slip when cold. Not when the trans is at normal
operating temp.
I appreciate the guidance but paranoid as I am, pictures would help. Any way someone could post a few pictures documenting the modification?
Very much appreciated ...
On 2001 and newer models (at least), the relay that powers the 12V sockets also appears to power the sensor for automatic headlights, as well as the temperature & compass display. The modification to force the relay closed is simple (even a half of a toothpick & piece of electrical tape to hold it would work), but it's not a solution for "always-on" to the 12V sockets on newer models since you get other stuff also always on. It was pretty funny when I turned the garage lights off and the headlights flicked on by themselves.
in our PF. If you look in Edmonds New car section under Nissan
Pathfinder you will find "regular unleaded fuel" Why is this?
Last winter my cloth seats got soaked with Resolve carpet cleaner and was wet for awhile..I tried vacuuming it and drying it out for days..It eventually felt dry but this winter when I sit on the seat it sounds like I'm sitting on crunched ice..The seat cloth is also worn out and shredding where I had been scrubbing dry..
I dont know if I need new seat covers or the cushion too..Anyone know how much it would run for driver/passenger seats..Is there anyway to add power to the seats on an SE without leather..
I hate that turn knob thing..It never stays at the heighest level,which is where i need it b/c of long legs..Thanks
-Rob
In October 2001, I purchased a 2001 Pathfinder LE with everything except ENT and NAV for $30,200. At the time, Nissan was offering 0.9% financing up to 36 months and 3.9% financing for 48 and 60 months. I chose 3.9% at 60 months. In addition, I received $1500 cash back.Nissan was trying to move the 2001 Pathfinders since 2002 Pathfinders were hitting the lots. I think it is only at the end of the model year that you will likely see both the low interest rate and cash back being offered. By the way, my price of $30,200 was after subtracting the $1500 cash back. Also, I did'nt have to make a payment until 90 days later. I got the dealer to throw in a $135 Nissan dog gate, 2 free oil changes, and 3 free car washes. Overall, not a bad deal.
Since the fuse for the console and rear sockets on this model is under the hood about 6" from the battery (#64 from lofquist's documentation, and verified), I tried jumpering hot to fuse #64 but no dice. The relay has to be energized to get juice to the sockets. But when you energize the relay, you also get juice to the other stuff mentioned before.
I can't see a way around this without hacking the wiring -- i.e., eliminating the relay from the circuit for the outlets completely, and then jumpering hot to their fuse on the underhood block. Jon, you have the wiring diagrams, is this at all feasible?
It sure would be nice to understand Nissan's rationale for making the power sockets only be hot when the switch is in ACC or higher. I don't know of any other vehicle where the sockets aren't always hot. Is there one?
Is the repair manual on CDROM still available for 2001's?
I'm not Canadian, but I do get notes back from lots of people who are going to Canada to get their Pathfinders. Here's some examples of what I've seen lately for prices. I've converted them to US dollars, and also added 2.5% for duty at the border.
- Path SE AWD (All-Mode, not the part-time one), Popular pkg, Sunroof pkg, LSD. $24,400. About $4000 under US dealer invoice.
- Path Chilkoot Special Edition, auto, AWD All-Mode. Essentially a base SE, but with Bose and LSD. $22,100. About $4700 under equivalent US dealer invoice.
- Path LE AWD with leather, LSD. $27,100. About $4100 under US dealer invoice.
- Infiniti QX4 AWD, Premium pkg, heated seats, sunroof. $29,400. About $5600 under US dealer invoice.
These Canadian prices are well below list, and I don't think you'll find them everywhere. We've been fortunate to find some great dealers to call. Toronto and Vancouver are still the best, but you could go about anywhere. As usual, I'm happy to help anyone with more info on how to do this. Just email.
-Jon
SE automatic trans models in the US also have the part-time. In Canada SE models with automatic trans get the All-Mode AWD system.
-Jon
Dash socket. This is fed directly by the accessory (ACC) relay in the dash fusebox through fuse #13. As nwwoods has seen, modifying this relay is not a good thing because power would then be fed to accessories all over the vehicle. To get constant power at this socket will require a little rewiring. It's late tonight - let's look at that later. Shouldn't be too difficult.
Rear seat socket. This is fed by the battery through fuse #64 (under the hood) and then through a relay above and to the left of the dash fusebox. This relay is energized by the ACC relay through fuse #29. Bypass (modify) this relay and you will have constant power to the socket. Note that this relay is not IN the fusebox, but ABOVE it. Pull out the fusebox cover and look up. The relay points up. It's the one on the left. It's much smaller than the ones directly plugged into the box.
Rear cargo area socket. This is exactly like the rear seat socket, but instead it's fed through fuse #51 (under the hood). The relay for this one is behind the panel on the left (yes left) side of the cargo area. Look in the little "grill" opening and you will see the Bose amplifier. It's right next to that. Again, bypassing that relay will provide constant power to the socket.
Is this helpful folks? Still want to get constant power to the dash, or is the easy fix for the rear seat socket good enough?
nwwoods, yes the shop manual is still available. It's $215 I think from Nissan. Lots of .pdf files. Drop me an email.
-Jon
1. Run a #12 cable (both leads + and -) from the battery back to the firewall, across the firewall to the drivers side. About 18" down on the drivers side you will see a plate held on with two nuts - remove these, remove the plate. I drilled a hole in the plate and fed the cable through with a strain relief grommet (there is a bar across the hole in the firewall so you have to ensure your hole in the plate will not align with the bar). I then reinstalled the plate.
At the battery I inserted an in-line fuse on the +ve lead (4" from the battery terminal). In the cabin, I terminated the cable in a small cast aluminum box. I use "Molex" two pin plugs as my 12VDC standard. I put eight of these on the box, four are powered directly from the battery, and 4 are powered through a relay in the box, which is energised from acc. power. There is a large elecrolytic capacitor on the battery input to the box.
This gives me switched and unswitched "filtered" power to run all my electronic "toys", such as radios, radar detectors, GPS, etc. The box and wiring is hidden in the console (The acc. lead for the relay comes from the acc. plug in the console).
Yes those are the choices. And no you should not go long distances on dry pavement in 4wd (with either system). But assume I'm on the highway in 2hi and it starts snowing and the road is covered with snow. I then just pull back on the stick and I'm then in 4hi. No slowing down, no stopping. Road gets better? Then just push it back to 2hi. Very easy.
Even if I had the All-mode, I'd turn to 4hi on snow covered roads. "Auto" is nice, but when traction is low, don't wait to get into trouble.
-Jon
Jeff
g159, thanks for all your input. I have the same thoughts as you: if I am going to get a new truck at almost 30k, I better get it right. I was looking at PT SE and 4Runner SR5, both at same price range, but SR5 has ATRAC, VSC, multi-mode 4WD, and nice looking attracts me. Yet I like PF's power and less truck like riding. Now since I know the SE is kinda traditional 4WD, I might just save some money and get a LE or wait until this fall for the new 4Runner coming out. I am not in a hurry.
The moving part of the relay is not visible even after removing the cover, so I instead eliminated the relay entirely and just jumpered the appropriate pins (3 & 5) on the connector (there's really only 4 pins, but the relay cover documents them as 1,2,3 & 5). Poof, now there is constant power to the console power outlet as well as the cargo area power outlet. Yay!
It was pretty simple once the correct thing to bypass was identified. I took pictures & will post if people want.
For the dome light additions, you can tie into the smart entrance controller unit. There is one terminal on it (#8) that is grounded whenever the dome light is on (door open, etc). The only thing is that you would not be able to shut off these extra lights like you can with the dome light switch. Nor would you be able to turn them on manually. A relay would be needed to not overload current through the smart entrance controller.
The smart entrance controller is located just to the right of the fuse box. It has two connectors with a total of 42 positions. Terminal 8 is on the white connector (18 positions) and has a red/black stripe wire.
-Jon
How do I go about getting an updated CD?
What Ver # of the nav software do you have? if it is 5.1 hold off to this Sep when 5.2 comes out, also go to ur Nissan Dealer and they can install the latest hardware upgrade u will get the latest frimware updates and that will give you the Nissan globe at startup!
now ruff, have u noticed on some courts and roads have this symbol a tic mark the dot then tic mark all attached what r these for?
R
Pit
Jeff
-Jon
jonlofquist@aol.com
Dano
Now for my first question. Does anyone know a way to get the climate controll to show up in Farenheit insteat of Celcius?
Bryan
Glad you had a great experience. What a way to save a few thousand.
The change on the climate control to degF is to disconnect a single ground wire on the back of the unit. I'll send you the instructions.
-Jon
Nice to hear from you. What we're referring to is the temperature display on the automatic climate control system. Since you and I both have SE's with the manual knobs we don't have any changes to make.
-Jon
They do alot of checking and changing fluids which includes oil, filter, grease whatever you get for regular service and rotate tires. Alot of money which includes transmission fluids antifreeze whole bit. I felt probably for investiment a good deal. Vehicle has been very good to me and I love it. I am not hard on vehicle I feel that if this was scheduled at 50000 miles it would make more sense. If I off roaded maybe 30000 would be o.k. At any rate is is done and over with. Like someone else said may be better to ask questions and pick and choose. Service Manager said they just reduced charge at first of year and dealers in large areas are getting alot more. Maybe if you are in big city check boondocks for cheaper deal.
I'm considering selling my PF and am wondering what price I should ask..I have an 01 Black SE w/
tan cloth int,6cd bose,moonroof,in cabin microfilter,auto,etc..Im in NJ..The meilage is around 14,000..I actually bought the PF in Sept
2000..It is in excellent cond..KBB gives an approx
for retail & trade in, but was wondering what sounds like a fair price..Thanks
-Robert
I checked this weekend on our LE with leather packaged similar to your SE and it shows $21,000 with 28K miles. Depending on your payoff I would make sure it was covered. I haven't seen many used newer model Pathy's for sale. Seem most owners like then that much!
Dano
I'd put it in the paper for 24.
Why do you want to get rid of it?
Sid
-Jon
Steve
would definitely sell it on my own..Dealers are
offering around 19-20K..I actually have 13,200mi..I thought I was at 14,000 not that it makes a difference..Sid the reason I'm thinking about selling is because I will be needing money for a ring,wedding,honeymoon,house,etc..I bought the PF in cash so I dont owe anything..I would use the cash from the sale for what I need and then look into financing something cheaper over
the next 5 years..The PF has been a great SUV though..Only big complaint (and its not that big)
is that I wish that the SE's came with power seats..I really wasnt looking to get leather seats
but if I were looking now to get a PF, I would get leather b/c of the power & heated seat option
I'm still contemplating whether to sell or not..Thanks
-Robert
I truly love this vehicle and plan to keep for a long time.
-Jon
While $540 is quite a large amount of money to pay for "maintenance" in one lump sum, it's worth it for some people to pay because they don't have to get themselves messy, spend time to fuss with it, then figure out what to do with the used fluids. (And if you don't have a good set of tools, it's a lot harder to do!)
If you aren't comfortable 'doing it yourself' and don't want to spend $540, break up the work a little. Do some of it the previous month (at 29,000K) or the following month (at 31,000K). 1,000 miles isn't going to hurt. Of course, if you do this, you have to consider there's more time without your transportation while the dealer has it.
A question- those of you whose truck has never seen a service bay, what do you do for non-scheduled maintenance (within the warranty period), such as "check engine soon" light is lit, or temp gauge reads 10 degrees to high, etc? I'm asking because my "check engine soon" light is lit. I'm think it's the oxygen sensors, but since I don't have a diagnostic computer, I can't be sure.
Do most non-Nissan auto repair shops have the tools to diagnose the cause of the "check engine" light?
