sounds like some of your repairs should have been covered under warranty. Try to push harder for that.
My '94 Golf needed replacement shocks after about two years (under warranty), but has been fine since, at about 130,000 miles now. I have not had a single repair in the past 50,000 miles. At significantly less than $1000 repair cost in 10 years and getting 29mpg ave/35 highway, I am not sure I want to replace this car.
- D.
To those concerned: please check your email. Also, feel free to email me if you have any questions/comments regarding this matter. Please do not address this with me here. Thanks.
Revka
Host/Hatchbacks & Wagons
Neuspeed makes 2 swaybars for the GTI, a 25mm and a 28mm. I have the 25mm which is recommended with the factory front sway bar. You would use the 28mm if you install their front sway bar. No need for the 28mm - the 25mm is an amazing transformation.
The Neuspeed sway bar really doesn't affect ground clearance, because it is so close to the bar. It maybe lowers it an inch - I never had any issues and I was lowered over 2". It really did help the body lean, even after I had the whole suspension done (shocks, struts, strut tower bar, front H&R sway bar) the rear really completed it. But if you aren't going to upgrade the front sway bar to a 25mm (no need to change the front sway bar unless you have driveshaft rubbing issues) then be sure to get a 25mm rear sway bar and not a 28mm. It is very important to properly match your front and rear sway bars. The 23mm stock front sway bar and the 25mm rear sway bar from neuspeed makes the car very neutral. You'll enjoy it.
nedzel, it is an easy fix to replace your shifter rod - it is a common problem with the 12v VR6s that they go bad. If you e-mail me at adg44@earthlink.net I will e-mail you the link. It is very easy and takes all of 10 minutes and $55 for the part. The car will run better and smoother and stronger after you replace this. To compare power differences, I was running 150whp and 169wtq when I dyno'd with the bad shifter rod, and after I replaced it a month later I ran 172whp and 188wtq (201 hp and 222 torque - mind you this is from a 12v VR6, not bad, eh?).
What is causing your rear brake discs to go is that the pad gets so low, there isn't any pad anymore and then it's just metal on metal, and that ruins your rotors. VW rotors can't be turned, they are too soft and don't have enough meat to be turned, like many japanese cars can. Rear rotors for the car are only 15 bucks a piece for replacement ATE rotors (the same people who make the VW rotors, pads, and calipers) from www.germanautoparts.com - they are great guys. The pads for the rear are dirt cheap also.
Anyway, drop me an e-mail and I'll give you the link to my pictoral how-to for the shifter rod replacement.
- Anthony
Clutches: Perhaps this pertains. I'm originally from the UK. I've noticed that American drivers do not restrain a manual transmission car by the hand brake at an intersection (in the UK you would fail a driving test for slipping the clutch to hold the car or for transitioning from footbrake to accelerator without using the handbrake to hold the car during the transition -- for failure to maintain postive control of the vehicle at all times). Time and time again, I see a car stopped at a hilly intersection, held on the foot brake, then slipping backwards in my direction as the light turns green and the driver attempts to transition from brake to accelerator. I quickly learned to anticipate this by assessing whether the car in front of me is a manual and allowing extra space accordingly. Why is this issue not addressed during driver education, I wonder? Besides risk to self and others, it's murder on clutches.
On a side note about the brakes, apparently one of my rear calipers is sticking because by the time I noticed the right rear pad was gone. I mean gone. other three pads are fine.
Pain in the rear to push the caliper piston back in without their special tool. I hate that. They couldn't make it easy, like use a c-clamp or screwdriver becasue they want you to buy the special part. I like the fact that even with the ABS you don't have to bleed the brakes, making it possible with one person.
However, I doubt the practice of not using the hand brake on a hill was much to do with accelerated clutch wear. Whether you preload the clutch against the hand brake, or simply "pop" the clutch quickly to get underway without rolling backwards, either way, you get about the same clutch wear.
What really kills a clutch is using engine power and clutch slip to hold the car on the hill with no brakes whatsoever. I see this being done now and then. Also, many US drivers do not understand that, at a stop, neutral should be engaged. Instead, they leave the car in gear and hold the clutch down. Over time, the clutch tends to bleed down, especially on an older car, and drags while they're sitting at the light.
Used properly and not abused, it has been my experience that most clutches will last virtually indefnitely - I have had cars go 200K miles with the original clutch, even driven aggressively, but not abused.
- Mark
As for neutral. I disagree with you. And here's why. While from a mechanical point of view you are right, saves wear and tear on the spring and all that (I never understood why a hydrolic clutch and not cables, but whatever)
But here's why you sit in first gear.
There's a guy in front of you at the red light, and a guy coming up behind you who's xxxxing his girlfriend. You see him coming and peel out into the shoulder (ALWAYS leave enough room in front of you to do this, so you don't have to back up) before he notices and slams on the brakes and hits the guy who was in front of you instead of you.
This actually happened to me, and I'll take a little clutch wear over getting killed in my gti any day.
This supercedes the previous replacement policy that only replaced failed coilpaks.
Thanks for your help!
Also, you have a 20AE if it's yellow.
Is there anyway to adjust the clutch to compensate or fix the problem without replacing the entire clutch?
How hard is it to replace and can a backyard mechanic do this to save $?
What do all of you GTI owners have to say?
I guess enough people called and complained about this. I know I did.
$200+ part, and $35 to get vw to tell me that they won't fix it under warantee.
So for all of you who had this done (and I know some of you have becuase you told me what was wrong when it happened to me) go call up vw and ask how to get the claim form for reimbursement.
The cool part is according to the letter, you don't have to have the actual receipt, I guess they're being reasonable, I certainly don't keep recipts for everything I buy, but if you CC bill shows the charge, they'll be happy with that.
Pass the word.
But ofcourse not all GTI are unreliable, and there are good dealers out there too. If you do decide to get a GTI , remember to put on rear swaybars and a nice set of tires and DRIVE SAFE!
What mods did you have to your 16v?
Not to mention how much fun it is in the snow
Only downside is the extra weight and drivetrain loss. And I miss not being able to chirp my wheels inbetween shifts.
As for service, owning three gti's in the past 12 years, I have had little trouble, and it's all about the particular dealer. The best I ever met: jack daniels porsche audi VW on route 4 in new jersey. the two worst places are now out of business (heh heh) VW does try, but I also remember trying to buy my 92 the salesman was almost yelling at me how much it sucks to be a vw dealer because they weren't exporting that many cars for 93 or so. Remember the year of no-gti?
Herm, still haven't heard back from VW about my maf refund...
1. Didn't fit - that i needed a plate that is supposed to come with it for installation between the stock Monsoon head unit, but nothing came with the Changer.
2. The changer was made for the New Beetle and so required and adaptor to connect the changer to the head unit, but the power adaptor fit.
3. That the VW techs didn't have enuf experience to do a work around.
PS. I already have the trunk mounted VW 6 Disc changer.
Getting frustrated, I decided to seek assistance from anybody who has been thru a self install of the 6 Disc In-Dash changer to give me a run down of how I can accomplish this install myself. I have the Radio removal tools to take out the head unit, but I cannot even get the storage receptacle that currently occupies the DIN slot where the In-Dash changer should go out of it's location.
Any assistance would help - do i need an adapter to connect the changer to the head unit? When i bought the changer on eBay.co.uk, the seller said it was a quick install, but these VW chaps are now telling me, no can't do? Please HELPP!!!!
aks - canada
But since I did it myself, I don't have a repair order. Now they don't seem to keen on helping me out, since I have no great way of proving I did it.
But they said they'd review it again.
Probably to make me feel better before they say no.
If you ordered it online, I am sure you can get a copy of your invoice.
Off course there is some lag with turbos anyway so add this fraction of a second to this other one. Still in stock form the 1.8t is my favorite engine for under $20k - think smooth, powerful, and thrifty. You don't get on Ward's 10 best list consective years by producing 2nd rate designs. Supposedly the lag can be cured with blow off valves, cold air intakes, chips, etc.
There are a lot of skeptics in regards to the wards top ten list.
I don't have a turbo gti, but I have a turbo subaru and turbo lag is turbo lag, no way around it, except to get rid of the turbo and get a supercharger :-)
www.giacusa.com
Dealer quote me $125 to fix the problem. Just the cost of labor. Ouch.
One of the things that broke was the washer fluid container. They replaced it but filled it with water not something with a lower freezing temp. I never noticed. So come winter the whole thing turned into a block of ice, when it all melted, the washer fluid never sprayed out the back. I think it was still under warantee when they fixed it (hell, they broke it) but I think the hose that fed the rear shprizter broken. Good luck finding the leak :-)
Won't be long now.
Sylvia
Town Hall Manager
Edmunds.com
#909 of 909 it's a honda by nixomose May 28, 2004 (2:55 pm)
are they serious?
Tell me this isn't the same car...
http://tinyurl.com/ysbqh
It may have taken over 6 months, but they did finally make good on their promise to pay back those who laid out the cash for the part.
- Both the 1.8T and the VR6 are exceptionally quick cars from 1st gear to last (5th for the 1.8T, 6th for the VR6). The VR6 is a bit smoother, though, and purports a higher top speed of 146 mph, vs. the 1.8T's "modest" 135.
- Whether you get the 1.8T or the VR6, you should definitely spring for the upgrade packages. Luxury (Monsoon sound system, Sunroof), Leather (Leather, plus heated seats and windshield cleaning fluid), and Technology (onboard computer, auto-dimming rearview mirror, Automatic Climate Control, and rain-sensing intermittent wipers), are all worthy additions. My wife has just the Luxury, which is a must-have. The Leather and Tech make a world of difference in this car, though. The entire thing feels SO luxurious (and for under 25K).
- About the leather: I recommend the black over the grey. The reason is, the grey gets you matching grey interior panels below the dash and on the door. This mix of dark and light colors tends to make the interior look cheap. It's NOT cheap, though, and the black leather keeps all surfaces the same tone, which really makes the whole car look great.
- The only real benefit of the Monsoon sound system is that you'll have hookups for eight speakers (6.5" mid plus .5" tweeter X 4) when you replace them all. The sooner you do this, the better, as far as I'm concerned. I'm not a "Ghetto Rattle" car stereo advocate, but I do like a nice, deep tone, and these speakers don't do it. In case you're wondering, I'm going with the same setup as in my last car: MB Quart Discus Series (www.mbquart.com) all the way around, plus a 10-inch sub, also MB Quart Discus, in the back and two Alpine amps to power them all.
- Despite what you may have read about cupholders in previous models, rest assured that the 04's on sale now include relocated holders (they're in the center console now, next to the parking brake lever). The previous location was, indeed, stupid. The current set-up is just fine.
- That being said, though, you should know that the armest/center storage bin, while scoring points for having an "Up" and "Down" position choice, isn't placed very well, and shifting with it in the "Down" position is a bit awkward. When it's in the "up" position, you're almost always going to smack it with your elbow if you're reaching back at all. Not too bad, since it's the only problem I have with these cars yet, but I'm picky, and it's a pain.
I'll update in a few weeks, but these cars are incredible. Regardless of which of the two GTI's you choose, you'll be really happy with the engine performance and handling. Spring for the upgrade packages, and you'll smile every time you open you car door to take a drive.
I have driven a '99 Jetta VR6, and fell in love with it instantly. I am a previous VW TDI owner and am familiar with their quirks (problems), but I have never owned a gas VW or the VR6 engine. How do these engines hold up? The VR6 is buttery smooth, and will very often be humming up around redline. Besides awful gas mileage, are these any problems that these engines encounter if they are worked out regularly. I always strictly adhere to manufacturer's break-in requirements, and I perform maintenance (oil changes, timing belts, water pumps) religiously. Any advice will be appreciated. Thanks!
Jeff
