Ford Expedition
This topic is a continuation of Topic 176....
Ford Expedition Eddie Bauer. Please continue
these discussions here. Thanks!
Front Porch Philosopher
I have a 1997 Eddie Bauer 4x4 without the load leveling suspension and 50K miles. I would like to upgrade the shocks.
Does anyone have any first hand experience?
1. Have the tires re-balanced and indexed. The
indexing I'm not sure what it is. My guess
is that the tire stem has to be at a certain
location with respect to the tire.
2. The drive shaft has to be re-indexed and
balanced.
Those 2 steps should cure your shaking problem.
It cured mine.
One more thing once the drive shaft is re-balanced and indexed you'll need the tires re-aligned. The balancing of the drive shaft caused
my truck to go out of alignment.
GOOD LUCK...
Anybody else had as many problems as me?
Unfortunately, sometimes that information gets "lost" depending what state is involved.
Even though the 5.3 has 20 more HP (on paper), its so high in the RPM band that its basically useless.
What I was really impressed with was the difference in drivetrain components (Axle, driveshaft, differrential, tranny, etc) between the two vehicles. When you look underneath, the Silverado (1500) shows its expected 1/2 ton related parts, while the Expedition surprisingly shows 3/4 ton components.
If you don't believe me, check the two side by side sometime. It also explains the heavier weight and the lower gas mileage in the Expy (more along the lines of a 3/4 ton).
I have not looked under a Tahoe or 1500 Sub, but I bet you find the 1/2 ton parts.
1) There is a vibration problem between 60-70 that post #128/ of 511 seems to know how to fix, but how do I tell if used 97 Expeditions I am looking at have fixed these problems
2) There seems to be potential for transmission to fail
3) Rear wipers seem almost a certainty to fail
4) Newer models seem to have intermittent problem with engine suddently turning off at slow speeds or turning at slow speeds
Does these seem excessive or comparable? I have always liked Fords am very interested in the Expedition but should I look at Durango or Suburban instead?
Has anyone else experienced this? I've talked to the dealer and they're hemming a hawwing about all tanks have a reserve. Reserve yes but not an 8 gallon reserve. Anybody know if I may cause damage (create new rattles) having the dealership look around in there to confirm the gas tank size.
Any comments appreciated.
thanks.
It turns out that, 8 miles to go was about 2 miles short of my destination. Pulled into the local Citgo... pumped in around 26 gallons (the tab was around $42, and gas prices were around $1.62/gal... do the math).
Speaking of gas, I use 89 octane in my 5.4l v8 Expy, despite the Owner's Manual indicating a 86 minimum. What do some other folks use?
And speaking of tires, my EB came with Firestone Wilderness ATs. Now, I'm not all panic-stricken about the situation concerning the 15" (mine are 17") - I'm actually more concerned about something that happened on my return trip from VA. Cruising along at around 50mph in a moderate rainstorm, rounding a gentle, slightly banked curve, I - in the inside lane - starting hydoplaning. My truck started sliding "downwards" ever so slightly off the road and towards the grass median. I never actually went offroad, but for a seconds it looked like I might. I stayed cool - eased up on the gas, kept away from the brake and held the wheel steady, and within a few seconds I was back in control (whether the Auto 4WD kicked in or not I couldn't tell). Anyway... no harm. But, when I got home I stated looking into the Firestones. I specifically ordered this truck with safety in mind - big, Auto4WD, Reverse-sensing system, - because I wanted my family and I to be glued to the road. So, I'm left a little disconcerted. As it turns out, the Firestone's have a Traction rating of "B"; I've looked into some Michelins (LTX M/S and the Pilot LTX) that have "A" ratings and - knowing Michelin - are likely to be much quieter, too.
Anyway... I'm sorry to say that if my EB's off road, I'm likely to be slumped unconscious behind the wheel, a spent airbag in my lap. I live in NYC, so all-season, street/highway performance - supreme, all-weather street/highway traction's what I really need, not all-terrain charactertics which might compromise foul-weather performance. Any tire experts out there like to recommend a tire, or tell me the aforementioned Michelins are a good choice? I'm likely to do something, tire-wise, within the next month. Maybe I'll get lucky and Ford/Firestone will pull the plug on all Wilderness AT's.
But since we are on the topic of gas. The owners manual is pretty specific about only using 87 octane gas. That's a good thing since it's the least expensive. Does anybody know if there is a benefit to using higher octane gas? Or do you just end up spending more money, or perhaps even lessoning engine performance.
I just purchased a used 1998 Expedition/Eddie Bauer w/54K miles. Runs/looks like new. Had a Ford dealer go thru it for 3 hours and found minor issues, front brake pads wearing uneven, tire scollop, and idler arm. My question is should I consider a 3 yr/36K mile extended warrenty from used/private dealer for $1450/w $200.00 deductable or 1Source warranty that Edmunds advertises for $1300/$0 deductable??
Also anyone have any comments on Edmunds 1Source extended warrenty program??
Been to dealer twice...they can't duplicate the condition in the shop. A/C drains normally when they look at it. Whenever I go on a long trip, sometime along the way, something stops up, water stops running through drain, and then runs under foil insulation blanket, under carpet, soaks padding through then fills up wire channel. Getting very frustrated. Dealer is D&D Ford in Greer SC. Dealer says he cannot get an OK from Ford to disassemble dash or condenser housing unless he sees water leaking from under insulation. He says he has cleaned drain tray (???external part???) I am always on a weekend trip when this happens, so no dealer is open for me to get it checked when it happens.
If anyone has any info that might help...please post response. I have called Ford in Dearborn, but no action has been taken as of yet.
Vehicle also suffers from high oil consumption (3/4 qt over 1000 miles) Anyone else have this problem?? Fords policy is to do nothing unless it uses over a qt in 1000 miles. 5.4 liter Engine, Tow, 3.55 rear end.
Still no fix on the A/C undercarpet leaking. Transmission was leaking (slow drips). Dealer, dropped Transmission, found stripped bolts in housing. New housing was built up with components from my transmission and unit was reinstalled. Vibration and noise increases are now very apparent. Idle vibration greatly increased as well as noise (Engine? Trans?) at highway speeds. Im am afraid that dealer did not index or balance something in the torque converter or transmission some how. Comments anyone?
The Expedition has an intermittent Horrible Exhaust odor. Dealer has R&R'd Catalytic Converters, PCM Module, Mass AirFlow sensor and still about every 4-6 days the exhaust smells REAL BAD.
Dealer just swapped it out for another 2000 EB Expedition after the dealer offered a $4000 Owner Appreciation Certificate rather than continue the Lemon Law Process. I am a Ford X-Plan buyer so I get to buy at 4% over A-Plan. This come sout to about $800 under invoice.
Ford just lowered the interest rates on left over 2000 Expeditions to 0.9% for 24 or 36 month, 1.9 for 48 month or 2.9% for 60 month. If you can find a 2000 that meets your needs it's a good deal.
Anyone else have this problem. I had a 98 F150 w/5.4L 99'F150 w/5.L that were great
I just recently bought an 2000 EB 4X4 and my wife loves it. Got a great deal on the vehicle, but the dealer wanted $1895 for the warranty, so I declined it. Now that the shock of dropping so much money on a new vehicle has almost worn off, I am looking for a Ford Premium Care 6/100 $0 deductable warranty. Anyone else know where to get a good deal on the warranty?
Well, I am sorry to say, I have been very, very unhappy with the service I have received for my vehicle. We have tried 3 Ford dealerships in the middle Tennessee area about 80 miles East of Nashville, and have met with complete frustration and disappointment with each one.
Just for one example of many: the vehicle has a problem with the steering, and after about 6 attempts, I have determined that they simply WILL NOT fix it. They try to hide their laziness or incompetence and say it is "normal". One time, the mechanic rode with me and admitted something was not right with the steering. I left the vehicle with them, with their promise they would call me when it was fixed. After about a week, I phoned them, and they said it needed some parts that were on order, etc. They kept the vehicle 12 days and never did call me to say it was ready. When I finally called them again, and they said it was ready, I drove to pick it up. Upon arriving, they announced they were not going to fix it because it was "normal". In short, they are Liars!
And not just that, but there was a loud rattle that took two trips to fix; they advised us wrongly about the tire rotation; they leave their greasy hand and palm prints all over the fine leather we try so hard to keep pristine, etc. etc. etc. The inconvenience they have caused us would take more paragraphs to write than I am probably allowed in this forum.
So, for those of you considering buying one, take my advice and don't. We surely regret it, and are now trying to get rid of this one, even at a heavy loss in depreciation.
Sanandton - or anyone else - If anyone got a better deal than that, please e-mail me at Mudpuppy9@hotmail.com with that price and dealer contact info. Thanks.
Rmacisit... definitely get the extended warranty. You'll need it.
Hodge52... I feel your pain. We kept our '98 EB Expedition for 1 year and could not take it any more. I took a financial enema to get rid of it. Bought a Honda Odyssey... more room, much better mileage, hopefully more dependable.
