Luckily for Bush, the Kuwaiti military intercepted the LC, not too mention that Bush's plane was a day late due to damage to a wing.
Its history, and well deserved reputation for incredible reliability in the harshest of environments, have made the LC the vehicle of choice wherever the pavement ends.
Also note that Landcruiser is not a single model but a range of models in most parts of the world. In the US we only get the most up-scale version and the 4Runner (which is the LC 90 elsewhere).
HiC
Have you ever looked under a LC and then looked under the lesser vehicles? The LC is for real and always has been, even the 100 series is much beefier than anyting out there except maybe an Hummer H1. That is why it is so sad that the LC may go away and that the top of the line Toyota will be a Sequioa and sme goes for the LX470. It will probably be a sequioa with a 5.5 liter v8, imagine the margin on that vs a LC with lexus badging.
Watch and see what happens with the H2 (tahoe based suv), it is beefy however the build quailty is not there and they will begin to depreciate very quickly. Give me a 100 with front and rear arb lockers and the hummer h2 better get out of the way and I will still be in a LC and I will still have the quality to go along with the offroad ability. And it will hold it's value like a gold brick. Not to mention superior road manners and cargo capacity.
Later,
fj100
'99 LC with stuff
It will be a sad day. However they bring out a tacoma based small Land Cruiser and get back to their roots. This was shown at the Detroit auto show. It was ok, I did not like the swing doors for the back doors like the tundra. EVerything else was pretty cool. My wife thought it was ugly.
And it's probably just the paint job, but overall it looks "squat" with high clearance. Wonder how the visibility is going to be?
I think I like it :-)
My vehicle has 83K miles. Any additives that would be safe to stop this problem?
The dash is, well.... oh, nevermind :-)
Ken
I've got a modified 80 and a modified 100. Both with OME suspensions. I believe the 100 is every bit the equal of the 80 in all areas including off road. Problem is different ride heights (about 3.5 " lift in the 80 v.1.5" or so on the 100) Also, one is less inclined to put a 100 in to a tough situation because of the cost of it.
If in fact the LC goes away--hard to believe that will happen--80s and 100s will probably become pretty prized vehicles.
I've heard and maybe some others have too, that Toyota's thinking of having truck only dealerships? If the LC goes to Lexus, maybe it would just be called Landcruiser? After all the LC's the first vehicle that Toyota brought to the US. And don't forget it had a Chevy engine in it
Ken
80 vs 100 offroad is an interesting topic, but I'd give it to the 80 due to solid front axle and factory lockers F/R. No contest, really. Would really like the 100's V8, however. Hmmmmmm........
As for the LC being the first Toyota shipped here. Incorrect. It was a small sedan of some sort - Toyopet I think they called it?
As for the LC being shipped here with a "Chevy" engine. Incorrect. It was a Toyota engine that many felt was too close to the Chevy straight 6 and started an urban legend. That sturdy chunk of steel was a lot of things, but it was all Toyota.
Finally, as for the "model" being tall - that is Jim Press, President of Toyota USA and he's about 6'1"
Idaho Doug
http://www.pbase.com/roane10/inbox
Later,
fj100
Thanks for the info. I have an appointment at the local Toyota dealer to change two seals(approx.$600). I just got off the phone questioning them and relating your post to them.
They said that they would double check before installing the new seals. I am going to take the vehicle to the dealership and talk with the service technician. Any suggestions as to what I should look for or question further?
By the way, the oil has been changed recently.
THANKS,
Gene
i think i have an oil leak in the rear seal as well and my quotes were for much more just to replace the rear main engine seal.
i've already replaced the valve cover seal (was definitely leaking from the back) and am going to replace the oil pan gasket next to see if that is the problem.
i'm in the los angeles area.
The crankcase and oil pump seals are to be replaced. How many miles on your LC?
I phoned a Lexus dealer($1500 estimate) and a different Toyota dealer($750 estimate) for quotes.
I wonder what is going on?
The range of the quotes for the same service is unbelievable.
As to 100 v 80 off road. Don't forget there is a solid axle 105 series available--just not here. But for my needs, I consider both more than capable. Agree that articulation in the 100 is not the equal of the 80, but I'm not doing any rock crawling in either of them. Would be interesting to see a 100 in that situation.
Windshield dings are a possibility - more so in the construction zones, since most of it is paved these days. Ditto the headlights, but covers are easily available at Dawson Creek or you can try some of that 3M or Stoneguard stuff.
My last few trips I didn't bother with doing anything special - just watch the "bump" signs 'cause they mean it. And grab a Milepost.
Ken
Scott
San Diego
scott@mobi-arc.com
The 105 is not V8 powered, so you may as well keep your 80 series if you want a live axle. I doubt Oz will see live axle TLCs for very long other than the 7x series.
$266 to fix, parts and labor. OBD picked it up immediately.
fj100
i got it for a good price and realized i would have to fix several things. nothing unexpected actually.
am very happy with it.
Personally, I'd do what I did. Get a can of foaming engine cleaner, slide under and spray the sides of the block and the areas with oil, then hose it off. Several months later, I slid under to change the oil and the entire block was still bare dry metal. A month after I changed the oil, the block had telltale traces of oil here and there, and a line around the pan seam from the oil change splatter. My brother owns 2 and he reported the exact same thing. It ends up around the rear main area due to air flow from the fan and vehicle movement. The leak diagnosis is an honest and frequent mistake by dealers, but a misdiagnosis in all likelihood. Toyota does not use a gasket on this engine's pan - it's called FIPG and is basically a wet gasket that cures into a flexible rubber glue - tough stuff. Drop $9 on a couple engine foaming cleaner cans and a half hour of your time. You'll see. Then spend the money you did not waste on a nice weekend with your wife - much higher return on investment.
94117 - As for headlight and fender protection, you should stop here in Coeur d'Alene, Idaho on your way to Alaska. One of the businesses I own is a company that provides paint and light protection to the area dealers and will have your Cruiser done at wholesale. We use 3M's latest paint protection to create an "invisible bra" that stops rock chips, and 3M's new headlight film to protect headlamps. Great stuff and you never have to worry again. We have bad rock chipping here, too. I demonstrate it with a shotgun on painted metal plates.
SteelCruiser - The urban legend that Toyota "stole" the design of the Chevy six has been around awhile, but it's not true. How do I know? I used to work for Toyota's US headquarters. Also, the 4.0L straight six LandCruiser engine that is the subject of this legend was a low RPM truck block that weighs almost as much as a Chevrolet big block V8. It is absolutely huge and would not even fit under the hood of the Chevy II that was powered by the Chevy "blue flame" six. There were a few similarities, however - thus the legend.
IdahoDoug
almost all of the mechanics i went too told me the rear main seal was the probable cause(both toyota dealers and independent shops (some that specialize in landcruisers)).
One toyota dealer told me that the oil pan gasket is rarely a leaking problem.
one shop that speacializes in LCs in the LA area told me that the rear main seal rarely is a problem and it was probably the oil pan gasket.
anyway, yesterday i got the oil pan gasket replaced and it was the problem. the gasket hardened and leaked at the back half circle end of the crankshaft.
i discovered that you could see the oil leak from the oil pan (as opposed to the rear seal) by looking at the tiny gap (probably 1/4 inch wide) between the oil pan and the front of the part that holds the transmission.
if there is not a noticable leak there, and the leak is coming from the back of part that holds the transmisison, i would assume that the rear main seal might be the problem.
changing the gasket did not seem to be that complicated, just time consuming, because it was hard to get the thick gasket scraped off the oil pan.
i'm not sure what you mean by the crankcase and oil pump seals. i beleive the oil pump is right under the crankshaft and both are housed in the in oil pan .
hope this is of some help to anyone that has this issue.
As for known problems with these rigs, there's none. Exception is the heat shield rattle and possible tranny whine which my dealer tells me is normal.
The 98 and up Lexus lx470 has all the memory stuff & more.
