Chevy Silverado/GMC Sierra - Owners hangout
My father in law just bought a new 2500 Silverado Crew Cab with the 6.0L. He says that every morning when he starts it - it sounds like someone is pounding on the side of his engine with a hammer. It does this for several minutes before getting quieter.
He asked the dealer and was told that it was normal - that all Chevy 6.0L do it. They explained that it takes awhile for the hydraulic lifters to pump up when they are cold. It sounds like a load of B.S. to me.
It sounds like a load of B.S. to me, too.
Warn shackle and a 30 foot 2" 20K lb tow strap
For those times i need to pull less capable trucks out of sticky situations (Tim just in case you get stuck give me a call haha)
I'm not here to talk about Tundras. I don't know why some people want to turn this into a brand war. I am interested in finding out more about Chevs from Chev owners.
Quad - you had two intermediate steering shafts replaced on your truck. Does this problem affect only 4WDs? Has GM done anything to address this problem?
Your rear slider also leaked. Chevy discontinued rear sliders. Do you think that Chevy will figure out how to make rear sliders and reintroduce them in the future?
Since you clearly didn't understand my definition of "full sized" let me explain.The "big 3" offer 1/2 ton ENTRY LEVEL full sized trucks which may or maynot be more capable than Tundra.I'm not talking about those differences,now or ever.What I'm saying is you can add to a real full size 'till it'll carry massive loads.You can get bigger engines and towing capacities.You can get adults into the back seat!
Tundra IS the up-sized toyota.I test drove one,and if I wanted a light duty truck with no rear seating I might have bought one.But then I've already got the tacoma.
kip
I STILL have not received an answer from Quad on the intermediate shafts and rear slider. He is really lying low on this one! Funny!
my 6.0 (early 2000) has the Cast Iron heads..and was a feature I liked...but they too went to aluminum like the 5.3.
I suppose todays engines are different.....mine seems to run rock solid for temp and has been purrrfect for 46,000 miles..
used to be aluminum heads were shot at 100K......but perhaps I am going too farr back?..
My 6.0 has the slight knock on cold start up...but has not effected anything....so who cares?..it goes away very quickly...engine is running/wearing fine....no oil use...what was concern again?
haha
I didn't get the extended warranty.....I figure once in a while somebody actually needs it......but if most people needed it.....they wouldn't be making money off them and wouldn't sell them...
Good luck
- Tim
erikheiker
I do not have an engine block heater - but if you do and that is where it is located it answers my question - thanks.
Growing up in Iowa, my dad was a mechanic at a Cadillac/Olsmobile/GMC dealership. I thought GMC was the only kind of truck other than the big KW's, White's and Pete's.
Mike L
Not sure, saw it in GMC Directions awhile ago.
The GM website lists the history as starting is 1902 as the Rapid Motor Vehicle Company. That evolved into the truck arm of GM. In 1912 the GMC nameplate was first used on GM trucks.
See the website at:
http://www.gmc.com/history/index.html
Mike L
at least as named in the trivia file of some forgettable car talk show. Could be a prank.
Mike L
Hunter
My thought was I would be spending at least $400-500 for a spray on liner. But w/the Pro-Tec you get so much more added protection since it won't rust or dent. It cost me $720. I did it without even seeing one, finally saw one a couple of weeks ago and I agree with you, it was done very neatly and I'm glad it is on it's way!!!
One down side is I can't get a retractable cover as I really had hoped for as the bed has no bed rails. I'll have to figure something out!!
Have several pictures of the box if anyone is interested.
http://www.chevrolet.com/silverado/index.htm
Click "Exterior" link under large Silverado heading. Then click "Strength & Duribility" near bottom left. The finally there is a link to "Pro-TEC Box". (Sorry - Don't think it is possible to have direct link b/c of Java style links)
txyank1....I agree w/you on the embossed tailgate! A little surprised as I think the base model comes that way.
Only draw backs in getting the Pro-Tec for me personally, were the embossed tailgate, no bed rails and unable to order it w/2 tone paint. Still feel the advantages will out weigh the disadvantages....time will tell.
Why GM embossed the Chevrolet name on the tailgate is a good question, if they would have left it a smooth style like the stock metal one, they could use them for the GMC also. Just like the tailgate protector, why two different styles?
BTW.....the Snugtop I had used brackets at the front that were bolted to the bed. And then you have the brackets on the side that the rod snaps in to that are also bolted to the bed. For an additional $60 or $80 they have a model that does attach with clamps. No drilling.
I know on the retractable covers the spoiler wouldn't be an issue as the cover will only go as far as the end of the bed and the tailgate has no bearing on the cover. It would be the mounting of it is the ?. Have forwarded the pictures to Roll-N-Lock www.rollnlock.com and Retrax www.rolltopcover.com to see what suggestions they may have.
Also have been bugging GM on what their plans are for a cover since they altered from the standard trck bed design(no rails). Have the GM Rep for NE also looking into it.
My '02 Pewter Lt Metallic Silverado LS 2WD Ext cab short bed with Pro-Tec box, automatic, 4.8L, Deep tint glass, RW defroster, 3.73, G80, Elect Traction Assist, Elect Conv Pkge, and Cast Alum wheels.....HAS ARRIVED!!!
Over all experience wasn't too bad just a little confusing at times....here is how it all unfolded:
11/15 - placed order
12/22 - order is accepted
01/07 - production to start wk of 1/14
01/15 - production under way this wk, no other status known but still not to late cancel order if I wanted to....per GM
01/23 - production completed on 1/16, trck in QA
01/25 - trck arrives at dealer
01/26 - I get call from dealer trck has been delivered
01/28 - I GLADLY drive trck home
....something somewhere just doesn't seem to make sense but I'll just enjoy the trck for now. Already have a lot of toys to start putting on.....right after a few coats of wax get applied!!!!!
real sweeeeeeet truck!!!
ENJOY!
Also can you snap some pics of it?
Turned 10k couple days ago...and it turned a year older too. No bitches or complaints as of yet, other than the fact is it stays dirty all the time from the salt and grime on the road. Spring is coming...good thing it got plenty of wax last fall. Can't wait to give'r a good cleaning inside and out.
Gonna add a cross bed tool box next week, too much stuff accumulating in the rear of the cab. My German Shepard figures if her seat is full she should sit in mine. Does make for some interesting looks goin down the road! LOL
You can adjust the torsion bars yourself. Crawl under the truck and find the backend of the torsion bars. Inside the crossmember at the end of the bars you will find a big adjuster bolt. Turn both adjusters 4-5 turns clockwise. Re adjust your headlights afterwards, and check your wheel alignment.
If you are ever going to carry a load in your truck, you might not want to do this. Level when empty equals back end down when loaded. GM sets the back high so it will level out when loaded.
It is a truck and you do use it to carry loads, right? Or is it just a big, macho car?
I've had my Adrian Steel single lid crossover tool box on my truck for 8 months now. It took about 40 minutes to install myself and not one bit of trouble in doing so, and I've had no problems with it what-so-ever.
- Tim
It's been a while since I've been on here, too busy at work!
Question: Anyone have a plow on their truck?
I have the 2001 GMC Sierra 1500 4 WD 4 Door. (Just put a Rhino Lining in it)
I was considering getting a plow for next year, but what do I look for. And, does it damage or wear the truck faster?
I know absolutely NOTHING about plows or blades (whatever you call them) so any advise or assistance would be helpful.
Truckchic
If you do get one you will need higher rated tbars, maybe a higher output alternator
Talk to you dealer or a plow dealer to help you better
ton Gms.....Be warned GM does NOT want you
to plow with a 99 & up 1/2 ton x-cab. They will
not warranty any plow related breakage !
Ask the dealer you bought your truck from.
Some dealers don't care. You may get lucky.
Thats why I had to go to a 01 2500 xcab this
time. I traded a 97 Chevy xcab 1/2 that i
used for plowing. But lucky me that 97
saw a GM dealer once...for a broken windsheild
wiper and a free oil change.
As far as plows i have had a Western 8 ft.
plow. Used it on 4 new GM trucks....Sold
it to my buddy....I got a new 8 ft.Western
Ultramount on my 01.......
Check out www.plowsite.com
Lots of plowheads and good advise over
there.....Good luck............Geo
one of the early things you learn is.....put the first plowing as farr back as ya can.....when nasty weather hits again and again...you can be stuck with no place to put the crud!..
and a 3/4 is really the way to go....as it is hard on a vehicle....
- Tim
on 1/2 xcab ...GVW gross vehicle weight
Gm assumes you will plow with 6 passengers
and the plow and exceed the 6400? lb.
GVW on a new xcab. Weird huh ?
But you can get the VYU plow prep on a
GM 1/2 ton reg cab tho.............
Like that has never happened before.
Guess I should spend more time on this site surfing with you guys and reading every post in every topic rather than wanting to spend the time with my wife, children, or at my engineering job which involves designing telecommunications systems and supporting the delivery flights of new $150 million jumbo jets!!!
Time to go fly on a new 767-300 for Delta Airlines which we will deliver to them tomorrow....see you on the ground boys.
