shimmy when I test drove it. The dealer claimed to try everything to fix it even swapping wheels from other civics and taking the wheels/tires to another shop where they can balance under load.
Ultimately they pretended it was fixed although I made them write up that I accepted the car with a condition that they were going to fix asap. They tried to say that the shimmy would likely go away with a few hundred miles driving, but I felt it wouldn't. They called me the next day and said they had ordered four new tires and would just replace them all. I later found the word FAIL written on one of the tires when washing the car ;-) I think they were playing me a little to appear to have my best interest at heart by going out of the way to replace the tires ;-)
After replacing the tires, (they replaced the 88V with 88H so I dropped a speed rating), the car runs fine. The repair guy indicated that they were having troubles with michelin tires on more than just Civic's, so heads up.
Anyone have good reccomendations on 17inch wheels and tires for 2002/3 Civic SI?
i'll try that and let you know.
thanks for reply.
The others probably have no idea what you are talking about. I've never noticed this myself.
Have the dealer check it out.
with approx 3 gallons left in the tank, it is
definitely biased to give you a fuel warning well
in advance of needing fuel.... I don't think
there is anything wrong with this. I am getting
around 28 mpg, the led is going on at approx
280 miles on the odometer.
P.S. The humidity sensing of the sensor is not a defect, seems Honda did it deliberately to "sense" a human body sitting in the seat and not a object. Think we humans really emmit that much moisture?...guess they can sure make sensitive sensors! LOL!
Most people don't know it, but the very best tire that you will ever have comes on your new car. Tires that are bought from stores are for the most part the tires that don't meet the specifications of the car manufacturers. That is not to say that the replacement tires are bad, just that they don't meet the original specifications that are very tight. Once the car has 30 to 40K miles on it, the slight difference (probably not noticeable to most people even on a new car) is not noticeable due to suspension wear.
Along those lines, the tires on the car are matched to the rims. The runout on the rims is offset by what is effectively the low spot on the tires.
I can tell you that all of the car manufacturers are very picky about the tires and don't hesitate to let the tire manufacturers know about problems. Honda is one of the pickiest.
It is a little strange to me that a set of H rated tires that have been remounted on your wheels has taken care of your problem. If I were you, I would insist on the V rated tires, especially if you drive at speed for extended period of times. As a result of the Firestone problem, a lot of dealers will not sell you a tire that is a lower speed rating than the tire that came on the car. This increases their liability in court if you decide to drive 135mph for 8 hours and blow out one of your H rated tires.
Even though there is little difference in H and V ratings (130 max speed vs 149) as far as you would normally see in your driving, the tire construction is different.
I'm curious, what model tire did they mount on your car, I believe even the Accords have V rated tires?
From your description of the attempted remedy, it seems that the symptoms would have changed as tire\wheels from other cars were mounted on your car or as your tire\wheels were moved from front to back or side to side.
I think the Si gets Pilot tires, these are all performance and very little ride comfort. The combination of the tire and stiffer suspension will provide some fairly harsh feedback on less than ideal roads. By changing the tires to a different model, they may have changed to a model that has more sidewall flex masking what you perceive or what really might be the real problem.
My SI came with MXV4 88V. The dealer replaced
these with 88H. I don't think they have any reason to avoid fixing my car properly, since its under warranty, although perhaps all the Civic folk out there can comment on the type of tires they are running with?
I haven't read any hints of a fundamental issue with the suspension of the SI.
The change in performance is dramatic, I really have no reason to doubt that the tires were the cause. The car rides fine now, although the SI
is pretty "road-noisy".
Whether Michelin is really having manufacturing
difficulties, I will never know. The dealership could have also been eating the cost themselves, but saving $100 bucks at my expense doesn't make much sense.
Since my car is new, brand new, this is a warranty issue, dealer is out no money. They get Michelin to take the tires back, or Honda covers the cost of the warranty. With this in mind, I think I got the 88H tires because this is the
tire Michelin can replace that is closest to what I had on the car. I am open to other possibilities although I don't really see how I can pursue them ;-)
I do sense that there is a possibility of getting
a few oil changes for free out of this though, given the drop in actual value of the tires.
For Civic SI owners, I test drove two 2002 SI's,
both had vibrations. The first was a used car with 1800 miles on it, vibrating just like mine but only at about 75MPH. Mine vibrated at multiple points, felt like the tires were literally making small bounces.
Anyone have similar experiences? Anyone have their tires replaced? What kind of tires do you have on your 2002 SI?
had excellent experiences with Michelin tires,
I purchased 130MPH rated mxv4 energy plus for
my last car, a 1995 Saturn SL2, and they were
smooth, quiet, never a vibration, great touring
tires, they seem to have great treadware, I loved em.
i've been trying the "key in the ON position for 4 seconds, then ACC", and although it still seems a tad sluggish, the ignition does the trick. I'll keep periodic updates on this issue...
a NEW problem/question: I recently noticed that 3 out of my 4 tires have been consistently at 30psi (the recommended pressure). HOWEVER, the right front tire, I just noticed yesterday, was at 20psi.
So, I tried to pump in more air via a local gas station air pump, but the tire stayed at 20psi.
Do I have a nail in that tire? Or am I just an idiot and not pumping air correctly? (semi-rhetorical question .
This was definitely not in the test car I drove that had only 600 km on it.
Will be back to the dealer about this.
Despite this...all smiles when driving it. Better that the 2001 2dr LX I turned in. Very reliable and 760 km on a tank. Only complaint rattles inside and crappy tires...FR690's.
Also, realize there is a lot more between the road and the perceived ride and handling than the tires. Consider that the shocks are brand new and stiff not to mention all of the suspension parts and bushings that are involved.
The reason that I'm interested in the tire change is that the tires can help cover up these problems by providing a more supple ride through more flexible sidewalls. In a lot of cases the auto manufacturers rely heavily on the tires to take care of car related problems.
We had a visit once by a major German auto manufacturer and they asked about the different tire parameters that other manufacturers require of the tire. While this is proprietary, at least the exact specifications, we were able to tell them typically what is required. Their response, "they don't know how to build cars if they require all of this from the tire".
We have also had one case where a major US manufacturer had a suspension problem that we were aware of. The tire specification that aggravated the problem was already very tight and the tires delivered were to that specification. Due to the suspension problem the manufacturer requested that we make available some "perfect" tires, essentially a tire that had been screened to ensure this parameter was at zero. If they had a customer who noticed the suspension problem and they couldn't get rid of them any other way they would mount a set of these perfect tires on the car. As a customer, you think you had a bad set of tires and the dealer was more than happy to let you believe this.
This is the main reason that auto manufacturers now outsource the suspension design. It is also the reason that major tire manufacturers are designing suspensions, acquiring companies that design suspensions or are partnering with companies that design suspensions. The requirements and dynamics are so closely related between the total package of tire, wheel, and suspension components that they need to be very closely matched to ensure that the delivered package will perform as a unit yielding the performance desired by the car designer.
The driver's seat rocks on its mount slightly which is really annoying in stop and go traffic.
The brakes pads clack inside the calipers when stopping after changing driving directions, such as from reverse to forward. Didn't it occur to the engineers that some drivers would be doing this. The dealer handed me a TSB and stated that "they all do this, this is normal".
I think the quality of this car is very cheap but the price was not. The door panel fabric was coming off after only 20,000 miles. What the $&#* !!
Next time in, I made the service rep come out and listen while I demonstrated. He agreed to fix it saying he might be able to bend the clips. Problem was fixed 98%.
Have owned 5 Hondas and 4 Toys. Long term, Toys are better. Hondas are more fun. Most recent is 2001 LX 2dr auto. 40km oil changes only. Yes there are some rattles that bug you. Other is a 92 Previa AWD now 260km. I will never sell it.
Grand AM...who knows you might get a good one. Don't let the price fool you. You will be buying shocks at 30K.
Before you buy...drive several times first.
labor (have heard dealers are a rip-off but doing it anyway) will check fluid levels when I get home & want the old plugs back to look for normal
wear (currently check the MPG once a month & its about 40 MPG driven easy mix of city & highway) and will continue to check so can 'tell' if things
have changed but is there anything in particular you'd ask for or about ? TIA
Rob Fruth - Houston, Tx
http://web2.airmail.net/rfruth
1981 Raleigh for errands & fun ____ __o
1997 Trek 2300 for real fun ! ____ _ \ | _)
2000 Civic hatchback (_)/ (_)
Wow, I appreciate the lengthy messages and interest in my tire issue. I remember reading MXV4 and 88V off of the last set of tires. Now I have MXV4 Energy Plus 88H tires, there is also the letters XSE on the tire.
The ride really was crappy by the way, other than below 40MPH. Even when you weren't at the most chattery speeds, the tires were still quite noisy, although the Civic SI transmits a good
deal of road noise (and wind noise) into the cabin.
When parked and in neutral, I can hit the accelerator and let off quickly, and hear the noise.
It also seems worse on a cold morning. I don't hear it after driving for a while.
Anyone have a suggestion?
I'd like to replace the car with a 2003 Civic or a left over 2002 one but the thought of poor air conditioning in the summer for another 10 years bothers me. Any complaints on air conditioning in recent Civics? Is the air conditioning in 2002 and 2003 automatic Civics as good as the air conditioning in competitive cars? Especially interested in hearing responses from those in New Orleans, Houston and Miami and other hot sticky climates.
I'd like to replace it with a 2003 Civic or a left over 2002 one but the thought of poor air conditioning in the summer for another 10 years bothers me. Any complaints on air conditioning in recent Civics? Is the air conditioning in 2002 and 2003 automatic Civics as good as the air conditioning in competitive cars? Especially interested in hearing responses from those in New Orleans, Houston and Miami and other hot sticky climates.
I live in boston, so I KNOW what you're talking about. It barely works well enough when I'm alone in the car, all the way blue, AND selected the recirculate option. With a full 5 people, forget it. They may as well open the windows for a nice muggy breeze.
dealer repair shops don't do a thing for your car under warranty unless something is blatantly wrong (like a tire falling off... or maybe they'll say your driving habits caused it I've taken the car to several local dealerships, and they don't even check to see if I have enough refrigerant.
OTHERWISE, I love my car. it's a very solid build quality (knock on wood), beautiful engine, some of the highest crash test ratings, solid resale values....
The 2002 LX a/c was factory installed, however, so there's no excuse for poor functioning.
Greetings from sunny Miami.
I recently purchased some oil filters made in Canada. They have the Genuine Honda logo on top of the filter but in small print on the bottom of the filter, it states "Manufactured by Fram". I would never buy a FRAM filter and am disappointed that Fram make filters in Canada and wondered if anyone know the source of US Oil Filters.
Why is it so hard to find Japanese models? Looking in parking lots all I usually see are USA or Canadian.
If it is mid level civic than it's LX. I am going Tuesday to get a EX coupe, I let you know if I hear the same noise.
You really think the place of origin matters? What about the parts? I bet those parts that were used in Japan are the same American parts that were used in the US plants. So why bother?Imagine the factory manufactures tons of cars a day, I think there's no way 100% of the cars will be problem free, no matter where it's manufactured in. If you hear whatever noise or squeaks during your test drive, test drive another one. My coworker has the same civic as mine. His car has some squeaks that my car doesn't have. And yes, they were made from the same plant.
If you're really picky and want a car made in Japan, you should request the manufacturer to make the car in Japan, use all Japanese parts, make sure they build the car on either Tue, Wed, or Thur (monday, still partying. friday, getting ready to party), and make sure those people that build your car are Japanese and not American. I think the manufacturer will laugh at you and tell you to go somewhere else. You're paying only $14K for a Japanese econobox, not $150K for a Ferrari. If you don't like buying a Japanese car that is made in US/Canada, go for a Protege or something else.
I realize that I am a picky person but my current vehicle has caused me much grief (timing belt/w.pump & head gasket replaced at 58k miles). The tensioner pulley on the timing belt went bad, etc........... (The dealership actually told me that the timing belt should last to 105k miles, what would cause the tensioner pulley to go bad at such early mileage and if it was a defect why did I have to pay for it? The head gasket was paid for (manufacturer defect) but I was charged for all the rest. The valve cover was leaking oil and I was charged (although a reduced rate) to replace that when a mechanich told me that I should not have been charged for this since they had to remove it to replace the head gasket. I have had other issues at much earlier mileage; oil leaks, etc. (at least two other times) Sorry to go on and on about this but hearing about some of these problems has me really scared of getting another lemon. I am just trying to get an honest to goodness reliable vehicle, one that I won't have to go broke on just trying to maintain it and the best way I can see to do this is to ask questions.
Believe me I have been told that I should be a reporter or work on safety commission. I am naturally inquisitive and don't mean to bend everyone's ear so much.
I'm just thinking that there're no way a manufacturer can make all the cars 100% problem free. Your chances might be higher in getting a reliable car if you buy Japanese, but that is not a guarantee. Otherwise, there're no Honda Problems & Solution Board here. Especially most of the problems will come out after the warranty has expired, which means you have to pay out of your own pocket. Also, if you use Edmunds Maintenance Guide, you will see there are tons of TSBs for Civics, which were made by reputable Honduh. My suggestion will be getting the extended warranty, or buy from those that offer 10yr/100,000 miles factory warranty.
Our 02 Civic EX is made in Japan and no problem so far. I don't know how Honda getting all the parts for their cars so I won't commen on whether Honda in Japan vs Honda in US share same part source or not. When car manufacturers assemble a car together, there are lots of assembly tools and technique are involved. Even two different assemblers will have different workmanship/craftsmanship. Workmanship could make alot of difference in some instance. In any given day I will take any made in Japan Honda over any made in US or Canada Honda.
IMHO if Japanese car made in US equals to made in Japan, why Japanese still assemble most of the Japanese luxury cars in Japan?
bjk
