Nissan Quest/Mercury Villager problems
I don't think that it is the switch because the indicator light on the dash goes out when I step on the brakes. You never know, though.
I just got a factory service manual. I'll follow the recommended troubleshooting steps when the weather warms up a bit.
It has low milage. I purchased it at 26k miles and not is has 31k miles on it.
If you rotated the tires, I'd suggest thinking about some new ones, since the original tires on most cars aren't that good (my original Quest tires lasted about 34,000 miles).
If you have new tires, then maybe you can find another mechanic to test drive it. Vibrations can be the result of lots of different things, and they are hard to diagnose over the net (esp. by me - I can barely turn a wrench).
Try a "Discussion Search" in here for "vibration" too.
I will check on milage after 30k service
If that doesn't fix the problem, have the shop check for runout or out-of-round problems. They may want to do this as they reblance them the first time.
If none of this fixes the problem, it could be a bent wheel, or worn out tie rod ends or ball joints (in descending order of probabliity.) If the shop does repairs other than just tires, they can check this out too.
Hope this helps.
Dave
Revka
Hatchbacks & Wagons Boards
Has anybody else had this problem with excessive brake wear/noise?
I found three service bulletins on the NHTSA web site (www.NHTSA.gov) concerning excessive brake wear and noise for late model Quests and Villagers but I’ve been unable to get the details from any source (including Mercury / Nissan Dealers and the NHTSA). The Villager SB # are: 13744, 99194 and 7907 (the Quest numbers are different). Does any one know the details behind these SB’s?
Our brake pads needed replacing after only 40k miles, so you may also want to have them checked. Sometimes the low fluid issue can be linked to worn brakes.
I would check the pads prior to topping up the fluid.
Here's a good post about it:
dhoff Jan 24, 2001 4:54pm
Try a discussion search for "throttle body" if you want more. I've done my '99 twice now at 80,000 miles and I think the dealer did it once for me early on.
dhoff Jan 9, 2001 5:41pm
I put the black tape to keep it in the place.
sometimes works, sometimes have to re tape.
Okay, I went the Nissan dealer this morning.
The engine 100m harness (#24012-7B115) $545.50 +tax !!
I didn't bother to ask about the labor.
Does anyone bought the used parts on the web?
Which one is reliable?
My '99 villager had problems with one headlight connector. The dealer replaced both connectors (spliced into the wiring harness) under warranty.
If the problem is at the headlight connection, you should be able to get the connector replaced for much, much less than you are being quoted for a wiring harness.
so, no warranty.
The Nissan dealer said there is no "headlight connector" for my car.
I have to buy the whole unit.
I had a similar problem on my Miata where the connector had corroded and a wire broke off when I went to change the bulb. My Mazda dealer sold me wire connectors that I could splice into my wiring because a connector was not sold separately. Make certain you have the appropriate size wire connectors.
During the 30000 miles service, dealer found that the steering pinions need replacement and he did it. Still, I am getting the vibration but, negligible. I am working on milage problem now.
Steve and Revka : Thanks for the suggestions.
The rear wiper on my '96 villager stopped working. The washer fliud works but the wiper does not. I checked the fuse and it is fine. I saw a few posts about rear wiper not working on this forum but did not see any solution. Can someone please post their experience if they solved such a problem, such as what and where to look etc... thanks...
Around 70,000 miles the engine was recalled and replaced free of charge by Ford. So far, no transmission or engine problems. I'm shooting for 1M miles...
I saw vehicle and verbally OK deal. My friend test-drove as he fixes his own cars at home.
Did not see underneath for leaks of any kind as
Seller seemed decent and honest.
But my Mechanic who lives 50 miles away and did not see van, Recommends Timing-belt change, & Minor tune-up immediately.
Asking price was $8000 and verbally finalized at $6700 and Book Value is $8300.
I was shopping for used 95-96 camry and already camry, but my wife asked me to look for Mini-Van instead.
Thanks in advance
I'm not sure which book you looked at, but you can run a customized price appraisal here using the "Used" links and drilling down to the Quest pricing pages.
My wife has a '99 Quest. Recently, the driver's window has been acting up. Sometimes it won't respond when you push/pull the button, but eventually works if you jiggle the button a bit.
Is this usually a switch issue, or the regulator? And, how big (and expensive) a deal is it to get fixed?
Another couple of foibles, and wifee will start making more noise about a new car (which she does whenever the old one has a problem). I better hurry up and get one for myself before it is too late.
dhoff Mar 23, 2002 10:30am
Mostly trouble free. All of a sudden today, it randomly will loose the electronic dash, the windows, turn signals, radio etc don't work, but the engine still runs. Transmission acts as it is starting in second or even third gear. I think it even drops out of fourth (overdrive) when this happens. A few minutes later, it all comes back. Twice it happened when we needed to shut it off. It started and all functions came back a few minutes later. First time it happened, the wife said it wouldn't crank. She called me, and then tried it a minutes later and it started. The mouse seat belts and lights at the bottom of the doors still work when all else is out.
Any ideas?
insert audio tape - this will activate tape
eject audio tape - this will turn off the system, including radio.
Anyway, does anybody knows how to fix this? I am just hopind some little trick may fix, otherwice this is not a big problem.
My drivers side power window switch is starting to get a bit erratic.
Anyone?
Yes, on the 99 & up Quest the top vents are for AC only. There are small vents under the front seats that supply heat to the rear passengers.
I've heard of the radio display problem before and it can be reparied. There's a website (shareamemory.com I think) where they sell instructions to fix it.
Dave
Luckily, my car was delivered to its first owner on 9-27-00 so its still under warranty.
Any news on the speedo, Johnwng?
