Kevin
Kevin
Thanks -- Read the messages regarding the intake manifold -- mine went out at 90,000 miles.. I have 106,000 miles on it now and its running great.
WN
Also, what is the normal time/signs to replace shocks and struts?
I like the BF Goodrich Radial or Touring T/A, too. But these are not expensive.
Just don't buy any Michelin because its Michelin. I've had the dreadful MXV and was glad to dump them. Michelin makes many cheap tires which are exactly this, el cheapo tires, besides some crown tires. Be sure to check the tire survey at TireRack before deciding for any Michelin or any other brand.
HTH
Pickin up my new Bonneville SLE tom and stumbled across this board.. Looks like some very useful information here. I owned a 88 SE that i bought brand new and sold it finally this year. It was quite a car! I hope they still make them like they used too!
Gary
Chuck.
I am new to the board so please bare with me. I have a 92 Bonneville, early this spring I had trouble with the compressor for the A/C. I had it replaced.The mechanic could not get the compressor to lock up. I eventually ran a hot wire with a toggle switch to the compressor. It works, but does not cool like it once did. I would like to repair it to stock instead of using the toggle switch. Any clues as to where to start troubleshooting, I have checked the fuse and it appears fine. Thanks ML
Also, the car bounces a fair amount but I would think that the OEM struts would be good for more than 50k. Anyone know how much it might cost to have them replaced? This is an SE so I don't think I have load-leveling and definitely not suspension selection.
i just set the temp, hit auto and it adjusts the fan speed accordingly- and works great. You didn't say what 98 model you have? On my 2000 SE,(No AUTO CONTROLS) sometimes when I turn the blower on high,I would like it to be a bit more powerful, but it still works fine as far as comfort etc. In comparison to my previous cars,I would have to say as far as fan speed etc, that they are comparable.
Chuck.
Bonneville's etc.- I'm not experiencing any problems with either car, but it seems that the 3800 Series II manifold may be faulty and GM should be considering re-calling and fixing the problem. Do you know of or hear about anyone else having this problem lately or is this still isolated cases?? Interesting in that this engine is in Buick's and Old's also but very few complaints on their sites. Ditto for the Grand-Prix site .
Chuck.
The second problem is my steering wheel contols do not work. All the lights are on, but none of them respond. I should mention that my radio is locked out and I am going to the dealer tomorrow to get a new code, but the heater controls should still work right? Has anyone had a problem with this before? I checked all the fuses to the left of the steering wheel and they seem all good. I read there are more but it told me to check my user manual, which I do not have.
Any help would be great.
2) The steering wheel radio controls can not work anything if the radio is theftlocked off. Once the dealer gets the radio working, the steering wheel controls will work.
3) The description of your A/C control panel dosen't match any I have seen. Perhaps Canadian panels are labeled differently. While your at the dealer, maybe they can give you some instructions or let you copy the pages out of the manual for a car they may have in stock.
I will do that at the dealer tomorrow.
From left to right, I have first a large auto button, then a large temperature button, then the display and underneath that I have three small buttons. Auto/defrost/rear defrost. To the right of the display I have a large button to control the fan speed and to the right of that I have three small button stacked on top of each other. outside temp./C or F button/off button.
Does that sound like anyones set up?
I subscribed to mygmlink.com and they have PDF downloads for the owner's manuals for my '99 Chevy and 2000 Pontiac; I presume they will have the manuals available for all models at some point, but who knows how many years back they are going to go.
I checked all fuses and they appear good so I can still not get the sterio to work. all the lights light up but the display is totaly blank??? Maybe there is an inline fuse behind the deck?
I last changed mine in May, just before the car was put away for the summer. So, in 4 months, I put a grand total of just under 900 miles on the car but the DIC said I was down to just 29% oil life. The miles I did put on were about 50-50 city versus highway so it isn't like I drive 2 miles to the store at 20mph and then come home. Obviously, this isn't a problem but just something I didn't realize about the service life calculation that the DIC performs.
