I have not received the car back yet to give it a full endorsement, but I'm too excited to have my car back after a near-month of this headache. I just had to update.
It is also likely that your intake plemum is plugged up. This tends to happen if TDI is "babied" combined with some other factors.
perfect. When we arrived home & let the car sit for a couple
of hours , started the engine noticed blue & black smoke.
smoke only lasts moments , then the engine runs smooth & the smoke is gone.She has been driving the car of 6 months & love's it.
I have changed the plugs,cap&rotor, air filter, oil& filter (twice).Used good grade high milage oil . There is a
lot of sluge in the engine,& changing the oil does not seem
to be removing it. I also found a plastic moulded hose connected from what I think is the PCV valve to the valve cover that was cracked. I replace the hose but the engine still smokes on start-up ONLY sometimes . The engine uses
very little oil ,does not use any anti-freeze. Seems a little sluggish in first gear but once you are in second gear & up the car has lots of power.Checked the compression , all cylinder are even @ 170 lbs. The catlic converter has
a rattle , I am wondering if this could cause the oxygen sensor to not work proverly . The car is hard on gas & seems to be running rich. Any one know there the PCV Valve
is located on a 2 liter or any ideas on the problem.
Father needs help
Basically oil left on the top of the engine after it shuts off then leaks down through the valve stem seals or worn guides and drips onto the tops of the pistons. When the car is started, this oil is burned off, and then the engine smooths out and burns cleaner.
This can be fixed but given the mileage on the engine, I wouldn't do correct surgery at this point, but rather live with it if you can.
I guess you could run a catalytic by-pass test pipe for a day and see how that works.
You could test for bad valve stem seals by driving to the top of a hill, then driving downhill with your foot off the gas...this creates high vacuum and should suck oil through the worn seals or guides....now, being very careful and aware of traffic ahead and behind, PUNCH the gas and observe if there is a cloud of blue smoke behind you at that point.
actually, i was thinking that a clogged cat would result in loss of power and increased consumption... harder to get uphill.
i imagine a cat convertor death spiral: too much fuel, nukes the cat some, modifies the back pressure, causes more fuel to be consumed, possibly more cat damage and so on and so on.
If I had to take a wild guess, and knowing Jettas, I'd suspect badly worn or corroded fuel injectors for openers.
I was not refering to the DSG. The conventional 6 speed automatic is from Japan. This is according to our window sticker. I had also indicated who the manufacturer is, according what I have read. This was related to someone stating that VW has had problematic transmissions, so I was wondering if those were from a different source.
So anyway, it does sound like they did change suppliers if the previous automatics were from Delphi.
1999 jetta rebuilted car..
may be second holding..
R is Ok.
D is some problem.
RPM is rise when I push the accelerator but when I remove my foot speed is down too fast with RPM.
diagnosis tell transmission problem.
but transsion shope don't.
what do i do?.
But here's the thing - even with an automatic, this car was silly fun to drive. It was both my best and my worst car.
A VW requires acceptance of high repair & maintenance cost and a AAA Plus membership.
Thanks for the ideas, I am going to clean or replace the pcv
valve & run some engine cleaner through to clean up the sluge.Reading the manual I have suggests that a falty EVAP
purge valve will cause an over rich problem. The tail pipe
is always black with oil residue & soot. But the engine burns
very little oil. I read how to check the evap valve , going to try that. Hard to get any work done on the car, does not
stop much.
Thanks :sick:
Is there any way of aligning and installing the bolt w/out disassembly?
Many thanks,
JRM3
I took it to a mechanic to get hooked up to the computer, he immediately got:
1- Cylinder ONE misfire
2- Gas cap not secured
I had them clear the computer and delete the code.
I then drove it home to NY. While driving the light came back on. I took it to another mechanic and hooked it up to the computer. This is what I got:
1- Throttle Control Arm
I had him clear it, and drove it and it came back on.
I took it to a third mechanic and he got:
CODE P1128- Unknown.
I looked up the P1128 code, and its a Gas problem. My question is, could this be a faulty computer? I have NEVER got the same code twice. I don't have the $$ to make many repairs, so I'm a little concerned about this. Thank-you.
First I had a coolant leak. Was putting in coolant about once a week. Would often find a big puddle under my car.
Then the leak stopped.
Then, in what I thought was an unrelated incident, the car made a dinging noise and flashed the oil light. I assumed it needed oil and put some in. The next day, I checked the oil dipstick and saw that there was way too much oil in there.
I am having someone drain the oil down to the correct level tonight. But I'm wondering...
Why else would the oil light and dinging kick in?
Is it related to the coolant leak or mysterious leak stop?
Once I have the oil out, do you think it's safe enough to drive until next friday when I can afford to have a mechanic take a look???
Please speak in layman's terms. THANKS.
Thanx
I own a 2001 Jetta GLX and I faced the same problem. It is to do with the Gas Cap. Most Jetta owners come across this problem. Fill gas and make sure the cap clicks atleast 3 times. If not the EVAP system sensor in the car senses a gas leak and the Emission Malfunction Indicator comes on. Just make sure the gas cap is secured tight and continue driving. There is no effect on the driveability of the car. Keep driving the car for 2-3 days normally and the light would go off automatically. The computer in the car senses that the problem in the car has been resolved and the indicator goes off. This is a very common problem with the Jetta, so don't spend a buck on it. I obtained this information from a VW dealership technician.
Hope this helps!!
The ONLY way to accurately measure oil level is to use the dipstick.
The 2 issues you describe *may* be related. Consider checking for the following problems.
Is the antifreeze getting into the engine oil?
Is engine oil getting into the antifreeze?
2006 silver jetta package 2 tdi with Nav.
You are right about that and you do not even need vagcom, this door unlock setting is covered in the owners manual.
600kgolfgt, "Volkswagen Passat: Sludge Issues" #99, 13 Jul 2006 7:13 am
Also:
Make sure you write down the vehicle's VIN number and run a Carfax on it.
Make sure all recall/Technical Service Bulletin (TSB) related items have been performed on this car.
I would have a good independent mechanic perform a thorough inspection of the vehicle.
HTH
We took it to the dealer and after waiting for over 3 hours, they declared that it was a fuse, charged us ~$40 and sent us on our way.
It seems rather suspicious to us that they took 3 hours to find a blown fuse and change it, especially since my husband had already checked fuses and they were okay. Has anyone else had this problem, and if so, what caused it?
Lee Ann
