MINI Cooper: Problems & Solutions
1. My ASC light went on--(goes off when I restart the car, but lights up shortly after.)
2. 48 hours later: Service Engine light went on.
3. Dealer says that it's because the gas I use has too much ethanol in it. They turned off the Service Engine light, but the ASC light still goes on periodically. They said the problem will disappear after I burn all the gas in my tank and refill with a low-octane gasoline.
I find this hard to believe. Are they just giving me the "run-around"?
Any advice would be good. Thanks
The premium package is nice, but not necessary (I'd still recommend it), but the sport package is almost essential--and it'll help you come resale time.
As well, you seem to have one light coming on for the same reason I had another light come on. Just from that alone, I think something smells fishy with your dealer. I hope this isn't a widespread issue that MINI is trying to avoid.
Oh, well, MINI is buying back my car, as I've had it with the issues I've been dealing with. I'm looking at the new GTI very very closely...
After a week at the dealer finaly got my car back, and return the loaner a beutifull 06 BMW 325(very nice)
My wife drove it for 2 day to realise that it was overheating, was not working now and a new noise just started, o and regarding the fan it still on! probaly running right now. i guess the dealr is making lost of cash having the mini return so many times to their shop
no to mention how incompetent they seam. bottom line still sonot have any idea what is wrong with the car.
- Mark
I just picked up a used '04 Mini and I am loving it!
This question ties to message #408 above, concerning programming the Mini. The manual discussed options that can be enabled and disabled by a Mini dealership. Does anyone know how to do some of this programming on their own? What I want to have done specifically is have the power windows go up all the way automatically when I briefly flick the switch. The windows open all the way on their own when I flick it, but they don't go up all the way. The other option that I want enabled is the "Follow me home" feature, where the lights stay on for a few minutes after the car is locked so that I can find my way back home.
Thanks all!
Also, any opinions on whether it would be risky to try out a 2007 given that it will be reworked and may have a bunch of glitches?
$1000 for brakes? Are they saying new rotors and pads at all 4 corners?
Take it to a brake shop for a 2nd opinion. Its one thing for the front pads to be worn at this point, but to need pads and rotors on 4 wheels? I seriously doubt it. Did you hear any noises while braking? Fronts always need replacing before the rears. So if the rears are so bad that new rotors are needed, then that would mean you've had nothing but metal to metal up front for quite a while, and, believe me, you'd notice!
It's certainly not impossible to wear out the brakes in 11K km. In fact, you can wear them out in 1K km. If the lights on the dash are prescribing an oil change at 11K km, that's a smoking gun that the car is being thrashed to within an inch of it's life.
Costs are high, but probably typical. If they're doing new rotors all-around, this cost is actually lower than I'd expect. You can do better at an independent shop.
- Mark
- Mark
- Mark
Also keep in mind that Mini's require synthetic oil. I doubt the Honda dealer is using synthetic oil at this price.
- Mark
- Mark
Painful Upkeep=
Serpentine Belt($400)
Gear Fork broke in tranny, Whole transmission($3500)
Clutch($1200)
Power Window Motor($300)
Throttle body($400)
.. still doesn't run
Mini has good troubleshooting charts for problems. I don't see any reason the dealer should have to go into total trial/error mode, but I'm not an expert. Do you have any other dealers close enough to give them a shot at it? Or a good independent shop?
- Mark
Soon later, car stalled when i was at a red light. They found the purge valve was defective. Have them look into it on your car.
I have a 2003 MC and this morning when trying to start it up to get to work, it wouldn't start. When I turned the ignition key (tried this several times with same result), the interior lights blinked 2 or three times and nothing happened. I thought it could be a battery problem (live in Las Vegas, NV and heat here wreaks havoc on batteries) and tried to jump start it with no success. It's only got 23K miles on it. Any ideas? Thanks in advance!!
2 water pumps, rear main seal, power stering pump, and a throttle body, 3 computers, etc, etc, etc. BE SURE TO ASK (and you'll have to get a factory rep) ABOUT ALL "serviice bullitens" and recalls - there are MANY)
Good luck--I'm going to sell mine ASAP!!! I'll take a beating but ?????????????????
While Mini's are made by BMW, it's a completely different car from every other BMW which means that to service them you need coompletely different mechanics training, service tools, diagnostics, computer systems, etc.
BMW made the decision to market the Mini as a separate brand and sell and service it in unique dealerships. This was a business decision on their part and well known to any customer buying a Mini. Maybe they'll change this policy at some point, but it would take a tremendous investment by BMW dealers to become Mini service centers and it would undecut the Mini dealer who has made substantial capital investment in their dealerships with the expecation that they would have exclusive rights to perform warranty service work over their defined territory. So it's not as simple as BMW snapping their fingers and "allowing" BMW dealers to do Mini work.
I always advise anyone interested in a Mini to consider that this car has a less than perfect service history and therefore having a dealer close by is probably a ironclad requirement for most owners. People buying Mini's when the nearest dealer is 500 miles away are taking a hell of a risk.
- Mark
So much for the rep. Anybody concedering buying a Mini needs to have their head examned!!! Mine inculded.
Want to buy mine???
I FINELY got an appt. w/ a factory "rep" so I'll be letting ya'll know what happens.
- Mark
BTW I'm not the only fool here - some people have to waste good time not solving things! Just pointing out other's "faults". Again this "E" sounds like an experienced "salesman (woman)"??
Have a good day unless you have other plans.
Would be interested in hearing your replay.
Cheers --- G
Jeannine Fallon
Corporate Communications
Edmunds.com
Date: 9/ 23/06
To: Mini Cooper
CC: CONSUMER REPORTS
Dear Sir,
I am writing this letter to express my severe disenchantment with both Mini Cooper as a company and their dealership (Prestige Mini NJ, USA).
I purchased my first Mini S (loaded) for $27,000, less then four months ago.
On 8/24/06 (11:20 hrs) my Mini S struck a “CAT” on RT 6 in NY. The result was the following:
1- No alarm sounded indicating my engine was in trouble, or overheating.
2- After approximately 6 – 7 miles, the red light on the dash finally came on, and I stopped and requested an accident report from the NY State Police ( see report # SP2F88000115).
3- I drove home (4 miles) to my home, and called Prestige Mini immediately.
4- The vehicle was towed to Prestige Mini.
I finally got my car back (28 days later).
The following chain of events too place.
1- I called Prestige Mini, and they stated they had a great relationship with State Farm insurance. Two weeks later, I personally had to intercede, in an effort to get State Farm to pay what they described as an “outrageous labor rate”. Worse, once approved, the expert technicians fools you employ, who command this “outrageous labor rate” at Prestige Mini “failed “to check the car properly and totally missed the “warped head” on the vehicle.
Had I not personally requested that they check the motor, no effort would have been made to ensure both my safety, and to prevent a second return to Mini.
2- Due to this incompetence, I was forced to wait again for the insurance adjuster from State Farm to arrive. While this transpired, my insurance co (like most) only allows $1,000 in rental fees. In view of the fact that there was an unreasonable delay, I requested a “loaner” from the service manager, who stated yes. When I called to come and pick up the loaner, the assistant service manager stated “no”? I guess $27,000 was not enough!
3- Two more weeks passed, as I waited for my car (needed to get to work), and I was finally advised (after I called approx: 10 times) it was done!
Just one small problem, the car needed “just one more part” for the AC unit. I was advised the car would be finally ready this past Friday 9/22/06, but when I called to ensure it was done, I was advised the part did not come in.
Until this point, I had remained polite, friendly and understanding, especially in view of the fact that the Mini Service Dept. could really put the screws to me.
Having had enough, I called the service manager, who now advised me the “car was done”, and the “other guy had made a mistake”? Classic incompetence, no!
In the 37 years I have been driving cars, I have never experienced such incompetence, wasted time, and have never been so inconvenienced by any car dealer, except yours.
Worse, I have used State Farm for 28 yrs, and never, had any problem with them, until I had to deal with Mini Cooper.
To compound matters, when I did go to get my car, I was left with the distinct impression that they were doing me a favor.
PS: My wife advised me not to send this e-mail to Mini, because I still need to get the service dept. to sign a “co-pay check”. Don’t want to “piss off the service/billing dept”. In short, I paid on credit card, which I find odd? In view of the fact that State Farm authorized payment for the work.
I guess Mini cash needs the cash, or being British/German does not “understand” that State Farm guaranteed their almighty dollar.
All other dealers, I have dealt with, have just said, thank you and out the door I went.
Needles to say, because I can not trust, or depend on Mini Cooper, I will no longer be “motoring”, or popping the “bonnet”, as Mini Cooper and its dealers have convinced me that their only interest is in selling cars, not customer support.
Regardless of the fact that I was involved in an auto accident.
Respectfully Yours
Martin Farrell
Warwick NY USA 10990
