needing some of the yard, it's that tight. Add the other cars parked there and it won't fit, period.
I asked if anyone wanted to guess what kind of investment it takes to be ready to do the whole job for her. The truck represents over $70,000 all by itself. The scan tool, and software licenses, oscilloscope etc. easily push the total over $100K.
I am the only tech/shop that could handle her situation completely, with no outside assistance. The pressure to be too cheap has left everyone else short of everything that would be required, and this is a ten year old car. Think about that for a bit.
Since you're talking about cost of the equipment to properly do a job let me ask you this. Do you ask for a down payment on any type of job or estimated cost of a job?
For example say someone has '99 RX300 towed in to your shop and you estimate $13K to R/R a sludge motor. Guy tells you yeah go ahead and do it. Do you ask for a down payment? For what amount?
On a repair of that magnatude, absolutely a deposit is required. They must pay the parts up front. There simply isn't a choice in ther matter because we don't have the kind of money that would allow me to buy an engine and sit on it for any length of time.
The greatest fears with repairs like that is a customer who says do the work, and then never picks the car up. Worse yet since Pa doesn't have a mechanics lien law they could report the car as stolen, and when the police find it they take it away form us and return it to the customer without the repair being paid for. We are essentially left to sue for the repairs but the odds are we win the case but still never see a dime.
I have had cars that the owner stopped making the payment on and get repo'ed that we had a repair waiting to be paid for. We have been ripped off for quite a sizeable amount of money that way through the years.
I'm surprised all your alarm bells didn't go off prior to even considering working on this car
Oh they were going off allright. The problem is we are so much about trying to help people that we often forge ahead no matter how rough the seas or dark the clouds are.
It's nice that you try so hard to help people but sometimes a shop just has to decline a job.
" I appreciate the fact you called on us to do this job but I just don't feel comfortable doing this job when the cost of repairs will be more than the value of the car"
Spent some time trying to look that up, found lots and lots of stuff but nothing that I felt explained the concept.
Ran into a guy this evening, really didn't know who he was but it didn't take too long and I realized it wasn't comfortable having a conversation with him.
Eventually the conversation turned towards what I do for a living, he was instantly interested because he has an oler Corvette that he claims he wants to sell but the radio doesn't work. He thinks (suspects) that there is wiring damage caused by a rodent. He wanted me to go to where he has the car stored to check it out.
Sorry, that's not how it works. I'll do remote diagnostics/repairs for another shop and may choose to do that for a long time customer, but not for someone that I just met.
Well it turns out we had a dealing with him about eight years ago, and now that he knows who I am things changed a bit. Another shop brought a cadillac to me because of a TPMS issue. I'm not a tire shop, but having the tools to deal with TPMS simply was in line with my overall approach. Back then I was the only shop equipped to fully handle that "new" technology. They couldn't get the light to go out and though there was a problem with the car. I was slammed with work but made room for it.
The only thing I found was the tires were over inflated, otherwise the system was working just fine. Inflating the tires correctly extinguished the light and warning on the car. (Spec 30psi, the tires were at 36psi)
I recall the guy coming and picking up the car and being all irate. Heck all we did was confirm that the system was actually working correctly when it alerted for over-inflation as well as under-inflation. That was the first time we had seen a car do that. Back then there was no published proceedures for changing the pressure specs that the system looked for. It was basically set by the factory and beyond our reach. Today, some manufactuers do have ways for the tire pressure system to be updated for changes in tire pressure specs, but not back then.
This guy still holds that against us. Combine that with his story changing several times until he realized that I actually recall that incident and I was glad that he never became "a customer" and got to tell him so. At one point he claimed he had to wait at my shop for three hours, and I had no problem pointing out that the tire store brought his car to me, and an hour later he picked it up. Then he tried to claim that we charged him too much, except he didn't pay anything because we only looked at it as a favor to the tire store. Then he claimed that "he fixed it himself", yea sure he did. His Caddy isn't on the list of cars that I know of for which we can do an update for the TPMS spec. Even then we have to go online and register (request) the spec change with the manufacturer, and they release the adjusted software to us, and then we do the reprograming.
He's not a customer, at best he's a guy with a broken car and I hope he realizes that he's not welcome at my place.
Basically there is nothing 'mystical' about this advice seems to me---you could re-word it, change the Buddhist nun to a guy in a white shop coat, and publish it in an auto repair Trade Journal. It's about handling people while handling your own welfare.
A repair shop owner is like one of those guys at a carnival in a cage hanging above a water tank---every customer is trying to hit the bulls-eye.
There will always be a small percentage of customers you simply don't want. It's a small percentage but a business has to know when to tell these people to go elsewhere.
These are the people who will blame a new scratch on the shop or tell you " It never leaked transmission fluid until you worked on the brakes...you MUST have done something"
We are fortunate to have a core group of customers who carry our shop year after year and they don't do the kinds of things that force us to split our concentration when it comes to servicing their vehicles. The ones who come in looking to take advantage of us cause us to have to keep looking over our shoulder to ward off the surprise complaint instead of getting to enjoy fixing their car. Even then, we usually get the task done perfectly, only to still see them unsatisfied.
There are some businesses in this trade who cater to those people at a level that they reward them for acting like selfish spoiled brats. They still can't make them happy and at the same time teach them to try and take advantage of everyone they meet. That's exactly what the guy with the Cadillac did back then and even when he basically stole from us, it was in his eye's our fault.
Frankly if he would have kept his mouth shut, I easily would have had him bring his Corvette in and repaired it for him. I don't recall names and faces and had easily forgot who he was. Yet I recall everything about individual repair events and the moment he mentioned his Cadillac it was total recall and I knew that he is poison.
I think something along those lines happened to my previous mechanic. Back in December 2009, I noticed an '85 or older Buick Riviera sitting in their fenced-in back lot. A month or so later I noticed it was still there, and asked about it. The mechanic said it belonged to a woman who, after they did all the repairs (forget now what all was done), decided it was too much, didn't pay for it, so they kept the car.
It's nearly three years later, and the last time I was in there, they STILL had the car! In fact, they still start it up every once in awhile to give it a run...which IMO is awfully nice of them.
I wonder what would ultimately happen to a car like that? I'll confess to having a fascination of cars from that era, so the mechanic let me look at it one day. Too rough though, even for my tastes!
I'm in Maryland, and have no idea what the laws are covering something like that.
Or, how about Sioux? Heck,almost every busy shop and a Sioux vlave machine and hard seat grinder.
Who does valve jobs anymore?
No, I didn't hire him as an alignment guy!
Yet another reason why I source the lion's share of my vehicles from Hiroshima, Munich, and Zuffenhausen...
325i. I took the your suggestion to him. That seems a lot easier than his plan! I appreciate your help.
http://www.grainger.com/Grainger/GEARWRENCH-Service-Kit-2HLF3
There is also this one
http://www.northerntool.com/shop/tools/product_200391518_200391518
and this works great if you have a strong air hammer
http://www.thetoolwarehouse.net/p-16120-lisle-43300.aspx
BMW thermostat -- it's like everything else...the first time you do something, it takes forever, the second time, it's a lot faster.
That's why when people ask me "how much labor to replace an X", I always say: "It's 4.5 hours book time for a mechanic, and it's two days for you". :P
Fun car but SO typlcally German!
It was dark last night when I looked so I'll give them another look. I just thought there may have been a trick the shops use.
OR
If the battery charger cord were long enough, the trunk lid would probably close over that, no problem.
I have seen, first hand, car batteries explode and it isn't pretty!
Goiing to go look at it now...
That's one experience I hope to miss. Definitely not on my bucket list.
Sorry for the late reply, but two comments:
1. The battery should be vented to the outside already if it is trunk mounted. A vent tube should be connected to the battery.
2. There is a positive terminal located under the hood for jump starting; you can hook up the trickle charger there. That is what most owners do.
Fezo, an exploding car battery can make an M-80 sound like a cap pistol.
I had forgotten all about the terminal under the hood....duh! Next time I'll use that! Thanks for reminding me!
Ooops, didn't see roadburner's reply .
You might want to re-think this.
Would it take a long time tryin to charge a battery at one amp of current flow, why of course. But the resistance of that cable isn't the reason.
So how to calculate what's at play in this case?
My only credible response is that I do know that the longer the cable, the more the resistance.
I also know that he'd be much better off with silver battery cables than copper ones! :shades:
So let's see here.....that would be R = P L
A
so what's your trick question?
I think they guy who sold me the BMW did just that. I sure don't see a vent hose!
Another good way to blow your face off is to apply a hi-amp fast charge to a completely discharged battery.
Life was different back then...
I never thought I would apply Buddhism psychology to running an auto repair shop, but you know, it kinda WORKS! :surprise:
IDIOT GENEROSITY
