Dealer said they had no idea & they would hate to have me spend $90 an hour to have their mechanic chasing a gremlin. They would hate it??? (With 33,000+ miles its out of warranty).
I've been keeping an informal log of when this occurs as it has been sporadic. When it does happen the one common thread I noticed is the outside temperature is at or above 90 degrees. I live in Phoenix so needless to say its easy to hit that mark in the summer. As if to confirm that theory, with the coming of fall we have had some cooler temps & the warnings have not come on. But by mid-day with the temps still hitting 90+ they have been coming back on.
So I'm wondering if some sensor is reacting to the higher heat? Or is there a module that is triggering due to the same issue? Because there are circuit boards involved (I presume) is the heat causing a faulty board connection to expand, open & separate causing what is known as a 'high open'?
Anyone have any thoughts on this? Or have they noticed theirs is coming on in higher temperature situations?
Why don't you see if there is a highly experienced IANT member near you?
www.iATN.net
click on "repair shops" when you get to that website
1and I would be very interested in filing a class action lawsuit GM knew of the issue and they passed it on to the consumer that's a mess after the tax payers saved them my truck is Also out of warranty. 124.000 miles
With a car as old as yours, and with the paltry results of a class action suit (most of the money goes to lawyers), I would recommend instead that you just take it to a competent person and get it fixed.
There is no reason this truck can't be repaired properly.
http://www.iatn.net/
Constant problems;
Light Flicker
Traction control and check engine light
surging at stops almost dieing
I’m disabled but have an automotive degree. I finally looked at the vehicle —————————————
SO.....I looked at vehicle as hard as it was for me. The dealership pulled finally after the 5th time and I replaced battery put new alternator in it. It helped with light flicker but not fixed. Upon exceleration lights flicker or regular driving......
SECOND MAJOR PROBLEM...not adding the smaller issues IS I received the dealership “under warranty paperwork” It states INTAKE LEAKING. OK WHY NO WARNING LIGHTS
This happens to me every so often and it seems to happen when it rains or the road is wet. Never happens driving on ice or snow. It also happens when it's dry out. The symptoms on our rig is the "STABILITRAK OFF" then it flashes "TRACTION CONTROL OFF". After this pops up the car tries to up shift and it's pretty loud, it also jerks forward, this has almost caused me to rear end people.
The first time I took it to Chevy they said it was something to do with the Gas Tank and we had a new sensor put in the tank and something else- this ran about $600. Drove away and the stabilitrak light IMMEDIATELY came back on. I took it back and they said that sometimes this is an issue but it doesn't mean anything.
A few months ago my check engine light came on and once I got to the dealer it was off. Then the stabilitrak light came on again and it was on and off for a few weeks.
Then today the stabilitrak error popped up and it did the usual loud shutter upshift and jerk motion. And then I pulled into a starbucks and when I turned the wheel hard it make a groaning sound and was very hard turning.
I brought it back in today and am hoping for answers. I feel like it's just going to be a different issue each time and they charge me EVERY time they diagnose it.
This either needs to be Recalled OR they need to not charge each time to fix. If something is wrong and they can fix it I will gladly pay. But I feel like it's just a money pit and I can't afford to keep guessing what it is. I am going to write chevy directly. I know that may be a long shot but this is a serious issue and potentially dangerous.
Maybe this tutorial can help you:
http://www.autotap.com/techlibrary/diagnosing_misfires.asp
(Exceptions)
Cruise control works when indicator lights are on.
Lights Remain on until reset. (Keyoff 15 sec).
(Occurances)
After driving 70+ miles, Only tested in Texas summer 90F.
And finally only in stop and go traffic or making a stop.
(Resent issues)
Back tail light out (Replaced) 700 miles ago.
Rear trailer braking module (replaced) - Service trailer braking. 5000 miles ago.
(Checked/Cleaned)
All rear grounds, engine intake sensors, fuses and wiring-for obvious damage including boots. Any obvious suspension noises including wheel bearings- not present.
(Issue that may be related)
Wondering steering - looser than ide like but safe enough to pass. Steering doesn't return to center completly but does "roll out" towards a return. Last alignment done 5000 miles.
Kind of the same story as everyone else.
Including the guy at Autozone. He thought a piece of tape on my cluster would be an applicable solution, as it solved his lights. I work for a living so my truck is too. Regrouping on this forum to see what's the best place to start throwing money. I think wheel bearings with sensors would be a start in the front? Unless you guys have a solution or theory?
Symptoms:
Gauges bouncing, Stabilitrak, ABS, Door Locks, traction control off, service suspension, service 4 wheel drive, park assist off, hard shift from 1st to 2nd, no auto 4x4, no cruise or back up camera.
Checked and tested all fuses, relays and switches all tested good.
Reset ECM
New:
Battery
Alternator
Negative Battery cable
Positive cable
Ignition switch
Plugs
Wires
Mega Fuse 175a
LAN wire terminating resistor
Cleaned ground points and other connection points:
Mega fuse connections
Front motor to battery ground
Frame to battery ground
Body to motor ground / tried new strap as well
Front driver’s side cab corner window ground behind pillar cover
Frame ground under drivers side door.
Pulled fuse #2 in main fuse box under hood (ESC/ALC EXH) (electronic suspension control/auto level control exhaust) this controls the exhaust valve on the compressor. After doing so all symptoms stopped malfunctioning and I was left with a check engine light and service suspension light. was able to drive it to work with no other issues. I will update and expanded on the root cause after I am able to dig in a bit deeper this week but wanted to put my findings out there to assist others in the meantime.
That's a great help to others because it shows that trying to diagnose and narrow the area of the problem can help to end up with a fix.
Months later the StabiliTrack and traction control messages started coming back, randomly. This time the cruise control no longer functioned. I drove it like this since it still drove fine, but did noticed that the error messages only showed during driving and stepping on the brake pedal to stop or slow down. So a friend suggested changing the brake actuator and i did. This solved this issue, been six months, cruise control works fine and no more messages from anything. Another mention I never got any actual codes for these issues so there was never really anything to clear. But that also meant there were never any codes that would help guide me to the problem.
Now if i could just figure out my O2 sensor wiring issue.
